- Nov 5, 2018
- 46
- 7
- Europe - Hungary
- C?ID=338434
I can't read out a brand new 2019 Touareg. Only just gateway controller.
What is the solution?
Ignition was on (the engine not run)
I lost a customer...
Wednesday,20,November,2019,15:45:48:64377
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
VCDS Version 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
Workshop Code: 790 73430 000063
VIN: License Plate: RMA-627
Gateway Installation List: 4N2 907 468 AB
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
Chassis Type: 4N2
Scan: 01 02 03 06 09 13 15 16 17 19 2B 36 42 44 46 52 5F 65 6C 6D
74 81 A5 AC CA CB
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
Address 06: Seat Mem. Pass
Address 09: Cent. Elect.
Address 13: Auto Dist. Reg
Address 15: Airbags
Address 16: Steering wheel
Address 17: Instruments
Part No SW: 4N2 907 468 AB HW: 4N2 907 468 AB
Component: Gateway H14 0037
Revision: 8P030005 Serial number: 0588P511319326
Coding: 0301000300000E407F07000000DB05325A9E00071C000000037D078E10000100
Shop #: WSC 31414 029 00001
ASAM Dataset: EV_CGateCONTIAU491 003150
ROD: EV_CGateCONTIAU491_003_AU58.rod
VCID: 79AFEE9F2956E55F8E9-802D
Subsystem 1 - Part No SW: 5G0 959 442 AB HW: 5G0 959 442 AB Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0052
Serial number: 39190000030640069044
Coding: 2DFFFF
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 2981111005
Address 2B: Steer. Col. Lock
Address 36: Seat Mem. Drvr
Address 44: Steering Assist
Address 46: Central Conv.
Address 52: Door Elect, Pass.
Address 65: Tire Pressure
Address 6C: Back-up Cam.
Address 6D: Trunk Elect.
Address 74: Chassis Control
Address 81: Gear Shift
Address A5: Frt Sens. Drv. Assist
Address AC: Reductant Control
Address CA: Sunroof
Address CB: Rear Axle Steering
End----(Elapsed Time: 00:33, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
