Hi all, first of all nice to meet you all so i took the plunge and bought my own hex net professional was sick of the costs at the garage for them to find my faults haha.
Here is a copy of my autoscan if anyone can help me with any of it
Just thought i better add its a Audi s4 b6 cabriolet
4.2 v8
Friday,06,December,2019,12:25:14:40804
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: WUAZZZ8HX4K901613 License Plate: MA54BVR
Mileage: 191540km-119017mi Repair Order:
Chassis Type: 8H (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
67 69 75 76 77
VIN: WUAZZZ8HX4K901613 Mileage: 191540km-119017miles
Address 01: Engine Labels: 079-910-560-BBK.lbl
Part No SW: 8H0 910 560 A HW: 8E0 907 560
Component: 4.2L V8/5V 0010
Coding: 0011774
Shop #: WSC 00672 785 00200
VCID: 2600EFBF9078697FFD-5160
7 Faults Found:
16524 - Oxygen (Lambda) Sensor B1 S2
P0140 - 004 - No Activity
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - Intermittent
16686 - Cylinder 2
P0302 - 001 - Misfire Detected - Intermittent
17985 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit - Intermittent
18010 - Power Supply Terminal 30
18080 - Coolant Fan Control 1
P1672 - 004 - Open or Short to Ground - Intermittent
18308 - Coolant Fan Control 2
P1900 - 004 - Open or Short to Ground - Intermittent
Readiness: 0110 1001
Part No SW: 8E0 910 156 HW: 09L 927 156
Component: AG6 09L 4.2L5V RdW 0040
Revision: 00000001 Serial number: 0009249
Coding: 0000001
VCID: 6386B6ABA3CADC57DA-5160
16946 - System Voltage
P0562 - 000 - Too Low - Intermittent
RPM: 1440 /min
RPM: 800 /min
(no units): 30.0
(no units): 0.0
Temperature: 12.0°C
T.B. Angle: 0.0°
Voltage: 6.64 V
Address 03: ABS Brakes Labels: None
VCID: 55E29873AD9E32E7A4-51A8
No Faults Found
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AD
Component: A4 Klimaautomat 1324
Coding: 00100
Shop #: WSC 00672
VCID: 6386B6ABF3CADC57DA-513C
07-00 - Signal too Low
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0617
Coding: 01001
Shop #: WSC 00672
VCID: 352238F30DDE12E744-4B00
Address 15: Airbags Labels: 8H0-959-655-84.lbl
Part No: 8H0 959 655 B
Component: Airbag 8.4EC 2015
Coding: 0010104
VCID: 393A34C371C6F687A0-5160
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 01111
Shop #: WSC 00672
VCID: 3E3027DF38E8D1BF95-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8H0 920 980 L
Component: KOMBI+WEGFAHRS. RB4 D22
Coding: 01401
Shop #: WSC 19411
VCID: 383C31C71ACCEF8F5F-5160
WUAZZZ8HX4K901613 AUZ6Z0D0118946
01304 - Radio
49-00 - No Communications
00-00 - -
Part No: 8H0 959 760
Component: Sitzmemory EE H05 X014
Coding: 00002
Shop #: WSC 00065
VCID: 74A4C5F745244BEFB3-4B00
02010 - Left Entry Assistance Control Module (J572)
79-00 - Please Check Fault Codes
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8H0 951 178
Component: Innenraumueberw. 0411
Coding: 00001
VCID: 6FAECA9B2F0268374E-50F4
01349 - Alarm via Theft Warning System; Front
43-00 - Closed
81-00 - Open
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8H0 959 433 F
Component: Komfortgerát T3B 3220
Coding: 32767
VCID: 373E32FB17D2E0F756-4B00
Subsystem 1 - Part No: 8H2959802
Component: Tõrsteuer.FS BRM 3020
Component: Tõrsteuer.BF BRM 0003
12 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
00955 - Key 1
35-10 - - - Intermittent
00957 - Key 3
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00070
Shop #: WSC 00672
VCID: 0444953715847B6F83-4AE0
35-00 - -
30-00 - Open or Short to Plus
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D09
Coding: 01105
Shop #: WSC 00672
VCID: 43C6562B500ABC57FA-513C
End----------(Elapsed Time: 05:13, VBatt start/end: 13.9V/13.9V)-----------
