08 4.2FSI Q7 Multiple cyl misfire. ROUGH running/ barely idles -at wits end....
imquattro
C?ID=274133
Bought the Q7 with no repair history in barely running condition.
Initially had tons of hard set short to ground codes that turned out to be a HPFP had failed and took out the ECU.
New HPFP(s), new pump cam followers, new correct spark plugs, new coils (8), all new injectors, intake runner's cleaned (oddly only the right bank was dirty, left bank was very clean??), new ECU, new battery.
Still have same basic issue. All short to ground faults were fixed with the new ECU and HPFPs.
Random cylinder misfires are so bad it's un-drivable and eventually stalls out.
I'm concerned its cam timing or chain related but there aren't any codes pointing to that.
I need some hope.
Thursday,05,December,2019,09:48:45:46475
VCDS Version: 19.6.2.0 (x64)
                Address 01: Engine       Labels: 079-907-560-BAR.clb
Control Module Part Number: 4L0 910 560 G    HW: 4L0 907 560 B
  Component and/or Version: 4.2l V8/4V          0020
           Software Coding: 01210009190F0960
            Work Shop Code: WSC 31414 790 00001
                      VCID: 2C57768D8FBEBC2F2B-8078
7 Faults Found:
               P0300 - 001 -
                    Fault Status: 01100001
                    Mileage: 217246 km
                    Date: 2007.06.02
                    Time: 08:28:29
                    RPM: 1934 /min
                    Load: 36.8 %
                    Temperature: 36.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.208 V
000772 - Cylinder 4
               P0304 - 001 - Misfire Detected
                    Mileage: 217246 km
                    Date: 2007.06.02
                    Time: 08:28:29
                    RPM: 1934 /min
                    Load: 36.8 %
                    Temperature: 36.0°C
                    Temperature: 21.0°C
                    Voltage: 13.208 V
000773 - Cylinder 5
               P0305 - 001 - Misfire Detected
                    Mileage: 217246 km
                    Date: 2007.06.02
                    Time: 08:28:31
                    RPM: 1777 /min
                    Load: 46.6 %
                    Temperature: 36.0°C
                    Temperature: 21.0°C
                    Voltage: 13.208 V
000774 - Cylinder 6
               P0306 - 001 - Misfire Detected
                    Mileage: 217246 km
                    Date: 2007.06.02
                    Time: 08:28:31
                    RPM: 1777 /min
                    Load: 46.6 %
                    Temperature: 36.0°C
                    Temperature: 21.0°C
                    Voltage: 13.208 V
000775 - Cylinder 7
               P0307 - 001 - Misfire Detected
                    Mileage: 217246 km
                    Date: 2007.06.02
                    Time: 08:28:31
                    RPM: 1777 /min
                    Load: 46.6 %
                    Temperature: 36.0°C
                    Temperature: 21.0°C
                    Voltage: 13.208 V
000262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
               P0106 - 008 - Implausible Signal
                    Fault Status: 01101000
                    Mileage: 217246 km
                    Date: 2007.06.02
                    Time: 08:29:45
                    RPM: 2374 /min
                    Load: 31.4 %
                    Temperature: 47.0°C
                    Temperature: 21.0°C
                    Voltage: 13.335 V
005241 - Brake Boost Vacuum System
               P1479 - 008 - Mechanical Failure
                    Mileage: 217246 km
                    Date: 2007.06.02
                    Time: 08:29:48
                    RPM: 490 /min
                    Load: 83.1 %
                    Temperature: 47.0°C
                    Temperature: 21.0°C
                    Voltage: 12.192 V
Readiness: 0110 1101
NostraJackAss
I need some hope.​
Hello & welcome to the VCDS forum OP.
That's an awful lot of parts changed already, how about a compression check? :rolleyes:
What is status of G71 MAP and IAT?
http://wiki.ross-tech.com/wiki/index.php/16490/P0106/000262
Please post a complete unedited auto-scan and JPPSG
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
If new why not at latest firmware level?
Component and/or Version: 4.2l V8/4V 0020 <<<<<<<<<<<<<<<<< HMMMMM
imquattro
C?ID=274133
Thanks. It'll take some time to get that info, but I'll get working on it.
Question regarding the ECU firmware: how do I get it updated? I bought the ECU from Auto Module Source last month. They needed my ECU 1st to program the one they sent. Wasn't aware of firmware edition(s) or how to update....
I'll get working on that list you gave me....
imquattro
C?ID=274133
Hope this is a good start. Took a while:
Audi/ Q7 / 2008/ Premium 4.2FSI
Step 1 Tag of PR-Build data picture
Step 2 Status of car is STOCK
Step 3 "VCDS" COMPLETE Auto-Scan in code tags!
***Scan includes some original scan info from started working on it after I purchased it. NOTE DATES****
Monday,11,November,2019,07:45:03:46475
VIN: WA1BV74L78D048214   License Plate:
Mileage: 217240km-134986mi   Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 28 36 37 42 46 47
          4F 52 55 56 61 62 65 69 6C 6D 6F 72 76 77
VIN: WA1BV74L78D048214   Mileage: 217240km-134986miles
0E-Media Player 1 -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine        Labels:. 079-907-560-BAR.clb
   Part No SW: 4L0 910 560 G    HW: 4L0 907 560 B
   Component: 4.2l V8/4V          0020
   Revision: 78H02---    Serial number:
   Shop #: WSC 31414 790 00001
9 Faults Found:
012361 - Control Circuit for Starter Relay 2
               P3049 - 004 - Open Circuit - Intermittent
                    Mileage: 217246 km
                    Temperature: 40.0°C
                    Temperature: 25.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.938 V
001557 - Output for Starter Relay
               P0615 - 004 - Open Circuit - Intermittent
                    Mileage: 217246 km
                    Date: 2007.05.21
                    Time: 15:24:59
                    Temperature: 41.0°C
                    Temperature: 26.0°C
                    Voltage: 11.684 V
001672 - ECM Power Relay Load Circuit
               P0688 - 002 - Open Circuit - Intermittent
                    Mileage: 217246 km
                    Date: 2007.05.21
                    Time: 15:26:15
                    Temperature: 41.0°C
                    Temperature: 26.0°C
                    Voltage: 1.143 V
001670 - ECM Power Relay Control Circuit
               P0686 - 002 - Short to GND - Intermittent
                    Mileage: 217246 km
                    Date: 2007.05.21
                    Time: 15:28:11
                    Temperature: 40.0°C
                    Temperature: 26.0°C
                    Voltage: 4.191 V
               P0300 - 001 -
                    Mileage: 217246 km
                    Date: 2007.05.21
                    Time: 16:25:07
                    RPM: 1101 /min
                    Load: 46.6 %
                    Temperature: 33.0°C
                    Temperature: 23.0°C
                    Voltage: 12.827 V
000773 - Cylinder 5
                    Mileage: 217246 km
                    Date: 2007.05.21
                    Time: 16:25:07
                    RPM: 1101 /min
                    Load: 46.6 %
                    Temperature: 33.0°C
                    Temperature: 23.0°C
                    Voltage: 12.827 V
000775 - Cylinder 7
                    Mileage: 217246 km
                    Date: 2007.05.21
                    Time: 16:25:07
                    RPM: 1101 /min
                    Load: 46.6 %
                    Temperature: 33.0°C
                    Temperature: 23.0°C
                    Voltage: 12.827 V
000776 - Cylinder 8
               P0308 - 001 - Misfire Detected
                    Mileage: 217246 km
                    Date: 2007.05.21
                    Time: 16:25:16
                    RPM: 1085 /min
                    Load: 44.3 %
                    Temperature: 33.0°C
                    Temperature: 22.0°C
                    Voltage: 12.954 V
000135 - Fuel Rail/System Pressure
               P0087 - 002 - Too Low - Intermittent
                    Mileage: 217246 km
                    Date: 2007.05.21
                    Time: 16:25:17
                    RPM: 1093 /min
                    Load: 44.3 %
                    Temperature: 33.0°C
                    Temperature: 22.0°C
                    Voltage: 12.954 V
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No SW: 09D 927 750 JH    HW: 09D 927 750 JH
   Component: AL 750 6A           1166
   Revision: 00H78000    Serial number:
   Coding: 0000504
   VCID: 7DF18BC92444E5A7CC-8028
   Part No SW: 4L0 910 517 B    HW: 4L0 614 517 D
   Component: ESP ALLRAD MK25E1   0010
   Revision: 00H30001
   Coding: 0082993
   VCID: 29598F99804CA907D0-807C
                    Fault Status: 00100001
                    Reset counter: 196
                    Mileage: 217238 km
                    Date: 2007.05.16
                    Time: 12:04:58
                    Count: 64
                    Count: 8449
                    Count: 129
                    Count: 56832
                    Reset counter: 199
                    Count: 192
                    Count: 11008
                    Count: 128
                    Count: 21248
                    Fault Status: 00101101
                    Reset counter: 159
                    Mileage: 217236 km
                    Date: 2007.05.21
                    Time: 16:08:06
                    Count: 64
                    Count: 4417
                    Count: 8193
                    Count: 36608
                    Reset counter: 159
                    Mileage: 217246 km
                    Date: 2007.05.21
                    Time: 15:26:14
                    Count: 8513
                    Count: 8194
                    Count: 41984
                    Reset counter: 153
                    Mileage: 217233 km
                    Date: 2007.05.16
                    Time: 12:00:16
                    Count: 192
                    Count: 9025
                    Count: 297
                    Count: 46848
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0230
   Revision: 09010701    Serial number: 10601500977301
   Coding: 0000135
   VCID: 63C5DDB1A2E03357DA-8036
   Subsystem 1 - Part No: 4F0 910 131 L
   Component: FBSAUDIC6 EZS   H46 0080
   Component: FBSAUDIC6 KSG   H27 0080
   Component: FBSAUDIC6 IDG   H01 0060
9 Faults Found:
00192 - Rear Left Door Handle Touch Sensor (G417)
            007 - Short to Ground
                    Fault Status: 01110111
                    Reset counter: 193
                    Mileage: 195344 km
                    Date: 2017.05.31
                    Time: 12:00:01
00190 - Driver's Door Handle Touch Sensor (G415)
                    Reset counter: 193
                    Mileage: 195344 km
                    Date: 2017.05.31
                    Time: 12:00:01
00193 - Rear Right Door Handle Touch Sensor (G418)
                    Reset counter: 193
                    Mileage: 195344 km
                    Date: 2017.05.31
                    Time: 12:00:01
00191 - Passenger's Door Handle Touch Sensor (G416)
                    Fault Status: 00110111
                    Reset counter: 195
                    Mileage: 208536 km
                    Date: 2018.01.23
                    Time: 16:20:10
                    Reset counter: 198
                    Mileage: 217233 km
                    Date: 2007.05.16
                    Time: 14:08:15
                    Fault Frequency: 14
                    Reset counter: 198
                    Mileage: 217235 km
                    Date: 2019.01.08
                    Time: 16:41:03
00230 - Transmission Park Selector Switch (F305)
                    Fault Status: 00101010
                    Reset counter: 199
                    Mileage: 217246 km
                    Date: 2007.05.21
                    Time: 15:27:17
                    Fault Status: 01111011
                    Reset counter: 193
                    Mileage: 195344 km
                    Date: 2017.05.31
                    Time: 12:00:01
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
   Part No SW: 4L0 910 731 P    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4140
   Revision: 00000000    Serial number: 354AN087534812
   Coding: 0002003
   VCID: 356153E95CF4FDE744-8060
   Subsystem 1 - Part No: 4L0 910 609
   Component: E0380 BedienteilH01 0060
   Subsystem 2 - Serial number: 00000000966818
   Subsystem 3 - Serial number: 0115.01.080000000100010648ÿ
   Subsystem 4 - Serial number: 010648ÿ
02244 - Button in Control Head is Stuck
                    Reset counter: 199
                    Mileage: 216929 km
                    Date: 2018.11.29
                    Time: 07:39:49
                    Bin. Bits: 00000000
                    Bin. Bits:  0000000
                    Bin. Bits:      001
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 196
                    Mileage: 217238 km
                    Date: 2007.05.16
                    Time: 12:48:04
                    Reset counter: 197
                    Time Indication: 15
   Part No SW: 4L0 910 043 B    HW: 4L0 820 043 L
   Component: KLIMABETAETIGUNGH07 0030
   Revision: 00---013    Serial number: 00000030079290
   Coding: 0655400
   VCID: 23459DB1E26073579A-8076
                    Fault Status: 00101001
                    Reset counter: 199
                    Mileage: 217246 km
                    Date: 2007.05.21
                    Time: 15:26:20
                    Temperature: 41.0°C
                    Temperature: 17.0°C
                    Temperature: -55.0°C
                    Absolute Pres.: 1.0 bar
                    Current: 0.000 A
                    Temperature: 20.0°C
                    Reset counter: 198
                    Mileage: 217235 km
                    Date: 2019.01.08
                    Time: 16:41:06
                    Voltage: 7.80 V
                    Reset counter: 196
                    Mileage: 217234 km
                    Date: 2007.05.19
                    Time: 18:57:08
                    Bin. Bits:    01111
                    Reset counter: 198
                    Mileage: 217244 km
                    Date: 2007.06.01
                    Time: 12:33:07
                    Reset counter: 199
                    Mileage: 217246 km
                    Date: 2007.05.21
                    Time: 15:26:20
   Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
   Component: ILM Fahrer      H18 0250
   Coding: 0114123
   VCID: 306F62FDA396D8CF17-8064
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H15 0100
   Coding: 00064792
   Shop #: WSC 31414
   Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0100
   Coding: 00150059
   Shop #: WSC 31414
                    Reset counter: 199
                    Mileage: 217244 km
                    Date: 2007.05.21
                    Time: 13:38:00
02385 - Rain / Light Recognition Sensor Function Restricted due to Under-Voltage
                    Reset counter: 193
                    Mileage: 217232 km
                    Date: 2019.01.08
                    Time: 16:41:00
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                    Reset counter: 193
                    Mileage: 217232 km
                    Date: 2007.05.16
                    Time: 12:08:00
02384 - Windshield Wiper Motor Function Restricted due to Over-Voltage
                    Reset counter: 196
                    Mileage: 217236 km
                    Date: 2007.05.16
                    Time: 12:01:00
01494 - Bulb for Parking Lamps; Left (M1)
                    Reset counter: 159
                    Mileage: 217236 km
                    Date: 2007.05.16
                    Time: 12:06:00
   Part No SW: 4L0 910 110 A    HW: 4L0 035 110
   Component: MP3-Changer     H45 0350
   Revision: 00045007    Serial number: AUZ5ZBG1243333
   VCID: 1D31AB49C40445A7AC-8048
                    Reset counter: 197
                    Mileage: 217233 km
                    Date: 2007.05.16
                    Time: 14:07:38
                    Reset counter: 197
                    Mileage: 217233 km
                    Date: 2007.05.16
                    Time: 14:08:18
02446 - Disk Drive Mechanical Malfunction
                    Fault Status: 00101110
                    Reset counter: 196
                    Mileage: 217238 km
                    Date: 2007.05.16
                    Time: 12:01:11
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 K    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0140
   Revision: 00000000    Serial number: AUZ4Z7H0239932
   Coding: 0000100
   VCID: 2F6D6181BEA8C7370E-807A
                    Reset counter: 197
                    Mileage: 217244 km
                    Date: 2007.05.31
                    Time: 19:40:14
                    Voltage: 8.40 V
                    Reset counter: 197
                    Mileage: 217244 km
                    Date: 2007.05.31
                    Time: 19:39:44
                    Voltage: 8.40 V
                    Reset counter: 76
                    Mileage: 215464 km
                    Date: 2018.10.19
                    Time: 17:32:31
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH42 0230
   Revision: 06H42000    Serial number: 0038QD07C0YH
   Coding: 0014131
   VCID: 2B5575918AB0BB1722-807E
   Subsystem 1 - Part No: 4L0 910 339 A
   Component: BF-Gewichtsens. H03 0030
   Subsystem 2 - Serial number: 6332QSME4D415325C
   Subsystem 3 - Serial number: 6342QSME4C274571I
   Subsystem 4 - Serial number: 6352QSME441242576
   Subsystem 5 - Serial number: 6362QSME4D410B31F
   Subsystem 6 - Serial number: 63734SME45781353.
   Subsystem 7 - Serial number: 63834SME4A4B294DG
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0410
   Revision: 00H03000    Serial number: 90054080040331
   Coding: 0012142
   VCID: 275D89A196589F77C6-8072
   Component: E0221           H02 0030
                    Fault Frequency: 17
                    Reset counter: 199
                    Mileage: 217233 km
                    Date: 2007.05.16
                    Time: 12:07:37
                    Reset counter: 199
                    Reset counter: 199
                    Date: 2063.15.31
                    Time: 31:63:02
02072 - Control Module for Energy Management (J644)
                    Reset counter: 199
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4L0 920 981 C
   Component: KOMBIINSTR. M73 H22 0240
   Revision: 00000000    Serial number: 74230AR18
   Coding: 3665288
   Shop #: WSC 12988 002 1048576
                    Reset counter: 196
                    Mileage: 217238 km
                    Date: 2007.05.16
                    Time: 12:20:32
                    Reset counter: 199
                    Mileage: 217246 km
                    Date: 2007.05.21
                    Time: 15:26:16
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 1100B081138035
   Coding: F7F7FE77703A0200
   VCID: 2D517B89B4A4B5273C-8078
                    Reset counter: 199
                    Mileage: 217246 km
                    Date: 2007.05.21
                    Time: 15:26:15
Address 1E: Media Player 2 (R192)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 B    HW: 4E0 035 785 B
   Component: SG ext.Player H15 0700
   Revision: 00000000
   VCID: 275D89A156589F77C6-8072
                    Reset counter: 197
   Part No SW: 4L0 910 158     HW: 4L0 919 158 C
   Component: KLIMABETAETIGUNGH05 0060
   Revision: 00---009    Serial number: 00000030079790
   Coding: 0000006
   VCID: 68DFCA9D5BC6500F0F-803C
00003 - Control Module
                    Fault Status: 00100011
                    Fault Frequency: 12
                    Mileage: 214047 km
                    Date: 2018.05.05
                    Time: 00:00:32
                    Reset counter: 198
                    Mileage: 217235 km
                    Date: 2019.01.08
                    Time: 16:41:06
                    Voltage: 8.50 V
                    Fault Status: 01101101
                    Reset counter: 43
                    Mileage: 215253 km
                    Date: 2018.08.11
                    Time: 00:20:45
   Part No SW: 4F0 910 760     HW: 4L0 959 760
   Component: Sitzmemory FS   H01 0100
   Revision: 00000000    Serial number: 00000000896401
   Coding: 0082954
   VCID: 61C9D7B9B8FC2147C8-8034
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
   Component: MNS US          H51 1100
   Revision: 00000000    Serial number: 313AH087531526
   Shop #: WSC 08143 444 89647
   VCID: 387F5ADD4BE6008F5F-806C
                    Reset counter: 198
                    Time Indication: 15
                    Hex Value: 0x5DBD
                    Hex Value: 0x8387
                    Hex Value: 0x0043
02445 - Disk Drive Initialization Error
                    Reset counter: 0
                    Mileage: 215271 km
                    Date: 2018.09.21
                    Time: 02:57:45
                    Hex Value: 0x464B
                    Hex Value: 0x106F
                    Hex Value: 0x3357
                    Hex Value: 0x0000
                    Reset counter: 197
                    Mileage: 217244 km
                    Date: 2007.05.31
                    Time: 19:40:18
                    Hex Value: 0x465F
                    Hex Value: 0x24A2
                    Hex Value: 0x0047
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0150
   Revision: 00-00000
   Coding: 0051915
01705 - Selection Switch for Mirror-Adjust (E48)
                    Reset counter: 159
                    Mileage: 217242 km
                    Date: 2007.05.16
                    Time: 21:05:02
   Part No SW: 4L0 910 289 F    HW: 4L0 907 289 C
   Component: Komfortgeraet   H07 0050
   Revision: 0050 ---    Serial number: 01090231270000
   Coding: 7632925
   VCID: 33656DF15280E3D76A-8066
                    Fault Status: 01101100
                    Reset counter: 159
                    Mileage: 140569 km
                    Date: 2014.12.30
                    Time: 07:25:19
                    Reset counter: 195
                    Mileage: 217236 km
                    Date: 2007.05.21
                    Time: 16:26:23
                    Reset counter: 196
                    Reset counter: 199
                    Mileage: 217246 km
                    Date: 2007.05.21
                    Time: 15:26:16
Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
   Part No SW: 4L0 910 223 G    HW: 4L0 035 223 D
   Component: DSP-High AU716  H03 0150
   Revision: PROD_01     Serial number: 00000000055993
   Coding: 0000016
   VCID: 285F8A9D9B46900FCF-807C
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000027543
   Coding: 0012001
   VCID: 5EB3EC4589821EBFF5-800A
                    Fault Status: 00110010
                    Reset counter: 198
                    Voltage: 6.100 V
                    Temperature: 15.0°C
                    Reset counter: 198
                    Mileage: 217244 km
                    Date: 2007.06.01
                    Time: 12:37:00
                    Voltage: 6.500 V
                    Temperature: 7.0°C
                    Reset counter: 199
                    Mileage: 217244 km
                    Date: 2007.05.21
                    Time: 15:26:00
                    Voltage: 11.600 V
                    Temperature: 20.0°C
                    Reset counter: 198
                    Mileage: 217232 km
                    Date: 2007.05.16
                    Time: 12:07:00
                    Voltage: 5.900 V
                        Not Recogn.
                    Reset counter: 196
                    Mileage: 217236 km
                    Date: 2007.05.16
                    Time: 12:01:00
                    Voltage: 15.700 V
                    Temperature: 20.0°C
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0150
   Revision: 00-00000
   Coding: 0051915
   Part No SW: 4L0 910 357     HW: 4L0 907 357
   Component: AFS 1           H01 0030
   Coding: 0000021
   VCID: 69D9CF9940CC690710-803C
   Component: AFS-Modul links H06 0002
   Component: AFS-Modul rechtsH06 0002
                    Reset counter: 155
                    Reset counter: 158
                    Reset counter: 199
                    Mileage: 217246 km
                    Date: 2007.05.21
                    Time: 15:26:15
   Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 S
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 388A+087668338
   Coding: 0000002
   VCID: 2E537C85B9A2CE3F05-807A
                    Reset counter: 199
                    Mileage: 215252 km
                    Date: 2018.07.31
                    Time: 22:00:47
                    Fault Frequency: 72
                    Reset counter: 199
                    Mileage: 215252 km
                    Date: 2018.07.31
                    Time: 21:58:54
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4L0 910 181 A    HW: 4L0 915 181
   Component: J0644 BEM       H12 0690
   Revision: --------    Serial number: 00000000002103
   VCID: 254183A9EC548D67F4-8070
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  34080660R0
   Coding: 344630393135313035442056413033343038303636305230
   Shop #: WSC 56092 001 1048576
                    Fault Frequency: 137
                    Mileage: 214969 km
                    Date: 2018.05.24
                    Time: 12:55:28
02256 - Quiescent Current
                    Reset counter: 194
                    Mileage: 217234 km
                    Date: 2007.05.16
                    Time: 23:57:55
                    Reset counter: 197
                    Mileage: 217244 km
                    Date: 2007.05.31
                    Time: 19:40:50
                    Reset counter: 199
                    Mileage: 217246 km
                    Date: 2007.05.21
                    Time: 15:26:15
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Component: TSG HL          H21 0150
   Coding: 0051722
   VCID: 316967F9A89CD1C718-8064
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.lbl
   Part No SW: 4F0 910 273 B    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0100
   Revision: 00050100    Serial number: 00000700064522
   Coding: 0062424
   VCID: 224B98B5FD7A7A5F91-8076
            002 - Lower Limit Exceeded - Intermittent - MIL ON
                    Fault Status: 10100010
                    (no units): 255.0
                    Voltage: 6.00 V
                    (no units): 42.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Reset counter: 199
                    Mileage: 217244 km
                    Date: 2007.06.01
                    Time: 12:37:09
                    (no units): 255.0
                    Voltage: 6.50 V
                    (no units): 19.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
02214 - Tire Pressure Warning
                    Fault Frequency: 253
                    Reset counter: 197
                    Mileage: 216871 km
                    Date: 2018.11.22
                    Time: 08:32:07
                    (no units): 29.0
                    Temperature: -6.0°C
                    Error Code: 1
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 E    HW: 4E0 907 383 E
   Component: Anhaenger     H14 0080
   Revision: 2A002001    Serial number: 00000107284132
   Coding: 0200000000000000
   VCID: 2C57768D4FBEBC2F2B-8078
            011 - Open Circuit - Intermittent - MIL ON
                    Fault Status: 10101011
                    Fault Frequency: 11
                    Reset counter: 198
                    Date: 2063.15.31
                    Time: 16:03:63
                    Reset counter: 198
                    Date: 2063.15.31
                    Time: 16:03:63
                    Reset counter: 199
                    Date: 2063.15.31
                    Time: 16:03:63
   Part No SW: 4L0 910 441 A    HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J7Z41YC
   Coding: 1021201
   VCID: 24479EADE76E746FE3-8070
                    Reset counter: 198
                    Mileage: 217235 km
                    Date: 2019.01.08
                    Time: 16:40:59
                        Reverse OFF
                    Count: 3
                    Reset counter: 159
                    Mileage: 217246 km
                    Date: 2007.05.23
                    Time: 09:39:15
                        Reverse OFF
                    Count: 3
                    Reset counter: 198
                    Mileage: 217236 km
                    Date: 2007.05.21
                    Time: 16:16:48
                        Reverse OFF
                    Count: 3
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 4L0 910 945     HW: 4L0 827 851 C
   Component: ValeoHeckdeckel H25 0290
   Revision: --H25001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6CD7B68D4F3E7C2F6B-8038
   Subsystem 3 - Serial number: RD22.01.08--H25001001C0155ÿ
   Subsystem 4 - Serial number: 1C0155ÿ
00317 - Rear Lid Control Module (J605)
                    Reset counter: 193
   Component: ILM HINTEN 2    H05 0060
   Revision: AAH05061    Serial number: 003414983-----
   Coding: 0003595
   VCID: 264384A59152867FFD-8072
   Subsystem 1 - Part No: 4L0 910 591
   Component: J_245_EE16_SKB09H10 0200
   Subsystem 2 - Part No: 4L0 910 591
   Component: J_394_EE16_SKB09H10 0200
   Subsystem 3 - Part No: 4L0 910 591
   Component: J_392_EE16_SKB09H10 0200
                    Fault Frequency: 17
                    Reset counter: 198
                    Mileage: 217233 km
                    Date: 2007.05.16
                    Time: 14:08:09
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Component: TSG HR          H21 0150
   Coding: 0051722
   Part No SW: 4F0 910 283 H    HW: 4F0 919 283 H
   Component: Parkhilfe 8-Kan H12 0080
   Revision: 00H12000    Serial number: 06320801504703
   Coding: 0231246
                    Reset counter: 198
                    Reset counter: 198
                    Mileage: 217236 km
                    Date: 2007.05.21
                    Time: 16:16:52
   Part No SW: 4F0 910 336 E    HW: 4E0 862 335
   Component: Handyvorb2      H18 0950
   Revision: 00000000    Serial number: 00000005021524
   Coding: 0010900
                    Reset counter: 197
                    Mileage: 217233 km
                    Date: 2007.05.16
                    Time: 14:08:27
                    Reset counter: 41
                    Time Indication: 15
End-------------------------(Elapsed Time: 03:34)--------------------------
Friday,22,November,2019,15:41:36:46475
65-Tire Pressure -- Status: Cannot be reached 1100
10 Faults Found:
009266 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 1
               P2432 - 002 - Short to Ground
                    Fault Status: 01100010
                    Mileage: 217246 km
                    Date: 2007.05.20
                    Time: 11:53:27
                    Temperature: 18.0°C
                    Temperature: 21.0°C
                    Voltage: 11.938 V
                    Mileage: 217246 km
                    Date: 2007.05.20
                    Time: 11:55:20
                    RPM: 368 /min
                    Load: 63.1 %
                    Temperature: 18.0°C
                    Temperature: 19.0°C
                    Voltage: 13.208 V
               P0300 - 001 -
                    Mileage: 217246 km
                    Date: 2007.05.20
                    Time: 11:55:46
                    RPM: 1645 /min
                    Load: 52.5 %
                    Temperature: 20.0°C
                    Temperature: 18.0°C
                    Voltage: 13.081 V
000772 - Cylinder 4
                    Mileage: 217246 km
                    Date: 2007.05.20
                    Time: 11:55:46
                    RPM: 1645 /min
                    Load: 52.5 %
                    Temperature: 20.0°C
                    Temperature: 18.0°C
                    Voltage: 13.081 V
000770 - Cylinder 2
               P0302 - 001 - Misfire Detected
                    Mileage: 217246 km
                    Date: 2007.05.20
                    Time: 11:55:46
                    RPM: 1645 /min
                    Load: 52.5 %
                    Temperature: 20.0°C
                    Temperature: 18.0°C
                    Voltage: 13.081 V
000774 - Cylinder 6
                    Mileage: 217246 km
                    Date: 2007.05.20
                    Time: 11:55:46
                    RPM: 1645 /min
                    Load: 57.6 %
                    Temperature: 20.0°C
                    Temperature: 18.0°C
                    Voltage: 13.081 V
000775 - Cylinder 7
                    Mileage: 217246 km
                    Date: 2007.05.20
                    Time: 11:55:46
                    RPM: 1645 /min
                    Load: 57.6 %
                    Temperature: 20.0°C
                    Temperature: 18.0°C
                    Voltage: 13.081 V
000773 - Cylinder 5
                    Mileage: 217246 km
                    Date: 2007.05.20
                    Time: 11:55:49
                    RPM: 2496 /min
                    Load: 27.8 %
                    Temperature: 20.0°C
                    Temperature: 18.0°C
                    Voltage: 13.208 V
                    Mileage: 217246 km
                    Date: 2007.05.20
                    Time: 11:55:49
                    RPM: 2559 /min
                    Load: 27.4 %
                    Temperature: 20.0°C
                    Temperature: 18.0°C
                    Voltage: 13.208 V
000776 - Cylinder 8
                    Mileage: 217246 km
                    Date: 2007.05.20
                    Time: 11:56:12
                    RPM: 2288 /min
                    Load: 25.1 %
                    Temperature: 25.0°C
                    Temperature: 18.0°C
                    Voltage: 13.208 V
   Coding: 0000504
   Revision: 00H30001
   Coding: 0082993
                    Reset counter: 159
                    Mileage: 217246 km
                    Date: 2007.05.20
                    Time: 11:53:30
                    Count: 128
                    Count: 8513
                    Count: 297
                    Count: 42752
   Coding: 0000135
                    Reset counter: 159
                    Mileage: 217246 km
                    Date: 2007.05.20
                    Time: 13:50:13
                    Reset counter: 159
                    Mileage: 217246 km
                    Date: 2007.05.20
                    Time: 13:50:13
                    Reset counter: 159
                    Mileage: 217246 km
                    Date: 2007.05.20
                    Time: 13:50:13
   Coding: 0002003
                    Reset counter: 159
                    Mileage: 217246 km
                    Date: 2007.05.20
                    Time: 11:53:38
   Coding: 0655400
   Coding: 0114123
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Reset counter: 159
                    Mileage: 217244 km
                    Date: 2007.05.20
                    Time: 11:55:00
   Coding: 0000100
                    Reset counter: 159
                    Mileage: 217246 km
                    Date: 2007.05.20
                    Time: 11:53:36
   Coding: 0014131
   Coding: 0012142
   Coding: 3665288
                    Reset counter: 159
                    Mileage: 217246 km
                    Date: 2007.05.20
                    Time: 11:53:30
   Revision: 00000000
   Coding: 0000006
   Coding: 0082954
   Revision: 00-00000
   Coding: 0051915
   Coding: 7632925
                    Reset counter: 159
                    Mileage: 140569 km
                    Date: 2014.12.30
                    Time: 07:25:19
   Coding: 0000016
   Coding: 0012001
   Revision: 00-00000
   Coding: 0051915
   Coding: 0000021
   Coding: 0000002
                    Reset counter: 199
                    Mileage: 215252 km
                    Date: 2018.07.31
                    Time: 22:00:47
                    Fault Frequency: 67
                    Reset counter: 199
                    Mileage: 215252 km
                    Date: 2018.07.31
                    Time: 21:58:54
   Coding: 0051722
   Coding: 1021201
                    Reset counter: 159
                    Mileage: 217246 km
                    Date: 2007.05.20
                    Time: 14:19:52
                        Reverse OFF
                    Count: 3
                    Reset counter: 193
   Coding: 0003595
   Coding: 0051722
   Coding: 0231246
   Coding: 0010900
End-------------------------(Elapsed Time: 03:26)--------------------------
Thursday,05,December,2019,15:00:37:46475
7 Faults Found:
               P0300 - 001 -
                    Mileage: 217246 km
                    Date: 2007.06.02
                    Time: 08:28:29
                    RPM: 1934 /min
                    Load: 36.8 %
                    Temperature: 36.0°C
                    Temperature: 21.0°C
                    Voltage: 13.208 V
000772 - Cylinder 4
                    Mileage: 217246 km
                    Date: 2007.06.02
                    Time: 08:28:29
                    RPM: 1934 /min
                    Load: 36.8 %
                    Temperature: 36.0°C
                    Temperature: 21.0°C
                    Voltage: 13.208 V
000773 - Cylinder 5
                    Mileage: 217246 km
                    Date: 2007.06.02
                    Time: 08:28:31
                    RPM: 1777 /min
                    Load: 46.6 %
                    Temperature: 36.0°C
                    Temperature: 21.0°C
                    Voltage: 13.208 V
000774 - Cylinder 6
                    Mileage: 217246 km
                    Date: 2007.06.02
                    Time: 08:28:31
                    RPM: 1777 /min
                    Load: 46.6 %
                    Temperature: 36.0°C
                    Temperature: 21.0°C
                    Voltage: 13.208 V
000775 - Cylinder 7
                    Mileage: 217246 km
                    Date: 2007.06.02
                    Time: 08:28:31
                    RPM: 1777 /min
                    Load: 46.6 %
                    Temperature: 36.0°C
                    Temperature: 21.0°C
                    Voltage: 13.208 V
                    Mileage: 217246 km
                    Date: 2007.06.02
                    Time: 08:29:45
                    RPM: 2374 /min
                    Load: 31.4 %
                    Temperature: 47.0°C
                    Temperature: 21.0°C
                    Voltage: 13.335 V
                    Mileage: 217246 km
                    Date: 2007.06.02
                    Time: 08:29:48
                    RPM: 490 /min
                    Load: 83.1 %
                    Temperature: 47.0°C
                    Temperature: 21.0°C
                    Voltage: 12.192 V
   Coding: 0000504
                    Reset counter: 0
   Revision: 00H30001
   Coding: 0082993
                    Reset counter: 159
                    Mileage: 217246 km
                    Date: 2007.05.31
                    Time: 14:31:35
                    Count: 128
                    Count: 13121
                    Count: 8196
                    Count: 41472
                    Reset counter: 159
                    Mileage: 217246 km
                    Date: 2007.05.20
                    Time: 14:56:24
                    Count: 128
                    Count: 8513
                    Count: 297
                    Count: 42240
   Coding: 0000135
                    Reset counter: 159
                    Mileage: 217246 km
                    Date: 2007.05.23
                    Time: 06:00:52
                    Reset counter: 159
                    Mileage: 217246 km
                    Date: 2007.05.23
                    Time: 06:00:52
                    Reset counter: 159
                    Mileage: 217246 km
                    Date: 2007.05.23
                    Time: 06:00:52
   Coding: 0002003
                    Reset counter: 159
                    Mileage: 217246 km
                    Date: 2007.05.23
                    Time: 06:21:46
   Coding: 0655400
   Coding: 0114123
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Reset counter: 159
                    Mileage: 217244 km
                    Date: 2007.05.20
                    Time: 15:00:00
   Coding: 0000100
                    Reset counter: 159
                    Mileage: 217246 km
                    Date: 2007.05.20
                    Time: 14:58:29
   Coding: 0014131
   Coding: 0012142
   Coding: 3665288
00771 - Fuel Level Sensor (G)
                    Reset counter: 199
                    Mileage: 217246 km
                    Date: 2007.05.23
                    Time: 11:32:37
00438 - Fuel Supply Sensor 2 (G169)
                    Reset counter: 199
                    Mileage: 217246 km
                    Date: 2007.05.23
                    Time: 11:32:37
                    Reset counter: 199
                    Mileage: 217246 km
                    Date: 2007.05.23
                    Time: 11:32:37
                    Reset counter: 159
                    Mileage: 217246 km
                    Date: 2007.05.20
                    Time: 14:59:02
   Revision: 00000000
   Coding: 0000006
   Coding: 0082954
   Revision: 00-00000
   Coding: 0051915
   Coding: 7632925
                    Reset counter: 159
                    Mileage: 140569 km
                    Date: 2014.12.30
                    Time: 07:25:19
   Coding: 0000016
   Coding: 0012001
   Revision: 00-00000
   Coding: 0051915
   Coding: 0000021
   Coding: 0000002
                    Fault Frequency: 12
                    Mileage: 217246 km
                    Date: 2007.05.23
                    Time: 06:18:46
   Coding: 0051722
   Coding: 1021201
                    Reset counter: 159
                    Mileage: 217246 km
                    Date: 2007.06.02
                    Time: 13:38:17
                        Reverse OFF
                    Count: 3
                    Reset counter: 199
   Coding: 0003595
   Coding: 0051722
   Coding: 0231246
   Coding: 0010900
End-------------------------(Elapsed Time: 03:27)--------------------------
Step 4 Recent repairs or services, problem at hand, & attempts at repair: This is going from memory and wasn't recorded as I did it so forgive me if some details are forgotten or mixed up. Any questions, let me know.
Purchased Nov 2nd with a claimed running issue. Seller was not the original owner and probably got it at auction and couldn't fix it. No other info given -seller played it up like he didn't know what was wrong, "may just need injectors" but his story didn't add up on how long he had it or what testing he had done. Vehicle’s condition is excellent other than barely running, idled like only running on 2 cyls. CEL blinking. Mutliple cyl misfires, Short to ground codes throughout most systems. Battery was original and vehicle had to be jumped to run and barely made it onto the trailer for transport to my shop.
Battery failed D-TAC Elite's tests and was replaced (NAPA Legend 7549).
Codes cleared after nothing turned up from visual inspection, many codes could be related to low battery voltage too.
Running condition didn't change upon code clearing, Short to ground codes remained as well as low rail pressure.
Reading posts regarding HPFP's failing and seeing as both were original and were on the hard&fast list of components shorting to ground two were ordered. Both from reputable aftermarket companies, and arrived as one Hitachi & one Delphi unit. Pump's cam followers were inspected as was the fuel pump lobes. Pumps were installed. Codes were cleared but same Short-to-Ground (STG) codes returned -even for the HPFPs.
No codes for timing, lean running conditions, injector, or coil codes...
Checked voltage at pumps following HPFP testing flow chart and found 2.87V where battery voltage should be found indicating faulty wiring. Pulled up wiring diagram to determine how it they were powered and trace out all the STG items -found all shared fuse #13 in underhood fuse/relay panel. Found #13 fuse blown.
Slapped forehead for overlooking the simple stuff and replaced fuse #13 with a new 15AMP fuse. (Probably came to me like that with a failed HPFP -but without the proper test equipment I couldn't be absolutely be sure the pump was bad -in hindsight).
Cleared the codes and started the vehicle with new fuse in. SAME running condition, same STG codes returned.
Still had only 2.87V at the HPFP KOEO???
Checked the fuse again, still in perfect condition but found KOEO I had 3.43V on leg (13a) of the fuse. Even with the key OFF and out. Thought maybe some failed component on that STG list was backfeeding voltage. I unplugged all the components on fuse 13's wiring diagram, still had 3.48V on leg 13a (red/Grn) wire.
Traced back wiring to fuse 13's source of power which is the Engine Component Power Supply Relay (C2) which had battery voltage on supply pin 1 (30) and battery voltage on send pin 2 (87iirc) when activated -this did turn off when key was removed, so voltage was still coming from somewhere to leg 13a on fuse #13.
Inspected wiring harness and saw no signs of water intrusion or corrosion or shorts. ECU grounds and engine grounds all looked and felt tight (snugged again for good measure.)
KOEO: Unplugged ECU and the 3.48V at fuse #13 disappeared. Traced the wire from fuse #13a to ECU pin #49, found 3.48V coming out of pin #49 to Secondary Air Injection Pump (A4) relay pin 4D even with relay removed.
Read quite a few accounts of water intrusion in ECU in cowl due to clogged cowl drains -check drains and found them missing. Pulled vent plug on ECU and didn't see any signs of water intrusion though. "Assuming" the ECU was faulty, I ordered a replacement.
Reconnected all disconnected components in preparation for the new ECU. Once the new ECU arrived, cleared all codes and started vehicle, all the short to ground faults disappeared. Same rough running condition though. No change other than the STG codes didn’t return.
Somewhere in the initial testing we removed the intake manifold and cleaned the intake/valves after seeing this was a common problem and resulted in rough idle, low power. Interestingly we found the right bank was dirty but not alarmingly so, left bank was pretty clean??? Injectors (original) were pulled, tested, cleaned and reinstalled. All but one had 1.5-1.7ohms of resistance, the odd ball had 3.2 ohms. All had pressurized injector cleaner pulsed through them, none leaked, and all had even spray patterns. Later after some thinking realizing our testing wasn’t at their typical pressure range of 18-100+bar at which they actually could leak, we ordered new (rebuilt) injectors and installed them. No change.
New spark plugs were also initially installed, came with the cheapest set of standard Autolite’s (around a $1 each) installed –not even certain if they even belonged in a 4.2FSI. Right bank plugs were found sooty, left bank plugs were pretty clean. Denso Iridium power 5304’s were installed. New coil packs were also installed (aftermarket). No change.
Fuel pressure was recorded using VCDS at (rough) idle. Found 6.74bar of supply pressure and 28.94bar rail pressure. Couldn’t keep engine running long enough to warm it up to do a leak down test (see if pressure dropped/raised KOEO). Fuel filter assembly in top of tank (behind driver side) was replaced (found original part –had not been through the recall campaign as it still had the cracking top without the VW/AUDI repair patch). Installed aftermarket fuel filter assembly due to cracks in original assembly and after pressure tests were made. Just out of curiosity the fuel filter was removed from original assembly and found dirty, tank and fuel looked clean.
Step 5 Are parts OEM or AFT? If so, "what", and what origin? See above.
Step 6 Identify specific issues to be addressed/concerned about, or say ALL. Engine Running issues/codes.
Step 7 Now that you jumped through the first few hoops of fire, did you check the FUSES/Battery connections? YES, multiple times and in all fuse boxes.
Regarding the MAP code, that's new to this ECU -haven't investigated at this moment.
imquattro
C?ID=274133
Sorry ran out of time to test today. FWIW, Engine cranks over with normal sounds (nothing indicating a valve hanging open) or off-timing sounds.
I will perform a compression test tomorrow and return with results.
NostraJackAss
FOR SHAME ..........BASICS NEGATED! :rolleyes:
imquattro
C?ID=274133
lol, yes, well it took all afternoon to type that other reply up while teaching... no excuses I know.
imquattro
C?ID=274133
Interesting compression test results.
Cylinder pressures in PSI
Right Bank :
1:219
2:219
3:210
4:225
Left bank (gets interesting):
5:291
6:297
7:299
8:303
imquattro
C?ID=274133
looks like the left bank valve cover's coming off.
imquattro
C?ID=274133
Removed left cam cover. Cams are turning as expected. Valves are opening as expected. Lobes and followers appear in good working order.
I would have expected cam correlation codes had the exhaust cam been broken.
Additionally, the right bank of cylinder's (1-4) new plugs were again, very sooty compared to the left bank (5-8).
Next: bore scope.
Just a thought: Would a completely plugged driver's side cat cause high compression values?
There were no catalyst efficiency codes, but then again, the engine couldn't run long enough to start checking those values???
I would think even with a plugged cat, with the other cylinders being open (no spark plug) this would release the built up pressure trapped between the exhaust valve and a plugged cat on the tested cylinder....???
I'll pull the upstream O2 sensor and perform a compression test again on that bank.
NostraJackAss
imquattro
C?ID=274133
O2 sensor removed, compression checked and -no change.
Bore scoped cylinders, exhaust valves verified opening.
imquattro
C?ID=274133
I'm sorry, I don't understand.
imquattro
C?ID=274133
Ok sigh. Thats an involved job that will require some time from what I'm seeing in my research. I miss the old days when timing could be verified with a light or just checking camshaft alignment vs crank position marks.
Any quick -n-dirty tips to check cam/crank timing on these 4.2FSI motors without plenum and timing cover(s) removal?
imquattro
C?ID=274133
I have full access to ShopKeyPro for my service manual.
I'm a former auto technician with 25yrs experience, now teaching automotive tech, so not my first rodeo.
Appreciate the suggestions, but looking for some corners to cut, avoiding IF POSSIBLE -(please Lord) motor out timing component replacement.
Having no codes relating to timing issues frustrates me going down this timing colored road...
