Need adaptation map from Passat US with Virtual Pedal
n4s
Portugal
C?ID=351319
I would like to retrofit virtual pedal and would like to compare my adaptation map with one from Passat US. Passat US has PQ35 Kessy module, like my car.
Address 05: Acc/Start Auth. (J518) Labels:* None
Part No SW: 5K0 959 434 K HW: 5K0 959 434
Component: VWKESSYPQ35GP 093 1403
Revision: 00093000 Serial number: 0194946513
Coding: 030C0C
Shop #: WSC 12345 123 01234
ASAM Dataset: EV_KESSYPQ35G A02721
VCID: 3D26CF192DFDF1EFE21-8068
Thank you
What the heck is a "Virtual Pedal"?
n4s
Portugal
C?ID=351319
It's the Easy Open of boot.
https://www.youtube.com/watch?v=f2Li28zsjKY
To have it's necessary Kessy module with VIP.
The car in the link has that, you can see the Slave module.
https://forums.ross-tech.com/showthread.php?7714-Rain-closing-windows-16-Passat-sel-premuim
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 F HW: 5K0 959 434
Component: VWKESSYPQ35GP 093 1202
Revision: 00093000 Serial number: 0402168773
Coding: 130C0C
Shop #: WSC 09003 957 00200
ROD: EV_KESSYPQ35G.rod
VCID: B875013403E15282D6-80EC
Slave 1:
Serial number: 93821207
hadez16
C?ID=289891
What exactly is your problem?
n4s
Portugal
C?ID=351319
I want to be prepared for Virtual pedal installation and it would be great if I could have adaptation map to compare with mine. I haven't installed the system yet, only the Kessy module with VIP.
OEMplusCC
C?ID=160054
I helped my brother code his easy open(virtual pedal) system on US 2016 CC but his car uses PQ47 Kessy Module.
All we had to do is change byte21 value from hex24 to hex37(binary 00110111). There was no Long Coding helper for it.
Here is 46 module with the change
Address 46: Central Conv.        Labels:. 3C0-959-799-46.clb
   Part No SW: 3AA 959 799 G    HW: 3AA 959 799 G
   Component:    KESSY PQ47   091 0414
   Revision: 00091000    Serial number: VWZCZ000000000
   Coding: 1B910F8001860E7E1202143FF08A8F0E10780203043798
   Shop #: WSC 05311 123 08193
   VCID: 4CC164057AC3DA4765F-8018
   Subsystem 4 - Part No: 3AA 962 243 D
   Component: GEB.F.Heckoef       0811
I also retrofired easy open on a MQB Tiguan. I wrote DYI for it here:
https://forums.ross-tech.com/showth...K2-MQB-Easy-Open-Retrofit&highlight=easy+open
Sorry dont know much about PQ35 systems
n4s
Portugal
C?ID=351319
thank you! for your help.
I'm using the same unit and I have the following error, did you had same?
Coding: 332C1C
221445 - Sensor for Rear Lid/Hatch Opening
B1303 54 [009] - Missing Calibration / Basic Setting
Reset counter: 219
Mileage: 162721 km
Date: 2020.01.26
Time: 22:53:17
Already have the menu and can select option, but not working yet
https://drive.google.com/open?id=12Rywkn64HnHR-L1RmX76JU8VYqmM_LOQ
n4s
Portugal
C?ID=351319
Thanks again!!!
I saw your links and probably found what I need
"After you finish all the coding mentioned in my post #8 go to OutputTest and run Control_Supply_Voltage_VIP. VCDS will not show you any special values and it will just show "Running" let it run for at least 1 minute and then hit stop .
The no response from VCDS is what got me because I though that nothing was actually happening."
I will test it
n4s
Portugal
C?ID=351319
I checked in my car and I don't have that option in output tests :(
