No Coding Information is Available for this ECU
VWTSI
Brazil
C?ID=223978
I am trying to access module 1 - Engine in a 2019 VW Tiguan, but I received a message "No Coding Information is Available for this ECU":
Please find below an Auto-Scan:
Tuesday,03,December,2019,16:56:50:38818
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
VIN: 3VVHJ65N4KM000000   License Plate:
Mileage: 4160km-2584mi   Repair Order:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 08 09 10 15 17 19 20 29 36 39 42 44 4B 52 5F 65 CA
          D6 D7
VIN: 3VVHJ65N4KM000000   Mileage: 4160km-2584miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CWLA)       Labels: None
   Part No SW: 04E 906 027 MB    HW: 04E 907 309 BP
   Component: R4 1.4l TFS   H23 4859
   Revision: RDH23---
   Coding: 011D003223241D002000
   Shop #: WSC 00066 790 00454
   ASAM Dataset: EV_ECM14TFS01104E906027MB 001004
   ROD: EV_ECM14TFS01104E906027MB.rod
   VCID: 70AC2B8BAB34B1CF57-8024
   Part No SW: 0D9 300 043     HW: 02E 927 770 AS
   Component: DQ250-6F MQB  H54 5202
   Revision: 06454104    Serial number: TFK01811261071
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 57FE70172E9AC6F7B6-8002
          P1734 00 [002] - -
   Part No SW: 5Q0 614 517 EH    HW: 5Q0 614 517 BR
   Component: ESC           H82 0107
   Revision: 00000000    Serial number: 50859000000322
   Coding: 0BEE6B9A40241B6C4779060662CB49D0D602D8E2604692712022500852024A0B00002764121A1C230A35351919323200
   Shop #: WSC 01383 790 50316
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 7BB60CA7F272C297F2-802E
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 5NA 907 044 R    HW: 5NA 907 044 R
   Component: AC Automat    H35 4401
   Revision: 20K03000    Serial number: 00000D00347385
   Coding: 0002002420010001100510000010142A
   ASAM Dataset: EV_ACClimaPrehVW37X 002025
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 4ED095731140873F65-801A
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
   Part No SW: 5Q0 937 086 BQ    HW: 5Q0 937 086 BQ
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: C864120419045I
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 0A585963ADA8EB1FF9-805E
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 190201  034 0373
   Serial number: 19013021081630
   Component: RLHS  052 0107
   Serial number: SBY19M02D27H10M26S24
   Coding: 00A8EE
   Serial number: 000000000ZY190430S1U
   Serial number: 00000000000046612817
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 521     HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0300150420190C200499
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000137088R19105
   Coding: 0471151011
   Shop #: WSC 00066 790 00440
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   VCID: 4CD49F7BE75CB52F0B-8018
   Part No SW: 5Q0 959 655 BR    HW: 5Q0 959 655 BR
   Component: AirbagVW21    006 0403
   Serial number: 003FLM00KSBY
   Coding: 88CCC000000000005C0000CF000800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 116A4E0FC0FED8C738-8044
   Subsystem 1 - Part No SW: -----------    HW: 480 001 802 19
   Serial number: 357000000000410DC93E
   Subsystem 2 - Part No SW: -----------    HW: 480 000 403 19
   Serial number: 35800000000FC07D693
   Subsystem 3 - Part No SW: -----------    HW: 480 400 901 19
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001BD2E6FB15274F
   Subsystem 4 - Part No SW: -----------    HW: 480 400 901 19
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001102BFA0C4649%
   Subsystem 5 - Part No SW: -----------    HW: 480 401 403 19
   Component: FrontSensor_D  003 6149
   Serial number: 35500019B2F282B37176
   Part No SW: 5NA 920 750 C    HW: 5NA 920 750 C
   Component: KOMBI         350 2700
   Coding: 07A509882A80000801086B041401000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
   VCID: 3E30C5B3A1E017BF95-806A
   Serial number: 06041900841945
   Coding: 030100047F085708FA00024A180F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 6E9035F3B100A73F45-803A
   Component: 0-01-13-01-04
   Subsystem 2 - Part No SW: 5NA 959 442 A    HW: 5NA 959 442 A
   Component: E221__MFL-TAT  H06 0025
   Serial number: 0661904524300501FD2B
   Coding: 290000
   Serial number: 6022346500
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 3G0 857 511 AE    HW: 3G0 857 511 AE
   Component: FLA           H10 0003
   Revision: AA001001
   Coding: 040400EA00000000000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001017
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 6B963CE78212521762-803E
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH08 0014
   VCID: 45C2AA5FC4364467D4-8010
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0006SA437394
   Coding: 0010000000000500018280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 3D32C2BFACE60CA78C-8068
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 42038909902902
   Coding: 00310220D200048000001000
   VCID: 4FEE8877164A8E376E-801A
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000002141386
   Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  173 1081
   Coding: 011F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 50EC8B0B0B7491CF77-8004
   Component: FCM MQB Low   002 0345
   Serial number: 15041900840998
   Coding: 0000000509001D4A00000F01020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 3522DA9F94D6D4E744-8060
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 46038909200495
   Coding: 00310020DE00048000001000
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000002154923
   Coding: 090000
   Part No SW: 3Q0 035 846 B    HW: 3Q0 035 846 B
   Component: MU-S-N-ER     853 0890
   Coding: 02730603FF00000051220001001828001F0500D401200500CF
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 302CEB8B6BB4F1CF17-8064
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  252 8130
   Serial number: VWZ6ZMW1065238
   Serial number: 30000000270391
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3424E79B9FACCDEF73-8060
   Coding: 40804073260C
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 75A21A9FD45694E784-8020
   Part No SW: 7P5 941 572 AG    HW: 7P5 941 572 A
   Component: LED1L         H07 0008
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 004C7B4B9B94A14FA7-8054
   Component: LED1R         H07 0008
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:32, VBatt start/end: 12.4V/12.4V)-----------
golfi_vend
Tartu, Estonia
C?ID=195131
Well indeed cause ASAM dataset doesn't carry one and there isn't one made specifically for this ECU.
Trying to change anything?
VWTSI
Brazil
C?ID=223978
Yes, I am trying to increase the pedal sensitivity adaptation changing Controller in:
01- Engine
07 - Coding
Byte 0, Bit 0-2,
South Molton, UK
01- Engine
07 - Coding
Byte 0, Bit 0-2,
Where have you seen that this information is relevant to your 2019 Tiguan?
TBAx
C?ID=287144
01- Engine
07 - Coding
Byte 0, Bit 0-2,
You can do this without the ASAM data. New coding for the ECU with "Manufacturer: Audi" is 021D003223241D002000
