Please switch on dipped headlight warning VW Golf 7.5 UK Model ???
Owen in Scotland
Troon
C?ID=105356
Hi guys, hoping you can help with a few suggestions. My car has a really annoying light assist function which is way too sensitive for my liking and wondering if there is a way to delay its operation as evening/daylight approaches. As the light begins to fall, a message appears on my Digital dashboard to switch on the dipped headlamps. While this message is displayed, and until you actually turn the headlights on, no other settings or displays are visible in the digital cockpit any longer. This is really frustrating as I drive quite a bit in very slow traffic at dusk/dawn and don’t want to have my dipped headlights on when I don’t need them, in particular in almost daylight conditions !!
I have looked in the 09 Central electrics module and channel map attached. Did a lot of converting German into English from there, and eventually found and played around a bit with the default lux settings I found (dumped below fyi) but it made no difference to the functionality of this dipped headlight warning at all regardless of trial changed values.
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze 1200 lx
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze 2200 lx
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle 0 lx
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO 600 lx
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten 1200 lx
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten 2200 lx
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity frueh
Assume its controlled by the slave HLRS coding in this channel, but could not find a deactivate option in there either.
Wondering if anyone has any knowledge of how I might be able to delay this warning till much later, (the vehicles head units “Late” option is also selected), but still the warning to switch my headlights comes on in almost full dayligh, or how to just deactivate the warning completely.
Tuesday,26,November,2019,21:05:49:15093
VIN: WVWZZZAUZHW345558   License Plate:
Mileage:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 29 39 42 44 4B 52 5F A9 D6 D7
VIN: WVWZZZAUZHW345558   Mileage: 33573km-20861miles
Monday,02,December,2019,18:16:18:15093
Mileage: 33607km-20882mi   Repair Order:
VIN: WVWZZZAUZHW345558   Mileage: 33607km-20882miles
Address 01: Engine (J623-DGCA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 HA    HW: 04L 907 309 R
   Component: R4 2.0l TDI   H24 4010
   Revision: B5H24---
   Coding: 01190012034405082000
   ASAM Dataset: EV_ECM20TDI01104L906026HA 004003
   ROD: EV_ECM20TDI01104L906026HA_004.rod
   VCID: 70B9D08D6A20BCD7397-8024
5169 - Manifold Pressure / Boost Sensor (G31)
          P0238 00 [036] - Signal too High
                    Mileage: 33607 km
                    Date: 2019.12.02
                    Time: 16:47:19
                    Engine speed: 0.00 /min
                    Coolant temperature: 60 °C
                    Intake air temperature: 50 °C
                    Voltage terminal 30: 12.500 V
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 4131.2 hPa
                    Engine status: COENG_STANDBY
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 50637000001901
   Coding: 01FA8AA134240971477C060540CB2980512C90E26002947534605078C009430000000012121212B835351919323200
   VCID: 76B5E695084492E7E3B-8022
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0012010420211001100500400010102A
   VCID: 6D87C9F97D12513F121-8038
   Air quality sensor:
   Part No SW: 5Q0 937 084 CF    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H34 0236
   Serial number: 02001706901834
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EA5FEB52074DAA7BBB-802A
   Component: WWS    170216  042 0551
   Serial number:         170303212708
   Component: RLHS  042 0105
   Serial number: S4Y17M03D15H00M58S45
   Coding: 00A8DD
   Serial number: 000000000ZY170521MZF
   Serial number: 00000000000068295429
204546 - Remote key 2
          B147A 18 [009] - Current Too Low
                    Reset counter: 110
                    Mileage: 33589 km
                    Date: 2019.12.02
                    Time: 11:47:17
   Part No SW: 5QA 919 294 A    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0038
   Serial number: 000308418617076
   Coding: 0471051001
   ASAM Dataset: EV_EPHVA18AU3700000 009031
   VCID: 4ACD62652C3CA607573-801E
   Part No SW: 5Q0 907 572 H    HW: 3QF 907 572
   Coding: 2B00608159FFC728949C810560400600000000000000000000
   VCID: 3C2134BD76E808B7D5F-8068
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0317
   Serial number: 003TDR2RYHT9
   Coding: 98CCC000000000005C0000CF008800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 1079B00D0AE0DCD7597-8044
   Belt Pretensioner left:
   Serial number: 34169677E14031741182
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676E15031751315
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 203 17
   Serial number: 35700000000727283225
   Subsystem 4 - Part No SW: -----------    HW: 480 001 303 17
   Serial number: 3580000000077738D12L
   Subsystem 5 - Part No SW: -----------    HW: 480 400 803 17
   Serial number: 3510001C124A43A6272U
   Subsystem 6 - Part No SW: -----------    HW: 480 401 403 17
   Serial number: 3520001A72507FC327C7
   Subsystem 7 - Part No SW: -----------    HW: 480 401 303 17
   Serial number: 3550001BF24CDB14E35N
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 13031708490654
   Coding: 0400
   VCID: 0D47A9791DD2F13FB21-8058
   Part No SW: 5G1 920 791     HW: 5G1 920 791
   Component: KOMBI         409 2180
   Coding: 23AD21002F802E0001886F011400000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
   VCID: 698FBDE949FA4D1F7E9-803C
13639427 - Databus
          [Steuergerät für Motor: bitte Fehlerspeicher auslesen]
                    Reset counter: 151
                    Mileage: 33607 km
                    Date: 2019.12.02
                    Time: 16:47:19
   Component: GW MQB High   418 4286
   Revision: --------    Serial number: 0006070503
   Coding: 030100045F086800FB00027E080F00010001050000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 2F3B13F1B79EE32F60D-807A
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29170000474240067082
   Coding: 2CFFFF
   Serial number: 6176703304
9175296 - Function Restriction due to Driver Fatigue Recognition
          B130E 00 [008] - -
          [Funktionseinschränkung Pausenempfehlung - Ausfall CAN-MSG Prio2]
                    Reset counter: 151
                    Mileage: 33601 km
                    Date: 2019.12.02
                    Time: 15:02:00
                    Supply voltage: Terminal 30: 13.1 V
                    Terminal 15: On
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   VCID: 47CB5B513F2E5B6F48D-8012
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 210217EBK22908
   Coding: 003F0220D001048000001000
   VCID: 43D34F410B16774F945-8016
   Serial number: 00000000000013778192
   Coding: 0D0000
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2D32A57CDC3687C73-806E
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Component: FCM MQB Low   001 0285
   Serial number: 10031710803312
   Coding: 000000050100164E01100F01020000000000000000000000000000000000
   VCID: 72BDDA85642C8EC7CF3-8026
   Serial number: 080317EC802954
   Coding: 003F0020DE01048000801000
   VCID: 42DD4A45140C7E479F3-8016
   Serial number: 00000000000013708881
   Coding: 150000
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    840 0757
   Coding: 02731001FF00000051110101008808001F0502E601200000CF
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 313F1589A1AAF5DF769-8064
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H41 8077
   Serial number: VWZ6ZET0770380
   Subsystem 2 - Part No SW: 5NA 919 866 H    HW: -----------
   Component: ECE1 2019/20  --- 1115
   Component: SAS-GEN 2     H06 0014
   Serial number: 170217200138
   VCID: 6B83C7E143065F0F0C5-803E
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 392F2DA979DA3D9FCE9-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:41, VBatt start/end: 12.3V/12.3V)-----------
Owen: It's very interesting (at least to me) how length of twilight period varies across continents and time-of-year!
I'm not sure that a solution to your problem is immediately obvious, but it will be illuminating (pun intended) if you post-up a complete (meaning unedited) auto-scan for the car in question (instead of just the Gateway installation list).
Again, I'm not sure about your mk7.5 - but in earlier model mk7 Golfs, the upper nibble of Byte 0 on the light-sensor (which is a LIN slave module to the BCM - so the sensor is not included in the gateway summary list) had a bunch of software switches that enabled earlier switch-on thresholds for the sensor. Since you haven't posted a complete auto-scan, it's not possible to ascertain whether the light sensor on your car has one of these earlier settings selected.
TBAx
DE
C?ID=287144
This can be disabled by changing the adaption channel "ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig" to "not active" in your BCM.
Am I the only one around here who thinks it's absurd that this car would tell the driver to turn on the lights, rather than just turning on the damn lights? I means it's not like those lights aren't under full digital control!
Owen in Scotland
Troon
C?ID=105356
Thankyou very much for this TBAx, I will give this a try tomorrow and let you know if it disables the switch on warning completely.
Owen in Scotland
Troon
C?ID=105356
Hi Don, have attempted to append my full autoscan as requested. Appreciate your reply and support.
TBAx
DE
C?ID=287144
Not, if the rotary light switch is set to 0. ;)
Owen in Scotland
Troon
C?ID=105356
Hi TBAx,
Tried your suggestion and it worked, disabled the warnings completely. However, I decided to choose one of the alternative setting options for that channel, “Hinweis_in_LDS-Stellung_Null” rather than the German option of "not active" per your recommendation. What this setting allows is for the warning to come on with the light switch in the 0 (Off) position only, and if I then briefly switch to Auto or Headlight setting with the rotary light switch for a few seconds in order to allow the dipped beams to come on, and the warning to go off, I then move the rotary switch to side light position only, and the warning remains off. So this is an ideal workaround for me, thank you so much.
For my further learning, I would be interested in finding out exactly which channel adaptations control the daylight sensor on/off thresholds for this dipped beam warning message and functionality. I know the trigger is via light senor on the rear of the interior mirror, as I have held my LED torch up to this and watched the warning message switch off on the dashboard. Further observed this through watching the advanced measuring data values changing in the following two channels as I moved the torch up to and away from the mirror sensor.
IDE05838-MAS04809 Light recognition sensor-Darkness - On
IDE05838-MAS04810 Light recognition sensor-Request for light activation - On
With the torch against the senor, both values above changed to Off. Moving it away they both change back to On. (Car in low ambient light garage)
The perfect solution for me would be to modify the low light trigger value(s) in the appropriate channel or channels, assuming there are some linked and related settings around this. (Hysteresis settings along with Lux light level settings etc.) If I could adjust this so that the warning does not come on at all in other than “appropriate low light levels actually requiring dipped headlights”, I would do that and revert the ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig setting you suggested, changing it back to Hinweis_in_LDS-Stellung_Null_und_SL per the vehicle default and VW’s intention I guess.
If you could add any more clarity around that aspect it would be very much appreciated, if not though, no problem as your suggestion has provided a very workable solution for me on this very annoying “switch on dipped headlight” VW Golf MK7.5 light problem.
Best regards,
Owen
Owen in Scotland
Troon
C?ID=105356
Hi Don, ref TBAx reply above, tried his suggestion and have sent a further reply back to him which you might find useful as well. Thanks again. Owen
Owen: Thanks for the heads-up. Yes, if anyone knows these answers, TBAx is definitely the one!!;).
Sounds like you have a passion for solving this problem and the intellectual capacity to pursue the matter - both excellent attributes.
In the primordial recesses of the last century when you were probably not born, a wonderfully kind and well respected teacher here in the Antipodes tried desperately to instill lighting theory into the stubborn minds of his students (of which I was one).
Although I suspect that the definition of twilight is a physical thing involving the relative position of the sun and the earth's surface, from a lighting perspective we used a standard of 500 lux in his classes. Because I was more interested in "extra-curricular" pursuits in those days, I'm not sure if this measure was a recognized standard (I suspect not) - but it's a not unreasonable rule-of-thumb metric IMO.
So - back to your problem: If I look at my database of BCM admaps on an application like MS Access and if I apply a search vector for settings around 500 lux, the following adaptation channels are returned:
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn > 200 lx
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day > 500 lx
Now - without any knowledge what-so-ever of how the boffins @ VW/Audi actually intended these channels to operate, I'm guessing that there is an inherent hysteresis built-into the design for the headlight ON/OFF function. By which I mean that in order to stop the control mechanism from "hunting" (i.e. stopping the switching ciruit from continuously cycling on/off around a single threshold light value) 2 x threshold values are used.
This means (and again, I'm guessing) that assuming that the ignition is kept switched-on, once the headlights are automatically enabled at the ENG123008 value of 500 lux (above), the control mechanism will stay switched-on until the ambient light level rises again to the ENG123007 value of 200 lux - see pic below:
I've not tried playing with settings on either of the 2 x channels above - but I believe that they are sufficiently intriguing for your purpose as to warrant your attention. Perhaps?
PS: and just in case you are wondering why I launched into a discussion about switching hysteresis - if you are successful in modifying the setting on the ENG123006 channel - you might consider retaining the same differential that is designed into the factory settings . By which I mean if you lower "day" level - increase the "dawn" level by the same amount
PPS:... and here is another aspect of the ability to alter the switch-on light thresholds - alas in the wrong direction for your purpose (it's the long-code string for the RLS/RHLS/RFLS). Notice that the code-string value is the same as in your auto-scan. It would be interesting to see what happens to the Lux settings in the 2 x adaptation channels above if the threshold settings are changed in this Byte ?
Owen in Scotland
Troon
C?ID=105356
Hi Don,
Appreciate the further input and comments. Unfortunately being born in the late 50’s last century as well, and from my interest in photography from my early teens at that time, I probably have an unhealthy interest in light levels and solving this problem for the general “Scottish” ambient light conditions, and my declining tolerance for annoying problems…...
Ref your input around the Lux values for dawn and daylight, I’ll have a play with those tomorrow. I’m assuming the lower light level at ENG123007 is what triggers the switch on warning, (200Lx), not the higher level indicated in ENG123006 (500Lux), but want to check with you again that that was not a typo on your part, affecting my understanding of how this circuit might be working. Appreciate if you could double check your thoughts on that, higher Lux is brighter triggering switch off, not switch on etc.
Understand and agree with your hysteresis theory and will keep that in mind with future trials.
Already had a go at changing the Long coding in the RLS/RHLS/RFLS slave controller a few days ago, with no significant difference noticed. Note though that although 4 alternatives are shown there, only 1 (+60% from memory) was accepted by the controller with the others being rejected as “out of range.” Will try the +60% one again and note any difference in the lux values then set in ENG123006 and ENG123007 and let you know.
Many thanks Don, great inputs,
Owen
Unfortunately being born in the late 50’s last century..............
"late 50's"? You are a mere baby!!!;)
hmm....... OK - it might be my thick Australian accent and my involuntary (and understandable) tendency to easily slip into "strine" (look it up) - but I suspect that we do misunderstand each over!!
That said, I'm not entirely sure which of us is correct - my ego makes me hope that it's you that is wrong, but past experience in interpreting the meaning of BCM channels suggests that it might be me that has erred (which would be an unmitigated disaster - I'm sure you would agree !! :D)
So this is my thinking - If you look at the wording of the channels - the "dawn" channel has the lower setting of 200 Lux. My assumption (and it's just that) is that the value in this channel relates to what happens when the car is traversing the period from late night to early morning. While I agree with your hypothesis about the relative values of the 2 x threshold values - the only way to make sense of the title words in the channel name is my way - I think.
In my befuddled mind, this logic tends to support the notion that the lower lux value in ENG123007 is the "switch-off" threshold (which may be accompanied by a warning message) and ENG123006 is the threshold for "switch-on" which is accompanied with the familiar nag-message that annoyingly and repeatedly has assailed your gaze.
But, as I have said numerous times before - there is no greater folly than a man (or woman) who believes that truth has only one face - so, I'm more than happy to be proven wrong!
Probieren geht über studieren ;)
(Yeah, yeah, I'm violating my own "post in English" rule. Call it Dictator's perrogative)
Owen in Scotland
Troon
C?ID=105356
Absolutely Uwe, where there is a will.......
Owen in Scotland
Troon
C?ID=105356
Hi Don, no baby any longer unfortunately, but thanks for the thought at least….
It’s not the strine that’s confusing us here, more the German translation of the coding intent I think. I agree with your thinking that the lower value relates to what happens at dawn, and the higher value dictates what happens at day. (Or dusk more to my thinking) Our thoughts are in line actually I think, not different. I got myself confused when you mentioned “the headlights are automatically enabled at the ENG123008 value of 500 lux (above)” The word (above) there confused me, as I agree it will switch on as the light fades to 500 lux or “below”, hysteresis values accepted, and then remain on until daylight fades completely into night, night turns into dawn next day and the light level rises to 200 lux or “above” again, hysteresis values accepted to prevent hunting around these single value thresholds, so we are in sync I think. I confused myself originally with your 500 (above) comment as mentioned.
I tried playing around with the various lux settings again today, but not much further forward I don’t think.
Trial 1-
Reduced the value in MAS08228-ENG133437 from 1200 to 60.
At the same time, reduced the value in MAS08228-ENG133438 to 80, that was the lowest value the controller would accept with MAS08228-ENG133437 set to 60.
While monitoring the actual trigger values for lights and warning on / off via the advanced measuring blocks below, noted that regardless of these changes, warning message and dipped headlights still came on around 300 lux, and remained on until around 3000 lux??? As such, changed these two back to their default values.
Light sensor advanced measuring blocks:
IDE05838-MAS02475 Light recognition sensor-Brightness infrared 0 lx
IDE05838-MAS02851 Light recognition sensor-Brightness 60 lx
IDE05838-MAS04809 Light recognition sensor-Darkness On
IDE05838-MAS04810 Light recognition sensor-Request for light activation On
Trial 2 -
Reduced the hysteresis settings at MAS08228-ENG133434 and MAS08228-ENG133435 both to 60, again the lowest value they would accept. Did not notice any change in switch off/on behaviour compared with the above Trial. So, changed those two back to their defaults as well.
Tried to change the sensitivity settings for dawn and day channels at ENG123007 and ENG123006, but the controller would not accept any different values there, returning the “out of range” error message on both channel change attempts. (Up or down)
Trial 3 –
Per your PPS comment, I changed the slave controller long coding to the +60% level option, the only one it would permit me to change rejecting all others as “out of range.” The revised coding was accepted as 18A8DD. I looked the actual lux values in ENG123007 and ENG123006 to determine if they had changed at all, but they were still the same level of 200 and 500 respectively.
So still needing to do a bit more thinking and research into this, I’m wondering if the Infra red sensor is in some way playing a part here, by way of a combination of both luminance light and infra red light permutations here??? E.g MAS08228-ENG133444
Thanks again for your thoughts,
Owen.
^^^Owen,
While it would be wonderful to read of your success in solving this issue - my more immediate delight is in the vindication of my previous intuitive observation:
....Sounds like you have a passion for solving this problem and the intellectual capacity to pursue the matter - both excellent attributes.
rocamet
Rancho Cucamonga, CA, USA
C?ID=419570
Changing the "ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig" channel to "kein_Hinweis" worked for me as well on my 2020 VW Atlas Cross Sport. That disabled the "Please switch on your lights" message all together.
I was annoyed when entering my car, starting it and being forced to turn on the lights just to back out of the dark garage before being allowed to changed the profile from my wife's to my own via the steering wheel controls.
I don't need the car to tell me when to turn on the lights, I can handle that one! :)
