2013 T5 Transporter 180 bi-turbo tdi. Senor reference fault?
wagenworx
uk
C?ID=89172
Hi Guys
I have This Vw transporter 2013 bi-turbo 180 tdi with a Sensor reference fault, it also displays in the instrument cluster change air filter which ive never seen before.
Can anyone help as I'm not sure what sensor/sensors to check or replace??
Thanks in advance,
Friday,06,December,2019,08:55:57:52053
Dealer/Shop Name: Wagenworx LTD
VIN: WV1ZZZ7HZDH105713   License Plate:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 56 69 0B
VIN: WV1ZZZ7HZDH105713   Mileage: 121690km-75614miles
56-Radio -- Status: Malfunction 1110
Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 019 GN    HW: 03L 907 309 L
   Component: R4 2,0L EDC   H38 6326
   Revision: 22H38---    Serial number: 00000000000000
   Coding: 01194012233400080000
   Shop #: WSC 00168 210 93958
   ASAM Dataset: EV_ECM20BTD01103L906019GN 003005
   ROD: EV_ECM20BTD01103L906019GK_003.rod
   VCID: FDB2A4F36C3ABBA74C-80A8
4123 - Sensor Reference Voltage A
          P0641 00 [175] - Open Circuit
                    Mileage: 121137 km
                    Date: 2019.11.09
                    Time: 11:10:54
                    Engine speed: 1994.00 /min
                    Vehicle speed: 104 km/h
                    Coolant temperature: 91 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 14.180 V
                    Exh.gas temp.sen 1: 280.1 °C
                    Exh.gas temp.sen 2: -0.0 °C
                    Exh.gas temp.sen 3: 325.6 °C
                    Exh.gas temp.sen 4: 308.1 °C
                    Shut-off timer: last engine shut-off time: 206 s
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0110
   Revision: 00H43001
   Coding: 108764AD09A4089A26A99072AA6110
   Shop #: WSC 02756 790 49152
   VCID: BA386FEF35944C9F29-80EE
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 104
                    Mileage: 120735 km
                    Date: 2014.03.16
                    Time: 08:27:55
                    Count: 23808
                    Count: 1
                    Count: 8241
                    Count: 764
   Part No SW: 7E5 907 047 BF    HW: 7E5 907 047 BF
   Component: Climatic-T5   H20 0506
   Revision: 00001010
   Coding: 0000000002
   Shop #: WSC 02756 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: F4A481D75F70FAEF33-80A0
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 087 K    HW: 7H0 937 087
   Component: BCM T5GP H+4  H32 0407
   Revision: BO032001    Serial number: 0533 054130723
   Coding: A0B0793A0A612413922048106C2B8CD40080410F60844000320000000000
   Shop #: WSC 93958 288 02691
   VCID: BC3469F73FA072AF3B-80E8
   Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3313
   Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3313
   Subsystem 3 - Part No: 7E1 951 172
   Subsystem 5 - Part No: 7E1 951 172
03789 - Terminal 75 Limp Mode Active
                    Reset counter: 132
                    Mileage: 120872 km
                    Date: 2014.03.16
                    Time: 16:49:47
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28261301500002
   Coding: 118001
   ASAM Dataset: EV_VW75XParkAssis8K 001003
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: BB366AEB32AE759732-80EE
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag009 H07 0013
   Revision: --------    Serial number: 003HL00GBJEF
   Coding: 000000000000000000000000000000003039
   Shop #: WSC 02754 790 50316
   VCID: B5227CD3148AA3E7C4-80E0
   Part No SW: 7E0 920 970 G    HW: 7E0 920 970 G
   Component: KOMBI         H06 0605
   Coding: 160A01
   VCID: AE1053BFF1DC903F85-80FA
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 H32 0407
   Revision: BO032001
   Coding: 042300
   VCID: F0AC8DC72368C6CFD7-80A4
01304 - Radio
                    Reset counter: 137
                    Mileage: 112806 km
                    Date: 2013.05.02
                    Time: 13:00:37
   Component: IMMO          H06 0605
   VCID: EA989FAF0DB43C1F99-80BE
Address 56: Radio
   Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
   Component: Anhaenger     H10 0110
   Revision: 3B001001    Serial number: 00000192852466
   Coding: 410D000101000000
   Shop #: WSC 02756 790 00000
   VCID: B12A48C3E8E28FC798-80E4
End----------(Elapsed Time: 01:55, VBatt start/end: 14.3V/14.2V)-----------
If I understand this correctly, the ECU outputs a 5V reference signal used by some of the sensors and the "open circuit" indicates that no current is being drawn from it. Got wiring diagrams for this vehicle?
wagenworx
uk
C?ID=89172
Yes I have wiring diagrams via Elsa win.
I forgot to say engine light on, glow plug light flashing and limp mode active. What I have noticed in the auto scan exhaust gas temp sensor 2 reads -0.0?
Did you check for the 5 volt ref at component directly?
Did you know all shared sensors on the BUS must be tested?
Did you check feed grounds and power sources that must also be verified by bifurcation first?
Did you try unplugging engine bay side to ECU harness & then scan car and clear fault to see if the sensor ref range voltage DTC vacates & if does did you know the issue is on that side most likely or respective sensors and if DTC stays it's on other feed side of ECU?
