Audi A1 2013 Model
Kam
United Kingdom
C?ID=41543
Hi I have a Audi A3 and have an issue with the Gearbox 7 speed DSG.
The gearbox itself has a mechanical breakdown and hence the selector lever is stuck. The TCM mechatronic unit seems fine.
However I am looking at replacing the Gearbox, which comes complete with new TCM/mechatronics unit, the question is does this vehicle need any security login or dealer level online coding? This is because I believe that the VIN and the possibility of Immobiliser information is stored in the TCM.
Auto scan Attached below
Wednesday,20,November,2019,14:49:19:32967
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 19.6.2.0 HEX-NET CB: 0.4508.4
VIN: WAUZZZ8X4DB082602 License Plate: KU13 MMO
Mileage: 109340km-67940mi Repair Order:
Chassis Type: 8X-AU21 (8U0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 62 72
VIN: WAUZZZ8X4DB082602 Mileage: 109340km-67940miles
Address 01: Engine (J623-CAXA) Labels:. 03C-906-016-CAX2.clb
Part No SW: 03C 906 016 DM HW: 03C 906 016 BG
Component: 1.4l R4/4V TS H11 7526
Revision: LEH11--- Serial number:
Coding: 00250032002401000000
Shop #: WSC 57361 001 1048576
ASAM Dataset: EV_ECM14TFS01103C906016DM 001009
ROD: EV_ECM14TFS01103C906016DM.rod
VCID: ED9241E83C11B927FC-80B8
Readiness: 1110 0101
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 060 E HW: 0AM 927 769 D
Component: GSG DSG AG7 431 5220
Revision: 00043014 Serial number: CU501301245247
Shop #: WSC 61773 001 1048576
VCID: AC148CEC0E8B702FAB-5160
001836 - Gear 1
P072C - 000 - Not Selectable - Intermittent
Mileage: 109340 km
Date: 2019.11.20
Time: 14:44:02
005949 - Position Sensor 4 for Gear Selector
P173D - 000 - Implausible Signal - Intermittent
Mileage: 109340 km
Date: 2019.11.20
Time: 14:44:24
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6R0 907 379 BR HW: 6R0 907 379 BA
Component: ESP9.0i front H02 0003
Serial number: --------------
Coding: 33DF488B432B02C2CC1A1269C25340951104
Shop #: WSC 00046 412 00000
ASAM Dataset: EV_Brake1ESP90iBOSCH 003031
ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
VCID: 8F6E3B6056DD2B37AE-80DA
Address 08: Auto HVAC Labels: None
Part No SW: 8X0 820 045 A HW: 8X0 820 045 A
Component: J255 Klima Manuell 0150
Revision: 0000708S Serial number: 03030018068685
Shop #: WSC 00046 000 00000
VCID: B424948CD7BB28EFF3-80E0
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 K HW: 8X0 907 063 K
Component: BCM PQ35 M 111 0715
Revision: AH111715
Coding: 0E000A2CA805F1C0201841E00100015443FB6C0A00EF4922DC0087830041
VCID: C4C4C44C471B986F43-8090
Subsystem 1 - Part No SW: 8U0 955 559 A HW: 8U0 955 559 A Labels: 8U0-955-559.CLB
Component: G397_RLS H06 0002
Serial number: 20106850
Coding: 02005D
Subsystem 2 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0020
02740 - Bulb for Tail Light 2; Left
Fault Status: 00101010
Reset counter: 225
Mileage: 109340 km
Date: 2019.11.20
Time: 14:37:33
Voltage: 14.40 V
Term 50 On
Address 10: Park/Steer Assist (J446) Labels:| 8X0-919-475.clb
Part No SW: 8X0 919 475 M HW: 8X0 919 475
Component: PARKHILFE 4K H03 0051
Revision: 11001001 Serial number: 37061302301775
Coding: 000101
ASAM Dataset: EV_EPHVA14AU21X0000 002005
ROD: EV_EPHVA14AU21X0000_002.rod
VCID: D0ECF81C8B6374CFF7-8084
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8X0 959 655 B HW: 8X0 959 655 B
Component: Airbag10.41 H05 0009
Revision: -------- Serial number: 003KZ0040WRZ
Coding: 30323236303230303138554A305238583053
ASAM Dataset: EV_Airba1041BPAAU210 001018
ROD: EV_Airba1041BPAAU210.rod
VCID: C9DAD57868394507B0-809C
Serial number: 3554VRB40044UOUE99PO
Serial number: 3575HRB405T1SJR2B9KF
Serial number: 3585HRB405L1SJR2BPUY
Rear Impact Crash Sensor:
Serial number: 3515ZRB40124UIV8819V
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 501 D HW: 5K0 953 569 H
Component: LENKS.MODUL 016 0140
Revision: FF010017 Serial number: 20130121201509
Coding: 1994204000
VCID: BB36BFB032E5E79732-80EE
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb-SRI1
Part No SW: 8X0 920 980 F HW: 8X0 920 980 F
Component: KOMBI_MEDIUM H03 0252
Coding: 41CE00
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04396
VCID: C2C8C254550F965F71-8096
1048578 - No Basic Setting
B2010 00 [009] - -
[Steuergerät keine oder falsche Grundeinstellung / Adaption]
Reset counter: 183
Mileage: 109330 km
Date: 2019.11.16
Time: 10:11:20
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8U0 907 468 G HW: 8U0 907 468 G
Component: GAT 4CAN 1L M H13 0059
Revision: 1P100034 Serial number: 3441P131230608
Coding: FBCF1064000100010353
VCID: C6C0DE447127AA7F5D-8092
Subsystem 1 - Part No SW: 8K0 915 181 L HW: 8K0 915 181 L
Component: J367-BDM H08 0181
Serial number: 00000000002040896420
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 121126000000000000E8
Component: IMMO H03 0252
Coding: 000002
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 H HW: 8X0 959 793 H
Component: TSG FA H10 0415
Coding: 011802201C01000000
VCID: D2E8F2148D6F06DFC1-8086
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11251
Shop #: WSC 00046
VCID: B02C989C77A314CF97-80E4
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 H HW: 8X0 959 792 H
Component: TSG BF H10 0415
Coding: 011802201E01000000
VCID: D1EAFD1888697DC7F8-8084
Part No SW: 8X0 035 183 F HW: 8X0 035 183 D
Component: RMC Cnct H53 0801
Coding: 01010400000053070023020103010000010000
VCID: BA38BAB435DFDE9F29-80EE
Subsystem 1 - Part No SW: 8X0 919 603 A HW: 8X0 919 603 A
Component: DU6 Basic H43 0084
Serial number: 9462AP0D2626206
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 8X0 959 795 D HW: 8X0 959 795 D
Component: TSG HL H07 0415
Coding: 010002200001000000
VCID: D0ECF81C836374CFF7-8084
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H07 0415
End----------(Elapsed Time: 01:24, VBatt start/end: 14.4V/14.4V)-----------
Kam
United Kingdom
C?ID=41543
Oops sorry this was posted in new users instead of Car repairs forum.
