Hi,
Is there a way to reset timing chain stretch adaption and oil pressure break in on newer 2.0l FSI AND TFSI engines (ex: CAED, CCTA, etc.) after replacing the timing chain and tensioner? There is a test plan in ODIS for this. I read that this should be reset and someone said that clearing the codes 3x in 10 seconds with VCDS will do this. Is this correct? Are there values to look at to confirm it has been reset sucessfully?
Thanks for any help or info.
Here is an applicable autoscan.
Friday,18,October,2019,13:37:10:57829
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4513.4
VIN: WAUAFAFL7FN012035 License Plate:
Mileage: 108270km-67275mi Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 44 46 47 52 53 56 62 72
77
VIN: WAUAFAFL7FN012035 Mileage: 108270km-67275miles
Address 01: Engine (MY15-CAED) Labels:. 06H-907-115-CDN.clb
Part No SW: 8K5 907 115 M HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0005
Revision: ECH09---
Coding: 4A030013242400062000
Shop #: WSC 47412 001 1048576
ASAM Dataset: EV_ECM20TFS0118K5907115M 001006
ROD: EV_ECM20TFS0118K5907115M.rod
VCID: BC346E99378AC2AF3B-80E8
8 Faults Found:
4573 - Ignition Control Circuit for Cylinder 3
P0353 00 [096] - Malfunction
Mileage: 108276 km
Date: 2019.10.14
Time: 08:38:49
Engine speed: 1205.50 /min
Normed load value: 34.5 %
Coolant temperature: 24 °C
Intake air temperature: 18 °C
Voltage terminal 30: 13.900 V
Engine status: COENG_RUNNING
4574 - Ignition Control Circuit for Cylinder 4
P0354 00 [104] - Malfunction
Mileage: 108276 km
Date: 2019.10.14
Time: 08:36:36
Engine speed: 1033.00 /min
Normed load value: 19.6 %
Coolant temperature: 30 °C
2697 - Fuel Pressure Sensor (G247)
P0190 00 [032] - Circuit Malfunction
Mileage: 108276 km
Date: 2019.10.14
Time: 07:16:13
Engine speed: 0.00 /min
Coolant temperature: -40 °C
Intake air temperature: 17 °C
Voltage terminal 30: 14.347 V
Engine status: COENG_FINISH
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 5
2778 - Engine Coolant Temp. Sensor (G62)
P0118 00 [100] - Signal too High
Mileage: 108276 km
Date: 2019.10.14
Time: 07:16:13
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [237] - -
Mileage: 108276 km
Date: 2019.10.14
Time: 07:16:05
Engine speed: 3382.00 /min
Normed load value: 52.9 %
Coolant temperature: 19 °C
Intake air temperature: 19 °C
Voltage terminal 30: 13.970 V
10594 - Cylinder 4
P0304 00 [237] - Misfire Detected
Mileage: 108276 km
Date: 2019.10.14
Time: 07:16:10
10592 - Cylinder 2
P0302 00 [237] - Misfire Detected
Mileage: 108276 km
Date: 2019.10.14
Time: 08:41:42
Engine speed: 816.00 /min
Normed load value: 22.7 %
Voltage terminal 30: 14.088 V
10205 - Cylinder Disabling
P130A 00 [032] - -
Mileage: 108276 km
Date: 2019.10.16
Time: 13:55:43
Engine speed: 1229.50 /min
Normed load value: 44.3 %
Vehicle speed: 14 km/h
Coolant temperature: 21 °C
Intake air temperature: 20 °C
Voltage terminal 30: 13.570 V
Readiness: 1110 0101
Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
Part No SW: 8K9 927 155 HW: 0AW 927 156 K
Component: 0AW 20TAVSUSA H07 0003
Revision: --H07--- Serial number: 0000001163
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMVL381 A02433
ROD: EV_TCMVL381.rod
VCID: F9BAB78D7838378760-80AC
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CN HW: 8K0 907 379 CN
Component: ESP8 front H09 0020
Coding: 081D1801
VCID: 875EC17536CC517766-80D2
Part No SW: 8K0 907 064 JL HW: 8K0 907 064 JL
Component: BCM2 2.0 H14 0650
Coding: 09814040000000000000
VCID: 8346D56502F47D573A-80D6
Subsystem 1 - Part No SW: 8K0 959 754 F HW: 8K0 959 754 F
Serial number: 0514000117250002
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 0214000151117010
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Revision: C1000000 Serial number: 01250820140505
Coding: 6400208000
VCID: F7BEB1B5462C21F716-80A2
Reset counter: 65
Mileage: 108276 km
Part No SW: 8K0 907 063 DF HW: 8K0 907 063 DF
Component: BCM1 1.0 H16 0103
Revision: 06016001 Serial number: 00000876672201
Coding: 26000091863CAFC00000480300003D0D0F1C530822090221000008004000020100000000000000
VCID: F6A0BCB1412658FF0D-80A2
Subsystem 1 - Part No SW: 8K1 955 119 B HW: 8K1 955 119 B Labels: 1KX-955-119.CLB
Component: MITSUBA090714 H18 0461
Serial number: 1407040608225
Coding: 004577
Component: G397_RLFS H06 0002
Serial number: 23099960
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000001208141469
Component: USHL4.2 H30 0030
Serial number: 00000000095Z0015762C
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 2E898147000000000001
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 Q HW: 8K0 959 655 Q
Component: AirbagVW-AU10 H51 0812
Serial number: 003NDD12AS18
Coding: 303844354730383131304A55304C384B3053
Shop #: WSC 44670 001 1048576
ASAM Dataset: EV_AirbaECUVWAUDI010 003114
VCID: CBD63D456224751782-809E
Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R140000LB12
Serial number: 6334MSME7E616A3BV
Serial number: 6344MSME483B257BP
Serial number: 6352QSME1544465CI
Serial number: 6362QSME77442968P
Serial number: 63732SME07454260R
Serial number: 63832SME16451F784
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862NHQ0009X
Coding: 000016
VCID: C8DC02497B529E0FAF-809C
Part No SW: 8K0 920 951 E HW: 8K0 920 951 E
Component: KOMBIINSTR. H09 0564
Revision: 00300000 Serial number: ZA1331Z7F
Coding: 8B9609000301D705020000
VCID: B22840A1EDCE04DFE1-80E6
Part No SW: 8R0 907 468 L HW: 8R0 907 468 A
Component: GW-BEM 5CAN H11 0060
Revision: 1V090029 Serial number: 2941V14820020D
Coding: 80C303FF00
Serial number: 5513134103
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0290
Revision: 00000000
Coding: 020302
VCID: B93A778D30B8F78720-80EC
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0305
Coding: 011C03204000410001
VCID: D6E0DC31A1E638FF2D-8082
Part No SW: 8K0 909 144 J HW: 8K0 909 144 B
Component: RCEPS H41 0509
Revision: 00001000 Serial number: 0017876867
Coding: 100000000001
ASAM Dataset: EV_RCEPSAU48X 008016
ROD: EV_RCEPSAU48X_008.rod
VCID: B83C728903B2EE8FDF-80EC
Revision: 00002001 Serial number: 0344882958
Coding: 0106023A00FA400480B0013200000000
Component: GTO BF H01 0080
Serial number: 00000000000000873240
Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J245 PS050 H08 0043
Part No SW: 8R1 035 223 A HW: 8R1 035 223
Component: DSP STD H08 0230
Revision: 26S00000
Coding: 0203010102
VCID: AB165DC5CAE45517A2-80FE
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0305
VCID: D5E2DB3DBCE033E724-8080
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 00000001530433
ROD: EV_ParkiBrake_AU48.rod
VCID: BA3868813DBEFC9F29-80EE
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8R1 035 186 Q HW: 8R1 035 186 Q
Component: Con3 Sirius H09 0471
Revision: 00000003 Serial number: AUZ5Z6N2072460
Coding: 04020002010185004359070800
VCID: C3C615654274BD577A-8096
Subsystem 1 - Part No SW: 8T0 919 603 G HW: 8T0 919 603 G
Component: Display
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H07 0305
Coding: 010C03204000210001
VCID: D9FAD70DD0F8178700-808C
Component: TSG HR H07 0305
Part No SW: 8T0 862 336 F HW: 8T0 862 336 E
Component: FSE_256x BT H45 0660
Revision: 00000000 Serial number: 00000005384841
Coding: 0010370
VCID: BE306491E996D0BF15-80EA
End----------(Elapsed Time: 01:41, VBatt start/end: 13.9V/14.0V)-----------
Address 01: DTCs cleared
