2015 Golf Sportwagen SEL (US) 2.0 TDI CRUA (Post Apocalyptic Dieselgate)
tallman
Austin, Texas, US
C?ID=387855
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75
VIN: 3VWCA7AU0XXXXXXXX   Mileage: 124643km-77449miles
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 022 N    HW: 04L 907 309
   Component: R4 2.0l TDI   H23 9459
   Revision: 85H23---
   Coding: 011D0012032410081000
   Shop #: WSC 25155 444 00000
   ASAM Dataset: EV_ECM20TDI01104L997022N 004002
   ROD: EV_ECM20TDI01104L997022N.rod
   VCID: 3B23306673E59D6FDC5-806F
Readiness: 0 0 0 1 1
   Part No SW: 0D9 300 041 N    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4512
   Revision: 05853104    Serial number: TFK01504141132
   Shop #: WSC 00066 790 00218
   ROD: EV_TCMDQ250021.rod
   VCID: 2313E806EB55C5AFF45-8077
10657 - RPM Signal from ECU
          P0726 00 [002] - Implausible Signal
10906 - Cooling Oil Valve
          P179D 00 [002] - Electrical Malfunction
          P1734 00 [002] - -
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Revision: 00000000    Serial number: 50885000000669
   Coding: 04FA6AA1242109730077020481C92520562490004081A4B200630050C002
   Shop #: WSC 01383 790 50316
   VCID: 47CB5C963F2DC98F48D-8013
   Revision: 00021000    Serial number: 0365760860
   Coding: 030C0C
   VCID: 3A2D35627CDFA467C73-806F
   Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
   Revision: 00001K01
   Coding: 02020124202100000005000012111400
   VCID: 42DD4D82140FECA79F3-8017
   Air quality sensor:
   Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
   Revision: --------    Serial number: 86580904150834
   Coding: 00511846404182E969E44000001407001800000000000000000000000000
   Shop #: WSC 00066 790 00215
   ROD: EV_BCMBOSCH_014.rod
   VCID: 4ACD65A22C3F34E7573-801F
   Component: WWS    150320  043 0581
   Serial number:         150527175817
   Component: RLHS  037 0059
   Serial number: S4Y15M04D27H00M14S38
   Coding: 90A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H03 0004
   Serial number: 0000FST0007JXRE00000
   Coding: 191800
   Roof Blind:
   Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS22.409  H03 0004
   Serial number: 0000FST0007JXUH00000
   Coding: 191800
   Serial number: 003GCR01P5FI
   ROD: EV_AirbaVW20SMEVW37X.rod
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH0000J150002UBC10+
   Coding: 303137
   Subsystem 2 - Part No SW: -----------    HW: 480 000 704 15
   Serial number: 357000000003AB1D631K
   Subsystem 3 - Part No SW: -----------    HW: 480 000 804 15
   Serial number: 3580000000040495F31E
   Subsystem 4 - Part No SW: -----------    HW: 480 400 804 15
   Serial number: 3510002C919EFF5190BQ
   Subsystem 5 - Part No SW: -----------    HW: 480 400 804 15
   Serial number: 3520002B91A14CA0228$
   Subsystem 6 - Part No SW: -----------    HW: 480 400 204 15
   Serial number: 3550002A71A87863D28C
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 204 15
   Serial number: 3560002A31A878659142
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150415500284
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 04518B9A4E9B2297EDF-8051
   Part No SW: 5G1 920 841     HW: 5G1 920 841
   Component: KOMBI         243 4270
   Coding: 0BA4121A2180CF0502086A001000000000000000
   VCID: 6597B61EA5E1FB9F5A1-8031
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2203
   Revision: --------    Serial number: 06051510002958
   Coding: 0901000800087300EF0002081C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 00199
   ROD: EV_GatewConti_011.rod
   VCID: 71BFD24E6129273F369-8025
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0101
   Serial number: 29150000856710115183
   Coding: 31FFFF
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0058929
   Revision: 00000000    Serial number: 15000079348003
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311B5A5EBB52171DF-8061
   Serial number: 18051506050FA9
   Coding: 003A13200000040000000000
   VCID: 40D9478A1A03FEB7897-8015
   Serial number: 00000000000001184298
   Coding: 011000
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   VCID: 43D348860B15E5AF945-8017
   Serial number: 120515060508K8
   VCID: 3FDB447667FD814FF0D-806B
   Serial number: 00000000000001159423
   Coding: 091000
   Part No SW: 5G0 035 876     HW: 5G0 035 876
   Component: MU-S-NS-US    014 0655
   Serial number: V7B00204150390
   Coding: 027302020000000021220002001800001F0100340100010546
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 698FBA2E49F9DFFF7E9-803D
   Subsystem 1 - Part No SW: 5G0 919 605 K    HW: 5G0 919 605 K
   Component: ABT_Std_Nav  H60 0030
   Serial number: VWZ8Z9RS600MK8
   Subsystem 2 - Part No SW: 5G0 919 866 S    HW: -----------
   Component:  NAR 2015  --- 0022
   Component: OCULowMQBUS   007 0564
   Coding: 02730202C2823A017F1E06000000
   Shop #: WSC 00066 790 00323
   ROD: EV_OCULowMQB.rod
End----------(Elapsed Time: 01:31, VBatt start/end: 14.2V/14.1V)-----------
