Monday,25,November,2019,23:53:40:31877
-- Windows Based VAG/VAS Emulator Running on Windows 7 x64
Version: 19.6.2.0 (x64)
VIN: WAUZZZ4G1JN071508 License Plate: AFTER CODE
Mileage: 51104km-31754mi Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 30 36 3B 3C 42 44 46
52 53 55 5F 62 6C 6D 72 82 85 8B 8E 8F 90 A9 AC C0
VIN: WAUZZZ4G1JN071508 Mileage: 51104km-31754miles
03- Brakes -- Status: Malfunction 0010
05-/Start Auth. -- Status: OK 0000
Address 01: Engine (J623-CVUA) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 589 F HW: 4G0 907 589 B
Component: 3.0BTD EDC17 H23 0008
Revision: 54H23---
Coding: 1A2A4032256603030800
Shop #: 54544 001 1048576
Dataset: EV_ECM30BTD0114G0907589F 001008
ROD: EV_ECM30BTD0114G0907589F.rod
VCID: 377D07B78E3101F756-8062
18728 - NOx Sensor 1 Bank 1
P2201 00 [237] - Implausible Signal
Mileage: 49114 km
Date: 2019.11.05
Time: 16:09:17
Engine speed: 1964.50 /min
Vehicle speed: 103 km/h
Coolant temperature: 89 °C
Intake air temperature: 26 °C
Voltage terminal 30: 14.200 V
Exh r N Ox Pres Comp NSC : -37 ppm
NOx-Sensor 1: oxygen concentration: 0.20439
O2 sensor 1: bank 1: voltage raw value O2 signal: 1277.0
O2 sensor 1 bank 1: adjusted oxygen value: -0.00055
Solen.val.: actual value: 99.89 %
Mean injection quantity: 0.00 mg/stroke
Exh.gas temp.sen 1: 298.2 °C
Readiness: 1 1 0 0 0
Part No SW: 4G0 927 158 AK HW: 0BK 927 156 AM
Component: 0BK 30RTDIRDW H22 1015
Revision: --H22---
Shop #: 00000 000 00000
Dataset: EV_TCMAL551211 002022
VCID: 77FDC7B7CEB1C1F796-8022
Address 03: Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 49A79E4B92E579D29B00
Shop #: 02391 785 00200
Dataset: EV_ESP9BOSCHAU57X 004018
ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
VCID: 4189696FD0F54F47E8-8014
171008 - Function Restricted due to Missing Message(s)
U1111 00 [047] - -
[New feature! Extended fault detail is only supported by current gen. interfaces]
Mileage: 51104 km
Date: 2019.11.25
Time: 23:38:52
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 22
Bit Info 4: 1F
Uz: 9C
Address 05: /Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 HW: 4H0 907 064
Component: BCM2 2.0 H61 0825
Coding: 01BA704E000000000000
VCID: 7CF7D89BFF97E2AFFB-8028
Component: J764 ELV H40 0046
Serial number: 3217000171792012
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Serial number: 01121700040212
Coding: 362311783D0000
Dataset: EV_AirCondiComfoUDS 003008
VCID: 63C583E76A293D57DA-8036
Part No SW: 4H0 907 063 GG HW: 4H0 907 063 AG
Component: BCM1 2.0 H20 0368
Revision: 1402003S Serial number: 00001819903601
Coding: 0105C01540348FE2C10140C780001800CF9DC30A2F080201800008946100130200400019010000
VCID: 73E5F3A7D2C9ADD7AA-8026
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 171017 H38 0080
Serial number: 171114221610
Coding: 004DF7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 21073893X81A955547A0
Coding: 02006E
Subsystem 3 - Part No SW: 4G0 941 531 BG HW: 4G0 941 531 BG
Component: E1 - H07 0044
Serial number: 27 11 2017 00000727
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA129149000038179320
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: 1E605CD800PAG0MUFU03
03455 - Function Restriction due to Faults in Other Modules
Reset counter: 39
Mileage: 51104 km
Date: 2019.11.25
Time: 23:37:20
Address 10: Park/Steer Assist (J791) Labels:| 4H0-919-475-7X5.clb
Part No SW: 4G0 919 475 L HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0090
Revision: -------- Serial number: 56231732003096
Coding: B83B10
Dataset: EV_EPHVA2CAU64X0000 001015
ROD: EV_EPHVA2CAU64X0000.rod
VCID: 3A7B1E83BD231C9FA9-806E
Component: ACC3 H21 0055
Coding: 7E04010201
Dataset: EV_AdaptCruisContrAU57X 002015
VCID: 2959D1CF4885A707D0-807C
154624 - Door Contact Switch
C1076 29 [008] - Signal Implausible
Reset counter: 67
Mileage: 49656 km
Date: 2019.11.10
Time: 15:29:22
Control Module temperature: 22 °C
Voltage terminal 15: 11.300 V
Longitudinal_acceleration_vehicle_reference: 0.00 m/sІ
Component: Airbag10.43 H83 0098
Revision: -------- Serial number: 003P100FB25J
Coding: 30333046313130313137554A305234473853
Dataset: EV_AirbaAU10BPAAU64X 001014
VCID: 3B751B87B2192597B2-806E
Serial number: 3575HRB400Q5BRV86HQL
Serial number: 3585HRB401C5BRV880NY
Serial number: 3515JRB400A5BT50CQ56
Serial number: 3525JRB405556RGO9023
Serial number: 3554VRB4051556M4E07U
Serial number: 3564VRB4051556M4LPHU
Component: Lenks.Modul H05 0005
Revision: -------- Serial number: 90372QKP0007Z
Coding: 0000FC
VCID: 377D07B7863101F756-8062
Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
Serial number: 06 11 2017 D0009509
Part No SW: 4G8 920 988 D HW: 4G8 920 988 D
Component: TDieGb H17 0225
Revision: 18001312 Serial number: 658221117592058
Coding: 338F05020F550408010100
Dataset: EV_RBD4K 004060
ROD: EV_RBD4K_AU57.rod
Part No SW: 4G8 907 468 K HW: 4G8 907 468
Component: J533--Gateway H15 0110
Revision: -------- Serial number: 00000002804002
Coding: C0CD078118
Dataset: EV_GatewPkoUDS 002011
VCID: 408F6C6BDBFF464FE7-8014
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Serial number: 2190945804
Voltage stabilizer:
Serial number: 1708250000000000017D
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0113
Serial number: 01121700040777
Coding: 22
Dataset: EV_ClimaContrUnitRearUDS 003004
VCID: 3D71159FAC0D2BA78C-8068
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: H07 0030
Revision: S0H07000 Serial number: 00000000006550
Coding: 01010101000000000001000202
VCID: 64C780FB67273A6F23-8030
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000288037971
Coding: 0078130000006001000001010101102030303232203232
VCID: 77FDC7B7C6B1C1F796-8022
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA820ERFGX
Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 36630AB3893BF8FF4D-8062
Component: Master H08 0070
Serial number: 0462040113
Coding: 040312
Dataset: EV_LaneChangAssis 001028
VCID: 3979018FB8251787A0-806C
Lane Change Assistant 2:
Component: Slave H08 0070
Serial number: 0462201850
Coding: 040312
262157 - Databus
Reset counter: 61
Mileage: 49116 km
Date: 2019.11.05
Time: 16:18:34
Component: FA H04 0511
Coding: 011F56035E21628002080413
VCID: 45817D7FCCDD6367D4-8010
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H55 0202
Revision: 00000002 Serial number: 0000269819
Coding: 101101010001
Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
Revision: 00002001 Serial number: 0461924966
Coding: 013F0622A0B93884C3200A840E010D470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 B
Component: Sensor, DWA 005 0002
Subsystem 2 - Part No: 1K0 951 605 F
Component: BACKUP HO H01 0008
Subsystem 3 - Part No SW: 4G8 959 591 A HW: 8V3 959 591 A
Component: J245 PS40.402 H04 0005
Serial number: 0000FST001W7YBD00000
Coding: 901F02
Subsystem 4 - Part No SW: 4G0 947 135 F HW: 4G0 947 135
Serial number: 0000000AP00040671781
Component: BF H03 0511
Coding: 011F56035E21628002080402
VCID: 46837A73F1DB687FDD-8012
Part No SW: 4H0 907 801 M HW: 4H0 907 801 M
Component: -4 H01 0018
Revision: -------- Serial number: 00000002381465
Dataset: EV_ParkiBrake 001033
ROD: EV_ParkiBrake_VW51.rod
VCID: 326B36A36553E4DF61-8066
Component: - 001 0100
Coding: 05FE02202A170200
Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
VCID: 346730BB9F47EAEF73-8060
Subsystem 1 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7570
Coding: E02100
Subsystem 2 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7570
Coding: E02100
Matrix Headlamp Powermodule 1 Left:
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: LeiMo li. H03 0031
Coding: E02100
Matrix Headlamp Powermodule 1 Right:
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: LeiMo re. H03 0031
Coding: E02100
5350720 - Left Matrix High Beam
C1175 54 [137] - Missing Calibration / Basic Setting
Reset counter: 26
Mileage: 49656 km
Date: 2019.11.10
Time: 22:45:18
5350976 - Right Matrix High Beam
C1176 54 [137] - Missing Calibration / Basic Setting
Reset counter: 26
Mileage: 49656 km
Date: 2019.11.10
Time: 22:45:18
Address 5F: Information Electr. (J794) Labels:* 4G1-035--HGH2.clb
Part No SW: 4G1 035 021 J HW: 4G1 035 021 D
Component: MU-H-LND-EU 054 0910
Serial number: A733K0HS022207
Coding: 017503010000000013111102000A00332F000CE7F17001009F
Dataset: EV_MUHig6C3Gen2HBAS 001115
VCID: 2149C9EF30B56F4788-8074
Subsystem 1 - Part No SW: V03 959 801 FD HW: -----------
Component: ECE 2017/2018 --- 0161
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9HY809FXP
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
Serial number: 90349QKM00012
Compact Disc Database:
Component: Gracenote2 --- 1016
Component: HL H03 0511
Coding: 010F14024021628002080002
VCID: 4999714FE0C5870730-801C
Address 6C: Back-up Cam. (J772) Labels:| 4S0-980-556.clb
Part No SW: 4S0 980 556 HW: 4M0 980 556
Component: RVC Compact H08 0140
Coding: 0275000102002003000040
Dataset: EV_CamSysRVRVCPANAAU57X 001001
ROD: EV_CamSysRVRVCPANAAU57X_001_AU57.rod
VCID: 78FFC48BC3AFCE8F9F-802C
Part No SW: 4G8 959 107 S HW: 4G8 959 107 H
Component: HDSG-Modul H14 0049
Revision: 11014001 Serial number: 287701390
Coding: 0A3305C002
Dataset: EV_HDSGAu573 001022
ROD: EV_HDSGAu571.rod
VCID: 45817D7FC4DD6367D4-8010
Component: HR H03 0511
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4G8 919 604 N HW: 4G8 919 604 N
Component: HeadUpDisplay H10 0306
Coding: C70000
Dataset: EV_HUDContiC7 001027
ROD: EV_HUDContiC7.rod
VCID: 3E731293A10B30BF95-806A
Component: DPC-SG H28 0081
Coding: 6A160000
Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C5728DB4777B22F2B-8078
Coding: 7E04010201
Dataset: EV_AdaptCruisContr2AU57X 002013
VCID: 275DD7F75E919177C6-8072
Reset counter: 67
Mileage: 49656 km
Date: 2019.11.10
Time: 15:29:22
Control Module temperature: 20 °C
Voltage terminal 15: 11.307 V
Velocity_vehicle_reference: -0.00 m/s
Component: BV-SG H34 0090
Serial number: 005002452111177
Coding: 03C239181111
Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Component: RGS-VL H16 0080
Coding: 0066E608031F0376070308004240C2010000
Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 316939AF6055DFC718-8064
Component: RGS-VR H16 0080
Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Part No SW: 4G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0007
Serial number: 170921204894
Dataset: EV_SoundActuaGen2AU64X 003010
VCID: 2E5322D3716BC03F05-807A
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 172471404
Dataset: EV_RDCMA00100 008040
ROD: EV_RDCMA00100_008.rod
VCID: 2F6D3FD77661C9370E-807A
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 4G0 907 160 E HW: 4G0 907 160 B
Component: SAS-GEN 2 H09 0011
Serial number: 171005200194
Dataset: EV_ActuaForExterNoiseUDS 003013
ROD: EV_ActuaForExterNoiseUDS.rod
End-------------------------(Elapsed Time: 06:59)--------------------------
