VW T5.1 Caravelle MFSW retrofit
Limalex
London
C?ID=260940
Hello Gents,
I fitted a Passat B7 Paddle Shift MFSW
It does lit up and the paddles working, but none of the buttons are.
Repir wires fitted in position 9 to 12V live and position 10 to BCM position 17
MFSW activated with VCDS and still no luck
here is my scan.
Any opinion would be appresiated
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 0D 10 15 17 18 19 25 56 69 6C 78 0B
VIN: WV2ZZZ7HZCH133237   Mileage: 133710km-83083miles
0D-Slide Door, Left -- Status: OK 0000
6C-Back-up Cam. -- Status: Cannot be reached 1100
78-Slide Door, Right -- Status: OK 0000
Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 022 JD    HW: 03L 907 309 H
   Component: R4 2,0L EDC   H36 9112
   Revision: 22H36---    Serial number: 00000000000000
   Coding: 0125401A232400080000
   Shop #: WSC 02756 790 50316
   ASAM Dataset: EV_ECM20BTD01103L906022JD 002012
   ROD: EV_ECM20BTD01103L906022JD_002.rod
   VCID: 70ACD288AB2E1FCF57-8024
   Part No SW: 0BT 300 045 M    HW: 0BH 927 711 C
   Component: DSG DQ500-7F  H05 1710
   Revision: 00H05V01
   ROD: EV_TCMDQ500021_VW36.rod
   VCID: 3FCE41B4A6F0B0B79E-806A
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 J    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0109
   Revision: 00H43001
   Coding: 108764AD09A7089826A49074AA6510
   Shop #: WSC 02756 790 49152
   VCID: 393A2FACB0D49E87A0-806C
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 7E5 907 040 AC    HW: 7E5 907 040 AC
   Component: ClimatronicT5 H19 0407
   Revision: 00001003
   Coding: 0004000102
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 699ABFEC88F4EE0710-803C
   Slave 1:
   Subsystem 1 - Part No SW: 7E5 907 049 B    HW: 7E5 907 049 B
   Component: Heckbedienung  H10 0202
   Serial number: BHB-0012304120015096
   Part No SW: 7H0 937 087 H    HW: 7H0 937 087
   Component: BCM T5GP H+4  H47 0254
   Revision: BO047001    Serial number: 0429 108120725
   Coding: A0B2793A0E612413932888106C2B8ED50080410F60844000300003000000
   Shop #: WSC 02756 790 12345
   Component: RLS 180412 05  54  0403
   Coding: 02302E
   Subsystem 2 - Part No: 7E1 951 171
   Subsystem 4 - Part No: 7E1 951 171
                    Reset counter: 76
                    Mileage: 133710 km
                    Date: 2014.04.19
                    Time: 23:50:13
                    Reset counter: 76
                    Mileage: 133710 km
                    Date: 2014.04.19
                    Time: 23:50:13
Address 0D: Slide Door, Left        Labels: Redir Fail!
   Part No: 7E0 959 243 D
   Component: Schiebetuer-SG  407 0328
   Shop #: WSC 02756 790 00000
   VCID: 302C1288A3AE5FCF17-8064
   Part No SW: 7E0 919 475 E    HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H11 0013
   Revision: --------    Serial number: 47461208500166
   Coding: 108102
   ASAM Dataset: EV_VW75XParkAssis8K A01005
   ROD: EV_VW75XParkAssis8K_A01.rod
   VCID: 34241E989FB663EF73-8060
   Part No SW: 7E0 959 655 C    HW: 7E0 959 655 C
   Component: VW10Airbag00P H07 0013
   Revision: --------    Serial number: 003HM002866L
   Coding: 000000000000000000000000000000003050
   Shop #: WSC 02754 790 50316
   VCID: 3620249089CA71FF4D-8062
   Serial number: 3495ZRB405B0P7HOEHCF
   Serial number: 3505ZRB40510P7AOGGM1
   Part No SW: 7E0 920 980 E    HW: 7E0 920 980 E
   Component: KOMBI         H04 0306
   Coding: 460F01
   VCID: 2D120BFC7C9C32273C-8078
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 815 071 B
   Component: J737__Standheizung  0605
   Revision: 00085000    Serial number: 09019275F00000
   Coding: 0000031
   Shop #: WSC 02757 790 00000
   VCID: 2404EED8E756F36FE3-8070
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 H47 0254
   Revision: BO047001
   Coding: 042300
   VCID: 70ACD288A32E1FCF57-8024
01304 - Radio
                    Reset counter: 76
                    Mileage: 133710 km
                    Date: 2014.04.19
                    Time: 23:50:14
                    Reset counter: 76
                    Mileage: 133710 km
                    Date: 2014.04.19
                    Time: 23:50:13
   Component: IMMO          H04 0306
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A98C0E08DF2E51F19-803E
Address 56: Radio
   Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Component: Anhaenger     H12 0130
   Revision: 3B001001    Serial number: 00000509112665
   Coding: 0100000101000000
   VCID: 322818806DA26DDF61-8066
Address 6C: Back-up Cam.
Address 78: Slide Door, Right        Labels: Redir Fail!
End----------(Elapsed Time: 02:24, VBatt start/end: 12.4V/12.2V)--
dnoermann
C?ID=358118
Reset counter: 76
Mileage: 133710 km
Date: 2014.04.19
Time: 23:50:13
Reset counter: 76
Mileage: 133710 km
Date: 2014.04.19
Time: 23:50:13
Looks like you disconnected the LinBus which is going to your door controllers by connecting your MFSW.
Normly those share the same Linbus pin 17 on BCM.
Try disonnecting your wire there and look if erros in BCM regarding doors is gone.
If yes, than your wire is probably connecting not to the LIN Bus from MFSW.
Check that wiering.
Limalex
London
C?ID=260940
Check that wiering.
Thank you Sir,
That faults possibly from previous work i have done and maybe has not been erased yet, but double check tomorrow.
If not pin 17 the right Location how can i figure out the right one ?
dnoermann
C?ID=358118
The Error regarding the Door Controllers is still there.
In your scan the Door Controllers as subsystems of the BCM are missing.
See here, my Autoscan: https://uk-polos.net/viewtopic.php?f=56&t=70203&start=75#p561789
There you see
   Subsystem 2 - Part No SW: 7E0 959 801 J    HW: 7E0 959 801 J  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8652
   Serial number: KU0KU008101300018609
   Coding: 0400A1
   Subsystem 3 - Part No SW: 7E0 959 802 J    HW: 7E0 959 802 J  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8652
   Serial number: KU0KU002101300011203
   Coding: 1400A1
And that is missing in your scan.
TSG ==> "Tür Steuergerät" ==> DoorController
FT Fahrertür ==> DriverDoor
BT Beifahrertür ==> PassengerDoor
And i am pretty shure that those are miising because of that you jammed up the Linbus who connects BCM and the Door Controllers.
Probably by connecting BCM Pin 17 to GND or 12V.
Or did you just put the origibnal wire out of Pin 17 on BCM ?
Get the original VW Shematic to better understand what you are doing.
Limalex
London
C?ID=260940
There you see
   Coding: 0400A1
   Coding: 1400A1
I just checked the wiring and the one was attached to the pin 17 somehow slipped off maybe because i did not soldered them. I used clamp instead. I Erased the fault codes and all buttons work fine. No fault in the latest scan.
dnoermann
C?ID=358118
Congrats, so your issue is solved now compleetely ?
Mari
C?ID=150535
... next time make good wire connections :)
Limalex
London
C?ID=260940
Yes finally :), but according to your project maybe new issues will come soon :)
Limalex
London
C?ID=260940
Well... Yes I thought I did, and did not even think that the connection causes the issues :)
