Security code for 44 Steering assist Touran 2011
NamrepuS
Denmark
I've just replaced the steering rack on my Touran 2011 with a used one from a wrecker, as the old one had a permanent fault with 03375 Mechanical malfunction.
My Touran is a 1.4TSI 125kw from 2011 (Steering-rack has: 1T1 423 050 A | 5N1 909 144 L - HWH03 - SW0802)
The used one is from 1.6TDI from 2012 (Steering-rack has: 1T1 423 050 G | 5N1 909 144 N - HWH03 - SW1101)
However, I have not had any success with getting it to work.
Faults are:
Steering torque sensor
Steering limit stop
Position in power steering motor
I noted the old one was coded "0000258" however the "new" one has "0000002"
I have tried to code on 44 and change the code, but no suggested "Security code" on VCDS allows me to change the coding.
MartinsX
Riga, Latvia
C?ID=268515
Post an autoscan, please. The best is one with old and another one with replacement rack installed.
MasterTommy
Amsterdam
C?ID=295586
Why would you buy a used part for your car with both a different SW and a different HW part number?
NamrepuS
Denmark
Not sure how to post code properly and currently the read-out is in Danish. So please bare with me.... :cry:
Additionally, I did not have access to a VCDS before mounting the "new" one. I am however able to "fit" the old one outside the car if necessary, and if I don't risk damaging anything??
Readout
Søndag,01,December,2019,18:07:21:50250
VCDS -- Windows baseret VAG/VAS emulator - Kører på Windows 10 x64
VCDS version: NEZ 19.6.2.1
Dataversion: 20191027 DS310.0
[url]www.vcds.dk[/url]
Stelnummer: WVGZZZ1TZBW058165   Indreg.nr.: BE61595
Kørestrækning: 182540km   Reparationsordre:
Modeltype: 1T-VW36 (7N0)
Søgt på: 01 02 03 08 09 10 15 16 17 19 20 25 42 44 46 4F 52 56 61 62
          69 72
Stelnummer: WVGZZZ1TZBW058165   Kørestrækning: 182540km
01-Motor -- Status: Ok 0000
02-Automatik -- Status: Ok 0000
03-ABS bremser -- Status: Fejlfunktion 0010
04-Styrevinkel -- Status: Ok 0000
08-Klimaanlæg -- Status: Ok 0000
09-Centralelektrik -- Status: Fejlfunktion 0010
10-Park.assist. -- Status: Ok 0000
15-Airbags -- Status: Ok 0000
16-Ratelektronik -- Status: Ok 0000
17-Instrument -- Status: Ok 0000
19-CAN Gateway -- Status: Fejlfunktion 0010
20-Fjernlysassistent -- Status: Ok 0000
25-Startspærre -- Status: Ok 0000
42-Dørelektr. V for -- Status: Ok 0000
44-Servostyring -- Status: Fejlfunktion 0010
46-Komfortelektronik -- Status: Ok 0000
4F-Centralelektrik II -- Status: Ok 0000
52-Dørelektr. H for -- Status: Ok 0000
56-Radio -- Status: Fejlfunktion 0010
61-Batteriregulering -- Status: Ok 0000
62-Dørelektr. V bag -- Status: Ok 0000
69-Anhængertræk -- Status: Periodisk kommunikationsfejl 1000
72-Dørelektr. H bag -- Status: Ok 0000
Styreenhed  01: Motor (CAV)     Forklaringsfil: NEZ\03C-906-027-CAV.clb
   Styreenhedsnr: SW: 03C 906 027 BQ    HW: 03C 907 309 B
   Komponent	: MED17.5.5       G   8025
   Revision	: LAH15---    Serienummer	:
   Kodning	: 0000077
   Forhandler	: WSC 01324 020 00200
   VCID: 71E23F3B686D50C759-8024
Ingen fejlkoder fundet.
Styreenhed  02: Automatik      Forklaringsfil: NEZ\0AM-927-769.clb
   Styreenhedsnr: SW: 0AM 300 050 F    HW: 0AM 927 769 D
   Komponent	: GSG DSG AG7     403 9031
   Revision	: 00040034    Serienummer	: CU501012116625
   Kodning	: 0000020
   Forhandler	: WSC 50291 001 1048576
   VCID: 2C5CEE4F8FCF7D2F2A-8078
Styreenhed  03: ABS bremser (J104)     Forklaringsfil:. NEZ\1K0-907-379-60EC1F.clb
   Styreenhedsnr: SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Komponent	: ESP MK60EC1   H31 0108
   Revision	: 00H31001
   Kodning	: 323B601621270E024C0C06EA841E7040350150
   VCID: 76E80C27C10377FF8C-8022
1 fejl fundet:
00287 - Omdrejningsføler højre baghjul (G44)
            008 - Urealistisk signal - Periodisk
             Fryserammedata:
                    Fejl status  : 00101000
                    Fejlprioritet: 1
                    Fejlhyppighed: 3
                    Nulstiltæller: 65
                    Kørestrækning: 182339 km
                    Tidsindikation: 0
                    Dato: 2014.04.23
                    Tid: 00:55:59
             Fryserammedata:
                    Tæller: 0
                    Tæller: 32768
                    Tæller: 4608
                    Tæller: 86
                    Tæller: 52992
                    Tæller: 0
                    Tæller: 258
                    Tæller: 47
Styreenhed  08: Klimaanlæg (J255)     Forklaringsfil:| NEZ\5K0-907-044.clb
   Styreenhedsnr: SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
   Komponent	: Climatronic   H17 1010
   Revision	: 00003001
   Kodning	: 0000000002
   ASAM datasæt	: EV_Climatronic A01010
   VCID: 6ED82447B1534F3F44-803A
Styreenhed  09: Centralelektrik (J519)     Forklaringsfil:. NEZ\1K0-937-08x-09.clb
   Styreenhedsnr: SW: 5K0 937 086 J    HW: 5K0 937 086 J
   Komponent	: BCM PQ35 M    011 0046
   Revision	: BC011001
   Kodning	: 40180A3B88251AE040080088540081E443518E08726D8560648042000040
   VCID: 3B7EDD13BAA1EA97B3-806E
   Komponent	: Wischer 27111  26  0512
   Kodning	: 009795
   Undersystem 2 - Styreenhedsnr:: 1K0 955 559 AH  Forklaringsfil: NEZ\1K0-955-559-AG.CLB
   Komponent	: RLS 101210 05  54  0403
   Kodning	: 0330ED
2 fejlkoder fundet:
01504 - Nummerpladelys (X)
            010 - Afbrydelse/Kortslutning til plus - Periodisk
             Fryserammedata:
                    Fejl status  : 00101010
                    Fejlprioritet: 2
                    Fejlhyppighed: 1
                    Nulstiltæller: 103
                    Kørestrækning: 182337 km
                    Tidsindikation: 0
                    Dato: 2014.04.23
                    Tid: 00:30:54
             Fryserammedata:
                        Kl. 15 FRA
                    Volt: 12.60 V
                        Fra
                        Til
                        Fra
                        Fra
                        Fra
01517 - Styreenhed for registrering af anhænger (J345)
            004 - Intet signal/kommunikation - Periodisk
             Fryserammedata:
                    Fejl status  : 00100100
                    Fejlprioritet: 6
                    Fejlhyppighed: 6
                    Nulstiltæller: 105
                    Kørestrækning: 182334 km
                    Tidsindikation: 0
                    Dato: 2014.04.23
                    Tid: 06:18:14
             Fryserammedata:
                        Kl. 15 FRA
                    Volt: 12.95 V
                        Fra
                        Til
                        Fra
                        Fra
                        Fra
Styreenhed  10: Park.assist. (J791)     Forklaringsfil:| NEZ\3AA-919-475.clb
   Styreenhedsnr: SW: 3AA 919 475 D    HW: 3AA 919 475 A
   Komponent	: PARKHILFE PLA H04 0007
   Revision	: --------    Serienummer	: 20431033501681
   Kodning	: 118101
   Forhandler	: WSC 00011 888 182020
   ASAM datasæt	: EV_EPHVA2C000000000 001006
   ROD: EV_EPHVA2C000000000_001_VW36.rod
   VCID: 3C7CDE0FB7AFEDAFBA-8068
Styreenhed  15: Airbags      Forklaringsfil: NEZ\1T0-909-605.lbl
   Styreenhedsnr: SW: 1T0 909 605 E    HW: 1T0 909 605 E
   Komponent	: 02 AIRBAG VW8   022 0100
   Revision	: 02022000    Serienummer	: 003K4D01LJA5
   Kodning	: 0012338
   VCID: 3776C1234689CEF757-8062
   Undersystem 1 - Serienummer	: 6332QSME1E772E38V
   Undersystem 2 - Serienummer	: 6342QSME1E775702J
   Undersystem 3 - Serienummer	: 6352QSME5C7B1E20T
   Undersystem 4 - Serienummer	: 6362QSME457B570AR
Styreenhed  16: Ratelektronik (J527)     Forklaringsfil:| NEZ\5K0-953-569.clb
   Styreenhedsnr: SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Komponent	: LENKS.MODUL   016 0180
   Revision	: --X01---    Serienummer	: 20190524100297
   Kodning	: 1982140000
   Forhandler	: WSC 12345 123 61029
   ASAM datasæt	: EV_VW360SteerWheelUDS A03004
   VCID: 020060F795CB5B5FB0-8056
   Styreenhed til multifunktionsrat:
   Undersystem 1 - Styreenhedsnr: SW: 5K0 959 542 A    HW: 5K0 959 542 A  Forklaringsfil: NEZ\3C8-959-537.CLB
   Komponent	: E221__MFL-TAS  H07 0013
   Serienummer	: 0148480
   Kodning	: 820000
Styreenhed  17: Instrument (J285)     Forklaringsfil:| NEZ\5K0-920-xxx-17.clb-SRI1
   Styreenhedsnr: SW: 1T0 920 881     HW: 1T0 920 881
   Komponent	: KOMBI         H05 0206
   Serienummer	: 00000000000000
   Kodning	: 181F01
   ASAM datasæt	: EV_Kombi_UDS_VDD_RM09 A04089
   VCID: 71E23F3BA06D50C759-8024
Styreenhed  19: CAN Gateway (J533)     Forklaringsfil:. NEZ\7N0-907-530-V2.clb
   Styreenhedsnr: SW: 7N0 907 530 D    HW: 1K0 907 951
   Komponent	: J533  Gateway H35 0614
   Revision	:   H35       Serienummer	: 151210F2001964
   Kodning	: 358002
   VCID: 3162FF3B68ED10C719-8064
2 fejlkoder fundet:
             Fryserammedata:
                    Fejlprioritet: 2
                    Fejlhyppighed: 7
                    Nulstiltæller: 105
                    Tidsindikation: 0
                    Dato: 2014.04.23
                    Tid: 04:08:30
01305 - Databus: Infotainment
             Fryserammedata:
                    Fejl status  : 01100100
                    Fejlprioritet: 1
                    Fejlhyppighed: 1
                    Nulstiltæller: 63
                    Kørestrækning: 182310 km
                    Tidsindikation: 0
                    Dato: 2014.04.23
                    Tid: 03:31:06
Styreenhed  20: Fjernlysassistent (J844)     Forklaringsfil:. NEZ\8K0-857-511.clb
   Styreenhedsnr: SW: 5K0 857 511 B    HW: 8P0 857 511 C
   Komponent	: FLA           H04 0006
   Revision	: AA001002
   Kodning	: 0101856B74745D545420363E00
   VCID: 2D5AE34B74D574273D-8078
Styreenhed  25: Startspærre (J334)     Forklaringsfil:| NEZ\5K0-920-xxx-25.clb
   Styreenhedsnr: SW: 5K0 953 234     HW: 5K0 953 234
   Komponent	: IMMO          H05 0206
   Kodning	: 000000
   Forhandler	: WSC 00000 000 00000
   ASAM datasæt	: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD028578DBBA31F18-803E
Styreenhed  42: Dørelektr. V for      Forklaringsfil:. NEZ\1K0-959-701-MAX3.clb
   Styreenhedsnr: SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Komponent	: Tuer-SG         009 2121
   Kodning	: 0004279
   VCID: 76E80C27010377FF8C-8022
Styreenhed  44: Servostyring      Forklaringsfil: NEZ\5N1-909-144.clb
   Styreenhedsnr: SW: 5N1 909 144 N    HW: 5N1 909 148 G
   Komponent	: J500__APA-BS KL.293 1101
   Revision	: 1AH03735    Serienummer	: 00122930208301
   Kodning	: 0000002
   VCID: 3D7AD30B64B5E4A78D-8068
10 fejlkoder fundet:
01288 - Kl. 30 servostyring
            011 - Afbrydelse - Periodisk
             Fryserammedata:
                    Fejl status  : 00101011
                    Fejlprioritet: 9
                    Fejlhyppighed: 1
                    Nulstiltæller: 201
                    Tidsindikation: 0
             Fryserammedata:
                        Kl. 15 TIL
                    Omdr.: 0 /min
                    Hastighed: 0.0 km/h
                    (uden enhed): 2.0
                    Volt: 12.60 V
00568 - Positionssensorer i servomotor
            008 - Urealistisk signal - Fejllampe aktiveret
             Fryserammedata:
                    Fejl status  : 11101000
                    Fejlprioritet: 1
                    Fejlhyppighed: 5
                    Nulstiltæller: 65
                    Kørestrækning: 182336 km
                    Tidsindikation: 0
                    Dato: 2014.04.23
                    Tid: 06:37:07
             Fryserammedata:
                    (uden enhed): 6042
                    (uden enhed): 0
                    Styrevinkel: 89.99°
                    (uden enhed): 0
                    (uden enhed): 14.0
00566 - Servostyrings drift
             Fryserammedata:
                    Fejlprioritet: 2
                    Fejlhyppighed: 1
                    Nulstiltæller: 201
                    Tidsindikation: 0
             Fryserammedata:
                        Kl. 15 TIL
                    Omdr.: 0 /min
                    Hastighed: 0.0 km/h
                    (uden enhed): 4.0
                    Volt: 12.60 V
00573 - Føler for styremoment (G269)
            012 - Elektrisk fejl i strømkreds - Fejllampe aktiveret
             Fryserammedata:
                    Fejl status  : 11101100
                    Fejlprioritet: 1
                    Fejlhyppighed: 1
                    Nulstiltæller: 65
                    Kørestrækning: 182548 km
                    Tidsindikation: 0
                    Dato: 2014.04.23
                    Tid: 18:04:40
             Fryserammedata:
                    Moment: 0.0 Nm
                    Moment: 0.0 Nm
                    Volt: 5.00 V
                        Ikke i brug
                        Ikke i brug
00750 - Fejllampe
            012 - Elektrisk fejl i strømkreds - Periodisk
             Fryserammedata:
                    Fejl status  : 00101100
                    Fejlprioritet: 2
                    Fejlhyppighed: 1
                    Nulstiltæller: 201
                    Tidsindikation: 0
             Fryserammedata:
                        Kl. 15 TIL
                    Omdr.: 0 /min
                    Hastighed: 0.0 km/h
                    (uden enhed): 14.0
                    Volt: 12.80 V
00576 - Kl. 15
             Fryserammedata:
                    Fejlprioritet: 6
                    Fejlhyppighed: 1
                    Nulstiltæller: 201
                    Kørestrækning: 182378 km
                    Tidsindikation: 0
                    Dato: 2014.04.23
                    Tid: 01:30:21
             Fryserammedata:
                        Kl. 15 TIL
                    Omdr.: 0 /min
                    Hastighed: 0.0 km/h
                    (uden enhed): 14.0
                    Volt: 12.80 V
02369 - Temperatursensor i styreenhed
             Fryserammedata:
                    Fejlprioritet: 2
                    Fejlhyppighed: 1
                    Nulstiltæller: 105
                    Kørestrækning: 182439 km
                    Tidsindikation: 0
                    Dato: 2014.04.23
                    Tid: 14:00:15
             Fryserammedata:
                    Temperatur: 28.0°C
                    Temperatur: 3.0°C
                    Temperatur: 28.0°C
                        Ikke i brug
                        Ikke i brug
             Fryserammedata:
                    Fejlprioritet: 2
                    Fejlhyppighed: 1
                    Nulstiltæller: 105
                    Kørestrækning: 182445 km
                    Tidsindikation: 0
                    Dato: 2014.04.23
                    Tid: 14:02:44
             Fryserammedata:
                    Temperatur: 29.0°C
                    Temperatur: -3.0°C
                    Temperatur: 29.0°C
                        Ikke i brug
                        Ikke i brug
             Fryserammedata:
                    Fejlprioritet: 1
                    Fejlhyppighed: 1
                    Nulstiltæller: 105
                    Kørestrækning: 182450 km
                    Tidsindikation: 0
                    Dato: 2014.04.23
                    Tid: 14:05:04
             Fryserammedata:
                    Temperatur: 29.0°C
                    Temperatur: 19.0°C
                    Temperatur: 29.0°C
                        Ikke i brug
                        Ikke i brug
02546 - Anslag for fuldt styreudslag
            005 - Manglende eller forkert grundindstilling/adaption - Fejllampe aktiveret
             Fryserammedata:
                    Fejl status  : 11100101
                    Fejlprioritet: 2
                    Fejlhyppighed: 1
                    Nulstiltæller: 65
                    Tidsindikation: 0
                    Dato: 2014.04.23
                    Tid: 18:04:40
             Fryserammedata:
                        Kl. 15 TIL
                    Omdr.: 1392 /min
                    Hastighed: 0.0 km/h
                    (uden enhed): 14.0
                    Volt: 14.60 V
Styreenhed  4F: Centralelektrik II (J520)     Forklaringsfil:. NEZ\1K0-907-532.clb
   Styreenhedsnr: SW: 7N0 907 532     HW: 1K0 907 951
   Komponent	: EZE_2         H35 0614
   Kodning	: 050B0500
   VCID: 6FE63943BE5946374F-803A
   Undersystem 1 - Styreenhedsnr: SW: 8R0 959 591 A    HW: 8R0 959 591
   Komponent	: J245EE20SKB13  H02 0220
   Serienummer	: 0123456789ABCDEFGHIJ
   Undersystem 2 - Styreenhedsnr: SW: 8R0 959 591 A    HW: 8R0 959 591
   Komponent	: J394EE20SKB13  H02 0220
Styreenhed  52: Dørelektr. H for      Forklaringsfil:. NEZ\1K0-959-702-MAX3.clb
   Styreenhedsnr: SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Kodning	: 0004535
   VCID: 4894B2DF3B77B10F2E-801C
Styreenhed  56: Radio
Kan ikke kontaktes
Styreenhed  61: Batteriregulering (J840)     Forklaringsfil:. NEZ\1K0-907-534.clb
   Styreenhedsnr: SW: 7N0 907 534     HW: 1K0 907 951
   Komponent	: Batt.regelung H35 0614
   Kodning	: E1200864
   VCID: 71E23F3BA86D50C759-8024
Styreenhed  62: Dørelektr. V bag      Forklaringsfil:. NEZ\1K0-959-703-GEN3.clb
   Styreenhedsnr: SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Komponent	: Tuer-SG         007 2104
   Kodning	: 0000144
   Forhandler	: WSC 01324 020 1012552
   VCID: 3260F037ADEB2BDF60-8066
Styreenhed  69: Anhængertræk (J345)     Forklaringsfil:. NEZ\1K0-907-383-V2.lbl
   Styreenhedsnr: SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Komponent	: Anhaenger     H12 0100
   Revision	: 3A001001    Serienummer	: 00000410498644
   Kodning	: 0100000100000000
   VCID: 3064FA3F63E719CF16-8064
Styreenhed  72: Dørelektr. H bag      Forklaringsfil:. NEZ\1K0-959-704-GEN3.clb
   Styreenhedsnr: SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Kodning	: 0000144
   VCID: 336EF53352F122D76B-8066
Slutning----------------------(Forløbet tid: 03:07)------------------------
Adresse 44: fejlkoder slettet
Adresse 44,5N1 909 144 N,omkodet (Kort kodning),fra,0000002,til,0000258,(00000/000/00000),
NamrepuS
Denmark
I told the wrecker which car I had, and it was sold as compatible with my car. Additionally, there is service bulletin (TPI 2026486) with software upgrade from SW0802 to at least SW1101, so I didn't think about software versions.
Furthermore, ETKA gives "3AB 423 061 L" as replacement for both vin-numbers (my car and the wrecker car)....
As for the Hardware number I have gotten Hardware number "5N1 909 148 G" on both steering racks.
South Molton, UK
Looks like OBD11 screenshots to me?
Any reason you haven't asked on their website/forum?
NamrepuS
Denmark
As with this fora I am experiencing very little response to my questions on their fora. The current screenshots from OBD11 were taken before I had access to a VCDS.
siLc
Tallinn, Estonia
C?ID=330192
There are so many faults in the "new" steering rack I would clear all faults and see what reappear...and post an autoscan with English-language VCDS.
If the new rack is good, it would be beneficial to flash the correct steering assist curve parameters to the new rack. For this, find someone handy with VCP or ODIS.
NamrepuS
Denmark
Is it possible to duplicate/copy the "current one" from the old steering rack and paste/write it to the "new one" from the wrecker using the VCDS??
Currently the car is at a VW workshop and they claim they cannot remove the faults from the steeringrack from the wrecker nor "code" it.
NamrepuS
Denmark
Now I got a chance to fit the old one outside the car to get a readout. And both read-outs are in English now.
First Autoscan is with the old steeringrack (denoted 5N1909144L). Please ignore the fault on oil-level sensor, couldn't make it reach outside the car.
Second Autoscan is with the steeringrack from wrecker (denoted 5N1909144N). Only difference I can see is the coding, which is the one I asked for the security code for as I don't succeed with writing the code. It says wrong security code with the codes I have tried. Hope that I am submitting the autoscan in the right format this time? Hehehe
Friday,06,December,2019,00:07:26:50250
VCDS Version: 19.6.2.0 (x64)
VIN: WVGZZZ1TZBW058165   License Plate: 5N1909144L
Mileage: 182650km-113493mi   Repair Order: PostClear
Chassis Type: 1T-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 20 25 42 44 46 4F 52 56 61 62
          69 72
VIN: WVGZZZ1TZBW058165   Mileage: 182650km-113493miles
Address 01: Engine (CAV)       Labels: 03C-906-027-CAV.clb
   Part No SW: 03C 906 027 BQ    HW: 03C 907 309 B
   Component: MED17.5.5       G   8025
   Revision: LAH15---    Serial number:
   Coding: 0000077
   Shop #: WSC 01324 020 00200
   VCID: 71E23F3B686D50C758-8024
000406 - Engine Oil Temp. Sensor (G8)
               P0196 - 000 - Implausible Signal
                    Mileage: 182653 km
                    Date: 2014.04.28
                    Time: 00:23:26
                    Temperature: 26.0°C
                    Temperature: 23.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.557 V
   Part No SW: 0AM 300 050 F    HW: 0AM 927 769 D
   Component: GSG DSG AG7     403 9031
   Revision: 00040034    Serial number: CU501012116625
   Shop #: WSC 50291 001 1048576
   VCID: 2C5CEE4F8FCF7D2F2B-8078
   Revision: 00H31001
   Coding: 323B601621270E024C0C06EA841E7040350150
   VCID: 76E80C27C10377FF8D-8022
   Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000000002
   VCID: 6ED82447B1534F3F45-803A
   Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
   Component: BCM PQ35 M    011 0046
   Revision: BC011001
   Coding: 40180A3B88251AE040080088540081E443518E08726D8560648042000040
   VCID: 3B7EDD13BAA1EA97B2-806E
   Subsystem 1 - Part No: 1T1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 27111  26  0512
   Coding: 009795
   Component: RLS 101210 05  54  0403
   Coding: 0330ED
Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
   Part No SW: 3AA 919 475 D    HW: 3AA 919 475 A
   Component: PARKHILFE PLA H04 0007
   Revision: --------    Serial number: 20431033501681
   Coding: 118101
   Shop #: WSC 00011 888 182020
   ASAM Dataset: EV_EPHVA2C000000000 001006
   VCID: 3C7CDE0FB7AFEDAFBB-8068
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605 E    HW: 1T0 909 605 E
   Component: 02 AIRBAG VW8   022 0100
   Revision: 02022000    Serial number: 003K4D01LJA5
   Coding: 0012338
   VCID: 3776C1234689CEF756-8062
   Subsystem 1 - Serial number: 6332QSME1E772E38V
   Subsystem 2 - Serial number: 6342QSME1E775702J
   Subsystem 3 - Serial number: 6352QSME5C7B1E20T
   Subsystem 4 - Serial number: 6362QSME457B570AR
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20190524100297
   Coding: 1982140000
   Shop #: WSC 12345 123 61029
   VCID: 020060F795CB5B5FB1-8056
   Component: E221__MFL-TAS  H07 0013
   Serial number: 0148480
   Coding: 820000
   Part No SW: 1T0 920 881     HW: 1T0 920 881
   Component: KOMBI         H05 0206
   Coding: 181F01
   VCID: 71E23F3BA06D50C758-8024
9453842 - Oil Level Thermal Sensor
          B1041 35 [009] - Signal high time > maximum
                    Reset counter: 72
                    Mileage: 182653 km
                    Date: 2019.12.06
                    Time: 00:27:11
   Part No SW: 7N0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H35 0614
   Revision:   H35       Serial number: 151210F2001964
   Coding: 358002
   VCID: 3162FF3B68ED10C718-8064
                    Reset counter: 72
                    Mileage: 182653 km
                    Date: 2014.04.28
                    Time: 00:27:15
   Part No SW: 5K0 857 511 B    HW: 8P0 857 511 C
   Component: FLA           H04 0006
   Revision: AA001002
   Coding: 0101856B74745D545420363E00
   VCID: 2D5AE34B74D574273C-8078
   Component: IMMO          H05 0206
   VCID: 6AD028578DBBA31F19-803E
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2121
   Coding: 0004279
   VCID: 76E80C27010377FF8D-8022
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.292 0802
   Revision: 1AH03729    Serial number: 00103440412801
   Coding: 0000258
   Shop #: WSC 12345 111 45725
   VCID: 3B7EDD137AA1EA97B2-806E
03375 - Steering Motor
            003 - Mechanical Failure - MIL ON
                    Fault Status: 11100011
                    Reset counter: 36
                    Mileage: 181719 km
                    Date: 2014.04.12
                    Time: 01:14:09
                    (no units): 7.0
                    Steering Angle: 0.00°
                        OK
                    (no units): 13
02546 - Steering Limit Stop
                    Fault Status: 11100101
                    Reset counter: 72
                    Mileage: 182653 km
                    Date: 2014.04.28
                    Time: 00:27:57
                    (no units): 4.0
                    Voltage: 11.70 V
   Component: EZE_2         H35 0614
   Coding: 050B0500
   VCID: 6FE63943BE5946374E-803A
   Component: J245EE20SKB13  H02 0220
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0004535
   VCID: 4894B2DF3B77B10F2F-801C
Address 56: Radio
   Component: Batt.regelung H35 0614
   Coding: E1200864
   VCID: 71E23F3BA86D50C758-8024
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2104
   Coding: 0000144
   Shop #: WSC 01324 020 1012552
   VCID: 3260F037ADEB2BDF61-8066
   Component: Anhaenger     H12 0100
   Revision: 3A001001    Serial number: 00000410498644
   Coding: 0100000100000000
   VCID: 3064FA3F63E719CF17-8064
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 336EF53352F122D76A-8066
End-------------------------(Elapsed Time: 02:50)--------------------------
Friday,06,December,2019,00:27:49:50250
VIN: WVGZZZ1TZBW058165   License Plate: 5N1909144N
          69 72
   Coding: 0000077
   Revision: 00H31001
   Revision: 00003001
   Coding: 0000000002
   Revision: BC011001
   Coding: 009795
   Coding: 0330ED
   Coding: 118101
   Coding: 0012338
   Coding: 1982140000
   Coding: 820000
   Coding: 181F01
   Coding: 358002
                    Reset counter: 72
                    Mileage: 182653 km
                    Date: 2014.04.28
                    Time: 00:08:54
   Revision: AA001002
   Coding: 0004279
   Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.293 1101
   Revision: 1AH03735    Serial number: 00122930208301
   Coding: 0000002
   Shop #: WSC 20902 002 1048576
   VCID: 3D7AD30B64B5E4A78C-8068
00573 - Steering Torque Sensor (G269)
                    Fault Status: 11101100
                    Reset counter: 72
                    Mileage: 182653 km
                    Date: 2014.04.28
                    Time: 00:08:52
                    Torque: 0.0 Nm
                    Torque: 0.1 Nm
                    Voltage: 5.00 V
                        Not Occup.
                        Not Occup.
                    Reset counter: 72
                    Mileage: 182653 km
                    Date: 2014.04.28
                    Time: 00:08:52
                    (no units): 14.0
                    Voltage: 11.60 V
00568 - Position Sensors in Steering Motor
            008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Reset counter: 72
                    Mileage: 182653 km
                    Date: 2014.04.28
                    Time: 00:08:52
                    (no units): 1700
                    (no units): 0
                    Steering Angle: 172.86°
                    (no units): -2401
                    (no units): 14.0
   Coding: 050B0500
   Coding: 0004535
Address 56: Radio
   Coding: E1200864
   Coding: 0000144
   Coding: 0000144
End-------------------------(Elapsed Time: 02:49)--------------------------
NamrepuS
Denmark
Bump! I will be replacing the steeringrack from the wrecker with another one tomorrow from a wreck.
