- Oct 28, 2019
- 10
- 2
- Portsmouth, UK
- C?ID=339078
hi all!
got an imported VW Tiguan that ive just picked up which wont accept a uk sd card, it keeps coming up when trying to download
"the regions do not match (main unit). "Europe" "RoW"
I have tried manually changing the coding to UK from Australia but this does not work, I have also copied the coding from my pals Tiguan and put it in and that didn't work either.
here is his coding UK: 02730601FF00000051110101008808001F0109C601200100CF
here is my coding aus: 02730601FF00000051510001000808001F0106E601200002DF
anyone got any ideas? is the region in another control unit that I need to also change?
Friday,06,December,2019,20:00:23:48845
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: WVGZZZ5NZHW375725 License Plate: YN67 GPU
Mileage: 33473km-20799mi Repair Order:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 36 39 3C 42
44 4B 52 5F 6C 6D A5 BB BC CA CF D6 D7
VIN: WVGZZZ5NZHW375725 Mileage: 33473km-20799miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CHHB) Labels:. 06K-907-425-V1.clb
Part No SW: 5N0 906 259 HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0001
Revision: --H13---
Coding: 092500322466050B3000
ASAM Dataset: EV_ECM20TFS0205N0906259 001003
ROD: EV_ECM20TFS0205N0906259.rod
VCID: 72A82BBDA511ECDFA1-8026
18934 - Oxygen (Lambda) Sensor Signal B1 S2
P2271 00 [096] - too Rich
Mileage: 33455 km
Date: 2019.12.05
Time: 18:40:59
Engine speed: 1203.25 /min
Normed load value: 39.2 %
Vehicle speed: 61 km/h
Coolant temperature: 99 °C
Intake air temperature: 24 °C
Voltage terminal 30: 14.492 V
14955 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
P2097 00 [101] - Too Rich
Mileage: 33431 km
Date: 2019.12.05
Time: 13:43:22
Engine speed: 906.50 /min
Normed load value: 8.2 %
Vehicle speed: 121 km/h
Coolant temperature: 93 °C
Intake air temperature: 14 °C
Voltage terminal 30: 14.707 V
Engine: operating status: IS
STATE_LS_SAE[1]: OL_INTR
T_AST_SAE: 266 s
MAP_MES_SAE: 26 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.607 V
FAC_TPS_1_SAE: 13.281250 %
FUP_H_SAE: 12330.0 kPa
Readiness: 0000 0001
Part No SW: 0DL 300 011 P HW: 0GC 927 711 G
Component: GSG DQ500 H06 2001
Revision: 00H06V07
VCID: 3522D0A194FFBBE744-8060
Part No SW: 5Q0 614 517 CH HW: 5Q0 614 517 AH
Component: ESC H62 0743
Revision: 00000000 Serial number: 63256000000674
Coding: 0AEE939A54272371477E070262C84950C92AC4E2E046927D384250B8C2AA4200002F641A1B13111435351919323200
VCID: 79BA1C91F8679F87E0-802C
Part No SW: 3Q0 959 435 E HW: 3Q0 959 435 E
Component: VWKESSYMQB 036 0811
Revision: 00036000 Serial number: 0424121850
Coding: 032C2C070F
ASAM Dataset: EV_KessyHellaMQBAB 004039
VCID: 3C34C585B7D56AAFBB-8068
Subsystem 1 - Part No SW: 3G0 962 243 A HW: 3G0 962 243 A
Component: GEB.F.Heckoef H17 0903
Serial number: 98100702
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 5NA 907 044 G HW: 5NA 907 044 G
Component: AC Automat H35 4101
Revision: 20K08000 Serial number: 00000E00312021
Coding: 0012002420010000110510001210142A
ASAM Dataset: EV_ACClimaPrehVW37X 002019
ROD: EV_ACClimaPrehVW37X.rod
VCID: 43C6BE79CA2B1557FA-8016
Subsystem 2 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 04031501850571
263425 - Air Quality Sensor
B10AF 04 [008] - Internal System Fault
Reset counter: 91
Mileage: 33438 km
Date: 2019.12.05
Time: 13:47:02
Outside air temperature: 8.5 °C
Voltage terminal 30: 12.9 V
System run time-Engine running time: 253 s
Air quality status: ERROR
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001632000333
ROD: EV_BCMBOSCH_017.rod
VCID: 7F4EF289E643B1B7DE-802A
Subsystem 1 - Part No SW: 5NC 955 119 HW: 5NC 955 119 Labels: 1KX-955-119.CLB
Component: 326 RL 160922 033 0372
Serial number: 00000001609200303485
Component: RLHS 042 0105
Serial number: S7Y16M11D23H16M12S46
Coding: 00A8DD
204546 - Remote key 2
B147A 18 [009] - Current Too Low
Reset counter: 50
Mileage: 33427 km
Date: 2019.12.05
Time: 10:48:04
Part No SW: 3Q0 919 298 A HW: 3Q0 919 298
Component: PLA 3.0 12K H09 0021
Serial number: 000111167478010
Coding: 0331667851
ASAM Dataset: EV_EPHBO2CVW3260000 010016
ROD: EV_EPHBO2CVW3260000.rod
VCID: 3B36C699B2DB6D97B2-806E
Part No SW: 2Q0 907 572 J HW: 2Q0 907 572 B
Component: ACCCONTIMQB H01 0156
Coding: 320047C358FF8428749C8065303085
ASAM Dataset: EV_ACCMRRCONTIVW376 001011
ROD: EV_ACCMRRCONTIVW376_001.rod
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 22101641351086
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 383CD99583ED468F5F-806C
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0317
Serial number: 003TDR2BSVET
Coding: 98CCC0C00C0000005C540000008800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 106C4135CBDDBECF37-8044
Subsystem 1 - Part No SW: ----------- HW: 480 001 811 16
Serial number: 357000000005DA650F1R
Subsystem 2 - Part No SW: ----------- HW: 480 001 811 16
Serial number: 358000000006DA650F1T
Subsystem 3 - Part No SW: ----------- HW: 480 402 211 16
Serial number: 35100019F22EA2A4F6BO
Subsystem 4 - Part No SW: ----------- HW: 480 402 211 16
Serial number: 3520001A7231F2C5830-
Subsystem 5 - Part No SW: ----------- HW: 480 402 111 16
Serial number: 3550001BF22F9766868N
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 401 301 17
Component: PedP_Sensor_D 000 6149
Serial number: 2280001BF2404066124P
Subsystem 7 - Part No SW: ----------- HW: 480 401 301 17
Component: PedP_Sensor_P 000 6149
Serial number: 2290001C124040621508
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 401 301 17
Component: PedP_Sensor_C 000 6149
Serial number: 2300001BF240406576BY
Subsystem 9 - Part No SW: ----------- HW: 480 001 010 16
Serial number: I0M00000000957A84E1C
Subsystem 10 - Part No SW: ----------- HW: 480 001 310 16
Serial number: I0N0000000084A30D812
Part No SW: 3Q0 953 521 DM HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF033033 Serial number: 20161124300333
Coding: 0C10
ASAM Dataset: EV_SMLSVALEOMQB 001016
ROD: EV_SMLSVALEOMQB.rod
VCID: 7EB00F8DE149B8BFD5-802A
Part No SW: 5NA 920 791 A HW: 5NA 920 791 A
Component: KOMBI 407 2160
Coding: 27A510187F88040801886B0B1401000000000000
Shop #: WSC 38100 381 12345
ASAM Dataset: EV_DashBoardVDDMQBAB 009052
VCID: 41CAB471D0370747E8-8014
Part No SW: 3Q0 907 530 C HW: 3Q0 907 530 C
Component: GW MQB High 418 4286
Revision: -------- Serial number: 0005618369
Coding: 030500347F085900FB07225A9E0F00010001050000000000000000000000
ROD: EV_GatewNF.rod
VCID: 2F2EE2C976A381370E-807A
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29160002326130086453
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 8134692204
9175296 - Function Restriction due to Driver Fatigue Recognition
B130E 00 [008] - -
[Funktionseinschränkung Pausenempfehlung - Ausfall CAN-MSG Prio2]
Reset counter: 91
Mileage: 33440 km
Date: 2019.12.05
Time: 13:48:25
Supply voltage: Terminal 30: 12.6 V
Terminal 15: On
Serial number: HA1-00028.10.16
Coding: 0101
VCID: 4AD8935DED01C41F39-801E
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 B HW: 8V0 907 399 B
Component: LCM_MLBevoH07 0014
VCID: 45C2A061C41F2B67D4-8010
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000304056008
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71AA24B1A017D7C758-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B
Component: Sitzmemory H08 0020
Serial number: Y0006PJS15750
Coding: 0014000000000500018281808181000000008181000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002021
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 C HW: 3Q0 907 566
Component: MRR1Rear H16 0310
Revision: --------
Coding: 44C002
ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
Component: TSG FS 020 0041
Serial number: 130916EIC11334
Coding: 003F1B20D201040000000000
65799 - Door Warning / Entry Lighting
B1775 01 [009] - Electrical Failure
Reset counter: 50
Mileage: 33427 km
Date: 2019.12.05
Time: 10:21:32
Part No SW: 5QF 909 144 HW: 5QF 909 144 _
Component: EPS_MQB_ZFLS 506 5572
Coding: 9307
ROD: EV_SteerAssisMQB_013.rod
VCID: 075E6A69BE93F977E6-8052
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 001 0285
Serial number: 09111610520624
Coding: 000000050100085607000F010A0000000000000000000000000000000000
Component: TSG BFS 020 0041
Serial number: 251016EJM36679
Coding: 003F1120DE01040000000000
VCID: 42C8BB7DD5311C5FF1-8016
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 045 D HW: 3G0 035 045
Component: MU-H-N-RW H51 0814
Serial number: A688K0G2509834
Coding: 02730601FF00000051510001000808001F0106E601200002DF
VCID: 1F0E1209060311B7BE-804A
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZJT3646500
Subsystem 2 - Part No SW: V03 959 801 EC HW: -----------
Component: ROW 2017 --- 0062
Compact Disc Database:
Component: Gracenote2--- --- 4009
B201A 00 [009] - -
Reset counter: 55
Mileage: 33473 km
Date: 2019.12.06
Time: 19:56:50
Voltage terminal 30: 13.4 V
Status_Software_Version_Management-module_name: MDUV612/Main
Part No SW: 5Q0 907 556 B HW: 5Q0 907 556
Component: Areaview 2 H13 0607
Serial number: C854707JG007196
Coding: 01230600A20F200000204094
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
Part No SW: 5Q0 959 107 M HW: 5Q0 959 107 C
Component: HDSG-Modul H12 0261
Revision: -------- Serial number: 30963171000000
Coding: 0A28
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 24111612P22573
Coding: 000307060000010100022346C050490084000E200000
Shop #: WSC 08852 002 1048576
Component: TSG HFS 020 0041
Serial number: 151116EKE28138
Coding: 002A11200100040000000000
Component: TSG HBFS 020 0041
Serial number: 151116EKE16154
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 013 0005
Coding: 108040732602
ROD: EV_SunRoofCONTIAU736_006.rod
VCID: 3D32C881ACCF63A78C-8068
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 C HW: 3Q0 907 590
Revision: --------
Coding: 44C002
ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
VCID: 1660372DE93950FF6D-8042
Component: LED1R H09 0003
ROD: EV_LEDModLeftMELCOAU736_VW48.rod
End----------(Elapsed Time: 02:23, VBatt start/end: 13.3V/13.3V)-----------
