Skoda Octavia VRS Petrol BWA Engine Not Starting
Gary Forrest
C?ID=26511
The symptoms is the car will start if i spray some petrol into the injector area it will run for about 25mins then stalls and wont restart even if i spray fuel into the injector area, if I leave the engine to cool down and repeat the procedure it will start and run for 25mins again,the vcds scan reads fuel pressure problems which i will include with this email, I have changed the tank fuel pump and the control relay, the fuel pressure sensor[06e906051k} along with the high pressure fuel pump and cam piston follower and spark plugs, any help would be greatly appreciated?
VIN: TMBEF21Z672091870   License Plate: KR56SXH
Mileage: 129650km-80560mi   Repair Order: 04.12.19
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72 76
VIN: TMBEF21Z672091870   Mileage: 129650km-80560miles
   Part No SW: 1Z0 907 115 A    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0040
   Revision: 5BH16---    Serial number: SKZ7Z0F3875002
   Coding: 0203000318070160
   Shop #: WSC 20026 576 88598
   VCID: 336F65AF5206F8D76A-8066
000406 - Engine Oil Temp. Sensor (G8)
               P0196 - 004 - Implausible Signal
                    Mileage: 129651 km
                    Time: 07:28:08
                    RPM: 2374 /min
                    Load: 32.1 %
                    Temperature: 20.0°C
                    Temperature: 2.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.478 V
012555 - Low Pressure Fuel regulation
               P310B - 002 - Fuel Pressure Outside Specification
                    Fault Status: 01100010
                    Mileage: 129651 km
                    Time: 07:31:33
                    RPM: 3742 /min
                    Load: 12.9 %
                    Temperature: 6.0°C
                    Temperature: -1.0°C
                    Voltage: 14.351 V
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage - Intermittent
                    Mileage: 129651 km
                    Temperature: 2.0°C
                    Temperature: 1.0°C
                    Voltage: 11.938 V
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
000135 - Fuel Rail/System Pressure
               P0087 - 002 - Too Low
                    Mileage: 129651 km
                    Time: 01:23:00
                    RPM: 772 /min
                    Load: 38.8 %
                    Temperature: 90.0°C
                    Temperature: 24.0°C
                    Voltage: 13.970 V
               P0087 - 008 - Too Low
                    Fault Status: 01101000
                    Mileage: 129651 km
                    Time: 01:23:04
                    RPM: 695 /min
                    Load: 36.5 %
                    Temperature: 91.0°C
                    Temperature: 23.0°C
                    Voltage: 13.843 V
Readiness: 0110 0001
   Revision: 00H11001
   Coding: 0004738
   Shop #: WSC 73430 790 00000
   VCID: 73EFA5AF1286B8D7AA-8026
   Part No: 1Z0 907 044 H
   Component: ClimatronicPQ35 084 0305
   VCID: 3B7F4D8F7A563097B2-806E
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000004592214
   Coding: 018E0F130004140000110D000000000000087F065C0000
   VCID: 6CDDBED34FB8672F6B-8038
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 281106 022  0601
   Coding: 00055223
   Shop #: WSC 73430
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0WKH0W
   Coding: 0020788
   VCID: 3D7B439764423EA78C-8068
   Subsystem 1 - Serial number: 6332MSME1474336CB
   Subsystem 2 - Serial number: 6342MSME15411B3DB
   Part No SW: 1K0 953 549 AK    HW: 1K0 953 549 AK
   Coding: 0001042
   VCID: 7BFF8D8F3AD6F097F2-802E
   Part No SW: 1Z0 920 912 C    HW: 1Z0 920 912 C
   Component: KOMBIINSTRUMENT VD1 1610
   Revision: V1610057    Serial number: SKZ7Z0F3875002
   Coding: 0007401
   Shop #: WSC 57632 001 1048576
   VCID: 356B5BB75C72E6E744-8060
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0020
   Revision:   H04 02    Serial number: 061206F2000196
   Coding: 7D3F074007001303
   VCID: 2F6769DFBE2EDC370E-807A
   Component: IMMO            VD1 1610
   Shop #: WSC 04766 210 92258
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         005 0954
   Coding: 0000756
   VCID: 387552834B601B8F5F-806C
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.074 H07 1806
   Shop #: WSC 02069 000 90108
   Component:    KSG PQ35 G2  020 0203
   Coding: 81801A085283007F3F04850540085F96907CA0
   VCID: 030FF56F42268857BA-8056
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 73430
   Subsystem 6 - Part No: 1K0 951 605 C
   Subsystem 7 - Component:       NGS n.mounted
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Component: Tuer-SG         005 0944
   Coding: 0000756
   VCID: 39735787706A0287A0-806C
   Part No: 1T0 907 357
   Coding: 0000007
   VCID: 74EDA6B31788BFEFB3-8020
00496 - Sensor for Vehicle Leveling; Front
            010 - Open or Short to Plus
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       019 0034
   Revision: 00019000    Serial number: SKZ7Z3F0105426
   Coding: 0000402
   VCID: 2E5974DBB924D53F05-807A
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         005 0907
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 377751BF467E14F756-8062
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0000001
End-------------------------(Elapsed Time: 02:15)--------------------------
                Address 01: Engine       Labels: 06F-907-115-AXX.clb
Control Module Part Number: 1Z0 907 115 A    HW: 8P0 907 115 B
  Component and/or Version: 2.0l R4/4V TFSI     0040
           Software Coding: 0203000318070160
            Work Shop Code: WSC 20026 576 88598
                    Mileage: 129651 km
                    Time: 07:28:08
                    RPM: 2374 /min
                    Load: 32.1 %
                    Temperature: 20.0°C
                    Temperature: 2.0°C
                    Voltage: 14.478 V
                    Mileage: 129651 km
                    Time: 07:31:33
                    RPM: 3742 /min
                    Load: 12.9 %
                    Temperature: 6.0°C
                    Temperature: -1.0°C
                    Voltage: 14.351 V
                    Mileage: 129651 km
                    Temperature: 2.0°C
                    Temperature: 1.0°C
                    Voltage: 11.938 V
                    Voltage: 0.000 V
                    Mileage: 129651 km
                    Time: 01:23:00
                    RPM: 772 /min
                    Load: 38.8 %
                    Temperature: 90.0°C
                    Temperature: 24.0°C
                    Voltage: 13.970 V
                    Mileage: 129651 km
                    Time: 01:23:04
                    RPM: 695 /min
                    Load: 36.5 %
                    Temperature: 91.0°C
                    Temperature: 23.0°C
                    Voltage: 13.843 V
Looks to me like you may have some intermittent electrical problem that underlies this.
NostraJackAss
Bad ground/Terminal 30 connection or relay?
JPPSG
Did you load light the harness yet and sort FP issues?
