VW caddy injectors
Boothy
Manchester UK
C?ID=305263
Hi All
Usual 1.6tdi Caddy problems 5 years old 30000 miles and three injectors gone.
First cylinder 3, replaced under warranty.
Second cylinder 2, new injector.
Third cylinder 1, I thought i would try a reconditioned injector.
The first two injectors no problem yet the third has left the engine noisy.
There were no faults on auto-scan so i assume its ok not to post.
I ran a Injection amount deviation, and this is were you guys come in and help me understand the values.
I am i right in thinking cylinder 1 should be a similar deviation to the other cylinders
	cylinder 1		cylinder 2		cylinder 3		cylinder 4
	  mg/stroke		  mg/stroke		  mg/stroke		  mg/stroke
	0.55	-1.5566		0.65	0.2349		0.77	0.4008		0.88	0.7722
	1.45	-1.446		1.55	0.1155		1.65	0.5715		1.77	0.7707
	2.3	-1.0988		2.4	0.0895		2.52	0.5609		2.62	0.7524
	3.14	-1.4991		3.24	0.1247		3.37	0.4514		3.49	0.7242
	4.02	-1.4918		4.14	0.0917		4.24	0.5484		4.37	0.7952
	4.93	-1.1695		5.02	0.1166		5.14	0.6019		5.24	0.7729
	5.8	-1.4054		5.93	0.1166		6.02	0.6088		6.14	0.574
	6.71	-1.4716		6.8	0.1357		6.92	0.4576		7.02	0.7198
	7.6	-1.5017		7.68	0.1199		7.8	0.5429		7.9	0.733
	8.43	-1.1464		8.55	0.1254		8.65	0.5909		8.74	0.5744
	9.3	-1.4823		9.42	0.1511		9.52	0.4418		9.65	0.6953
Thursday,21,November,2019,15:18:10:05886
VIN: WV1ZZZ2KZFX021268   License Plate:
Mileage: 55860km-34709mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 77
VIN: WV1ZZZ2KZFX021268   Mileage: 55860km-34709miles
Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 TK    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9977
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00254014032500080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023TK 003001
   ROD: EV_ECM16TDI02103L997557M.rod
   VCID: 025E838A748E7EF7DF3-8056
   Part No SW: 0AM 300 065 M    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6560
   Revision: 00043014    Serial number: CU501406086579
   Shop #: WSC 49678 001 1048576
   VCID: 392C24665558FD2FCE9-806C
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: 433C400D092403FBC20D02EA9021C081A1000020
   Shop #: WSC 35110 377 00144
   VCID: 7EA6F77A00F61A17BBB-802A
   Part No SW: 7N0 907 426 BT    HW: 7N0 907 426 BT
   Component: AC Manuell    H20 0607
   Revision: 00001004
   Coding: 0010004002
   VCID: 0748929E5FAC5BDF88D-8052
   Part No SW: 5K0 937 086 S    HW: 5K0 937 086 S
   Component: BCM PQ35 M+   122 0174
   Revision: BD122001
   Coding: 491A583E8025F16A088800829000016403017288524F8160648000000040
   VCID: 44D245922E9AB0C7ADF-8010
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 13051  26  0512
   Coding: 009795
   Subsystem 2 - Part No: 7N0 951 171 A
   Component: DWA-Sensor 00  002 0206
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 2K0 919 475     HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0004
   Revision: --------    Serial number: 32901417500455
   Coding: 108101
   ASAM Dataset: EV_EPHVA14VN3370000 001006
   ROD: EV_EPHVA14VN3370000.rod
   VCID: 70BAD9424A227C67397-8024
   Component: VW10Airbag02Q H07 0013
   Revision: --------    Serial number: 003HL00RE4NN
   Coding: 000000000000000000000000000000003251
   VCID: 3534285675C0194F2A1-8060
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20190206300055
   Coding: 1892160000
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H08 0010
   Serial number: 0010626
   Coding: 830000
   Part No SW: 2K0 920 976 E    HW: 2K0 920 976 E
   Component: KOMBI         H03 0905
   Coding: 180800
   VCID: 3330164E7BB4077F045-8066
   Part No SW: 7N0 907 530 AP    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1653
   Revision:   H57       Serial number: 250614F2002453
   Coding: 357401
   Component: IMMO          H03 0905
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8ECB2A6CFE86B7773-803E
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2110
   Coding: 0000560
   VCID: 48CA51A21EB294A7417-801C
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 140    3501
   Revision: 00H22000
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000560
   VCID: 47C8529E13AC9BDF48D-8012
   Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
   Component: RCD310 EU     H05 5006
   Revision: -----09S    Serial number: VWZ4Z2P1257858
   Coding: 05000200010013
   VCID: 72BED34A44AE4E77CF3-8026
   Part No SW: 7P6 035 730 M    HW: 7P6 035 730 M
   Component: TELEFON       H16 4217
   Revision: 1B001001    Serial number: 00007666392933
   Coding: 0A01010000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3C223D7256EAC807D5F-8068
End----------(Elapsed Time: 01:08, VBatt start/end: 12.3V/12.2V)-----------
Thanks Boothy
It would still be helpful. There's a lot if info in an Auto-Scan besides just fault codes. Things like the exact ECU variant, the software version that the ECU has in it, and so on.
MartinsX
Riga, Latvia
C?ID=268515
Are all replaced injectors adapted/coded as required?
Do the reconditioned one is reconditioned by qualified workshop having test stand and do it has got new trim code after repair?
Gone But Not Forgotten
BavarianCare
Ireland
C?ID=11022
In Ireland those are covered with lifetime warranty from VW provided software fix has been done.
Boothy
Manchester UK
C?ID=305263
Thanks for the replies.
All of the new injectors have been coded.
The reconditioned injector has passed there in house calibration, although their data sheet showed it failed on the Flush and NOP (nozzle opening pressure) test.
I did query theses failures and they said it would work fine.
I do use a redex diesel additive and use Costco UK fuel.
In the UK we are given two year warranty post fix.
MartinsX
Riga, Latvia
C?ID=268515
According Your log posted in first post injector for cylinder 1 may not be ok. To test try replacing it or swaping to another cyl.
Ethanol in diesel? I don't think so, and this isn't the first time I've questioned it.
Yeah I been questioning it too & almost on a daily, it seems fuel suppliers are indeed putting Ethanol in bio diesel and not even telling people it's bio diesel Uwe and sometimes with no ref to it in some regions at all, did you see the links?
Suitable for all commercial motor oils in gasoline and diesel engines with and without diesel particulate filter (DPF). Tested safe with catalytic converters and turbochargers. Our dosage recommendation: add from 3 – 5 % to motor oil. For motorcycles with wet clutches, add maximum 2 % of the oil filling volume.
Suitable for all 2-stroke and 4-stroke engines. 20 ml (1 tube) sufficient for 1 l of motor oil. 2-stroke engines: 10 ml per 10 l of fuel mixture or 20 ml for 400 ml of 2-stroke oil. Tested on engines with catalytic converters.
This is why I tried these in ALL fuels and so far shows positive results...........
https://www.energy.gov/eere/bioenergy/biofuels-basics
http://www.algaenergy.es/en/technol...iesel-and-e-ethanol-fuel-for-future-mobility/
FIRMWARE IS ABSOLUTELY AVAILABLE FOR THIS VEHICLE, NO?
https://vag-flashinfo.de/index.php?partno=03L906023TK&as=
Boothy
Manchester UK
C?ID=305263
I am in the process of finding out which prefix software was on my caddy, there is nothing on the ECU. My immediate problem is getting the injectors sorted out. Do you think a rollback will improve injector performance?
Nope but installation of a proper working and adapted injector set will, in addition to considered aforementioned solutions to cause to prevent it.
Did you know there is an update available going forward?
What does Costco rate the fuel as B7, ED etc.?
Post a picture of the fuel pumps and data sheets please.
Boothy
Manchester UK
C?ID=305263
I hope this is of use.
Deposit control additives:
Every grade of Kirkland Signature™ Fuel contains deposit control additive that keeps your engine protected and running like new.
Variations in deposit control additive formulations are the main difference between brands of fuel. Kirkland Signature™ Fuels have been proven to clean deposits and restore dirty engine components to like-new performance.
To comply with the Renewable Transport Fuel Obligation (RFTO) order and European legislation, a certain amount of ethanol may be blended with British Standard petrol (BS EN 228) and biodiesel with British Standard diesel (BS EN 590).I hope this is of use.
Westbury, UK
Pump labelling was introduced in the UK in the second half of 2019, diesel pumps are now labelled B7 and petrol (gasoline) labelled E5.
A lobby group are calling for all UK petrol (gasoline) to become E10 in 2020, but the Government have not decided what to do yet.
Well, I think that settles what is damaging pumps or injection systems, no?
Alcohol!
Westbury, UK
Alcohol!
When I went to France a couple of years ago in one small town the only available gasoline was E10, it took less than 10 miles for the wide range lambda sensor on my 1.4TSI Skoda Octavia to "throw it's toys out of the pram" by reporting crazy inconsistent values. Since the next refill (with E5 gasoline) and clearing the DTC all has been back to normal with no spurious DTCs from the lambda sensor.
Now I avoid E10 gasoline like the plague, if it ever becomes "normal" in the UK I'll be spending most of the time driving with the emissions light on :banghead:
I would speculate you got a bad batch of fuel in your tank. Almost all the gasoline sold here in the US is E10 and while one can certainly see the difference between it and non-ethanol gasoline if one looks at the fuel trims (I've done this!), using it should not set any DTCs unless something is already much closer to the edge than it should be.
