Amarok V6 2018-2019, disable foglight when cornering
magloman
Sweden
C?ID=2673
Hi
Anyone knows how to turn off that annoying foglight turning on when taking a corner?
Also how to disable or reverse engine-stop would be much appricated.
Attaching an autoscan
Thursday,15,November,2018,13:06:28:45218
VCDS Version: 18.9.0.2 (x64)  HEX-NET CB: 0.4436.4
Dealer/Shop Name: EDT
Workshop Code: 001 00001 000001
VIN: WV1ZZZ2HZKH00xxxx   License Plate: xxxxx
Mileage: 950km-590mi   Repair Order:
Chassis Type: 2H-VN81 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 18 19 25 32 5F 61 65 69 6E 0B
VIN: WV1ZZZ2HZKH002xxx   Mileage: 950km-590miles
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (J623-DDXE)       Labels: None
   Part No SW: 2H6 907 311 K    HW: 059 907 309 J
   Component: 3.0l V6 TDI   H23 0002
   Revision: 9AH23---
   Coding: 012A403A233601030001
   Shop #: WSC 02776 790 50316
   ASAM Dataset: EV_ECM30TDI0112H6907311K 001002
   ROD: EV_ECM30TDI0112H6907311K.rod
   VCID: B02C6325EB9371CAE5-80E4
Address 02: Auto Trans (J217)       Labels:| 0CM-325-025.clb
   Part No SW: 2H0 927 158 M    HW: 0DR 325 025 B
   Component: 0CM  30TDIRdW H22 1001
   Revision: --H22---
   ASAM Dataset: EV_TCMAL450211 002011
   ROD: EV_TCMAL450211.rod
   VCID: B73E58390EFDA6F2A4-80E2
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 2H6 907 379 A    HW: 2H6 907 379
   Component: ESC           H06 0310
   Revision: 00000000    Serial number: 62128000001331
   Coding: 207368B64994B69704A516A892556D85380000
   ASAM Dataset: EV_Brake1ESCCONTIVN817GP 008001
   ROD: EV_Brake1ESCCONTIVN817GP_008.rod
   VCID: B4246F351F8B4DEA81-80E0
   Serial number: 26081813470610
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: FEB08D1D614757BA27-80AA
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 2H6 907 040 B    HW: 2H6 907 040 B
   Component: ClimatronicT5 H04 0613
   Revision: 00001K05
   Coding: 0000000003
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: A600857DD9572F7A0F-80F2
   Part No SW: 7E0 937 089 C    HW: 7E0 937 089 C
   Component: BCM PQ25 MMI4 H82 0762
   Revision: BB082001    Serial number: 8701 242180487
   Coding: 220002380C610400933807316CCB86D4B281654F60CE7160310000030803
   Shop #: WSC 66305 000 1453318
   VCID: B3266C2912854AD298-80E6
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 150818 05  50  0106
   Coding: 0228DD
   Subsystem 2 - Part No SW: 6R0 959 801 EE    HW: 6R0 959 801 EE  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  023 2332
   Serial number: 13102845180816195440
   Subsystem 3 - Part No SW: 6R0 959 802 EH    HW: 6R0 959 802 EH  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  023 2332
   Serial number: 13202846180814150807
   Subsystem 4 - Part No: 5C0 951 171
   Subsystem 5 - Part No: 1K0 951 605 F
   Subsystem 6 - Part No: 5C0 951 171
   Subsystem 7 - Part No SW: 2H0 959 442     HW: 2H0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39180001620000018326
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 P    HW: 6R0 959 811 P
   Component: J388__TSG_HL  022 1334
   Serial number: 13202709180814234648
   Subsystem 9 - Part No SW: 6R0 959 812 P    HW: 6R0 959 812 P
   Component: J389__TSG_HR  022 1334
   Serial number: 13202708180814034922
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28231822200838
   Coding: 31810E
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: F1AAA621201938C2AA-80A4
   Part No SW: 2K5 959 655 D    HW: 2K5 959 655 D
   Component: VW10Airbag018 010 0018
   Revision: --------    Serial number: 003EL0032YNE
   Coding: 000000000000000000000000000000003138
   Shop #: WSC 02774 790 50316
   VCID: BD324A112CC18CA27E-80E8
   Serial number: 3495RRB40165E1GOIGCV
   Serial number: 3505RRB40165E1GODPV3
   Serial number: 3555YRB404P5KKNKJ88V
   Serial number: 3565YRB40595HHM0KOED
   Part No SW: 2H6 920 873 A    HW: 2H6 920 873 A
   Component: KOMBI         H02 2030
   Coding: 131E000300
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
   VCID: AE107D5DF1A7673AF7-80FA
Address 18: Aux. Heat (J364)       Labels:| User\7E0-963-272-B.clb
   Part No SW: 7E0 963 272 B    HW: 7E0 963 272 B
   Component: STH-T5GP2     003 0009
   Coding: 5133
   Shop #: WSC 00001 001 00001
   ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
   ROD: EV_AuxilParkiHeateWOST5G2.rod
   VCID: AB167449C2B51212D0-80FE
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0402
   Serial number: 00000000000000530360
   Part No SW: 7E0 909 901     HW: 7E0 937 089 C
   Component: GW-K-CAN TP20 H82 0762
   Revision: BB082001
   Coding: 742203
   VCID: E89CCB451BC3F90AFD-80BC
   Component: IMMO          H02 2030
   Coding: 000002
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: EA98B14D0DCFCB1AEB-80BE
Address 32: Differential Locks (J647)       Labels:* 2H0-927-771.clb
   Part No SW: 2H0 927 771 B    HW: 2H0 927 771
   Component: Quersperre    H04 0018
   Revision: 11001001    Serial number: 4DG 24.07.18 00
   ASAM Dataset: EV_QuersUDSAAMVN817 002001
   ROD: EV_QuersUDSAAMVN817.rod
   VCID: AD127A51FCA11C22CE-80F8
   Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
   Component: MU-S-ND-ER    H41 0472
   Serial number: VWZAZ2U1000062
   Coding: 06180701BE00000011111101008808001F0100D4002001004F
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: A5028271A451246206-80F0
   Subsystem 1 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
   Part No SW: 7E0 907 534     HW: 7E0 937 089 C
   Component: Batt.regelung H82 0762
   Coding: 330B18AF
   Shop #: WSC 02776 790 00000
   Subsystem 1 - Part No SW: 2H6 915 181     HW: 2H6 915 181
   Serial number: 7497540800180821042F
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 2H6 907 273     HW: 5Q0 907 273
   Component: RDKBERU30     H04 0003
   Serial number: 40000000029104
   ASAM Dataset: EV_RDKBERU30 006003
   ROD: EV_RDKBERU30_006_VW48.rod
   VCID: EC94B755073BD52A99-80B8
   Component: Anhaenger     H12 0100
   Revision: 3A001001    Serial number: 00000487527452
   Coding: 010D000100000000
   VCID: B02C6325E39371CAE5-80E4
Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-W2.clb
   Part No SW: 7E5 919 037 J    HW: 7E5 919 037 J
   Component: Dachdisplay   H17 0200
   Revision: 1010013S    Serial number: 564559
   Coding: 000103
   VCID: B83C5B050BE3A98AAD-80EC
End----------(Elapsed Time: 02:20, VBatt start/end: 13.3V/13.3V)-----------
Address 17,2H6 920 873 A,channel IDE02494-Automatic door locking,adapted from,Yes ,to,No ,
Address 17,2H6 920 873 A,channel IDE00344-Seat belt warning,adapted from,Version 4 ,to,Version 1 ,
NEtech
Denmark
C?ID=56995
Try Coding [09-Cent. Elect.], remove check mark, Byte 12 Bit 6
