Hello everyone
Need some help with GTE Passat. Factory installed headlights were LED Lows and now I have retrofitted those to OEM high ones. Adapters and aLWR module from Kufatec. Also coded with Kufatec-dongle.
Problem is that the main beams and static cornering lights are not working at all. Dipped beams, dlr's and turn signals are ok. AFS fault is showing in MIB
Any idea?
Any idea?
Wednesday,20,November,2019,11:11:51:55961
Dealer/Shop Name: T.R
Workshop Code: 103 05311 000001
VIN: WVWZZZ3CZGE160285 License Plate:
Mileage: 63079km-39195mi Repair Order: forum
Chassis Type: 3C-VW48 (5QE)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 23 2B 42 44 51 52 55
5F 69 6C 75 8C A9 BB BC C6
VIN: WVWZZZ3CZGE160285 Mileage: 63079km-39195miles
Address 01: Engine (J623-CUKC) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 023 AH HW: 04E 907 309 F
Component: R4 1.4l TFS H22 3379
Revision: X3H22---
Coding: 011D001A647405083000
Shop #: WSC 40850 222 12345
ASAM Dataset: EV_ECM14TFS01104E906023AH 006006
ROD: EV_ECM14TFS_006_VW48.rod
VCID: 6695B68ED8EA64A753B-8032
Readiness: 1110 0001
Part No SW: 0DD 300 045 T HW: 0DD 927 770 B
Component: GSG DQ400E H31 1601
Revision: 00031033 Serial number: TFK01511280148
Shop #: WSC 40850 222 00000
ROD: EV_TCMDQ400021_VW37.rod
VCID: 382928F6C2DE2257317-806C
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Part No SW: 3Q0 907 379 S HW: 3Q0 907 379 G
Component: ESC H42 0823
Revision: 00000000 Serial number: 63425000000230
Coding: 0FEC408F3826336C0779060841C849F0021CCCE0608292F118A1F078C202
Shop #: WSC 45182 002 1048576
ASAM Dataset: EV_Brake1UDSContiMK100OMG 002001
ROD: EV_Brake1UDSContiMK100OMG_002.rod
VCID: 4ACD623EAC32A0C7573-801E
Part No SW: 3Q0 959 435 B HW: 3Q0 959 435 B
Component: VWKESSYMQB 026 0710
Revision: 00026000 Serial number: 0392284624
Coding: 000F0F0F03
Shop #: WSC 05311 115 00300
ROD: EV_KessyHellaMQBAB_VW48.rod
VCID: 392F2DF2F9D43B5FCE9-806C
Part No SW: 5GE 907 044 E HW: 5GE 907 044 E
Component: Climatronic H04 1301
Revision: 00001K07
Coding: 1202100420010101001550000010180A
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_ACClimaBHBVW37X 005137
VCID: 3E253EEEE0FA1C67FBB-806A
Subsystem 3 - Part No SW: 3Q0 963 231 A HW: 3Q0 963 231 A
Component: J848 HV-PTC 200 0202
Serial number: -00100.2T.1B20340259
Air quality sensor:
Air Conditioning Compressor Sub:
H02
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Revision: -------- Serial number: 86580601161522
Coding: 00031C46C3D102F72F8C5094B13C07381C80000000000000000000000000
Shop #: WSC 17873 123 50804
ROD: EV_BCMBOSCH_015.rod
VCID: 03538F1ACB98B18FD45-8056
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 151208 042 0607
Serial number: 160109213215
Component: RLHS 037 0059
Serial number: S3Y16M01D13H20M57S48
Coding: 90A8DD
Subsystem 3 - Part No SW: 3G0 941 633 J HW: 3G0 941 633 J
Component: E1 - LDS MQB H01 0032
Serial number: 27 10 2015 10001293
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY153210SL3
Serial number: 00000000000064437426
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 39391601204423
Coding: 0071151911
Shop #: WSC 05311 115 00093
VCID: 44D14C068E1676B7ADF-8010
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Coding: 5200678A11FFC428949C804D
ROD: EV_ACCBOSCHVW48X.rod
VCID: 34311CC6DEB6C6371DF-8060
Part No SW: 5Q0 959 655 S HW: 5Q0 959 655 S
Component: AirbagVW20 010 0870
Serial number: 003MFR01SDR7
Coding: 88CCC000002000005C5400CF004800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 50F970564A6E9A17197-8004
Belt Pretensioner left:
Serial number: 3G1857705G0156Q01110
Coding: 80000D
Belt Pretensioner right:
Serial number: 3G1857706G0183Q00202
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 000 601 16
Serial number: 35700000000F0924281D
Subsystem 4 - Part No SW: ----------- HW: 480 000 601 16
Serial number: 35800000000739242819
Subsystem 5 - Part No SW: ----------- HW: 480 401 012 15
Serial number: 35100029B1E3EAA41316
Subsystem 6 - Part No SW: ----------- HW: 480 401 012 15
Serial number: 3520002AF1E3EAA2E22N
Subsystem 7 - Part No SW: ----------- HW: 480 402 909 16
Serial number: 3550002A1229A29501E.
Part No SW: 3Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20160114500578
Coding: 0410
Shop #: WSC 00015 115 00001
ROD: EV_SMLSVALEOMQB.rod
VCID: 3D2739E2EDFC077FE21-8068
Part No SW: 3G0 920 794 D HW: 3G0 920 794 D
Component: KOMBI 401 4191
Coding: 07AD0B182FC000080C886F111600002000000000
VCID: 2D0709A23D9C97FF521-8078
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 F HW: 5Q0 963 272 F
Component: STH-MQB 007 0072
Coding: 13C1
Shop #: WSC 15486 002 1048576
Subsystem 1 - Part No SW: 5Q0 963 513 A HW: 5Q0 963 513 A
Component: R149 T91-LIN 003 0301
Serial number: 00000000000001301585
Address 19: CAN Gateway (J533) Labels:* Redir Fail!
Part No SW: 5QE 907 530 E HW: 5QE 907 530 A
Component: GW MQB EV 312 3245
Revision: -------- Serial number: 12011610800494
Coding: 020300172EF21000FF00527E5C1F00000001070100010000000300000000
Shop #: WSC 05311 103 00001
ASAM Dataset: EV_GatewEVConti 013020
ROD: EV_GatewEVConti_013.rod
VCID: 48C95836B23E52D7417-801C
Subsystem 1 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 29150002460490115504
Coding: 2DFFFF
Subsystem 2 - Part No SW: 3Q0 915 181 A HW: 3Q0 915 181 A
Component: J367-BDMHella H04 8050
Serial number: 5543008303
Analog clock:
Subsystem 3 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Address 23: Brake Booster (J539) Labels:* None
Part No SW: 5QE 909 059 D HW: 5QE 909 059 B
Component: EBKV H14 0182
Serial number: 085430011074
Coding: 05720100431900020002060500
Shop #: WSC 17300 205 00000
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
ROD: EV_BrakeBoostBoschMQBOMG_003_VW37.rod
VCID: 4FFB732A575085EF00D-801A
Brake Assistance Sub:
Subsystem 1 - Part No SW: 5QE 909 057 C HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0152
Serial number: 05802861141215125525
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 15000180983012
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71BFD5D2E124B31F369-8024
Component: TSG FS 020 0041
Serial number: 101115BK904191
Coding: 003F0E208000028000001000
VCID: 43D34F1A8B18718F945-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 M HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2041
Revision: 00000000 Serial number: 0000569007
Coding: 01000010005101
Shop #: WSC 00015 115 00300
ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
Address 51: Electric Drive (J841) Labels: None
Part No SW: 3G0 907 080 E HW: 3G0 907 080 D
Component: LE Gen 3.3H10 0072
Revision: 00H10000
Coding: C0020000000000000000
Shop #: WSC 09502 002 1048576
ASAM Dataset: EV_DMCM08530113G0907080E 001017
ROD: EV_DMCM08530113G0907080E.rod
VCID: 270BFB8A1F60BDAFA8D-8072
Component: TSG BFS 020 0041
Serial number: 071115BK611649
Coding: 003F00208000028000001000
VCID: 42DD4A1E940278879F3-8016
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0120
Coding: 039A00000F200200
ROD: EV_HeadlRegulAFSMQBMLB.rod
VCID: 3FDB43EAE7F0156FF0D-806A
Subsystem 1 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _
Component: LeiMo links H02 0003
Coding: E02400
Subsystem 2 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _
Component: LeiMo rechts H02 0003
Coding: E02400
5545009 - LED Headlamp Power Output Stage; Left
B149C 31 [137] - No Signal
Reset counter: 58
Mileage: 63079 km
Date: 2019.11.20
Time: 11:04:37
5544753 - LED Headlamp Power Output Stage; Right
B149B 31 [137] - No Signal
Reset counter: 58
Mileage: 63079 km
Date: 2019.11.20
Time: 11:04:37
Part No SW: 5NA 035 022 D HW: 5NA 035 022
Component: MU-H-LND-EU H55 1367
Serial number: A846J0JS022231
Coding: 028482010000000051110001008808101F0109F441A002009C
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H50 9120
Serial number: VWZ6ZHT1600142
Subsystem 2 - Part No SW: V03 959 806 FM HW: -----------
Component: ECE 2019/2020 --- 0177
Compact Disc Database:
Component: Gracenote2 --- 1017
Part No SW: 5Q0 907 383 G HW: 5Q0 907 383 D
Component: Anhaenger H21 0203
Revision: 8A001003 Serial number: 0392243933
Coding: 0100000202000000
VCID: 3B2337FAF3E8094FDC5-806E
Part No SW: 5Q0 980 556 HW: 5Q0 980 556
Component: RVC Compact H09 0170
Coding: 0184020163002217000041
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
ROD: EV_CamSysRVRVCPANAMQBAB_005_VW48.rod
VCID: 77ABEBCA8F40ED2FF8D-8022
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 284 C HW: 5QE 035 284 C
Component: OCULowMQBEU 012 0715
Coding: 0284720110169A0300F800000000
ROD: EV_OCULowMQB.rod
Address 8C: Hybrid Battery (J840) Labels: 5QE-915-227.clb
Part No SW: 3Q0 915 227 P HW: 3Q0 915 227 K
Component: K8C H05 0520
Serial number: 20111515010233
ASAM Dataset: EV_BECM09620213Q0915227P 002009
ROD: EV_BECM09620213Q0915227P.rod
Battery Junction Box:
Subsystem 1 - Part No SW: 3Q0 915 227 J HW: 3Q0 915 227 J
Component: A2 HVSMBJBECU H08 0410
Serial number: 00000007111514010009
Cell module: control module 1:
Subsystem 2 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC1 H04 0442
Serial number: 15914ZKK311A01040871
Cell module: control module 2:
Subsystem 3 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC2 H04 0442
Serial number: 15914ZKK311A01040670
Cell module: control module 3:
Subsystem 4 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC3 H04 0442
Serial number: 15914ZKK311A01041076
Cell module: control module 4:
Subsystem 5 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC4 H04 0442
Serial number: 15914ZKK311A01040384
Cell module: control module 5:
Subsystem 6 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC5 H04 0442
Serial number: 15914ZKK311A01040248
Cell module: control module 6:
Subsystem 7 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC6 H04 0442
Serial number: 15914ZKK311A01040322
Cell module: control module 7:
Subsystem 8 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC7 H04 0442
Serial number: 15915ZKK311A01040183
Cell module: control module 8:
Subsystem 9 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC8 H04 0442
Serial number: 15917ZKK311A01040047
Part No SW: 3G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0006
Serial number: 151116200427
VCID: 698FBDB2C9F44BDF7E9-803C
Component: TSG HFS 020 0041
Serial number: 091215BL901256
Coding: 000E00200100028000001000
Shop #: WSC 13623 002 1048576
VCID: 45D75102852C4FBFBA1-8010
Component: TSG HBFS 020 0041
Serial number: 091215BL901253
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 5QE 915 682 M HW: 5QE 915 682 M
Component: OBC KOSTAL H31 4006
Revision: -------- Serial number: 0607160G40004D
Coding: 115068222000
ASAM Dataset: EV_OBCSinglPhaseKLOMQB11P 004001
ROD: EV_OBCSinglPhaseKLOMQB11P.rod
VCID: 57EB8B4A6F80CD2FD8D-8002
End----------(Elapsed Time: 02:24, VBatt start/end: 13.2V/13.2V)-----------
