New Polo cruise control/speed limiter change.
Dp41n8w
Finland
C?ID=372411
Hello. Does anybody know is there any change code cruise control to car where is only speed limiter? what kind of modifications does it need? Different switch to limiter/cruise control? Can it be done just that easy?
Thanks!
Here´s autoscan
Friday,29,November,2019,08:00:14:19148
VIN: WVWZZZAWZKY018972   License Plate: POLO LA
Mileage: 32621km-20269mi   Repair Order:
Chassis Type: AW-VW27 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 44 5F
VIN: WVWZZZAWZKY018972   Mileage: 32621km-20269miles
Address 01: Engine (J623-DKLA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 B    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6249
   Revision: D7H20000
   Coding: 01250032230415080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM10TFS01104C906025B 002004
   ROD: EV_ECM10TFS01104C906025B_002_VW27.rod
   VCID: 1F1BE36BE739703FD0D-804A
40572 - Unknown Error Code
          U3501 00 [032] - -
                    Mileage: 32621 km
                    Date: 2019.11.27
                    Time: 16:24:50
                    Engine speed: 0.00 /min
                    Coolant temperature: 45 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 8.940 V
                    Outside air temperature: 10 °C
                    Absolute intake pressure: 97 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel: tank fill level: 29.0 l
                    Oxygen sensor bank 1 sensor 1: specified value: 15.9998
                    Particulate filter: loading stage: 0
                    Overrun cut-off-Bits 0-7: 0
34279 - Reset-Resistant Limp-Mode Active
          P1680 00 [032] - -
                    Mileage: 32621 km
                    Engine speed: 8781.50 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: 18 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 6.220 V
                    Outside air temperature: 215 °C
                    Absolute intake pressure: 85 kPa abs
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
   Part No SW: 0CW 300 042 D    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1607
   Revision: 00005008    Serial number: CU501807167282
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: 372B2BCB6FC9287F38D-8062
10810 - Function Restricted due to Insufficient Voltage
          U1400 00 [040] - -
                    Mileage: 32621 km
                    Date: 2019.11.28
                    Time: 07:55:21
                    Engine speed: 4.75 /min
                    Engine torque: -100 Nm
                    Vehicle speed: 60 km/h
                    Control Module temperature: -20 °C
                    CURRENT pressure: -9.5 bar
                    Clutch: primary stat: Driving
                    selected gear: GANG_3
                    Driving position: N
                    Accelerator position: 0.0 %
                    DTC memory status: 45824
10821 - System Voltage
          P0562 00 [040] - Too Low
                    Mileage: 32621 km
                    Date: 2019.11.27
                    Time: 16:50:03
                    Engine speed: 5.25 /min
                    Vehicle speed: 65 km/h
                    Driving position: N
                    DTC memory status: 48640
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 2Q0 614 517 AD    HW: 2Q0 614 517 N
   Component: ESC_base_vFGS H23 0223
   Serial number: 08508241180729
   Coding: 0A034B64154250B5D205A81D24DC42A649124526226A245844541254452442659248A2644456241A222A482AA249D64A3D926B52BC
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
   ROD: EV_Brake1BOSCHESPMQBA0.rod
   VCID: 70B9D0D74A27BF47397-8024
0142 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [HydraulicSupplyUndervoltage]
                    Reset counter: 146
                    Mileage: 32621 km
                    Date: 2019.11.27
                    Time: 16:22:47
0462 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [NET_Undervoltage]
                    Reset counter: 146
                    Mileage: 32621 km
                    Date: 2019.11.27
                    Time: 16:23:14
1384 - Supply Voltage for ABS Valves
          C106A 16 [008] - Voltage Too Low
                    Reset counter: 146
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 2G1 820 045 G    HW: 2G1 820 045 G
   Component: SG_AC_Manuell H50 0301
   Coding: 012000000800010001000800020000000000000000000000000000000000
   ASAM Dataset: EV_ACManuePrehMQBA0 001011
   ROD: EV_ACManuePrehMQBA0_VW27.rod
   VCID: 2411EC87CE5F53E78DF-8070
   Part No SW: 2Q0 937 090 A    HW: 2Q0 937 090
   Component: BCM A0 Std+   H98 0926
   Serial number: 00001822401150
   ASAM Dataset: EV_BCMA0 204001
   ROD: EV_BCMA0_204.rod
   VCID: 303910D78AA7FF47797-8064
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 2Q1 959 881     HW: 2Q1 959 881
   Component: FHSG_DRV  001 0001
   Serial number: 00000000000023330082
   Coding: 130000
   Subsystem 2 - Part No SW: 2Q1 959 882     HW: 2Q1 959 882
   Component: FHSG_PSG  001 0001
   Serial number: 00000000000023298802
   Coding: 090000
   Serial number: 000000000ZY181422C2B
   Serial number: 00000000000099434613
   Subsystem 5 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Serial number: 00000000000023482456
   Coding: 030000
   Subsystem 6 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Serial number: 00000000000023475805
   Coding: 1B0000
21 Faults Found:
131330 - Supply voltage
          [Versorgungsspannung -unterer Grenzwert unterschritten>]
                    Reset counter: 146
                    Mileage: 32621 km
                    Date: 2019.11.27
                    Time: 16:50:06
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: On
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beam: not activated
                    Zusaetzliche Umgebungsdaten-OFF: not activated
                    Zusaetzliche Umgebungsdaten-Outside air temperature: 0
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: not activated
                    Zusaetzliche Umgebungsdaten-Parking light: not activated
                    Zusaetzliche Umgebungsdaten-Parking light left: not activated
                    Zusaetzliche Umgebungsdaten-Parking light right: not activated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: 33
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 8.1 V
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung -unterer Grenzwert unterschritten>]
                    Reset counter: 146
                    Mileage: 32621 km
                    Date: 2019.11.27
                    Time: 16:48:38
                    Zusaetzliche Umgebungsdaten-voltage measurement: 8.5 V
132363 - Voltage Supply; Terminal 30; Left
          B140D 13 [008] - Open Circuit
                    Reset counter: 143
                    Mileage: 32567 km
                    Date: 2019.10.03
                    Time: 15:41:04
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: OFF
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: operated
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.1 V
133131 - Voltage Supply Terminal 30
          B1423 13 [008] - Open Circuit
                    Reset counter: 143
                    Mileage: 32567 km
                    Date: 2019.10.03
                    Time: 15:41:04
134155 - Voltage Supply for Terminal 30 of Signal Horn
          B1898 13 [008] - Open Circuit
                    Reset counter: 143
                    Mileage: 32567 km
                    Date: 2019.10.03
                    Time: 15:41:04
134667 - Voltage Supply for Terminal 30 of Exterior Mirror Heating
          B1900 13 [008] - Open Circuit
                    Reset counter: 143
                    Mileage: 32567 km
                    Date: 2019.10.03
                    Time: 15:41:04
134923 - Voltage Supply for Terminal 30 of Rear Window Heating
          B1901 13 [008] - Open Circuit
                    Reset counter: 143
                    Mileage: 32567 km
                    Date: 2019.10.03
                    Time: 15:41:04
136740 - Unknown Error Code
          B18FB F0 [008] - Unknown Error Elaboration
                    Reset counter: 125
                    Zusaetzliche Umgebungsdaten-last wakeup: 45
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.2 V
262936 - Sensor for anti-theft alarm system
          B1330 29 [008] - Signal Implausible
                    Reset counter: 144
                    Mileage: 32569 km
                    Date: 2019.10.08
                    Time: 17:31:20
264452 - No Communications with Anti-Theft Sensor
          U10F4 00 [008] - -
          [Sensor-DWA->kein Signal/ Kommunikation]
                    Reset counter: 143
                    Mileage: 32567 km
                    Date: 2019.10.03
                    Time: 15:41:04
331786 - Relay Output for Heated Exterior Mirror(s)
          B1730 15 [008] - Open or Short to Plus
                    Reset counter: 143
                    Mileage: 32567 km
                    Date: 2019.10.03
                    Time: 15:41:04
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.0 V
460042 - Heated Rear Window
          B1265 15 [008] - Open or Short to Plus
                    Reset counter: 143
                    Mileage: 32567 km
                    Date: 2019.10.03
                    Time: 15:41:04
589826 - Window Regulator; Rear Driver side
          B131F F5 [008] - Supply Voltage too Low
                    Reset counter: 146
                    Mileage: 32621 km
                    Date: 2019.11.28
                    Time: 06:58:57
                    Zusaetzliche Umgebungsdaten-last wakeup: 43
590084 - Window Regulator Motor; Rear Driver Side
          U1211 00 [008] - No Communications
          [Motor für Fensterheber hinten Fahrerseite-> keine Kommunikation]
                    Reset counter: 143
                    Mileage: 32567 km
                    Date: 2019.10.03
                    Time: 15:41:04
590338 - Window Regulator; Front Passenger side
          B1320 F5 [008] - Supply Voltage too Low
                    Reset counter: 146
                    Mileage: 32621 km
                    Date: 2019.11.28
                    Time: 06:57:40
590596 - Window Regulator Motor; Rear Passenger Side
          U1213 00 [008] - No Communications
          [Motor für Fensterheber hinten Beifahrerseite-> keine Kommunikation]
                    Reset counter: 143
                    Mileage: 32567 km
                    Date: 2019.10.03
                    Time: 15:41:04
591108 - Window Regulator Motor; Front Driver Side
          U120D 00 [008] - No Communications
          [Motor für Fensterheber vorn Fahrerseite-> keine Kommunikation]
                    Reset counter: 143
                    Mileage: 32567 km
                    Date: 2019.10.03
                    Time: 15:41:04
592388 - Window Regulator Motor; Front Passenger Side
          U120F 00 [008] - No Communications
          [Motor für Fensterheber vorn Beifahrerseite-> keine Kommunikation]
                    Reset counter: 143
                    Mileage: 32567 km
                    Date: 2019.10.03
                    Time: 15:41:04
660498 - Program Monitoring
          B201B 00 [008] - -
          [LHR 01 - Fehlerhafte LIN-Kommunikation]
                    Reset counter: 143
                    Mileage: 32567 km
                    Date: 2019.10.03
                    Time: 15:41:04
919560 - Light Switch
          B126A 29 [008] - Signal Implausible
                    Reset counter: 143
                    Mileage: 32567 km
                    Date: 2019.10.03
                    Time: 15:34:39
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: OFF
950278 - Light recognition sensor
          B13CA 15 [008] - Open or Short to Plus
                    Reset counter: 143
                    Mileage: 32567 km
                    Date: 2019.10.03
                    Time: 15:41:04
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418018194
   Coding: 0471051011
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   ROD: EV_EPHVA18AU3700000_009_VW27.rod
   VCID: 4CC16427064FBBA765F-8018
13635840 - Supply voltage
          [Versorgungsspannung - zu niedrig]
                    Reset counter: 146
                    Mileage: 32621 km
                    Date: 2019.11.27
                    Time: 16:48:14
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
                    Reset counter: 146
                    Mileage: 32621 km
                    Date: 2019.11.27
                    Time: 16:46:54
   Component: ACCCONTIMQB   H03 0233
   Coding: 3200600200FF8748949C8145004087
   VCID: 3E253EEF40F31937FBB-806A
1389 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [FAULT_VBAT_BUSMON_LOW]
                    Reset counter: 146
                    Mileage: 32621 km
                    Date: 2019.11.27
                    Time: 16:24:58
                    Voltage terminal 15: 8.9 V
                    Control Module temperature: 52 °C
                    Longitudinal_acceleration_vehicle_reference: 0.03 m/s²
   Part No SW: 2Q0 959 655 AG    HW: 2Q0 959 655 AG
   Component: VW22Airbag    010 0248
   Revision: --------
   Coding: 88CCC0C0000000005C5400CF000800000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 025D8A1F748BBDD7DF3-8056
   Subsystem 1 - Part No SW: -----------    HW: 442 061 008 18
   Serial number: 3577Y20C1279D040E42/
   Subsystem 2 - Part No SW: -----------    HW: 442 061 008 18
   Serial number: 3587Y209B2833DB34412
   Subsystem 3 - Part No SW: -----------    HW: 442 0B0 108 18
   Serial number: 3517783BD2958602E17Q
   Subsystem 4 - Part No SW: -----------    HW: 442 0B0 108 18
   Serial number: 3527783C72B0ECC1726Z
   Subsystem 5 - Part No SW: -----------    HW: 442 132 607 18
   Component: FrontSensor_D  290 118A
   Serial number: 355AG11A929B6A41F5E8
   Part No SW: 2G0 920 740 C    HW: 2G0 920 740 C
   Component: KOMBI         310 2500
   Coding: 04A4010821800008018822011001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001029
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
   VCID: 221DEA9FD44B5DD7FF3-8076
          [Versorgungsspannung - unterer Grenzwert unterschritten Versorgungsspannung Spannung dauerhaft zu niedrig]
                    Reset counter: 146
                    Mileage: 32621 km
                    Date: 2019.11.27
                    Time: 16:49:42
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   439 4344
   Revision: --------    Serial number: 0008339837
   Coding: 030100046F085600FA0000481C0F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF.rod
   VCID: 3D2739E34DF5022FE21-8068
   Subsystem 2 - Part No SW: 2G0 959 442 K    HW: 2G0 959 442 K
   Component: E221__MFL-DC1  H02 0052
   Serial number: 39180001438260028291
   Coding: 24FFFF
   Subsystem 3 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
   Component: J367-BDMBOSCH  H02 2011
   Serial number: 10091640
1282 - Supply voltage
          [Versorgungsspannung - unterer Grenzwert unterschritten]
                    Reset counter: 146
                    Mileage: 32621 km
                    Date: 2019.11.27
                    Time: 16:47:32
                    Supply voltage: Terminal 30: 8.4 V
                    Terminal 15: On
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Ruhestrom oberer Grenzwert überschritten]
                    Fault Frequency: 25
                    Reset counter: 143
                    Mileage: 30530 km
                    Date: 2019.09.01
                    Time: 18:31:37
                    Supply voltage: Terminal 30: 12.1 V
                    Terminal 15: OFF
8526361 - LV Energy Management
          B1802 F1 [009] - Warning Triggered
                    Reset counter: 106
                    Mileage: 32570 km
                    Date: 2019.11.06
                    Time: 13:17:08
                    Supply voltage: Terminal 30: 11.2 V
                    Terminal 15: On
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q1 909 144 M    HW: 2Q1 909 144 F
   Component: TRW_G4L_MQBA0 611 6041
   Serial number: 00695767CP3J240
   Coding: 010000000000000001010201010001000000010101
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
   ROD: EV_SteerAssisTRWG4LMQBA0.rod
   VCID: 3C2134E756EF0B27D5F-8068
10492416 - Supply voltage
          [DEM_LOW_BATT_FAULT]
                    Reset counter: 146
                    Mileage: 32621 km
                    Date: 2019.11.27
                    Time: 16:19:01
                    Engine speed: 0 /min
                    System status: Cut_off
                    Voltage terminal 30: 9.86 V
                    Power steering current consumption: 0.5 A
                    max.value: 13.1 A
                    End stage temperature: 15 °C
                    Steering assistance: engine output: 100 %
                    Engine angle: 141 °
                    Electric motor speed: 0 /min
                    Steering assistance: target engine torque: 0.0 Nm
                    Steering torque: 0.0 Nm
10591488 - Internal Fault
          B200F F0 [008] - Unknown Error Elaboration
          [DEM_LATE_HALL_EDGE_FAULT]
                    Reset counter: 67
                    Mileage: 31904 km
                    Date: 2019.09.12
                    Time: 20:48:48
                    Engine speed: 974 /min
                    System status: Driving mode
                    Voltage terminal 30: 13.26 V
                    max.value: 0.6 A
                    End stage temperature: 31 °C
                    Engine angle: 9 °
                    Steering torque: 0.2 Nm
   Part No SW: 3Q0 035 819 C    HW: 3Q0 035 819 C
   Component: MU-S--ER      H41 0472
   Serial number: VWZAZ2U1142054
   Coding: 02720000BE0000004111000100090A001F0500C40120010001
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 313F15D381ADF64F769-8064
   Subsystem 1 - Part No SW: 5G6 919 605     HW: 5G6 919 605
   Component: ABT_Std-2  H52 8130
   Serial number: VWZ6ZJV2060325
1537 - Supply voltage
          [Supply voltage - lower limit value not reached]
                    Reset counter: 146
                    Mileage: 32621 km
                    Date: 2019.11.27
                    Time: 16:24:15
                    Voltage terminal 30: 9.1 V
          U1400 00 [008] - -
          [Function restriction due to insufficient voltage - lower limit value not reached]
                    Reset counter: 146
                    Date: 2019.11.28
                    Time: 07:56:00
                    Voltage terminal 30: 5.8 V
End----------(Elapsed Time: 01:00, VBatt start/end: 12.6V/12.6V)-----------
Mari
C?ID=150535
On a Golf MK7 there is a button on the MFSW to switch between modes (limiter/CC), don't know if the Polo works the same way.
Start with clearing the fault-codes and see which of them come back! Fix the ones that come back!
Dp41n8w
Finland
C?ID=372411
I cleared all faults and none of them come back. There was bad battery what caused those fault in memories. Also I have checked that there is no button. Friend of mine told me that some of the models in some country do have only limiter. I don´t know if that´s true.
Dp41n8w
Finland
C?ID=372411
Thought that if VW has put some secret coding options in 13 or 09... or somewhere
Dp41n8w
Finland
C?ID=372411
Steering wheel buttos must change also. I guess that isnt only coding...
iichel
Eindhoven, NB, NL
C?ID=284912
Remember to do SWaP as well
Dp41n8w
Finland
C?ID=372411
I took today other polo autoscan. There is Cruise control and limiter. CM 13 part number is same, coding is different. Abs CM part number is different ( Last digit) also coding is different ofcourse. I tooked admaps from both cars and there is same channels and numbers. Im not sure is the abs module so different that it have to change...
Dp41n8w
Finland
C?ID=372411
That autoscan is from car where is limiter and cruise control
Monday,02,December,2019,15:13:42:19148
VIN: WVWZZZAWZJY071433   License Plate: GMX-148
Mileage: 55710km-34616mi   Repair Order: POLO18
Chassis Type: AW-VW27 (2Q0)
Scan: 01 03 08 09 13 15 17 19 44 5F
VIN: WVWZZZAWZJY071433   Mileage: 55710km-34616miles
Address 01: Engine (J623-CHYB)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 057 AP    HW: 04C 907 309 BE
   Component: R3 1.0l MPI   H20 4248
   Revision: 33H20000
   Coding: 01110012022405080000
   ASAM Dataset: EV_ECM10MPI01104C906057AP 001002
   ROD: EV_ECM10MPI01104C906057AP_VW27.rod
   VCID: 73B3DFDB3B31845FC45-8026
Readiness: 1110 0001
   Part No SW: 2Q0 614 517 AA    HW: 2Q0 614 517 N
   Component: ESC_base_vFGS H23 0222
   Serial number: 08500129171123
   Coding: 09034A64154890AE5200A81924DD42A649124926114A24584454125445244265924892648852241A222A482AA249D6423D926B42BC
   Shop #: WSC 29204 001 1048576
   VCID: 6D87C9A35D1552AF121-8038
   Coding: 012000000800010011000400020000000000000000000000000000000000
   Part No SW: 2Q0 937 089     HW: 2Q0 937 089
   Component: BCM A0 Std    H97 0915
   Serial number: 07001734900031
   VCID: 77ABEBCB2F49E87FF8D-8022
   Serial number: 00000000000017745758
   Coding: 130000
   Serial number: 00000000000017889151
   Coding: 090000
   Subsystem 3 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Serial number: 00000000000017999827
   Coding: 030000
   Subsystem 4 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Serial number: 00000000000018033668
   Coding: 1B0000
8202 - Bulb for Left DRL
          B121D 15 [009] - Open or Short to Plus
                    Reset counter: 208
                    Mileage: 55710 km
                    Date: 2019.11.28
                    Time: 00:04:53
                    Zusaetzliche Umgebungsdaten-voltage measurement: 13.3 V
8458 - Bulb for Right DRL
          B121E 15 [009] - Open or Short to Plus
                    Reset counter: 208
                    Mileage: 55710 km
                    Date: 2019.11.28
                    Time: 00:04:53
590853 - Window Regulator; Front Drivers Side
          B14D1 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 208
                    Mileage: 55710 km
                    Date: 2019.11.28
                    Time: 00:04:51
                    Zusaetzliche Umgebungsdaten-voltage measurement: 13.5 V
592133 - Window Regulator; Front Passenger Side
          B14D2 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 208
                    Mileage: 55710 km
                    Date: 2019.11.28
                    Time: 00:04:51
   Component: ACCCONTIMQB   H02 0233
   Coding: 2A00600100F78748949C8145004087
   Part No SW: 2Q0 959 655     HW: 2Q0 959 655
   Component: VW22Airbag    010 0246
   Revision: --------
   VCID: 7AADF2FF1C5BF517873-802E
   Subsystem 1 - Part No SW: -----------    HW: 442 060 911 17
   Serial number: 3577Y21AB263F3C2E07F
   Subsystem 2 - Part No SW: -----------    HW: 442 060 911 17
   Serial number: 3587Y21C326068A0C2C4
   Subsystem 3 - Part No SW: -----------    HW: 442 0B1 210 17
   Serial number: 3517735C52839F5293AS
   Subsystem 4 - Part No SW: -----------    HW: 442 0B1 210 17
   Serial number: 3527735C92839F54001E
   Subsystem 5 - Part No SW: -----------    HW: 442 130 311 17
   Serial number: 355AG11A927CBDB42283
   Part No SW: 2G0 920 730 A    HW: 2G0 920 730 A
   Component: KOMBI         209 0460
   Coding: 04A4010021000008018800010000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001020
   Part No SW: 2Q0 909 901     HW: 2Q0 937 089
   Component: GW MQB A0     H97 0915
   Coding: 030000046F086400F8000048080E00010001070000000000000000000000
   ASAM Dataset: EV_GatewA0 013020
   ROD: EV_GatewA0_VW27.rod
   VCID: 6FBBD3AB5719A0BF20D-803A
   Subsystem 2 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
   Serial number: 1002CB81
   Component: TRW_G4L_MQBA0 610 6041
   Serial number: 0253856CB2H3421
   Part No SW: 17A 035 869     HW: 17A 035 869
   Component: MU-E--ER      671 8732
   Serial number: 05121700011146
   Coding: 027200003C00000041110001000002001F0000C40000010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001041
   ROD: EV_MUEnt4CGen2LGE_VW27.rod
   VCID: 6889B8B772F77787617-803C
End----------(Elapsed Time: 00:39, VBatt start/end: 13.5V/13.5V)-----------
Dp41n8w
Finland
C?ID=372411
I guess that is just try and figure it out? ��
Dp41n8w
Finland
C?ID=372411
There is avalibe ccs set for Polo. There comes steering wheel buttons, wires and new stalk.
vastechnics
C?ID=143747
Remember this is Polo 2G. There is no such set available yet! They do it otherway. I do research now some to do with Skoda.
vastechnics
C?ID=143747
Yes but the SWAP code they use is from other car not polo aw because polo aw no have swap for ccs. I have try from skoda no work. I now try other tomorrow
sportmotor
Czech Republic
C?ID=14747
But 599 EUR for Cruise control is little bit nonsense.
