No Rear Climate / Passenger Heated Mirror / rear view Mirror
RS6-CDUB
England
C?ID=373156
Evening All
seem to have lost power to a few things on my RS6 Avant 2018
No Rear Climate control
No Passenger Heated Mirror
No Power on rear view mirror
I've Ran Scan on controller and got the following , can anyone help
Chris
28-HVAC, Rear -- Status: Cannot be reached 0100
30-Special Function II -- Status: Malfunction 0010
3B-Sensor Elect. -- Status: Malfunction 0010
Address 01: Engine (------CWUC)       Labels: Redir Fail!
   Part No SW: 4G0 906 560 F    HW: 4H0 906 014
   Component: 4.0l V8TFSI / X63 0002
   Revision: NCX63---
   Coding: 122A00326526010B2800
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM40TFS0114G0906560F 001003
   ROD: EV_ECM40TFS0114G0906560F.rod
   VCID: 2B03078B638F1F5F4FB-807E
4718 - No Communication with Transmission Control Module
          U0101 00 [032] - -
Readiness: 0000 0001
   Part No SW: 4G0 927 158 BH    HW: 0BK 927 156 AM
   Component: 0BK 40TFSIRdW H22 1010
   Revision: --H22---
   VCID: 75B7E1F3F54B19AFE9F-8020
   Part No SW: 4G0 907 379 T    HW: 4G0 907 379 T
   Component: ESP9 Premium  H01 0100
   Coding: 62B7DA4146ED5B829F00
   Shop #: WSC 02391 785 00200
   ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
   VCID: 42DD4A2FF405FE179CD-8016
   Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
   Component: BCM2 2.0      H61 0825
   Coding: 01B9704E000000000000
   VCID: 7CA1F4D7D6E148E7961-8028
   Serial number: 3217000244032016
                    Fault Status: 00101101
                    Reset counter: 251
                    Mileage: 33061 km
                    Date: 2019.11.13
                    Time: 09:07:03
   Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
   Serial number: 02021800040043
   Coding: 682210B80D0000
   VCID: 6A8DC28FACF5C65774D-803E
0243 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Steuergerät für Bordnetz: Bitte Fehlerspeicher auslesen]
                    Reset counter: 211
                    Mileage: 33061 km
                    Date: 2019.11.13
                    Time: 09:12:12
                    Voltage terminal 30: 11.84 V
                    Outside air temperature: 10.0 °C
                    Engine speed: 0 /min
0317 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Klima hinten: kein Signal / Kommunikation]
                    Reset counter: 99
                    Mileage: 29650 km
                    Date: 2019.10.01
                    Time: 12:46:32
                    Voltage terminal 30: 12.17 V
                    Outside air temperature: 22.5 °C
0387 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Fault Frequency: 83
                    Reset counter: 248
                    Mileage: 33061 km
                    Date: 2019.11.13
                    Time: 09:12:12
   Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0368
   Revision: 1502003S    Serial number: 00001909785902
   Coding: 0105001440349FE0690140C7A0001800CF9DC70A2F08020180000894E100170200400024030000
   VCID: 74B1DCF7FEB100A7DE1-8020
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 171201  H38 0080
   Serial number:         171213172016
   Coding: 0045F7
   Serial number: 21178560X81A955547A0
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 01 02 2018  00000731
   Component: EVLS-SG  H08 0300
   Serial number: WA130066000042067972
   Coding: 020300
03123 - Terminal 30 - 2
                    Fault Status: 00101011
                    Reset counter: 251
                    Mileage: 33061 km
                    Date: 2019.11.13
                    Time: 08:57:39
01800 - Light Switch (E1)
                    Reset counter: 251
                    Mileage: 33061 km
                    Date: 2019.11.13
                    Time: 09:08:47
01543 - Parking Aid Warning Chime (H15)
                    Fault Status: 00101001
                    Reset counter: 251
                    Mileage: 33061 km
                    Date: 2019.11.13
                    Time: 09:12:08
01625 - Front Parking Aid Warning Chime (H22)
                    Reset counter: 251
                    Mileage: 33061 km
                    Date: 2019.11.13
                    Time: 09:12:08
                    Reset counter: 211
                    Mileage: 33061 km
                    Date: 2019.11.13
                    Time: 09:12:12
03608 - Humidity Sensor in Fresh Air Intake Duct
                    Fault Status: 01100101
                    Fault Frequency: 56
                    Reset counter: 248
                    Mileage: 33061 km
                    Date: 2019.11.13
                    Time: 09:12:12
   Component: Airbag10.43   H83 0098
   Revision: --------    Serial number: 003P100FT8D8
   Coding: 30333130313730323737554A305234473053
   VCID: 3B2337CB93EF8FDFDFB-806E
   Serial number: 3575HRB40125DLTM694J
   Serial number: 3585HRB400C5DL9MH9Q%
   Serial number: 3515JRB405T57BBU5PK8
   Serial number: 3525JRB404V583SQJ1A$
   Serial number: 3554VRB405T57BBE28S
   Serial number: 3564VRB405T57BBEB1Q$
   Component: Lenks.Modul   H05 0005
   Revision: --------    Serial number: 90372RB500017
   Coding: 000035
   VCID: 372B2BFBAF47ABBF3B3-8062
   Subsystem 1 - Part No SW: 4G0 951 528 J    HW: 4G0 951 528 J
   Serial number: 20 11 2017  E0032460
   Part No SW: 4G0 920 982 T    HW: 4G0 920 982 T
   Component: TBenGb    Nv  H17 0225
   Revision: 18001312    Serial number: 658240118592003
   Coding: 33AF910B9B412600010400
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K_AU57.rod
   VCID: 3D2739D38DFB81EFE1F-8068
   Part No SW: 4G8 907 468 K    HW: 4G8 907 468
   Component: J533--Gateway H15 0110
   Revision: --------    Serial number: 00000002885011
   Coding: C0ED07481C
   ASAM Dataset: EV_GatewPkoUDS 002011
   VCID: 40D94027FA09EC078A9-8014
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 8863905804
   Voltage stabilizer:
   Serial number: 17112400000000000275
5055 - No Communications with HVAC Control Module (J301)
          U0164 00 [008] - -
                    Reset counter: 251
                    Mileage: 33061 km
                    Date: 2019.11.13
                    Time: 09:09:30
                    Voltage terminal 30: 11.8 V
                    Voltage terminal 15: 0.1 V
                    Control Module temperature: 20 °C
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
5088 - Rear A/C control module
          U1072 00 [009] - No communication
                    Reset counter: 99
                    Mileage: 29650 km
                    Date: 2019.10.01
                    Time: 12:46:32
                    Voltage terminal 30: 11.9 V
                    Voltage terminal 15: 11.9 V
                    Control Module temperature: 32 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
4352 - ABS Control Module on FlexRay Data Bus
          U10BD 00 [008] - No Communication
                    Reset counter: 251
                    Mileage: 33061 km
                    Date: 2019.11.13
                    Time: 09:07:02
                    Voltage terminal 30: 12.1 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 19 °C
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H19 0200
   Serial number: 003001180001004
   VCID: 2809F88772793447A29-807C
0390 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Getriebe - Steuergerät keine Kommunikation DTC_FRAY_GETRIEBE_03_NO_COM]
                    Mileage: 29650 km
                    Date: 2019.10.01
                    Time: 12:46:39
Address 28: HVAC, Rear
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H07 0030
   Revision: S0H07000    Serial number: 00000000007234
   Coding: 01010101000000000001000102
   VCID: 6491ACB74E5190274E1-8030
                    Reset counter: 251
                    Mileage: 33061 km
                    Date: 2019.11.13
                    Time: 09:07:02
                    Reset counter: 251
                    Mileage: 33061 km
                    Date: 2019.11.13
                    Time: 09:07:02
   Coding: 008000
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F3B139B5797637F633-807A
   Revision: AA000000    Serial number: 00000299133283
   Coding: 0078130000006001000001010101102030303232203232
   VCID: 77ABEBFBEFC76BBFFB3-8022
                    Reset counter: 251
                    Mileage: 33061 km
                    Date: 2019.11.13
                    Time: 09:09:34
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E036GMJ
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 372B2BFBAFC7ABBF3B3-8062
3801346 - Databus
          [PDU Timeout]
                    Reset counter: 251
                    Mileage: 33061 km
                    Date: 2019.11.13
                    Time: 09:07:02
                    DCU_Internal_DTC: 3A 01 02
                    Ignition Cycle Count: 7805
                    DCU Temperature: 6 °C
                    Voltage VBG 22: 2.5 V
                    VIN received: 00000000000000000
                    Debug Data: 00 00 00 00 00 00 00 00
   Component: TSG FA        H03 0511
   Coding: 011F16015E21620002080002
   VCID: 47CB5B3BDFA7DB3F4B3-8012
   Component: RCevo         H55 0202
   Revision: 00000002    Serial number: 0000450894
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2D32CF9CD5B6D7C4D-806E
   Revision: 00002001    Serial number: 0470224473
   Coding: 013B0622A0B93894C3300984000113470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 B
   Component: Sensor, DWA  005 0002
   Subsystem 2 - Part No: 1K0 951 605 F
   Subsystem 3 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS20.403  H04 0005
   Serial number: 0000FST001YA3R300000
   Coding: 901E00
   Subsystem 4 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS20.403  H04 0005
   Serial number: 0000FST001YA36I00000
   Coding: 801E00
01308 - Control Module for Roof Electronics (J528)
                    Fault Frequency: 9
                    Reset counter: 223
                    Mileage: 29650 km
                    Date: 2019.10.01
                    Time: 12:46:36
                    Reset counter: 251
                    Mileage: 33061 km
                    Date: 2019.11.13
                    Time: 09:07:03
                    Reset counter: 251
                    Mileage: 33061 km
                    Date: 2019.11.13
                    Time: 09:09:34
                    Fault Frequency: 21
                    Reset counter: 7
                    Mileage: 33073 km
                    Date: 2019.11.13
                    Time: 10:58:17
00216 - Signal EC-mirror Fade Out
                    Fault Status: 01101100
                    Reset counter: 218
                    Mileage: 33201 km
                    Date: 2019.11.15
                    Time: 09:13:42
   Component: TSG BF        H03 0511
   VCID: 46D5563FD8ADC237B05-8012
                    Fault Frequency: 13
                    Reset counter: 206
                    Mileage: 29920 km
                    Date: 2019.10.03
                    Time: 16:54:26
   Part No SW: 4H0 907 801 N    HW: 4H0 907 801 M
   Component: EPB-4         H01 0020
   Revision: --------    Serial number: 00000002431642
   ASAM Dataset: EV_ParkiBrake 001033
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 33331FEBBBBF479F07B-8066
   Coding: 04FE02202A130200
   VCID: 34311CF7BEB140A71E1-8060
   Coding: E01F00
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E01F00
   Part No SW: 4G1 035 020 J    HW: 4G1 035 020 D
   Component: MU-H-ND-EU    054 0910
   Serial number: A735B0JS005423
   Coding: 017562010000000013111102000A00002F0008E7F1700100DF
   VCID: 2019E0A71A49CC07EA9-8074
   Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9HY809RDG
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349RB7000GS
   Compact Disc Database:
   Component: Gracenote2  --- 1016
   Component: TSG HL        H03 0511
   Coding: 010F14004021620002080002
   VCID: 49CF5D03C9B32D4F5D7-801C
Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273 B    HW: 4H0 907 273 B
   Component: RDKBERU25     H10 0820
   Serial number: 10000000047163
   ASAM Dataset: EV_RDKBERU25 003014
   ROD: EV_RDKBERU25_AU57.rod
   VCID: 2A0D028F6C750657B4D-807E
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0152
   Revision: 14005003    Serial number: 024801591
   Coding: 093205C010
   ROD: EV_HDSGAu571.rod
   VCID: 363526FFA8CD52B7205-8062
   Component: TSG HR        H03 0511
   Component: DPC-SG        H28 0081
   Coding: E0140000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C01049766811867461-8078
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H10 0008
   Revision: 00001001    Serial number: 97813009250001
   ROD: EV_AEMLearAU64X_AU57.rod
End----(Elapsed Time: 02:16, VBatt start/end: 11.9V/11.9V. VIgn 0.0V)------
myounus
Northwest UK
C?ID=321059
Can you please post a complete scan with the headers included. Thanks.
Has anybody or have you done any work on the car?
No Vign at the DLC either.
I would say it's time to study the wring diagrams for this car and look for a common point of supply voltage for all the things that aren't working.
RS6-CDUB
England
C?ID=373156
I’ve had Stage 2 remap and Akrapovic exhaust fitted
MartinsX
Riga, Latvia
C?ID=268515
I remember one Polo 9N where a lot of Airbag faults appeared after mechanical repairs done by another workshop. I tried to disconnect connector at CU, but I can't. I tried to remove Airbag control unit for inspection but I can't. All 3 fixing nuts were removed but unit was fixed in place like welded... Someone decided to fix exhaust heat shield from below with self-tapping screws directly to tunnel... and to Airbag CU as well :D:D:D Couple screws through bottom cover and through PCB, one through connector's male and female parts making them married forever :D:D:D
myounus
Northwest UK
C?ID=321059
Try clearing all faults and scanning again.
If faults return then check fuses first. If all good then it maybe loose plug or wiring as suggested��.
