New User - Converting Beetle 5c from US to EURO specs
nadiundwolle
UC152825 (2nd Hand?)
hi there,
i am about to convert my beetle to EURO spec, in order to take it back to germany.
now i am in need of some help from you guys:
1.) Need a rear fog light
Already have the EURO light switch, and am about to run the trigger wire to the ECM.
Need to do the coding for that, anyone an idea. I do have access to a friends VCDS at the moment.
As an alternative: is it possible to change the rear lights to only one back up light on the right, and use the left back-up light as rear fog? (with a red bulb of course) so i wouldnt need a new reflector for the bumper...
2.) Need to get the EURO light switch working right
Currently as the DRL are on, they will turn off, if i switch to parklights. Anyone some ideas about coding?
Most of the other stuff, like orange indicators will be handled with the original Euro taillights i got on order.
Would appreciate your help here...
Wolfgang
nadiundwolle
Just finished it...
VCDS Version: Release 12.12.2
Data version: 20140212
Tuesday,25,March,2014,19:27:58:42396
Chassis Type: AT (6R0)
Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 44 56 77 B9
VIN: 3VWJL7ATXDM629472
09-Cent. Elect. -- Status: Sporadic communication error 1000
B9-Aux. Display -- Status: Malfunction 0010
   Part No SW: 03L 906 019 AP    HW: 03L 907 309 AA
   Component: R4 2,0L EDC G000AG  4814
   Revision: 12H15---    Serial number:
   Coding: 0050078
   Shop #: WSC 00066 000 00000
   VCID: 79D73A1E307CCED6DC9-802C
   Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3524
   Revision: 05551213    Serial number: 00001208011538
   VCID: 24693B6AE77E633EDFF-8071
   Part No SW: 5C0 907 379 C    HW: 5C0 907 379 C
   Component: ESP MK60EC1   H31 0156
   Revision: 00H31001
   Coding: E14B401649240003870F02EB921B0042A71000
   VCID: 2E7DD94279B2D96E39B-807B
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0182705623
   Coding: 030C0C
   ASAM Dataset: EV_KESSYPQ35G A02014
   ROD: EV_KESSYPQ35G.rod
   VCID: 3449CB2A9F9EF3BE4FF-8061
133124 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 64
                    Mileage: 7481 km
                    Date: 2016.14.30
                    Time: 15:42:20
1069319 - Wake-Up Signal from Control Module for Access/Start Authorization
          U1093 00 [008] - Short to GND
                    Reset counter: 64
                    Mileage: 7481 km
                    Date: 2016.14.30
                    Time: 15:38:04
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 BC    HW: 5C0 820 047 BC
   Component: J301  Klimaanlage   0204
   Revision: 2001111S    Serial number: 00000001183802
   VCID: 62E57D72BDEA2D0EED3-8037
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 088 G    HW: 6R0 937 088 A
   Component: BCM PQ25 Re3  H50 0353
   Revision: BT050001    Serial number: 04551241120432
   Coding: 3BBC6918088B080000A82930240D84C5AD82622F60000C51B2E004000000
   VCID: 42A59DF2DD2A4D0ECD3-8017
   Subsystem 1 - Part No SW: 5C5 959 801 M    HW: 5C5 959 801 M
   Component: J386__TSG_FT  011 1032
   Coding: 800000
   Subsystem 2 - Part No SW: 5C5 959 802 P    HW: 5C5 959 802 P
   Component: J387__TSG_BT  011 1032
   Coding: 800000
   Subsystem 3 - Part No SW: 5C0 959 442     HW: 5C0 959 442
   Component: E221__MFL-YVJ  H02 0103
   Coding: E30000
   Part No SW: 5C0 959 655 Q    HW: 5C0 959 655 Q
   Component: AirbagVW10G   013 0851
   Serial number: 003LKM022DXU
   Coding: 00004E45
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 40A197FADB265F1EDB7-8015
   Serial number: 6940000Y120000HTTR0T
   Coding: 30304C
   Serial number: 3572MSME793A056EZZZ4
   Serial number: 3582MSME2841056EZZZY
   Subsystem 4 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
   Serial number: 3556LSME0B645C1CZZZ2
   Crash sensor for front airbag; passenger side:
   Subsystem 5 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
   Serial number: 3566LSME324A5C1CZZZ1
   Part No SW: 5C5 920 970 G    HW: 5C5 920 970 G
   Component: KOMBI         H23 0103
   Revision: X0023005    Serial number:
   Coding: 250E01
   Shop #: WSC 00066 000 00125
   ASAM Dataset: EV_KombiUDSMM9RM10 A04712
   ROD: EV_KombiUDSMM9RM10_SE12.rod
   VCID: 2F43C44676B8D06632D-807A
Address 19: CAN Gateway (J533)       Labels: 6R0-907-530-V2.clb
   Part No SW: 6R0 907 530 E    HW: 1K0 907 951
   Component: J533  Gateway H38 0041
   Revision:   H38       Serial number: 17091203300297
   Coding: 254080
   VCID: 354FF62E9CE4EAB6781-8060
00457 - Control Module for Network (J519)
                    Fault Status: 00110100
                    Reset counter: 64
                    Mileage: 7481 km
                    Date: 2016.14.30
                    Time: 15:42:21
   Part No SW: 5K0 953 234     HW: 5C5 920 970 G
   Component: IMMO          H23 0103
   Coding: 000007
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   ROD: EV_ImmoUDSMM9RM10_SE36.rod
   VCID: EAF595520DDAF54EA53-80BF
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 12000174969002
   Coding: 4900000000000000
   Shop #: WSC 00066 790 50316
   ROD: EV_ELVMarquMPVW36X.rod
12664832 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 64
                    Mileage: 7481 km
                    Date: 2016.14.30
                    Time: 15:42:19
12665089 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 64
                    Mileage: 7481 km
                    Date: 2016.14.30
                    Time: 15:42:20
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662997872
   Coding: 010100
   VCID: 2A75D552455AB54EE53-807F
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 70     3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 3753FC2646E818A66AD-8062
Address 56: Radio (J503)       Labels: None
   Part No SW: 1K0 035 164 F    HW: 1K0 035 164 F
   Component: LOW NAR SDARS H03 0005
   Revision: -----07S    Serial number: VWZ4Z6M3428682
   Coding: 01000400040002
   VCID: 256F266E2C449A36C81-8070
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007663126577
   Coding: 0A10040000010110
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3A55E512BDFA05CE953-806F
Address B9: Aux. Display (J285)       Labels: None
   Part No SW: 5C5 919 527 C    HW: 5C5 919 527 C
   Component: ZUSATZANZEIGE H16 0014
   Coding: 05
   ASAM Dataset: EV_Auxi_Disp_Unit_UDS_VDD 001007
   ROD: EV_Auxi_Disp_Unit_UDS_VDD.rod
   VCID: 3147C23E608CC696249-8064
2097173 - Databus
                    Reset counter: 64
                    Mileage: 7481 km
                    Date: 2016.14.30
                    Time: 15:42:19
nadiundwolle
any ideas?
