2019 VW T-ROC help with fault codes
adam_m87
Croatia
C?ID=387799
Hello everybody :-)
Just got my brand new HEX-V2 from Ross-Tech and i am a complete newby, but i love tweaking with my cars so here i am :)
So i just scanned my new T-ROC which i bought yesterday, and its only 7 months old. When i ran the auto-scan i got some fault codes which i don't understand.
The car has warranty so i don't worry so much, but i am not sure if these fault codes are serious issues or is it just alright to clear them. Can someone translate them for me and tell me if i should be worried or not.
Thanks for your help :-)
Friday,29,November,2019,23:08:20:55161
VIN: WVGZZZA1ZKV114199   License Plate: GZ1303S
Mileage: 26192km-16274mi   Repair Order:
Chassis Type: A1-VW27 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 42 44 4B 52 5F 75 A5 D6 D7
VIN: WVGZZZA1ZKV114199   Mileage: 26192km-16274miles
Address 01: Engine (J623-DADA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 05E 906 018 R    HW: 05E 907 309
   Component: R4 1.5l TFS   H22 6090
   Revision: 81H22000
   Coding: 0125003223641D0820000000000000000000000000000000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM15TFS01105E906018R 003002
   ROD: EV_ECM15TFS01105E906018R_VW27.rod
   VCID: 34311B5BEEB618371DF-8060
17156 - Databus
33708 - Coolant Pump 2
          P2B63 00 [032] - Stuck
23765 - Control unit for information electronics 1
          U1054 00 [032] - No Communication
          [Information electronics control module 1No Communication]
                    Mileage: 25556 km
                    Date: 2019.11.29
                    Time: 12:49:27
                    Engine speed: 1048.50 /min
                    Normed load value: 1.6 %
                    Vehicle speed: 15 km/h
                    Coolant temperature: 98 °C
                    Intake air temperature: 45 °C
                    Ambient air pressure: 940 mbar
                    Voltage terminal 30: 13.220 V
                    Outside air temperature: 13 °C
                    Absolute intake pressure: 23 kPa abs
                    Engine torque: 8.5 Nm
                    Fuel: tank fill level: 47.0 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Particulate filter: loading stage: 0
                    Overrun cut-off-Bits 0-7: 0
   Part No SW: 0CW 300 043 D    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1607
   Revision: 00005008    Serial number: CU501902166051
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: 38292F6BF2DEFC57317-806C
25472 - No Communication with Gear Selector Module
          U0103 00 [008] - -
                    Mileage: 25289 km
                    Date: 2019.09.23
                    Time: 18:48:58
                    Engine speed: 5.25 /min
                    Engine torque: -100 Nm
                    Vehicle speed: 108 km/h
                    Control Module temperature: -20 °C
                    CURRENT pressure: -10.0 bar
                    Clutch: primary stat: Driving
                    selected gear: GANG_5
                    Driving position: N
                    Accelerator position: 0.4 %
                    DTC memory status: 17408
   Part No SW: 5Q0 614 517 EF    HW: 5Q0 614 517 BP
   Component: ESC           H35 0107
   Revision: 00000000    Serial number: 60549000003439
   Coding: 46FA6A7D202124704778060962CC2562560424E26046A4733822F078D2224B0B00000523525212121035351919323200
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 79AFEA6F8954255F8E9-802C
   Part No SW: 5G0 907 044 DA    HW: 5G0 907 044 DA
   Component: Climatronic   H04 2002
   Revision: 00001K08
   Coding: 0602000420011001110500000010102A
   VCID: 698FBA2FF9F495DF7E9-803C
   Air quality sensor:
   Part No SW: 5Q0 937 084 DC    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H38 0273
   Serial number: 01001905000168
   ROD: EV_BCMBOSCH_019_VW27.rod
   VCID: 7CA1F37B8666107795F-8028
   Subsystem 1 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  052 0107
   Serial number: S4Y19M02D28H11M02S24
   Coding: 0038DD
   Steering Column Switch:
   Subsystem 2 - Part No SW: 5Q1 953 521     HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0100020320190C203570
558356 - Databus
          [Gateway_73 Datenbus empfangener Fehlerwert]
                    Reset counter: 161
                    Mileage: 25289 km
                    Date: 2019.09.23
                    Time: 18:48:59
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418319061
   Coding: 0471051811
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   ROD: EV_EPHVA18AU3700000_009_VW27.rod
   VCID: 4CC163BB964660F765F-8018
   Part No SW: 2Q0 907 572 Q    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0342
   Coding: 3204674258FF8748949C810580408700000000000000000000
   ASAM Dataset: EV_ACCMRRCONTIVW376 003015
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: 42DD4D83A402A6879F3-8016
1218 - Databus
          [FAULT_TIMEOUT_PSD_05]
                    Reset counter: 165
                    Mileage: 25556 km
                    Date: 2019.11.29
                    Time: 12:49:28
                    Voltage terminal 15: 13.4 V
                    Control Module temperature: 47 °C
                    Vehicle speed: 4.33 m/s
                    Longitudinal acceleration: -0.44 m/s²
                    Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
1219 - Databus
          [FAULT_TIMEOUT_PSD_06]
                    Reset counter: 165
                    Mileage: 25556 km
                    Date: 2019.11.29
                    Time: 12:49:28
                    Vehicle speed: 4.30 m/s
                    Longitudinal acceleration: -0.47 m/s²
   Part No SW: 3Q0 959 655 CM    HW: 3Q0 959 655 CM
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z2P3HE5HZ
   Coding: 88CCC0C0000000005C5400CF000840000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 0B43A0A7D3C827CFAC5-805E
   Subsystem 1 - Part No SW: -----------    HW: 454 000 403 19
   Serial number: 3570000000037B51D83N
   Subsystem 2 - Part No SW: -----------    HW: 454 000 303 19
   Serial number: 3580000000097720983I
   Subsystem 3 - Part No SW: -----------    HW: 454 800 602 19
   Serial number: 351004F80A517000000G
   Subsystem 4 - Part No SW: -----------    HW: 454 801 602 19
   Serial number: 352007B11EE17000000N
   Subsystem 5 - Part No SW: -----------    HW: 454 801 402 19
   Serial number: 3550070E76717000000J
   Part No SW: 17A 920 790 A    HW: 17A 920 790 A
   Component: KOMBI         508 1701
   Coding: 05A4020E6F800008018863031001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001026
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
   VCID: 2517F61F556C71BF9A1-8070
   Component: GW MQB High   442 4367
   Revision: --------    Serial number: 0009179686
   Coding: 030100046F085600FA0002581C0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 6E85C933C01A72E72BB-803A
   Component: 0-00-00-00-00
   Subsystem 2 - Part No SW: 5NA 959 442 B    HW: 5NA 959 442 B
   Component: E221__MFL-TAT  H06 0025
   Serial number: 0361903350400330FH2B
   Coding: 2D0000
   Serial number: 2374060505
   Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
   Component: TSG FS        006 0246
   Serial number: 0000365444690
   Coding: 003A03208000028000001000
   VCID: 48C95FAB823E8CD7417-801C
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000027637812
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Coding: 151F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B1DB5BAE365837DDF-8020
   Component: FCM MQB Low   002 0345
   Serial number: 24021910520207
   Coding: 000000070900204200000900000000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW27.rod
   VCID: 3537265FE5CC013F2A1-8060
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000367262717
   Coding: 003A01208000028000001000
   VCID: 47CB5C978F2083AF48D-8012
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000027698175
   Coding: 190000
   Part No SW: 3Q0 035 864 C    HW: 3Q0 035 864 C
   Component: MU-S-N-ER     853 0890
   Coding: 02720601BE0000004111000100080A001F0500E401200000CE
   ROD: EV_MUStd4CDELP_VW27.rod
   VCID: 313F124F11A42D1F769-8064
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZJW0632648
   Subsystem 2 - Part No SW: 5NA 919 866 AG    HW: -----------
   Component: ECE AS 2020  --- 1310
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------
   Coding: 02720601EA42180D3F1CBE000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW27.rod
   VCID: 3D273E7FDDFCD97FE21-8068
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H11 0610
   Serial number: 25021915K21918
   Coding: 0002070600000401002213448150A90084000E20000000
   ROD: EV_MFKBoschMQBB_002_VW27.rod
   VCID: 40D9478BAA0EB497897-8014
   Part No SW: 7P5 941 591 AH    HW: 7P5 941 591 A
   Component: LED1L         H07 0009
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW27.rod
   VCID: 025D8D83E4826687DF3-8056
   Component: LED1R         H07 0009
End----------(Elapsed Time: 01:30, VBatt start/end: 12.4V/12.4V)-----------
Address 09,5Q0 937 084 DC,channel ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,adapted from,not active ,to,active ,
VCDS Release 19.6.2:  SRI Reset-SRI3.CLB
Control Module Part Number: 17A 920 790 A       Labels:  .*5G0-920-XXX-17.clb-SRI3
Component:KOMBI         508 1701, Coding:05A4020E6F800008018863031001000000000000
Channel        Description                                                 	Current val.                                                	New val.
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                	no warning                                                  	---
IDE00510-ESI: distance driven from inspection                                                       	ESI: Distance since Inspection                              	26192 km                                                    	---
IDE00511-ESI: time from inspection        ESI: Time since Inspection                                  	260 d                                                       	---
IDE00515-ESI: oil quality        ESI: Oil Quality                                            	good oil quality                                            	---
IDE00517-ESI: soot entry        ESI: Soot Quantity                                          	0 km                                                        	---
IDE00518-ESI: thermal load        ESI: Thermal Load                                           	37500 km                                                    	---
IDE01153-SIA: maximum value of distance to service                                                  	SIA: Maximum Distance to Service                            	15000 km                                                    	---
IDE01154-SIA: maximum value of time to service                                                      	SIA: Maximum Time to Service                                	365 d                                                       	---
IDE03349-FIX: Max. distance until next mileage-related inspection                                   	FIX: Maximum Distance to Inspection                         	30000 km                                                    	---
IDE03350-FIX: Maximum time until next time-dependent inspection                                     	FIX: Maximum Time to Inspection                             	730 d                                                       	---
IDE03351-FIX: Distance covered since last mileage-dependent inspection                              	FIX: Distance since Inspection                              	26100 km                                                    	---
IDE03352-FIX: Time since last time-dependent inspection                                             	FIX: Time since Inspection                                  	260 d                                                       	---
^^^Adam: congrats on the new car - and welcome to the mystical and magical world of VCDS!!;)
I'm by no means an authoritative forum member when it comes to the black arts of interpreting DTCs - but as a general approach, I always find it illuminating to reference both the date-time, mileage of the first part of the auto-scan, and the same info on the actual DTC (including the "Fault frequency")
In your auto-scan, my approach suggests as follows for example:
The scan was taken on Friday,29,November,2019 @ 23:08:20 (wow - you were up late at night!) and the mileage was 26192km
Let's take the DTC on the Address 02 module:
U0103 00 [008] - -
Mileage: 25289 km
Date: 2019.09.23
Time: 18:48:58
Because the Fault Frequency=1, this data tells you that the error was first recorded on 23rd September 2019 (i.e. when the car was not in your possession) and that the fault has not re-occurred on any subsequent ignition cycle. So - because the DTC was recorded about two months ago and because the car has traveled about 900 kms since that first (and only) recorded error - it's fair to say (I think) that this is what accountants would call an "aged" DTC.
Also, notice that at the very same time (almost to the second), the BCM (address 09) has recorded another DTC. So it's entirely possible that the two DTCs are related
In any event - the DTCs appear to be intermittent (and "aged") - so even if you raised these as a warranty matter, it will be very difficult to fault trace the original problem. This appears to be the general trend with the DTCs throughout your autoscan report. Probably better to just clear the errors and keep a record of the auto-scan in case they re-appear - I think. Of course if the DTCs reappear after clearing, it my be prudent to have a deep and meaningful chat to the dealer - I think!
PS: the tweak that you implemented to put a switch on the MENU to turn OFF/ON the DRLs - shouldn't be a problem in respect of the DTCs
Spacewalker
Poland
C?ID=159607
Are you able to read adapt from 17 and 5F ?
