Monday,04,February,2019,18:01:47:12530
-- Windows Based VAG/VAS Emulator Running on Windows 7 x64
Version: 18.9.0.2 (x64) HEX-V2 : 0.4436.4
Data version: 20181017 DS296.0
VIN: WAUZZZ4G8GN095717 License Plate:
Mileage: 45117km-28034mi Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 3B 42 44 46 52 53 55 5F
62 72 A9 AC C0
VIN: WAUZZZ4G8GN095717 Mileage: 45117km-28034miles
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: OK 0000
Address 01: Engine (J623-CVUA) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 589 D HW: 4G0 907 589 B
Component: 3.0BTD EDC17 H23 0002
Revision: 54H23---
Coding: 0A2A4032252603030000
Shop #: 02391 785 00200
Dataset: EV_ECM30BTD0114G0907589D 001002
ROD: EV_ECM30BTD0114G0907589D.rod
VCID: 3537DC9805C2798F7D3-8060
Part No SW: 4G0 927 158 AK HW: 0BK 927 156 AM
Component: 0BK 30RTDIRdW H19 1005
Revision: --H19---
Shop #: 00000 000 00000
Dataset: EV_TCMAL551211 002022
VCID: 77AB16905F4E4B9FAFF-8022
Address 03: Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 49A79E4192E579829B00
Dataset: EV_ESP9BOSCHAU57X 004018
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41DFB848410AC52FD1B-8014
Address 05: /Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 GN HW: 4H0 907 064 GN
Component: BCM2 2.0 H37 0572
Coding: 01B8704E000000000000
VCID: 7BA30AA063E66FFFCB7-802E
Component: J764 ELV H40 0046
Serial number: 0215000188678006
Part No SW: 4G0 820 043 CC HW: 4G0 820 043 CC
Serial number: 08101500040560
Coding: 36211178210000
Dataset: EV_AirCondiComfoUDS 003008
VCID: 629D57C4E4CCBE37E81-8036
0243 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[Steuergerät für Bordnetz: Bitte Fehlerspeicher auslesen]
Reset counter: 57
Mileage: 42778 km
Date: 2018.12.16
Time: 12:44:15
Voltage terminal 30: 11.65 V
Outside air temperature: 5.5 °C
Engine speed: 999 /min
0387 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Fault Frequency: 211
Reset counter: 109
Mileage: 42778 km
Date: 2018.12.16
Time: 12:44:14
Voltage terminal 30: 11.34 V
Engine speed: 1017 /min
Address 09: Cent. Elect. (J519) Labels:. User\4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00001182453302
Coding: 0105801440349FE0410140C0000018000F9DC3082F08020100000894E100150200400024030000
VCID: 71BF288831AA15AF61B-8024
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 150715 H38 0080
Serial number: 150819223949
Coding: 0045F7
Component: G397_RLFS H06 0004
Serial number: 20763505
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - H07 0044
Serial number: 13 10 2015 00000873
Serial number: ED8880D7000000000001
Reset counter: 57
Mileage: 42778 km
Date: 2018.12.16
Time: 12:44:15
Revision: -------- Serial number: 003P1006SWY0
Coding: 30333130313730323737554A305234473053
Dataset: EV_AirbaAU10BPAAU64X 001014
VCID: 3B23CAA023E6AFFF8B7-806E
Serial number: 3575HRB40633JUD03OCK
Serial number: 3585HRB40573KGI0APDP
Serial number: 3515JRB404T3JK6259MM
Serial number: 3525JRB40633FSTU6HIG
Serial number: 3554VRB400S553HED8T/
Serial number: 3564VRB400S553HED90D
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862OJC00068
Coding: 000034
VCID: 3B23CAA02366AFFF8B7-806E
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Serial number: 01 09 2015 C0002893
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 986 M HW: 4G8 920 986 M
Component: TDieGb H11 0106
Revision: 07001088 Serial number: 658150915596041
Coding: 23A70A000B412600010000
Dataset: EV_RBD4K 004055
ROD: EV_RBD4K.rod
VCID: 42DDB744440CDE37C81-8016
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G8 907 468 F HW: 4G8 907 468
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000002004092
Coding: C0CD078118
Dataset: EV_GatewPkoUDS 001028
Serial number: 1931577903
Voltage stabilizer:
Serial number: 150725000000000004E9
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: H04 0021
Revision: AA001002
Coding: 04028264747464545425363E00
VCID: 678B46D00F6EDB1F3FF-8032
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 09101500040125
Coding: 22
Dataset: EV_ClimaContrUnitRearUDS 003004
VCID: 3D27C4B83DF2A1CFB53-8068
0075 - Button or Switch in Operating Unit
B10C7 07 [008] - Mechanical Failure
Reset counter: 149
Mileage: 45111 km
Date: 2019.02.04
Time: 15:44:27
Outside air temperature: 6.5 °C
Left rear vent temperature: 10.3 °C
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720KW0DP
Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3333E2800BB667BF537-8066
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: FA H03 0511
Coding: 011C16014001620002080002
VCID: 47CBA6506FAEFB1F1FF-8012
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H53 0202
Revision: 00000002 Serial number: 0000283456
Coding: 101000010001
Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A2DCFA42CDC96F7901-806E
Revision: 00002001 Serial number: 0382488804
Coding: 011F062280B90000C320080400010E470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 A
Component: Sensor, DWA 005 0002
Component: BACKUP HO H05 1501
Address 52: Door Elect, Pass. (J387) Labels: None
Component: BF H03 0511
VCID: 46D5AB5468A4E217E49-8012
Component: -4 H04 0015
Revision: -------- Serial number: 00000001619448
Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D07F4F8ED92314F053-8078
Component: - 001 0100
Coding: 04FE02102A630200
Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
VCID: 3431E19C0EB860874AD-8060
Coding: E01E00
Coding: E01E00
Part No SW: 4G1 035 021 E HW: 4G1 035 021
Component: MU-H-LND-EU 042 0335
Serial number: A588J0F7528209
Coding: 017501010000000013111102000A00132F0006E7F1700100DF
Dataset: EV_MUHig6C3Gen2HBAS 001115
VCID: 1C61293C8628C8C762D-8048
Subsystem 1 - Part No SW: V03 959 801 FC HW: -----------
Component: ECE 2017 --- 0157
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0006
Serial number: AUZ8Z9FY802QD8
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
Serial number: 90349OJ6000EJ
Compact Disc Database:
Component: Gracenote --- 1010
Address 62: Door, Rear Left (J388) Labels: None
Component: HL H03 0511
Coding: 010814004001620002080002
VCID: 49CFA06879BA0D6F09B-801C
Address 72: Door, Rear Right (J389) Labels: None
Component: HR H03 0511
Part No SW: 4G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0007
Serial number: 151002203103
Dataset: EV_SoundActuaGen2AU64X 003010
VCID: 2E05F3F4E0944A573C9-807A
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 152451062
Dataset: EV_RDCMA00100 008040
ROD: EV_RDCMA00100_008.rod
VCID: 2F3BEEF0E79E435F37F-807A
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 4G0 907 160 E HW: 4G0 907 160 B
Component: SAS-GEN 2 H09 0011
Serial number: 151001200324
Dataset: EV_ActuaForExterNoiseUDS 003013
ROD: EV_ActuaForExterNoiseUDS.rod
VCID: 270B06D0CF6E1B1FFFF-8072
End----------(Elapsed Time: 02:05, VBatt start/end: 13.5V/14.4V)-----------
