Monday,02,December,2019,18:21:51:39744
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 17.1.3.0 (x64)
License Plate:
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 34 3B 42 44 46 52 53 5F 62
6D 72 85 8B 8E 8F 90 AC
Mileage: 256770km-159549miles
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: OK 0000
Address 01: Engine (J623-CRTE) Labels: None
Part No SW: 4G2 907 311 C HW: 4G2 907 401
Component: 3.0TDI EDC17 H33 0001
Revision: 92H33---
Coding: 32254012056609030000
Shop #: 02391 785 00200
Dataset: EV_EC3M0TDI0114G2907311C 001001
ROD: N/A
VCID: 25462AD6247A4669BA-8070
No data for: "EV_EC3M0TDI0114G2907311C" (AU57)
9645 - ROD - Unknown Error Code
- 00 [032]
Mileage: 256663 km
Date: 2019.11.28
Time: 17:56:34
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 4G0 927 166 G HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H03 0002
Revision: --H03---
Coding: 100001
Dataset: EV_TCMDL501012 001021
ROD: N/A
VCID: 316ECE8660B21AC956-8064
No data for: "EV_TCMDL501012" (AU57)
Address 03: Brakes (J104) Labels: Redir Fail!
Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q
Component: ESP9 Premium H01 0420
Coding: 27A6DE4DE4657BB29B00
Dataset: EV_ESP9BOSHCAU57X 003019
ROD: N/A
VCID: 3F8A98BEA6E6FCB9D0-806A
No data for: "EV_ESP9BOSHCAU57X" (AU57)
Address 05: /Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 FN HW: 4H0 907 064 EN
Component: BCM2 2.0 H36 0560
Coding: 01A9700E000000000000
VCID: 7AFC29AAF5441991A7-802E
Address 08: Auto HVAC (J255) Labels: 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 HW: 4G0 820 043
Component: KLIMA 2 ZONEN H14 0112
Serial number: 18111400110457
Coding: 360211082D0000
Dataset: EV_AriCondiBasisUDS 003009
ROD: N/A
VCID: 61CE7EC670D2EA4986-8034
No data for: "EV_AriCondiBasisUDS" (AU57)
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00000949348001
Coding: 2600001401349FE28981408300001D0C4F9C47082609020100000420610117020040002C030000
VCID: 71EE0E86A8325AC916-8024
Component: WWS57X 141109 H37 0080
Serial number: 141114120242
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 23481868
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 AL HW: 4G0 941 531 AL
Component: E1 - H07 0044
Serial number: 17 11 2014 00000868
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: AF188957000000000001
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Component: ACC3 H21 0053
Coding: 7804010202
Dataset: EV_AdaptCruisContrAU57X 002014
VCID: 295E26E6486262099E-807C
12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [008] - -
Fault Frequency: 81
Reset counter: 96
Mileage: 256647 km
Date: 2019.11.27
Time: 13:15:25
Control Module temperature: 30 °C
Voltage terminal 15: 14.579 V
Velocity_vehicle_reference: -0.00 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Revision: -------- Serial number: 003P1002A110
Coding: 30333130313930313830554A304C34473053
Dataset: EV_AirabAU10BPAAU64X 001014
ROD: N/A
VCID: 3B72ECAEB2FEE099FC-806E
Subsystem 1 - Serial number: 3575HRB405V2QRBI7O4J
Subsystem 2 - Serial number: 3585HRB40572ORMG9OST
Subsystem 3 - Serial number: 3515JRB405R31R1QH07H
Subsystem 4 - Serial number: 3525JRB405T31R1QA039
Subsystem 5 - Serial number: 3554VRB405D332528068
Subsystem 6 - Serial number: 3564VRB405D33252AH3P
No data for: "EV_AirabAU10BPAAU64X" (AU57)
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Revision: -------- Serial number: 90372NKG0000H
Coding: 00001D
VCID: 377AF09E86D6C4F918-8062
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Serial number: 28 10 2014 F0086450
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G9 920 950 T HW: 4G9 920 950 T
Component: TDieRdwAccNv H07 0043
Revision: 03001036 Serial number: 658131114592064
Coding: 138F22081F410008030600
Dataset: EV_RBD4K 004048
ROD: EV_RBD4K.rod
VCID: 418E9E46D0128A49A6-8014
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 AE HW: 4G0 907 468 AC
Revision: -------- Serial number: 00000001532645
Coding: C0CD078118
Dataset: EV_GatewPkoUSD 001024
ROD: N/A
VCID: 73E2048EDA2E68D9E4-8026
Serial number: 3604984903
No data for: "EV_GatewPkoUSD" (AU57)
Address 34: Level Control (J197) Labels: 4G0-907-553.clb
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Coding: 008002
Dataset: EV_AirSuspe 003025
ROD: EV_AirSuspe_VW51.rod
VCID: 2F6AC8FE76860C3940-807A
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA8208J9SP
Shop #: 00000 000 00000
Dataset: EV_SARA2 005012
ROD: EV_SARA2_VW51.rod
VCID: 3664FD9A89DC3DF103-8062
Address 42: Door Elect, Driver (J386) Labels: None
Component: FA H04 0507
Coding: 011E17014000628002080003
VCID: 45868A56CC3AA6699A-8010
Address 44: Steering Assist (J500) Labels: 4G0-909-144.clb
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0009189074
Coding: 101000010001
Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_009.rod
VCID: 3362C48E9AAE28D924-8066
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0352441589
Coding: 0100063820B93014832009040E010F470000000000000000000000000000
Subsystem 1 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J245 PS20.008 H02 0007
Serial number: WOO33651091
Coding: 901F00
Subsystem 2 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J394 PS20.008 H02 0007
Serial number: WOO33651394
Coding: 801F00
Address 52: Door Elect, Pass. (J387) Labels: None
Component: BF H03 0507
Coding: 011E17014400628002080002
VCID: 46848D5AF13CAD7193-8012
Component: -4 H04 0015
Revision: -------- Serial number: 00000001275704
Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_AU57.rod
VCID: 2D56D2F67C8A7E2972-8078
Part No SW: 4G1 035 193 A HW: 4G1 035 193 A
Component: RMC Cnct Nav H61 0139
Coding: 0100050001715B674C2B060301010000000000
VCID: 224C31CA3D54B151DF-8076
Subsystem 1 - Part No: 8X0 919 884 H
Component: P28-50-14.06 0001
Subsystem 2 - Part No SW: 4G0 919 603 B HW: 4G0 919 603 B
Component: DU6 Basic H43 0084
Serial number: 9464J40E2689441
Subsystem 3 - Part No SW: 4G1 919 610 E HW: 4G1 919 610 E
Serial number: 90349NK60011T
Reset counter: 95
Mileage: 256754 km
Date: 2019.12.02
Time: 15:41:22
Bin. Bits: 00000000 00100000
Bin. Bits: 00001000 00000000
Bin. Bits: 00000000 00000000
03787 - Rotation Mechanism for Display Module Front
Fault Status: 00100011
Reset counter: 91
Mileage: 256660 km
Date: 2019.11.28
Time: 11:38:15
Voltage: 12.30 V
Address 62: Door, Rear Left (J388) Labels: None
Component: HL H03 0507
Coding: 010E15004000628002080002
VCID: 499E8666E02242097E-801C
Address 6D: Trunk Elect. (----) Labels: Redir Fail!
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0150
Revision: 14005001 Serial number: 322400411
Coding: 093205C010
Dataset: EV_HDGSAu572 001022
ROD: N/A
No data for: "EV_HDGSAu572" (AU57)
Address 72: Door, Rear Right (J389) Labels: None
Component: HR H03 0507
Address 85: On Board Cam. (J852) Labels: None
Component: DPC-SG H27 0081
Coding: EA040000
Dataset: EV_OnBoardCamerPDC 001007
ROD: N/A
VCID: 2C50DFF24790772165-8078
No data for: "EV_OnBoardCamerPDC" (AU57)
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Coding: 7804010202
Dataset: EV_AdaptCrusiContr2AU57X 002012
ROD: N/A
VCID: 275A20DE5E76547988-8072
No data for: "EV_AdaptCrusiContr2AU57X" (AU57)
Address 8E: Image Processing (J851) Labels: 4H0-907-107-V2.clb
Component: BV-SG H33 0090
Serial number: 005000621011147
Coding: 04808A181211
Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Component: RGS-VL H13 0080
Coding: 00660600031F0376000308014248D2010000
Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
Component: RGS-VR H13 0080
Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 326CC18A65B421D12F-8066
Part No SW: 4G0 907 355 C HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0010
Revision: 00000000 Serial number: 143060210
Dataset: EV_RDCMA00100 008040
ROD: EV_RDCMA00100_008.rod
VCID: 2B52DCEE429E70196C-807E
End-------------------------(Elapsed Time: 05:16)--------------------------
