2012 Golf R, ABS coding lost
Jef
HQ
The original ABS module was dirty so I purchased a replacement unit and installed it. But I didn't run an Auto-Scan first thing, and I set the original ABS module on fire and then buried it in a shallow grave next to my 1st wife. Anyway, I need help coding this replacement ABS module so I can go cruising this weekend... this is the only reason I purchased VCDS. As per forum rules, here is the current Auto-Scan:
Wednesday,04,December,2019,10:04:19:51346
VCDS Version: 19.9.0.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WVWRF7AJ7CW226401   License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 05 08 09 15 16 17 19 22 25 2B 2E 37 42 44 46 47 4C 52
          55 56
VIN: WVWRF7AJ7CW226401   Mileage: 124890km-77603miles
4C-Tire Pressure II -- Status: Cannot be reached 1100
Address 01: Engine (CRZ)       Labels:. 06F-907-115-CDL.clb
   Part No SW: 5K0 907 115 M    HW: 8P0 907 115 B
   Revision: 5BH20---    Serial number:
   Coding: 0403010A180F0160
   Shop #: WSC 78391 284 419398
   VCID: 342B9F9157F3FDEE6B-8060
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage - MIL ON
                    Fault Status: 11100100
                    Mileage: 124898 km
                    Temperature: 1.0°C
                    Temperature: 2.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 11.430 V
   Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
   Revision: 00H35001
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 61160 002 1048576
   VCID: 76AF6599C10FAFFE95-8022
                    Fault Status: 01100101
                    Reset counter: 0
                    Mileage: 124898 km
                    Count: 16387
                    Count: 2
                    Count: 13056
                    Count: 279
                    Count: 40192
                    Count: 57024
                    Count: 21760
                    Reset counter: 0
                    Mileage: 124898 km
                    Count: 16387
                    Count: 2
                    Count: 13056
                    Count: 295
                    Count: 40192
                    Count: 57024
                    Count: 21760
                    Reset counter: 0
                    Mileage: 124898 km
                    Count: 16387
                    Count: 2
                    Count: 13056
                    Count: 270
                    Count: 40192
                    Count: 57024
                    Count: 21760
                    Fault Status: 01101100
                    Reset counter: 0
                    Mileage: 124898 km
                    Date: 2014.04.26
                    Time: 21:49:45
                    Count: 7
                    Count: 2
                    Count: 13056
                    Count: 272
                    Count: 50944
                    Count: 56832
                    Count: 21760
                    Reset counter: 218
                    Mileage: 124898 km
                    Date: 2014.04.26
                    Time: 21:49:45
                    Count: 7
                    Count: 2
                    Count: 13056
                    Count: 195
                    Count: 50944
                    Count: 56832
                    Count: 21760
                    Reset counter: 218
                    Mileage: 124898 km
                    Date: 2014.04.26
                    Time: 21:48:33
                    Count: 16386
                    Count: 2
                    Count: 13056
                    Count: 107
                    Count: 44288
                    Count: 56832
                    Count: 21760
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0163656723
   Coding: 030C0C
   VCID: 342B9F919FF3FDEE6B-8060
   Part No SW: 5K0 907 044 FE    HW: 5K0 907 044 FE
   Component: Climatronic   H18 1112
   Revision: 00001004
   Coding: 0000001002
   VCID: 73A95C8DDA7DBAD6B2-8026
   Part No SW: 1K0 937 084 G    HW: 1K0 937 084 G
   Component: BCM PQ35  B   110 0651
   Revision: 00110 AC
   Coding: 77190A3FF9272A04108800C171000C6C4A650486774D8DB0E48430248040
   Shop #: WSC 12345 444 12345
   VCID: 322799896DE7F3DE79-8066
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 21121  26  0512
   Coding: 009795
   Part No SW: 5K0 959 655 H    HW: 5K0 959 655 H
   Component: AirbagVW10G   013 0724
   Serial number: 003GVRA17TLG
   Coding: 00003131
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3FC1C0BDA6B52EB686-806A
   Subsystem 1 - Part No SW: 5K0 959 339 B    HW: 5K0 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00002WRX00
   Serial number: 3572MSME5F462168ZZZ/
   Serial number: 3582MSME67582268ZZZ
   Serial number: 3512QSME4619681FZZZ+
   Serial number: 3522QSME442E667BZZZ3
   Serial number: 35527SME29027129ZZZ8
   Serial number: 35627SME340F7129ZZZI
          B10B3 00 [008] - Function Restriction due to Implausible Message(s)
                    Reset counter: 3
                    Mileage: 124898 km
                    Date: 2019.12.04
                    Time: 21:48:49
   Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20111215300770
   Coding: 100A160002
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DBD7AB5EC39FCA6D4-8028
   Component: E221__MFL-TAS  H09 0013
   Coding: 820000
   Part No SW: 5K6 920 972 E    HW: 5K6 920 972 E
   Component: KOMBI         H04 0617
   Coding: 470F01
   VCID: 3833ABA1839B198E47-806C
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 191211F2002176
   Coding: 350000
   VCID: 3A37B1A9B5970B9EB1-806E
03109 - Tire Pressure Monitoring Control Module 2 (J793)
                    Reset counter: 218
                    Mileage: 124898 km
                    Date: 2014.04.26
                    Time: 21:48:37
   Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
   Component: Haldex 4Motion      3018
   Coding: 0000005
   VCID: 45CDD2550C697466CC-8010
   Component: IMMO          H04 0617
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A9741E98DB77B1E01-803E
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000280347002
   Coding: 0100000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2E1F8DF971DFD73E1D-807A
   Revision: A1001003    Serial number: 7661503010
   Coding: 020000
   VCID: 29157EE54031B006C8-807C
   Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
   Component: RNS315-NAR    H34 0265
   Serial number: VWZAZ2M8488725
   Coding: 04050001010005000000100A
   ASAM Dataset: EV_RNS315NARV2UDS A01004
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 23096CCD2A1D6A5682-8076
   Component: NAR_V2  0002
          B11CF 53 [009] - Deactivated
                    Reset counter: 184
                    Mileage: 124039 km
                    Date: 2019.10.28
                    Time: 00:06:12
1048642 - Internal Control Module Memory Check Sum Error
          B2000 42 [009] - General memory failure
          [ECU defect data memory failure]
                    Mileage: 102618 km
                    Date: 2018.03.01
                    Time: 20:11:04
   Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
   Component: Tuer-SG         009 2103
   Coding: 0001332
   Shop #: WSC 12345 444 00000
   VCID: 3731A89D468516F64E-8062
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 251    3501
   Revision: 00H20000
   Shop #: WSC 58566 000 1048576
   VCID: 3935AEA570910086B8-806C
   Part No SW: 5K0 035 456 B    HW: 5K0 035 456 B
   Component: KonzernAmp 8K H07 0368
   Revision: --------    Serial number: EAA085A0009562
   ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
   ROD: EV_AudioVerst8KanalBNO1.rod
   VCID: 29157EE54831B006C8-807C
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Component: Tuer-SG         009 2117
   Coding: 0001340
   VCID: 32279989ADE7F3DE79-8066
   Coding: 1479708
   Component: AFS-Lst.-Modul l    0005
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0005
   Coding: 00000022
End----(Elapsed Time: 01:04, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Hello Jef,
Make sure you checked both of these folders to see if a factory condition scan was saved at any point prior to replacing the ABS module:
C:\Ross-Tech\VCDS\Logs
C:\Ross-Tech\VCDS\Scans
If not, I believe the factory condition 03-ABS coding of WVWRF7AJ7CW226401 was: 144B800C49248000280F01E4921A0141B70400
Copy and Paste that directly into the New Coding followed by clicking [Do It!] After the coding is accepted, complete the first 4 Basic Setting operations on this page before exiting the module:
VW Golf (1K) Brake Electronics (MK60EC1)
The Replacement section at the bottom of that page should be helpful. If you encounter difficulty please see the MK60EC1 ABS FAQ .
NostraJackAss
I can't but help feel your pain Jef I was there myself.
So did Dana's code function as needed?
Jef
HQ
Dana, the ABS module is coded. One quick question, real simple. In the ABS module in measuring block group 273, field 3 reads O11O1OOO when I'm driving in reverse at 3MPH, but then reads 1OO1O111 when doing 3.5MPH in reverse. On my other VW, a 1997 Golf, the ABS module doesn't have group 273. What is wrong with VCDS?
