VW Touareg 2018 vcds
rlteck
Australia
C?ID=380706
Hi from Australia.
is there any way to disable drivers door open Chime.TOUAREG 2018.
This option is not available in 2018
Turn off "ignition on" chime
1. Control Module 17
2. Adaptations
3. Ignition Active Message, Actuator: Driver Door -> No Display
Thanks rlteck
Tuesday,26,November,2019,13:23:14:39348
VIN: WVGZZZ7PZJD016783   License Plate: 1G0E
Mileage: 14630km-9090mi   Repair Order:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 34 36 42 46 52 53 55 56
          5F 62 69 6C 6D 72
VIN: WVGZZZ7PZJD016783   Mileage: 14630km-9090miles
Address 01: Engine (J623-CRCA)       Labels: None
   Part No SW: 7P1 907 401 D    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H41 0001
   Revision: 53H41---
   Coding: 292A4012233E01020000
   Shop #: WSC 40556 002 1048576
   ASAM Dataset: EV_ECM30TDI0117P1907401D 001002
   ROD: EV_ECM30TDI0117P1907401D.rod
   VCID: 313F152F41A0C1CF769-8064
Address 02: Auto Trans (J217)       Labels: 0C8-927-755.clb
   Part No SW: 0C8 927 755 M    HW: 0C8 927 755
   Component: 34O06G0Q.MOT  130 3073
   Coding: 010100011C008400000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_TCMAL991031 003118
   ROD: EV_TCMAL991031_003.rod
   VCID: 3B23370793EC3B9FDC5-806E
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 R    HW: 7P0 907 379 A
   Component: MK25A         H37 0521
   Revision: --------    Serial number: 42457446686892
   Coding: 5B6B13C34B252559DAFBC89BD2D5A470F701
   ASAM Dataset: EV_MK25AXT 010001
   ROD: EV_ESPMK25A01000.rod
   VCID: 4CC164DBC6428C2765F-8018
   Part No SW: 4H0 907 064 JM    HW: 4H0 907 064 JM
   Component: BCM2 2.0      H44 0582
   Coding: 05B60016000000000000
   VCID: 7DA7F91FCDF8F5AFA21-8028
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 3218000021224010
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-BFS       H08 0156
   Revision: AA000000    Serial number: 00000306008661
   Coding: 0038330000004201000001010101202020202121202020
   VCID: 34311C3BBE32F4E71DF-8060
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 CR    HW: 7P6 907 040 CR
   Component: Klima 2 Zonen H23 1608
   Coding: 3626200E90
   VCID: 065596F398AEB677F3B-8052
   Part No SW: 4H0 907 063 DA    HW: 4H0 907 063 AA
   Component: BCM1 2.0      H20 0311
   Revision: 2202007S    Serial number: 00001925032902
   Coding: 26000015D0345D010029400780005D4C431D670827010241800000000040110000000000000000
   Shop #: WSC 12345 123 61029
   VCID: 6A8DC243AC767217773-803E
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    171103  033 0021
   Serial number: 90243401171117072221
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 81193411
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 AB    HW: 7P6 941 431 AB
   Component: E1 - LDS  H02 0040
   Serial number: 00000000002002180231
   Component: EVLS-SG  H08 0300
   Serial number: WA130580000043561172
   Coding: 020300
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 D    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0030
   Revision: --------    Serial number: 28261805902392
   Coding: 518504
   ASAM Dataset: EV_VW526ParkiAssis2 001013
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 44D14CFBEE124467ADF-8010
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 G    HW: 7P0 959 655 G
   Component: VW10Airbag00T H11 0048
   Revision: --------    Serial number: 003TU004BCFI
   Coding: 000000000000000000000000000000003054
   ASAM Dataset: EV_AirbaVW10BPAVW526 002001
   ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
   VCID: 45D751FFE5287D6FBA1-8010
   Serial number: 3575LRB40145DLTMF1Q5
   Serial number: 3585LRB40185DLTMGP09
   Serial number: 3517ARB404R56MM4NORH
   Serial number: 3527ARB405B57114B1L7
   Serial number: 3557BRB406556KBSJ0VW
   Serial number: 3567BRB406556KBSA98A
   Part No SW: 4H0 953 568 P    HW: 7P6 953 507 AL
   Component: Lenks.Modul   H06 0010
   Revision: C0077960    Serial number: 91560RBL0001Y
   Coding: 000015
   VCID: 40D940EBFA8A5847897-8014
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H05 0028
   Serial number: 0093265 TRW 20180214
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 883 L    HW: 7P6 920 883 L
   Component: Kombi         H15 0607
   Revision: 16240316    Serial number: 658270218592022
   Coding: 233533003A00000801000C
   ASAM Dataset: EV_KombiUDSRBVW526 001030
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 47CB5BF7DF246F7F48D-8012
   Part No SW: 7P6 907 530 Q    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H15 6055
   Revision: --------    Serial number: 00000002905356
   Coding: 000D07AD00
   ASAM Dataset: EV_GatewVW526UDS 001008
   ROD: EV_GatewUDS_VW52.rod
   VCID: 46D556F3D82E7677B3B-8012
   Subsystem 1 - Part No SW: 7P0 915 181 C    HW: 7P0 915 181 C
   Component: Batt_Sensor  H07 0270
   Serial number: 44228I51245811861861
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
   Serial number: 18045001997021200181
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 AH    HW: 7P0 907 553 AH
   Component: PASM          H05 0960
   Revision: 00000000    Serial number: 00000180270332
   Coding: 14210000
   ASAM Dataset: EV_PASMConti 001005
   ROD: EV_PASMConti.rod
   VCID: 7DA7F91FCD78F5AFA21-8028
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000305992207
   Coding: 00383B0000004201000001010101202020202121202020
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H03 0306
   Revision: --------    Serial number: 0000297954368
   Coding: 011D1620DE01451205080002
   VCID: 7AADF203DCD6C297873-802E
   Revision: 00002001    Serial number: 0473143341
   Coding: 019B1E20A8B9108183200624210000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 172
   Component: Sensor, DWA  005 0502
   Subsystem 2 - Part No: 1K0 951 605 F
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H03 0306
   Revision: --------    Serial number: 0000305273542
   Coding: 011D1620DE01451205080000
   VCID: 48C958CBD2BA6007417-801C
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 G    HW: 7P0 907 801 G
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1820600820
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 372B2B37AFC41FFF38D-8062
   Slave 3:
   Component: AFS-ECU       H01 0120
   Coding: 01A602000B000200
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   VCID: 3FDB431787F427BFF0D-806A
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0006
   Coding: B00000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0006
   Coding: B00000
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227BX0J5057413
   Coding: 040005020100000003
   VCID: 2615F67378EE967793B-8072
   Part No SW: 7P6 035 764 N    HW: 7P6 035 764 A
   Component: H-BNT-RW      H43 1062
   Revision: --------    Serial number: 605BW0J7515510
   Coding: 010A01050040C1EF41000B0E00000003F00001030000000000
   VCID: 44D14CFBEE924467ADF-8010
   Subsystem 1 - Part No: 8R0 060 884 EG
   Component: ROW 2017  0905
   Subsystem 2 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
   Component: DU8 SV Touch  H56 0046
   Serial number: VWZ8Z9VGF025TZ
   Subsystem 3 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
   Component: CD-Database  9040
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H04 0306
   Revision: --------    Serial number: 0000306183593
   Coding: 011814200001251005080000
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4H0 907 383 M    HW: 4H0 907 383 K
   Component: Anhaenger     H20 0160
   Revision: 7C001003    Serial number: 0429917806
   Coding: 0300000202000000
   ROD: EV_TrailFunctGener2Hella_VW52.rod
Address 6C: Back-up Cam. (J928)       Labels:| 7P6-907-441-V1.clb
   Part No SW: 7P6 907 441 G    HW: 7P6 907 441 G
   Component: TopView       H09 0115
   Revision: 11001001    Serial number: 82330JG0476771
   Coding: 0100000001000000010102000000
   ASAM Dataset: EV_CamerSysteTopViewVW 001014
   ROD: EV_CamerSysteTopViewVW.rod
   VCID: 3D27391F8DF835AFE21-8068
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010003    Serial number: 044800095
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H04 0306
   Revision: --------    Serial number: 0000306195360
End----------(Elapsed Time: 01:56, VBatt start/end: 12.2V/12.1V)-----------
Hi and welcome.
I don't see an obvious way to accomplish that.
Where did you find the instructions you're trying to follow?
Gonna move this to the Tweaks section.
Hah! A Touareg is nothing like a Golf.
The systems in the original 7L Touaregs were similar to the Phaeton and several Bentley models of the period.
The systems in the 7P Touareg like yours are similar to the Audi A6/A8 of the time.
rlteck
Australia
C?ID=380706
Made a few changes,
Seatbelt Chime,Green Screen,
Enable Video In Motion,
disable Stop-Start,
daylight lights.
But haven't find any codes for drivers door open chime.
Thanks for that.
