Monday,02,December,2019,08:12:47:23598
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 19.6.2.0 (x64) HEX-V2 : 0.4508.4
VIN: WAUZZZF1XKD020041 License Plate:
Chassis Type: F1-AU58 (4N2)
Scan: 01 02 03 06 09 13 15 16 17 19 2B 36 3C 42 44 46 47 52 5F 61
69 6D 74 81 82 A5 AC BB BC C4 CA CC CD CF D6 D7 DB DC DE
VIN: WAUZZZF1XKD020041 Mileage: 18974km-11789miles
03- Brakes -- Status: OK 0000
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
-Rear Axle Steering -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
CD-Laser Scanner -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
Address 01: Engine (J623-DHXA) Labels: Redir Fail!
Part No SW: 4M8 907 401 HW: 059 907 309 L
Component: 3.0l V6 TDI H26 0001
Revision: CAH26---
Coding: 2A2A4012057E050334286000000400000000000000000000
Shop #: 31414 242 00001
Dataset: EV_ECM30TDI0114M8907401 001002
ROD: EV_ECM30TDI0114M8907401.rod
VCID: 6E85CE9CA012C7972BB-803A
4814 - Unknown Error Code
U3501 00 [038] - -
Mileage: 18753 km
Date: 2019.11.28
Time: 19:19:54
Engine speed: 0.00 /min
Coolant temperature: 45 ∞C
Intake air temperature: 16 ∞C
Voltage terminal 30: 10.980 V
Control module temp.: max. value: 67.0 ∞C
Mean injection quantity: 0.00 mg/stroke
Ambient temperature: 9.3 ∞C
Control Module temperature: 33.9 ∞C
Part No SW: 4M8 927 158 G HW: 0D5 927 156 P
Component: 0D5 30TDIRdW H05 1001
Revision: --H05---
Coding: 100000
Shop #: 31414 239 00001
Dataset: EV_TCMALX52011 002014
ROD: EV_TCMALX52011.rod
VCID: 40D94024CA0601E7897-8014
Automatic Transmission Fluid Pump:
Subsystem 1 - Part No SW: 4M0 927 154 AA HW: 0D7 321 281 A
Component: V552 ATFP H01 0705
Serial number: 180317000200
Address 03: Brakes (J104) Labels: 4M0-907-379-PRE-V1.clb
Part No SW: 4M6 907 379 N HW: 4M6 907 379
Component: ESP9 Premium H06 0850
Coding: 24AA329631A40B96D39E5C95187ED6E2F5BAC9244C8CD0CB3A186B47AF5D93
Dataset: EV_ESP9BOSCHCMP 004011
ROD: EV_ESP9BOSCHCMP_004_AU65.rod
VCID: 48C95804E23639A7417-801C
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 4M6 959 760 B HW: 4M6 959 760 B
Component: MEM-BFS 009 0042
Serial number: 00000356876723
Coding: 0038B2400001BE810043010101010000810000070700878700000000000000
Shop #: 31414 050 00001
Dataset: EV_SCMPasseSideCONTIAU736 006009
ROD: EV_SCMPasseSideCONTIAU736_VW53.rod
VCID: 3D2739D0BDF46C0FE21-8068
Valve Block 1 In Passenger Side Front Seat:
Subsystem 1 - Part No SW: 4N0 907 182 HW: 4N0 907 182
Component: N477 VB1 BFSv H04 0011
Serial number: SJ8001131118402580EB
Coding: BF2F00
Address 09: Cent. Elect. (J519) Labels:* 4N0-907-063-V2.clb
Part No SW: 4N0 907 063 DE HW: 4N0 907 063 AE
Component: BCM1 MLBevo H10 0652
Coding: 07000143C13900DD070C57889FFB8C78131B33110406009781010A001B3316810A45090200100000000003030041081B1802000044010104000000000000000000
Dataset: EV_BCM1BOSCHAU651 014010
ROD: EV_BCM1BOSCHAU651_014.rod
VCID: 74B1DCF4CE3EED47DDF-8020
Subsystem 1 - Part No SW: 4M8 955 119 A HW: 4M8 955 119 A Labels: 1KX-955-119.CLB
Component: J400FRWISCH 052 0997
Serial number: 904853F0401825000080
Coding: 7DC727
Serial number: 22115216X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4K2 941 501 A HW: 4K2 941 501 A
Component: E1 - LTM H09 0086
Serial number: 14S09.11.1800690839
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE114091823810927
Coding: 210000
Interior Light Module:
Subsystem 5 - Part No SW: 4K0 947 135 L HW: 4K0 947 135 L
Component: Dachmodul H42 0413
Serial number: Q00659725
Coding: 0D0104
Electrically Adjustable Steering Column:
Subsystem 6 - Part No SW: 80A 907 705 HW: 80A 907 705
Component: J866-EVLS-SG H03 0100
Serial number: WA135181000058589407
Coding: 0A0100
Front windshield washer pump:
Subsystem 7 - Part No SW: 4N0 907 605 C HW: 4N0 907 605 A
Component: J1100/SWP H21 0015
Serial number: 00000000001833000817
Coding: 040000
67736 - Databus
[Camera sensor blocked]
Reset counter: 253
Mileage: 18790 km
Date: 2019.11.29
Time: 15:17:08
average_Voltage_terminals: 15.10 V
Outside air temperature sensor-Outside air temperature on CAN: 6.50 ∞C
interior_temperature: 15.00 ∞C
Vehicle speed: 29.53 km/h
Terminal control-Terminal 75 status: On
Terminal control-Terminal 15 status signal: On
Terminal control-Terminal 15 via CAN: On
Terminal control-Term 75: qualification: OFF
405507 - Functional Limitation due to Energy Management
B10CD 00 [009] - -
[Function limitation due to energy management system]
Reset counter: 216
Mileage: 18753 km
Date: 2019.11.28
Time: 19:21:47
average_Voltage_terminals: 11.20 V
Outside air temperature sensor-Outside air temperature on CAN: 9.00 ∞C
interior_temperature: 14.50 ∞C
Vehicle speed: 0.00 km/h
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 4M0 907 561 L HW: 4K0 907 561
Component: LRR4R H04 0332
Coding: 5665FF5C78082C00010360E0000000BE4A1246484481009E00
Shop #: 31414 042 00001
Dataset: EV_ACCBOSCHAU65X 002023
ROD: EV_ACCBOSCHAU65X_AU58.rod
VCID: 392F2DC0A9DC502FCE9-806C
2344 - Databus
[FAULT_CAMERA_DIRT_OBJ]
Reset counter: 253
Mileage: 18790 km
Date: 2019.11.29
Time: 15:16:55
Control Module temperature: 30 ∞C
Voltage terminal 15: 11.7 V
Velocity_vehicle_reference: 11.07 m/s
Longitudinal_acceleration_vehicle_reference: -0.16 m/s≤
Steering_angle-Data: 11.400 ∞
Yaw_rate-Data: 0.838 rad/s
adjustment_calculation: On
Misalignment angle: horiz: 0.167 ∞
Misalignment angle: horiz: fast algorithm: -0.025 ∞
Congestion pilot: status: OFF
Outside air temperature: 6.50 ∞C
Sensor blindness: radar: no blindness detected
2343 - Databus
[FAULT_CAMERA_DIRT_PEDEST]
Reset counter: 253
Mileage: 18790 km
Date: 2019.11.29
Time: 15:16:55
Address 15: Airbags (J234) Labels:* None
Part No SW: 4N0 959 655 Q HW: 4N0 959 655 Q
Component: AirbagVW31 H09 2710
Serial number: 003YZM01HLRV
Coding: AACCF0C000C00000985400FFF08D41A800C5
Shop #: 31414 030 00001
Dataset: EV_AirbaVW31SMEAU65x 001032
ROD: EV_AirbaVW31SMEAU65x_VW53.rod
VCID: 4ACD620CFC3ACBB7573-801E
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4N0 980 945 A HW: 4N0 980 945 A
Component: BeltPretRevFL H10 0115
Serial number: 00AI2018320353200000
Coding: 03F001
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4N0 980 946 A HW: 4N0 980 946 A
Component: BeltPretRevFR H10 0115
Serial number: 00AI2018321306600000
Coding: 03F001
Subsystem 3 - Part No SW: ----------- HW: 480 001 711 18
Serial number: 3570000000051B79C53P
Subsystem 4 - Part No SW: ----------- HW: 480 001 711 18
Serial number: 3580000000011A79C53L
Subsystem 5 - Part No SW: ----------- HW: 480 032 111 18
Component: SideSensor_Dr 002 0149
Serial number: 351001C143E5EE60ED9X
Subsystem 6 - Part No SW: ----------- HW: 480 031 911 18
Component: SideSensor_Pr 002 0149
Serial number: 352001C10D1E2CD03E0A
Subsystem 7 - Part No SW: ----------- HW: 480 032 310 18
Component: FrontSensor_D 002 0149
Serial number: 355001C185A20E408AEG
Front Sensor Passenger:
Subsystem 8 - Part No SW: ----------- HW: 480 032 310 18
Component: FrontSensor_P 002 0149
Serial number: 356001C149F1E9F13C1Q
Side Sensor B-Pillar Driver Front:
Subsystem 9 - Part No SW: ----------- HW: 480 032 111 18
Component: SideSens_B_Df 002 0149
Serial number: 352001C143E5EA80AB1I
Side Sensor B-Pillar Passenger Front:
Subsystem 10 - Part No SW: ----------- HW: 480 031 911 18
Component: SideSens_B_Pf 002 0149
Serial number: 355001C10D1E2530FB27
Part No SW: 4N0 907 129 AJ HW: 4N0 907 129 AJ
Component: Lenks.Modul H03 0005
Dataset: EV_SMLSKLOAU736 007012
ROD: EV_SMLSKLOAU736_VW53.rod
VCID: 79AFEDC0E95C902F8E9-802C
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 4K0 920 790 C HW: 4K0 920 790 C
Component: FBenRDWACC--- H11 0153
Coding: A58410E67C88060001A3E160B080680008003000
Dataset: EV_DashBoardAU65X 001017
ROD: EV_DashBoardAU65X_VW53.rod
VCID: 2D0709906D94FC8F521-8078
Part No SW: 4N2 907 468 AB HW: 4N2 907 468 AB
Component: Gateway H14 0037
Revision: 8P030005 Serial number: 0588P769518B26
Coding: 02010005000486408C960000005B0132DC9A00471C000000097D078E10000000
Shop #: 31414 245 00001
Dataset: EV_CGateCONTIAU491 003150
ROD: EV_CGateCONTIAU491_003_AU58.rod
Subsystem 1 - Part No SW: 4M8 951 523 HW: 4M8 951 523
Component: J453 MFL H07 0004
Serial number: 20181122100820 30881
Subsystem 2 - Part No SW: 4K0 915 181 A HW: 4K0 915 181 A
Serial number: 7588520200181116073C
8519683 - Energy Management Active
U140B 00 [009] - -
Reset counter: 216
Mileage: 18753 km
Date: 2019.11.28
Time: 19:21:37
EM_vehicle_state: 02 1C
Static current shutdown level: Deactivation stage 1
Auxiliary heater activation restriction request-Parking heater: Permitted
Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
Part No SW: 3Q0 905 861 C HW: 3Q0 905 861 C
Component: ELV-MLBevo H05 0020
Serial number: 18000342682014
Coding: 8800000000000000
Dataset: EV_ELVMarqMQBA0 002002
ROD: EV_ELVMarqMQBA0_VW41.rod
VCID: 34311CF48EBEAD471DF-8060
Component: MEM-FS 009 0042
Serial number: 00000356887363
Coding: 00389A400001BE810003010101010000810000070700878700000000004000
Dataset: EV_SCMDriveSideCONTIAU736 006009
Valve Block 1 In Driver Side Front Seat:
Component: N475 VB1 FSv H04 0011
Serial number: SJ80011311184025805E
Coding: BF2F00
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4N0 907 566 F HW: 4N0 907 566 A
Component: MRR_HR H12 0266
Coding: 5FFC00
Dataset: EV_RearRadarS1DelphAU651 001018
ROD: EV_RearRadarS1DelphAU651_AU58.rod
Part No SW: 4M1 959 793 D HW: 4M1 959 793 D
Component: FS001 0188
Serial number: YE007RI626569
Coding: 001DDA42520104C2A009B436
Dataset: EV_DCU2DriveSideMAXHKLO 001010
196665 - Switch for Central Locking
B122D 29 [008] - Signal Implausible
Reset counter: 1
Mileage: 18918 km
Date: 2019.11.30
Time: 17:45:53
196724 - Motors for Central Locking
B122B 13 [008] - Open Circuit
Reset counter: 1
Mileage: 18918 km
Date: 2019.11.30
Time: 17:45:51
Part No SW: 4N0 909 144 D HW: 4N0 909 144 A
Component: EPS_MLBEVO2BS H21 0504
Coding: B2000101010000
Dataset: EV_EPSVWBSAU426 009015
ROD: EV_EPSVWBSAU426_009.rod
VCID: 313F15E071AC986F769-8064
Part No SW: 8W0 907 064 FP HW: 8W0 907 064 DP
Component: BCM2 MLBevo 025 0406
Coding: 013500002FB100406309A0046C00C80203004000804F02502F0400200504823F001F0100010F01
Dataset: EV_BCM2HellaAU736 015015
ROD: EV_BCM2HellaAU736_015_AU58.rod
VCID: 0F7BB318C7D8AE9F40D-805A
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY182842VMQ
Subsystem 2 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000248300
Rear Light Left 1:
Subsystem 3 - Part No SW: 4M8 945 069 B HW: 4M8 945 069 B
Component: SHL_li1 H04 0004
Serial number: 069B1811150000037063
Subsystem 4 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 11315144
Rear Light Left 2:
Subsystem 5 - Part No SW: 4M8 945 217 F HW: 4M8 945 217 F
Component: SHL_li2 H04 0004
Serial number: 217F1811050000033098
Rear Light Right 1:
Subsystem 6 - Part No SW: 4M8 945 070 B HW: 4M8 945 070 B
Component: SHL_re1 H04 0004
Serial number: 070B1811140000036935
Rear Light Right 2:
Subsystem 7 - Part No SW: 4M8 945 218 F HW: 4M8 945 218 F
Component: SHL_re2 H04 0004
Serial number: 218F1811050000033098
Part No SW: 4N0 035 223 B HW: 4N0 035 223
Component: MIB2_amp_P_D5 H01 0150
Revision: 00000001 Serial number: AUZ8ZAJ6S00ZBS/
Coding: 0135360A00AAAAAFAA0000010000
Dataset: EV_AMPMst16C1Gen2pALPI 001010
ROD: EV_AMPMst16C1Gen2pALPI.rod
VCID: 2313EFA83B503AFFF45-8076
Part No SW: 4M1 959 792 D HW: 4M1 959 792 D
Component: BFS001 0188
Serial number: YE007RJO12468
Coding: 001DDA025E0104C2A009B434
Dataset: EV_DCU2PasseSideMAXHKLO 001010
VCID: 3FDB43D8B7F87E1FF0D-806A
Address 5F: Information Electr. (J794) Labels:* 4G1-035--HGH2.clb
Part No SW: 4K0 035 063 A HW: 4K0 035 063 A
Component: MU-H-LND-EU 046 2470
Coding: 0135360100000000C3111102C00800302F0001E601F008008E
Dataset: EV_MUHigGen2pALPI 001001
VCID: 211FE5A0214C28EFE69-8074
Subsystem 1 - Part No: V03 959 804 LN
Component: MIB2P_EU_Q219 0371
Subsystem 2 - Part No SW: 4M8 919 605 A HW: 4M8 919 605
Component: DU AU536 High H41 0144
Serial number: INX00108101800100506
Compact Disc Database:
Component: Gracenote2 1008
Volume Control 1:
Subsystem 4 - Part No SW: 4N1 919 616 A HW: 4N1 919 616
Component: LSR-D5/C8 H33 0108
Serial number: 00004418000227672057
Display Unit 5 For Multimedia System:
Subsystem 5 - Part No SW: 4N0 919 603 B HW: 4N0 919 603
Component: DU AU651 Bot H41 0144
Serial number: INX00112081800050718
Media socket:
Subsystem 6 - Part No SW: 4N0 035 736 A HW: 4N0 035 736
Component: MediaConnectH 014 0133
Serial number: 051800707102001
7179 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Rear-view camera (0x0B) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 254
Mileage: 18813 km
Date: 2019.11.29
Time: 16:04:13
Voltage terminal 30: 12.0 V
-BAP_Function_ID: 26
Address 61: Battery Regul. (J1120) Labels: None
Part No SW: 4N0 915 105 B HW: 4N0 915 105 B
Component: BMS_48V_LiIon H06 0108
Shop #: 00000 000 00000
Dataset: EV_BMS48VLiIonLGAU536 001001
ROD: EV_BMS48VLiIonLGAU536_AU58.rod
VCID: 290FFD80597CE0AFBE9-807C
Part No SW: 4M0 907 383 G HW: 4M0 907 383 B
Component: Anhaenger H33 0273
Revision: 9A001003 Serial number: 0499625962
Coding: 0110000202000000
Dataset: EV_TrailFunctGener2Hella 001008
ROD: EV_TrailFunctGener2Hella_VW27.rod
VCID: 363526FC98C2BF5723B-8062
Part No SW: 4M0 959 107 D HW: 4M0 959 107 A
Component: HDSG-Modul H13 0170
Revision: -------- Serial number: A2-C737-6252-2
Coding: 28F0
Dataset: EV_DeckLidCONTIAU736 001016
ROD: EV_DeckLidCONTIAU736_AU38.rod
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 4M8 907 777 N HW: 4M8 907 777
Component: Fahrwerk-SG H51 2031
Serial number: 2411180589
Coding: B85C6050F840
Dataset: EV_ChassContrContiAU651 001011
ROD: EV_ChassContrContiAU651_001_AU58.rod
VCID: 4CC16414F64ED58765F-8018
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 HW: 4M0 907 778
Component: V66LFKompOLV H06 0013
Serial number: 00000000004130460309
Coding: 303030
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4M8 713 041 A HW: 4N2 713 041 C
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 18080448660610
Dataset: EV_GSMWaehlZFAU736 001017
ROD: EV_GSMWaehlZFAU736.rod
VCID: 2A0D028C5C7AEBB7B73-807E
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4M8 919 617 C HW: 4M8 919 617 C
Component: HeadupDisplay H08 1815
Coding: 4700E0
Dataset: EV_HeadUpDisplAU65X 001010
ROD: EV_HeadUpDisplAU65X_AU58.rod
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* None
Part No SW: 4KE 907 107 AC HW: 4N0 907 107 H
Component: zFAS Var C H09 0291
Coding: 04C184000000000000FFD60000F0C60C1B9F760000000000000000000096D401009BA8000000000000000080000000000000000000000000F980400000000000000078D0008000B000800080000000000080400000E0
Dataset: EV_ZFASAU516 001003
ROD: EV_ZFASAU516_001_AU58.rod
VCID: 005980248A86C1E7C97-8054
2114905 - Databus
[LED_Feh_LM_L_01_LED_L_Fernl_Def]
Reset counter: 1
Mileage: 18941 km
Date: 2019.11.30
Time: 18:12:48
2117692 - Control unit for information electronics 1
U1054 00 [008] - No Communication
[Databus_Ethernet_missing_PDU]
Reset counter: 252
Mileage: 18760 km
Date: 2019.11.29
Time: 11:53:18
Ethernet signal quality: good: link available
221284 - Front Camera for Driver Assist Systems
C12B3 FD [008] - View Temporarily Restricted
[temp view limitations]
Reset counter: 253
Mileage: 18790 km
Date: 2019.11.29
Time: 15:16:55
EyeQ temperatures-CPU: -40 ∞C
EyeQ temperatures-VPM: 16 ∞C
Vehicle speed: 39.21 km/h
Front camera: blinding detection-Status: not active
Front camera: blinding detection-Blinding detected by light assistance assessment module: Yes
Front camera: blinding detection-Blinding detected by road sign recognition assessment module: Yes
Front camera: blinding detection-Blinding detected by pedestrian recognition assessment module: Yes
Front camera: blinding detection-Blinding detected by lane recognition assessment module: Yes
Front camera: blinding detection-Blinding detected by object recognition assessment module: Yes
Front camera: blinding detection-Blinding detected by distance regulation assessment module: Yes
Front camera: blinding detection-Blinding detected by road profile estimation assessment module: Yes
Front camera: blinding detection-Blinding detected by free space recognition assessment module: Yes
Front camera: blinding detection-Request for window defogger for front sensor system due to blinding: Yes
Front camera: blinding detection-Glare detected: No
Front camera: blinding detection-free view detected once: No
282656 - Video Cable for Information Electronics 1
B13B9 01 [008] - Electrical Failure
Reset counter: 252
Mileage: 18760 km
Date: 2019.11.29
Time: 11:53:22
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 D HW: 4M0 907 355 B
Component: SCR-Stg-G3H05 0006
Dataset: EV_RDCMINERGAU736 005012
ROD: EV_RDCMINERGAU736_VW53.rod
VCID: 323D1AEC74AAA3770F3-8066
Part No SW: 4M1 959 795 D HW: 4M1 959 795 D
Component: HFS003 0188
Serial number: YE007RK617541
Coding: 000DD802000104C2A008B024
Dataset: EV_DCU2RearDriveMAXHKLO 001010
VCID: 42DD4A2CC40A13F79F3-8016
Component: HBFS003 0188
Serial number: YE007RK614195
Dataset: EV_DCU2RearPasseMAXHKLO 001010
Address C4: DC/DC Converter (A7) Labels: 4M0-959-663.clb
Part No SW: 4M0 959 663 C HW: 4M0 959 663 C
Component: PCU10 022 0324
Dataset: EV_DCDC48V210ABOSCHAU736 001008
ROD: EV_DCDC48V210ABOSCHAU736.rod
VCID: 3A2D32CCACDA5B37C73-806E
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 005 0002
Coding: 728040053632
Dataset: EV_SunRoofCONTIAU736 009011
VCID: 75B7E1F0C544F44FEA1-8020
Address : Rear Axle Steering (J1019) Labels:* None
Part No SW: 4M0 909 145 AA HW: 4M0 909 145 E
Component: HAL_MLBevoH08 0698
Revision: -------- Serial number: CCC_098_B_1122_
Coding: 42242A00
Dataset: EV_RearAxleSteerZFAU736 010018
ROD: EV_RearAxleSteerZFAU736_010.rod
VCID: 6FBBD398A718CE9F20D-803A
Address CC: Starter-Generator (----) Labels:* None
Part No SW: 4N0 903 028 H HW: 4N0 903 028 H
Component: BSG-HP1-65 H16 0523
Serial number: 01121800020076
Coding: 28000000000000
Dataset: EV_Start48VAU651 001006
ROD: EV_Start48VAU651_001.rod
VCID: 303910E47AA69167797-8064
Address CD: Laser Scanner (J1122) Labels: None
Part No SW: 4K8 907 660 B HW: 4N0 907 660
Component: LASER_SCANNER H36 0202
Dataset: EV_LaserScannAU651 013013
ROD: EV_LaserScannAU651_013.rod
VCID: 353721F085C4B44F2A1-8060
Address CF: Lane Chge Asst 2 (J770) Labels:* None
Component: MRR_HL H12 0266
Coding: 5FFC00
Dataset: EV_RearRadarS2DelphAU651 001018
ROD: EV_RearRadarS2DelphAU651_AU58.rod
Part No SW: 4K0 941 592 BC HW: 4K0 941 592 B
Component: LMS_MLBevo H11 0031
Dataset: EV_LMSLeftHELLAAU58X 001013
ROD: EV_LMSLeftHELLAAU58X_AU38.rod
VCID: 72BDDAECB42AE377CF3-8026
2336 - Light Bulb for High Beam
C1199 01 [008] - Electrical Failure
Reset counter: 1
Mileage: 18941 km
Date: 2019.11.30
Time: 18:12:47
Dataset: EV_LMSRightHELLAAU58X 001013
ROD: EV_LMSRightHELLAAU58X_AU38.rod
Address DB: Frt Corner Rdar 1 (J1089) Labels:* None
Part No SW: 4N0 907 669 F HW: 4N0 907 669 A
Component: MRR_VR H12 0266
Coding: 003000
Dataset: EV_FrontCorneRadarS1AU651 001018
ROD: EV_FrontCorneRadarS1AU651_AU58.rod
Address DC: Frt Corner Rdar 2 (J1088) Labels:* None
Component: MRR_VL H12 0266
Coding: 003000
Shop #: 31414 142 00001
Dataset: EV_FrontCorneRadarS2AU651 001018
ROD: EV_FrontCorneRadarS2AU651_AU58.rod
Address DE: Charger 1 for mobile dev (J1146) Labels:* 4N0-035-502.clb
Part No SW: 4N0 035 502 A HW: 4N0 035 502 A
Component: WLC Front H10 0057
Coding: 400000
Dataset: EV_Charg1MobilDevicAU651 004001
VCID: 221DEAAC244A33F7FF3-8076
End----(Elapsed Time: 02:36, VBatt start/end: 11.5V/11.6V. VIgn 11.6V)-----
