2016 A6 2.0TDI REDUCTANT SENSOR FAULT
BOBSER1
Ireland
C?ID=275670
hello folks ,was just looking to see if anybody has came across these faults shown in scan
or has anybody replaced there reductant sensor as i am starting to suspect it is faulty .any help would be great .cheers...
Thursday,05,December,2019,19:45:56:65251
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUZZZ4G9GN124318   License Plate:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 3B 42 44 46 52 53 55 5F
          62 6D 72 AC
VIN: WAUZZZ4G9GN124318   Mileage: 98563km-61244miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FQ    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 1649
   Revision: 85H23---
   Coding: 12254012242401080000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TDI01104L906021FQ 002004
   ROD: EV_ECM20TDI01104L906021FQ_002.rod
   VCID: F9BAA48B7827318760-80AC
9646 - Reductant
          P20E9 00 [032] - Pressure too High
                    Mileage: 98530 km
                    Date: 2019.12.04
                    Time: 20:03:17
                    Engine speed: 829.00 /min
                    Normed load value: 34.9 %
                    Coolant temperature: 83 °C
                    Intake air temperature: 51 °C
                    Voltage terminal 30: 13.040 V
                    Extern.temp.sens.1 bank 1: raw value: 8.0 °C
                    Pressure sensor for reducing agent: measured pressure: 889 hPa
                    Sensor for reducing agent tank temperature: temperature: 9.1 °C
                    Reducing agent pump: activation: 30.00 %
                    Sensor for reducing agent fill level: voltage: 3100.0 mV
9658 - Reductant Pressure Sensor Circuit
          P204B 00 [047] - Implausible Signal
                    Mileage: 98526 km
                    Date: 2019.12.04
                    Time: 19:43:37
                    Engine speed: 829.50 /min
                    Normed load value: 27.5 %
                    Coolant temperature: 79 °C
                    Intake air temperature: 43 °C
                    Voltage terminal 30: 14.620 V
                    Extern.temp.sens.1 bank 1: raw value: 7.0 °C
                    Pressure sensor for reducing agent: measured pressure: 925 hPa
                    Reducing agent pump: activation: 0.00 %
                    Sensor for reducing agent fill level: voltage: 3105.0 mV
Readiness: 0 1 0 0 0
   Part No SW: 4G1 927 153 B    HW: 0CK 927 156 S
   Component: 0CK 20TDI RdW H04 0002
   Revision: --H04---    Serial number: 0000000851
   Coding: 100001
   ASAM Dataset: EV_TCMDL382021 002020
   ROD: EV_TCMDL382021_AU57.rod
   VCID: A91AB4CBC807410750-80FC
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  HB1 0572
   Serial number: 75117051150325000536
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 06A29E41604579829B00
   ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
   VCID: C1CA0C6B5077A94768-8094
   Part No SW: 4H0 907 064 GN    HW: 4H0 907 064 GN
   Component: BCM2 2.0      H37 0572
   Coding: 01B9704E000000000000
   VCID: FBB6BE837A1B039772-80AE
   Serial number: 3215000180378001
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 26111500040061
   Coding: 34220978210000
   VCID: E386E6E3EAABDB575A-80B6
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0311
   Revision: 15020001    Serial number: 00001231228901
   Coding: 0105001440349FE041014083000018000F9DC7082F08020100000894E100140200400024030000
   VCID: F1AA9CAB285779C7D8-80A4
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 150919  H38 0080
   Serial number:         151002033303
   Coding: 0045F7
   Serial number: 61001742
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 28 11 2015  00000337
   Serial number: 2EA98CD7000000000001
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1007LJVL
   Coding: 30333130313630323639554A305234473053
   VCID: BB367E83329BC39732-80EE
   Serial number: 3575HRB40673LPS861P.
   Serial number: 3585HRB40693LPS848M%
   Serial number: 3515JRB40085558A81KG
   Serial number: 3525JRB40085558AMHI2
   Serial number: 3554VRB401G554Q2COS+
   Serial number: 3564VRB400E555N0M9RT
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 90862OL2001D7
   Coding: 000035
   VCID: BB367E833A9BC39732-80EE
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Serial number: 22 10 2015  G0063319
   Part No SW: 4G8 920 951 E    HW: 4G8 920 951 E
   Component: MDieGb        H43 0604
   Revision: 29450306    Serial number: 658301115592013
   Coding: 33A612000B412600010000
   ASAM Dataset: EV_RBC7KMID 004050
   ROD: EV_RBC7KMID.rod
   VCID: B22853A7E5D102DFE1-80E6
   Part No SW: 4G5 907 468 F    HW: 4G0 907 468 AC
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000002071108
   Coding: C0CD074418
   ASAM Dataset: EV_GatewPkoUDS 001028
   VCID: B83C618F03ADE88FDF-80EC
   Serial number: 8471058603
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
   Serial number: 150903000000000003B0
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04028264747464545425363E00
   VCID: E79EF2F31693B77786-80B2
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 26111500041560
   Coding: 22
   VCID: BD32709B2C8FCDA70C-80E8
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720LVUDC
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: B32656A31ACB0BD7EA-80E6
   Component: TSG FA        H03 0511
   Coding: 011C16014001620002080002
   VCID: C7DE127376539777A6-8092
   Component: RCevo         H53 0202
   Revision: 00000002    Serial number: 0000419456
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: BA387B873DA1FA9F29-80EE
   Revision: 00002001    Serial number: 0388031400
   Coding: 013B0622A0B93000C320090400010F470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 A
   Component: Sensor, DWA  005 0002
   Component: TSG BF        H03 0511
   VCID: C6C01F7771598E7F5D-8092
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001674214
   ROD: EV_ParkiBrake_VW51.rod
   VCID: AD1240DBFCEF5D27BC-80F8
   Coding: 04FE02102A600200
   VCID: B42455BF1FC50CEFF3-80E0
   Coding: E01E00
   Coding: E01E00
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 4G1 035 192 A    HW: 4G1 035 192 A
   Component: RMC Nav Plus  H61 0139
   Coding: 0101010101415B47082B060301010000000000
   VCID: A10AACEBB837894708-80F4
   Subsystem 1 - Part No: 8X0 919 884 J
   Component: P32-50-15.03  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464K10F2741285
   Subsystem 3 - Part No SW: 4G2 919 610 E    HW: 4G2 919 610 E
   Serial number: 90349OKJ0009H
   Component: TSG HL        H03 0511
   Coding: 010814004001620002080002
   VCID: C9DA144B60476107B0-809C
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0151
   Revision: 14005001    Serial number: 323501349
   Coding: 093205C010
   ROD: EV_HDSGAu571.rod
   VCID: B6206FB709B91EFFCD-80E2
   Component: TSG HR        H03 0511
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 153090520
   ROD: EV_RDCMA00100_008.rod
   VCID: AF2E5AD3F6E32F378E-80FA
End----------(Elapsed Time: 01:58, VBatt start/end: 14.6V/14.6V)-----------
I think we've seen pressure too low, but I don't recall one with pressure too high.
BOBSER1
Ireland
C?ID=275670
Yea man on previous scan it had pressure to low also. Was the outcome a faulty sensor can u recall?
BOBSER1
Ireland
C?ID=275670
yea very true it only seemed to start throwing this fault when the weather was dropping below zero.cheers ill let ya know th result when i get to the bottom of it
NostraJackAss
BOBSER1
Ireland
C?ID=275670
i did not but thanks very much for the info and links ,much appreciated man .
