2016 Audi RS3 Adaptive Headlight Fault
m3nt4l
C?ID=348982
This vehicle has the adaptive headlight fault (among others).
Was wondering if anyone knows what needs doing in order to eliminate the error on the dash?
The errors in relation to the ACC is because there is a grill covering the unit so not worried about that.
Here is the log:
Friday,06,December,2019,11:25:01:08713
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WUAZZZ8V6GA910471   License Plate: DWAYNE
Mileage: 56861km-35331mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 22 2B 3C 42 44 52 55
          5F 6C BB BC
VIN: WUAZZZ8V6GA910471   Mileage: 56861km-35331miles
Address 01: Engine (------CZGB)       Labels:. 07K-907-309-V1.clb
   Part No SW: 8V0 907 404     HW: 07K 907 309 C
   Component: 2.5l R5/4V TF H52 0005
   Revision: NKH52---
   Coding: 12250032256601033620
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM25TFS0118V0907404 001006
   ROD: EV_ECM25TFS0118V0907404.rod
   VCID: 76A018FFC9E534FF8D-8022
8 Faults Found:
5456 - Starter Will Not Turn
          P3054 00 [096] - Jammed or Electrical Malfunction
17156 - Databus
17158 - Databus
          U0428 00 [032] - -
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [032] - -
          [Lost Communication WithCruise Control Front Distance Range Sensor]
4629 - ECM Power Relay Load Circuit
          P068A 00 [096] - Opens Too Early
4651 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
5523 - Engine Start Blocked by Immobilizer
          P1570 00 [036] - -
                    Fault Frequency: 106
                    Mileage: 42771 km
                    Date: 2019.01.27
                    Time: 12:37:25
                    Engine speed: 1484.00 /min
                    Normed load value: 14.1 %
                    Coolant temperature: 11 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 11.500 V
                    Immobilizer snapshot A-Sia Error Snap A: 00 00 00
                    Immobilizer snapshot B-Sia Error Snap B: 00 00 00
   Part No SW: 0DL 300 011 D    HW: 0BH 927 711 F
   Component: GSG DQ500     H10 5210
   Revision: 00H10V01
   VCID: 291A038348DB2B07D0-807C
   Part No SW: 8V0 907 379 A    HW: 8V0 907 379 A
   Component: ESC           H42 0030
   Revision: 00000000    Serial number: 61566000000293
   Coding: 999CF08DBA9A15A94095016B4392B20644990F5DA80280C24D6022
   Shop #: WSC 44950 002 1048576
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 061006
   ROD: EV_Brake1UDSContiMK100IPB_061.rod
   VCID: 42C8B42FD5ADD85FF1-8016
0289 - Steering angle sensor
          B1168 29 [008] - Signal Implausible
                    Reset counter: 168
                    Mileage: 42842 km
                    Date: 2019.01.29
                    Time: 18:04:57
0293 - Steering angle sensor
                    Reset counter: 168
                    Mileage: 42857 km
                    Date: 2019.01.31
                    Time: 10:40:46
0301 - Steering angle sensor
                    Reset counter: 168
                    Mileage: 42886 km
                    Date: 2019.01.31
                    Time: 13:38:11
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0406254514
   Coding: 030C0C
   VCID: 3B36C9CBB247A997B2-806E
   Component: AC Automat    H14 0060
   Revision: 20028000    Serial number: 00000000955995
   Coding: 03100005110000001000000000001400
   VCID: 3326E1EB9A1761D76A-8066
   Component: AQ_Hum_Sensor  H03 0005
   Serial number: 3D98C13800PAG0MUFU01
   Part No SW: 5Q0 937 085 BL    HW: 5Q0 937 085 AF
   Component: BCM MQBAB HNA H24 0175
   Serial number: 01061615700708
   Coding: 07051D46C24106FD01844004B31C07A80800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 044472378F39166F83-8050
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 160521  043 0580
   Serial number:         160531142902
   Coding: 0A47F7
   Serial number: 61918698
   Coding: 00006C
   Serial number: 30 03 2016  00000776
   Serial number: 000000000ZY161160TKU
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000066189588
204290 - Remote key 1
          B1479 18 [008] - Current Too Low
                    Reset counter: 116
                    Mileage: 56589 km
                    Date: 2019.11.18
                    Time: 00:14:08
204293 - Remote key 1
          B1479 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 116
                    Mileage: 56589 km
                    Date: 2019.11.18
                    Time: 00:14:08
   Revision: --------    Serial number: 39331616105868
   Coding: 0070150011
   VCID: 43C6B12BCAB7D157FA-8016
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 P    HW: 5Q0 907 567 P
   Component: ACC3          H10 0100
   Serial number: 27041676110962
   Coding: 023E1301FE0309
   ASAM Dataset: EV_ACCBoschMQB 001024
   ROD: EV_ACCBoschMQB_AU37.rod
   VCID: 48DCA607F391F20F2F-801C
0049 - Sensor for Automatic Distance Control
          C110B F0 [040] - Limited Visibility
          [FAULT_BLR_LRR_BLIND]
                    Reset counter: 132
                    Mileage: 50290 km
                    Date: 2019.07.21
                    Time: 00:13:21
                    Control Module temperature: 28 °C
                    Voltage terminal 15: 13.9 V
                    Vehicle speed: 6.22 m/s
                    Acceleration: -0.91 m/s²
0053 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [047] - -
          [FAULT_MAR_FAST_ACC_MISALIGNMENT]
                    Reset counter: 47
                    Mileage: 56100 km
                    Date: 2019.10.31
                    Time: 13:16:06
                    Control Module temperature: 12 °C
                    Voltage terminal 15: 14.8 V
                    Vehicle speed: 18.22 m/s
                    Acceleration: -0.43 m/s²
0054 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [047] - -
          [FAULT_MAR_FAST_PSS_MISALIGNMENT]
                    Reset counter: 47
                    Mileage: 56100 km
                    Date: 2019.10.31
                    Time: 13:16:06
0055 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [047] - -
          [FAULT_MAR_PRE_MISALIGNMENT]
                    Reset counter: 59
                    Mileage: 56391 km
                    Date: 2019.11.08
                    Time: 18:46:45
                    Control Module temperature: 11 °C
                    Voltage terminal 15: 14.5 V
                    Vehicle speed: 16.86 m/s
                    Acceleration: -0.19 m/s²
1085 - Databus
          U1123 00 [047] - Received Error Message
          [FAULT_CIS_DIS_FAIL]
                    Reset counter: 147
                    Mileage: 51344 km
                    Date: 2019.07.31
                    Time: 05:54:11
                    Control Module temperature: 21 °C
                    Voltage terminal 15: 14.6 V
                    Vehicle speed: 0.58 m/s
                    Acceleration: 0.00 m/s²
   Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
   Component: AirbagVW20    012 0364
   Serial number: 003M1R1U7218
   Coding: 98FCC000008000005C54000000C800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4AD89C0FED9D001F39-801E
   Belt Pretensioner left:
   Belt Pretensioner right:
   Subsystem 3 - Part No SW: -----------    HW: 480 001 006 16
   Serial number: 357670000002B85CBB13
   Subsystem 4 - Part No SW: -----------    HW: 480 001 006 16
   Serial number: 358670000008F85CBB1E
   Subsystem 5 - Part No SW: -----------    HW: 480 400 906 16
   Serial number: 3516502A92076361732Z
   Subsystem 6 - Part No SW: -----------    HW: 480 400 906 16
   Serial number: 3526502A92076362E152
   Subsystem 7 - Part No SW: -----------    HW: 480 402 905 12
   Serial number: 3556502C30A2A503B196
9634899 - Control Module for Front Left Belt Tensioner
          B1304 53 [009] - Deactivated
                    Mileage: 42771 km
                    Date: 2019.01.27
                    Time: 12:42:19
9635155 - Control Module for Front Right Belt Tensioner
          B1305 53 [009] - Deactivated
                    Mileage: 42771 km
                    Date: 2019.01.27
                    Time: 12:42:19
   Part No SW: 8V0 953 521 FD    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 11061608490054
   Coding: E418
   VCID: 014A7B23902B0347A8-8054
   Part No SW: 8V0 920 971 N    HW: 8V0 920 971 N
   Component: KOMBI         H02 6420
   Coding: 278D080A2B8026000104E8001000000000000000
   Shop #: WSC 57781 001 1048576
          U1014 00 [009] - -
                    Reset counter: 92
                    Mileage: 42771 km
                    Date: 2019.01.27
                    Time: 12:36:50
9456128 - Engine Control Module (ECM) not authorized
          B104A 00 [008] - -
                    Mileage: 41063 km
                    Date: 2018.12.21
                    Time: 20:10:14
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1244
   Revision: --------    Serial number: 0004966237
   Coding: 030100043F0860005B00027C380B00000001010000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 79BA13C3F8FB5B87E0-802C
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 03 06 2016  F0009354
   Subsystem 3 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9052
   Serial number: 1089940104
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 8S0 857 511 C    HW: 8S0 857 511 C
   Component: FLA           H09 0003
   Revision: AA001001
   Coding: 0404010700000100010001
   ASAM Dataset: EV_HighBeamAssisAU33X 001017
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 393AD3C3B87B9B87A0-806C
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7754
   Serial number: HA1-00003.05.16
   Coding: 0601
   VCID: 45C2AF33C483EF67D4-8010
   Revision: 00000000    Serial number: 16000102147008
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3424E2F79F1966EF73-8060
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Component: SWA Master    H07 0080
   Serial number: 0406311204
   Coding: 030312
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 383CD6C78371828F5F-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
   Component: SWA Slave  H07 0080
   Serial number: 0406392268
   Coding: 030312
   Serial number: 270516EEQ34737
   Coding: 005D1A205C01048000001003
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8103
22528 - Databus
          [MOTOR_12 Botschaft - CAN-Timeout]
                    Reset counter: 147
                    Mileage: 49640 km
                    Date: 2019.07.17
                    Time: 19:18:26
                    Motor status: 03
                    System status: Driving mode
                    Supply voltage: 11.50 V
                    Temperature: 23.0 °C
                    KFC: 58
                    KFA: 00 00
                    Environmental conditions: 20
                    uioUdNotFilt_xdu16: 11.72 V
                    uAdSensI_SwitchedKl30_xdu16: 11.72 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
23040 - Databus
          [MOTOR_20 Botschaft - CAN-Timeout]
                    Reset counter: 147
                    Mileage: 49640 km
                    Date: 2019.07.17
                    Time: 19:18:26
                    Motor status: 03
                    KFC: 5A
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 11.59 V
                    uAdSensI_SwitchedKl30_xdu16: 11.59 V
22784 - Databus
          [MOTOR_14-Botschaft - CAN-Timeout]
                    Reset counter: 147
                    Mileage: 49640 km
                    Date: 2019.07.17
                    Time: 19:18:27
                    Motor status: 03
                    KFC: 59
                    KFA: 00 00
19460 - Databus
          [ESP_05 Botschaft - SNA-Check]
                    Reset counter: 147
                    Mileage: 49640 km
                    Date: 2019.07.17
                    Time: 19:18:29
                    Motor status: 03
                    KFC: 4C
                    KFA: 00 04
                    uioUdNotFilt_xdu16: 11.55 V
                    uAdSensI_SwitchedKl30_xdu16: 11.57 V
23296 - Databus
          [MOTOR_CODE_01 Botschaft - CAN-Timeout]
                    Reset counter: 147
                    Mileage: 49640 km
                    Date: 2019.07.17
                    Time: 19:18:31
                    Motor status: 03
                    KFC: 5B
                    KFA: 00 00
   Serial number: 200516EEJ15048
   Coding: 005D12205E01048000001003
   Component: AFS-ECU       H01 0120
   Coding: 01AE00002B200200
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   VCID: 3FCEBDDBA65FB5B79E-806A
   Coding: E00100
   Coding: E00100
          U1014 00 [137] - -
          [Steuergeraet falsch codiert]
                    Reset counter: 119
                    Mileage: 42771 km
                    Date: 2019.01.27
                    Time: 12:37:27
5276145 - Power Output Module for Left Headlamp
          C1081 F1 [137] - Incorrectly Coded
                    Reset counter: 119
                    Mileage: 42771 km
                    Date: 2019.01.27
                    Time: 12:37:27
5276401 - Power Output Module for Right Headlamp
          C1082 F1 [137] - Incorrectly Coded
                    Reset counter: 119
                    Mileage: 42771 km
                    Date: 2019.01.27
                    Time: 12:37:27
5275953 - Power Output Module for Left Headlamp
          C1081 31 [137] - No Signal
                    Reset counter: 92
                    Mileage: 42771 km
                    Date: 2019.01.27
                    Time: 12:36:52
5276209 - Power Output Module for Right Headlamp
          C1082 31 [137] - No Signal
                    Reset counter: 92
                    Mileage: 42771 km
                    Date: 2019.01.27
                    Time: 12:36:52
   Part No SW: 8V0 035 034 E    HW: 8V0 035 034 D
   Component: MU-H-TN-JP    044 0271
   Serial number: K5F AW7HZ09I4R
   Coding: 017303060000000021330002001200102F000326010001007E
   ASAM Dataset: EV_MUHig6C3AW7 001115
   ROD: EV_MUHig6C3AW7_AU37.rod
   VCID: 3228E4EF650D68DF61-8066
   Subsystem 1 - Part No SW: V03 959 801 AB    HW: -----------
   Component: JPN 2016  --- 7521
   Component: DU High  H49 0014
   Serial number: AUZ8Z9GY205MW9
   Chip Card Reader Control Module:
   Subsystem 3 - Part No SW: 8V0 919 813 B    HW: 8V0 919 813 B
   Component: DSRC UNIT  H09 0002
   Serial number: 502129395140
   Multimedia Operating Unit:
   Subsystem 4 - Part No SW: 8V0 919 614 AA    HW: 8V0 919 614 AA
   Component: ControlUnit_H  H81 0816
   Serial number: ALJAL130031600040100
   Compact Disc Database:
   Subsystem 5 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote  --- 2009
1537 - Supply voltage
          [Supply voltage - lower limit value not reached]
                    Reset counter: 132
                    Mileage: 50290 km
                    Date: 2019.07.21
                    Time: 19:58:06
                    Voltage terminal 30: 8.6 V
          U1400 00 [008] - -
          [Function restriction due to insufficient voltage - lower limit value not reached]
                    Reset counter: 124
                    Mileage: 50290 km
                    Date: 2019.07.21
                    Time: 19:58:09
                    Voltage terminal 30: 8.5 V
2569 - Antenna for Traffic Data
          B128E 31 [009] - No Signal
                    Reset counter: 119
                    Mileage: 42771 km
                    Date: 2019.01.27
                    Time: 12:52:44
                    Voltage terminal 30: 12.3 V
6708 - Databus
          [Engine: no communication]
                    Reset counter: 132
                    Mileage: 49640 km
                    Date: 2019.07.17
                    Time: 19:18:27
                    Voltage terminal 30: 11.7 V
                    Network diagnosis-Status: Enabled
7173 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 132
                    Mileage: 42771 km
                    Date: 2019.01.27
                    Time: 12:36:55
                    Voltage terminal 30: 12.2 V
                    BAP-BAP_Function_ID: 02
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 132
                    Mileage: 42771 km
                    Date: 2019.01.27
                    Time: 12:36:55
   Coding: 027300060201000300
   ROD: EV_2CamSysRearPASE.rod
   VCID: 302CEEE76B015ACF17-8064
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 200516EEI3076B
   Coding: 004D12204001048000001002
   Serial number: 200516EEI30768
End----------(Elapsed Time: 01:48, VBatt start/end: 14.6V/14.6V)-----------
