2009 VW Jetta, Replaced ABS Module, new coding giving me trouble
kostya1989
Hello there fellas, to make long story short i replaced failed ABS module (1k0907375AD) with the new updated module (1k0907375AN). Used long coding that i saved from original module. Getting these fault codes and cant seem to figure out why? since its a different part number it may need a different code? Please help, thank you in advance. Posted log with Vin and codes.
VIN: 3VWRM71K99M038242   License Plate: 1454555555
Mileage: 245420km-152496mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRM71K99M038242   Mileage: 245420km-152496miles
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 P    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   3254
   Revision: G6H02---    Serial number: VWX7Z0H724I0P9
   Coding: 0000075
   Shop #: WSC 00066 000 00000
   VCID: 3B7E25997A849492C0-806E
049441 - No Communication with ABS Brake Control Module
               U0121 - 000 -  - Intermittent
                    Mileage: 245424 km
                    Time: 21:29:40
                    Temperature: 68.0°C
                    Temperature: 32.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.811 V
               U1017 - 000 -  - Intermittent
                    Mileage: 245424 km
                    Time: 21:30:03
                    Speed: 19.0 km/h
                    Temperature: 68.0°C
                    Temperature: 32.0°C
                    Voltage: 11.684 V
050197 - Implausible Data Received from ABS Control Module
               U0415 - 000 -  - Intermittent
                    Mileage: 245424 km
                    Time: 21:30:04
                    Speed: 255.0 km/h
                    Temperature: 68.0°C
                    Temperature: 32.0°C
                    Voltage: 11.684 V
Readiness: 0010 0000
   Part No SW: 09G 927 750 JE    HW: 09G 927 750 JE
   Component: AQ 250 6F           1377
   Revision: 00H76000    Serial number:
   Coding: 0000840
   VCID: 7DFAEB8124105AA2BE-8028
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 113B400D49250002880D02E8921B00403000
   Shop #: WSC 09550 758 180955
   VCID: 7EF8EC8DE91641BAA7-802A
01486 - System Function Test Activated
            000 -  -
                    Mileage: 245424 km
                    Count: 3
                    Count: 14
                    Count: 12288
                    Count: 320
                    Count: 41728
                    Fault Status: 01100101
                    Mileage: 245424 km
                    Count: 3
                    Count: 14
                    Count: 12288
                    Count: 279
                    Count: 41728
                    Mileage: 245424 km
                    Count: 3
                    Count: 14
                    Count: 12288
                    Count: 295
                    Count: 41728
                    Mileage: 245424 km
                    Count: 3
                    Count: 14
                    Count: 12288
                    Count: 270
                    Count: 41728
00003 - Control Module
                    Mileage: 245424 km
                    Count: 3
                    Count: 14
                    Count: 12288
                    Count: 143
                    Count: 41728
   Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
   VCID: 7CFCE6853F0A53AA89-8028
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000001056923
   Coding: 14058E234004150007140000001400000008730B5C000120000000000000
   VCID: 326008BDADCE55DA13-8066
   Component: Wischer 250808 021  0501
   Coding: 00038805
   Shop #: WSC 00066
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0392294
   Coding: 0000100
   VCID: 336E0DB952D45CD218-8066
                    Fault Status: 00101110
                    Reset counter: 243
                    Mileage: 228370 km
                    Time: 14:56:44
            000 -  -
                    Reset counter: 204
                    Mileage: 244517 km
                    Time: 16:17:25
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M06EJFA
   Coding: 0013889
   VCID: 6CDCD6C54F6AC32A19-8038
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME3B33467EM
   Subsystem 3 - Serial number: 6342MSME3B324C05C
   Subsystem 4 - Serial number: 6351HSME173F022C9
   Subsystem 5 - Serial number: 6361HSME174A4F6FU
   Subsystem 6 - Serial number: 63727SME16710725W
   Subsystem 7 - Serial number: 63827SME167D74076
            004 - No Signal/Communication - Intermittent - MIL ON
01312 - Powertrain Data Bus
            014 - Defective - Intermittent - MIL ON
            002 - Lower Limit Exceeded - Intermittent - MIL ON
   Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
   Coding: 0010021
   VCID: 030E9D7942F42C52C8-8056
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
   Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0003000    Serial number: VWX7Z0H724I0P9
   Coding: 0023203
   Shop #: WSC 00066 067 57207
   VCID: 3C7C26857F8A93AAC9-8068
                    Reset counter: 80
                    Mileage: 245424 km
                    Time: 21:29:40
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 010708F2002166
   Coding: ED807F070003021002
   VCID: 356A33A15CA042E236-8060
                    Mileage: 244526 km
                    Time: 09:49:21
                    Reset counter: 80
                    Mileage: 245424 km
                    Time: 21:29:42
   Component: IMMO            3HL 1222
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000527488807
   Coding: 0001205
   VCID: 6FE6C1C97E7C38323C-803A
01552 - Motor for Central Locking; Drivers Door (V56); Lock
                    Fault Status: 01101100
                    Mileage: 244517 km
                    Fault Frequency: 146
                    Reset counter: 80
                    Mileage: 244517 km
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A5010DD851E1D1AAB-807E
                    Reset counter: 90
                    Mileage: 245424 km
                    Time: 21:32:03
                    Voltage: 11.88 V
                        DD
                    Temperature: 27.0°C
                    Fault Status: 00101101
                    Reset counter: 90
                    Mileage: 245424 km
                    Time: 21:30:03
                    Voltage: 11.88 V
                        DU
                    Temperature: 27.0°C
                    Speed: 50.0 km/h
                    Speed: 50.0 km/h
                    Reset counter: 90
                    Mileage: 245424 km
                    Time: 21:30:05
                    Voltage: 11.88 V
                        DU
                    Temperature: 27.0°C
                    Speed: 44.0 km/h
                    Speed: 44.0 km/h
   Coding: 13900F880186281B0904058FB0880F0488DCA0
   VCID: 040C9E6547FA2B6AF1-8050
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 00000272488808
   Coding: 0001204
   VCID: 70E4C2B5634227CA25-8024
01553 - Motor for Central Locking; Passenger Door (V57); Lock
                    Fault Frequency: 134
                    Reset counter: 80
                    Mileage: 244517 km
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio DE2       016 0020
   Revision: 00016000    Serial number: VWZ4Z7H2221863
   Coding: 0010400
   VCID: 2952EFD180181602A2-807C
            000 -  -
            014 - Defective
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003361177
   Coding: 0001168
   VCID: 76E8F4AD012609FAFF-8022
   Coding: 0100101
00625 - Vehicle Speed Signal
                    Reset counter: 80
                    Mileage: 245424 km
                    Time: 21:32:05
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000003353835
   Coding: 0001168
   VCID: 77F6F9A9062C70F2E4-8022
End-------------------------(Elapsed Time: 02:30)--------------------------
MartinsX
Riga, Latvia
C?ID=268515
Hi and welcome!
First of all post full unedited autoscan, in
 tags would be excellent.
Second - why did You replace old module? What was wrong with it?
kostya1989
Hi and welcome!
Second - why did You replace old module? What was wrong with it?[/QUOTE]
I didnt edit anything in the log but ill see if i can get you another copy!
Replaced it because it started malfunctioning - not showing speed was one of the problems. I tried to find a used one and none of them matched up, this vehicle takes only one part number(or updated part number).
It looks like it needs some of the Basic Settings described on this page.
