Audi S5 8T 4.2 CAUA Manual gearbox ACC retrofit
gabor.ruppert
Switzerland
C?ID=386932
Dear All,
I'm trying to extend the capabilites of my car with ACC. All the parts are mounted and coded except the radar sensor(Address 13: Auto Dist. Reg (J428)).
I've got a manual which tells how to calculate the coding, but it does not cover my car. There is a reference for the S4 with automatic, which is the same as the S5 automatic version, but I couldn't find the coding for the manual version. If anyone has this setup or knows someone I would really appreciate the coding.
What I've found so far you need 5 decimal digits which then you turn to hex.
1.
1 – S4, S5, Automatic
3 – 3.0TDI, Manual
4 – 2.0TDI, Manual
5 – 2.0T, 3.2, Automatic
6 – 2.0TDI, Automatic
2.
1 - Maybe before facelift
2 - ???
3 - Maybe dynamic steering
3.
Always 1
4
1 – USA (mph)
2 – Canada (kmh)
4 – Japan (kmh)
5 – RoW (mph)
6 – RoW (kmh)
5
1 - With trailer hitch
8 - Without trailer hitch
So an S5 automatic without trailer for europe is: 11168 which then translates to 2BA0
At the end what I'm missing is the first digit. But if we could gather enough information it could be included in VCDS itself.
Sunday,17,November,2019,10:16:55:38133
VIN: WAUZZZ8T29Axxxxxx   License Plate:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 03 05 06 08 09 13 15 16 17 19 36 42 46 52 53 55 56 77
VIN: WAUZZZ8T29Axxxxxx   Mileage: 115320km-71656miles
Address 01: Engine (J623-CAUA)       Labels:. 079-907-560-CAU.clb
   Part No SW: 8T0 907 560 J    HW: 8T0 907 560
   Component: 4.2l V8/4V    H10 0004
   Revision: 76H10---
   Coding: 01140003180F0220
   Shop #: WSC 06325 123 12345
   VCID: 41DEBE7C5180855F869-8014
005640 - Steering Angle Signal
               P1608 - 008 - Malfunction indication from Steering Angle Sensor - Intermittent
                    Mileage: 115326 km
                    Date: 2019.11.16
                    Time: 17:30:51
                    Temperature: 5.0°C
                    Temperature: 13.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 11.811 V
005717 - Please check DTC Memory of Auto. Distance Controller
               P1655 - 004 -
                    Mileage: 115326 km
                    Date: 2019.11.16
                    Time: 17:30:51
                    Temperature: 5.0°C
                    Temperature: 13.0°C
                    Voltage: 11.811 V
005720 - Powertrain Data Bus
               P1658 - 004 - Implausible Message from Auto Distance Controller - Intermittent
                    Mileage: 115326 km
                    Date: 2019.11.16
                    Time: 17:30:51
                    Temperature: 5.0°C
                    Temperature: 13.0°C
                    Voltage: 11.811 V
               P1653 - 004 -  - Intermittent
                    Mileage: 115326 km
                    Date: 2019.11.16
                    Time: 17:30:51
                    Temperature: 5.0°C
                    Temperature: 13.0°C
                    Voltage: 11.811 V
005703 - Check Coding of ECUs on Powertrain Data Bus
               P1647 - 008 -  - Intermittent
                    Mileage: 115326 km
                    Date: 2019.11.16
                    Time: 17:30:52
                    Temperature: 5.0°C
                    Temperature: 13.0°C
                    Voltage: 11.811 V
Readiness: 0110 1101
   Part No SW: 8K0 907 379 AH    HW: 8K0 907 379 AH
   Component: ESP8 quattro  H04 0230
   Coding: 110D00
   Shop #: WSC 06325 000 00000
   VCID: 7F5AF88467F433AFB0D-802A
   Part No SW: 8K0 907 064 BP    HW: 8K0 907 064 BP
   Component: BCM2 1.1      H90 0247
   Coding: 030000
   Subsystem 1 - Part No SW: 8T0 959 754 Q    HW: 8T0 959 754 Q
   Serial number: 0509000005389011
   Component: ELVAUDIB8  H36 0041
   Serial number: 0209000011616009
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 B    HW: 8T0 959 760 B
   Component: MEM-BFS       H09 0043
   Revision: AA000000    Serial number: 00001001235192
   Coding: C80170250F2400001000
   VCID: 42DCB17054869E479F3-8016
   Part No SW: 8T1 820 043 AD    HW: 8T1 820 043 AD
   Component: KLIMA 3 ZONEN H06 0150
   Revision: C3000000    Serial number: 01120220091392
   Coding: 48020006
   VCID: 73B224B45BBC67CFC45-8026
                    Reset counter: 228
                    Mileage: 115326 km
                    Date: 2019.11.17
                    Time: 10:14:54
   Component: BCM1 1.0      H24 0253
   Revision: 05024001    Serial number: 00000000223287
   Coding: 260050914134AF010009000000005D5D0F1C038800010141000000
   VCID: 3038EBB8EA2A1CD7797-8064
   Subsystem 1 - Part No SW: 8T1 955 119 C    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 030309  H13 0040
   Serial number: SWF09030030611
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10406395
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
   Component: E1 - LDS  H07 0090
   Serial number: 00000000000203090611
                    Reset counter: 228
                    Mileage: 115326 km
                    Date: 2019.11.17
                    Time: 10:14:00
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561     HW: 8K0 907 561
   Component: ACC2          H09 0080
   VCID: 6FBA28C43794432F20D-803A
00234 - Sensor for Automatic Distance Regulation Misadjusted
                    Reset counter: 228
                    Mileage: 115326 km
                    Date: 2019.11.17
                    Time: 10:14:54
                    Temperature: 15.0°C
                    Voltage: 12.03 V
                    Bin. Bits:    01011
                    Hex Value: 0x0941
                    Hex Value: 0x0001
                    Speed: -3.6 km/h
                    Lateral Accel.: 0.00 m/s^2
                    Reset counter: 228
                    Mileage: 115326 km
                    Date: 2019.11.17
                    Time: 10:14:54
                    Temperature: 15.0°C
                    Voltage: 12.03 V
                    Bin. Bits:    01011
                    Hex Value: 0x0411
                    Hex Value: 0x0001
                    Speed: -3.6 km/h
02084 - Component Protection
                    Fault Status: 01100101
                    Reset counter: 228
                    Mileage: 115326 km
                    Date: 2019.11.16
                    Time: 17:24:12
                    Temperature: 5.0°C
                    Voltage: 11.52 V
                    Bin. Bits:    01011
                    Hex Value: 0x04F1
                    Hex Value: 0x0001
                    Reset counter: 228
                    Mileage: 115326 km
                    Date: 2019.11.17
                    Time: 10:14:54
                    Temperature: 15.0°C
                    Voltage: 12.03 V
                    Bin. Bits:    01011
                    Hex Value: 0x04F1
                    Hex Value: 0x0002
                    Speed: -3.6 km/h
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0038JD1ELPHZ
   Coding: 30313433363030303030554A304C38543053
   VCID: 3C20CF8836E2E8B7D5F-8068
   Serial number: 6334MSME4463792EM
   Serial number: 6344MSME4433472FG
   Serial number: 6352QSME0F1A4908O
   Serial number: 6362QSME151B510CE
   Serial number: 63732SME77213936.
   Serial number: 63832SME00225604J
13697280 - Component Protection
          U1101 00 [137] - Active
                    Mileage: 115326 km
                    Date: 2019.11.17
                    Time: 10:14:56
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90304HK700028
   Coding: 00001E
   Shop #: WSC 06335 123 12345
   VCID: 3E24C580207EFAA7FBB-806A
   Part No SW: 8T0 920 931 B    HW: 8T0 920 931 B
   Component: KOMBIINSTR.   H32 0224
   Revision: 00200000    Serial number: 9D7654239
   Coding: 0F0D010007000008000000
   VCID: 3634DDA0084E32E723B-8062
                    Reset counter: 228
                    Mileage: 115326 km
                    Date: 2019.11.17
                    Time: 10:14:55
   Part No SW: 8T0 907 468 S    HW: 8T0 907 468 J
   Component: GW-BEM 6CAN   H06 0101
   Revision: HB500049    Serial number: 4900H09430000D
   Coding: 000303
   VCID: 51FE8E3C81E075DF169-8004
   Component: J367-BDM  H06 0160
   Serial number: 1906BD04250209
   Component: MEM-FS        H09 0043
   Revision: AA000000    Serial number: 00001001235217
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000008518133
   Coding: 011C02224000120102
   Revision: 00002001    Serial number: 0117211829
   Coding: 011A0680003904400330000000000000
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000008531863
   Coding: 011C02224C00120102
   VCID: 40D8BB785A8A8C57897-8014
   Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
   Component: EPB Audi B8   H08 0080
   Revision: 00000003    Serial number: 00000000327134
   VCID: 3332E4B41B3C27CF045-8066
   Part No: 8K5 907 357
   Coding: 0000002
   Shop #: WSC 06324 000 00000
   VCID: 77AA10A443C40BEFF8D-8022
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 195 AA    HW: 8T1 035 195 AA
   Component: Symphony3     H01 0300
   Revision: 00000003    Serial number: AUZ5Z4I1084698
   Coding: 050004820404850053D9470001
   VCID: 76B41DA048CE72E7E3B-8022
                    Reset counter: 228
                    Mileage: 115326 km
                    Date: 2019.11.17
                    Time: 10:14:54
02259 - Information Display and Control Head (Front) (J685)
                    Reset counter: 228
                    Mileage: 115326 km
                    Date: 2019.11.17
                    Time: 10:15:05
   Part No SW: 8T0 862 335 C    HW: 8T0 862 335 C
   Component: FSE_256x BT     H33 0550
   Revision: 00000000    Serial number: 00000005062046
   Coding: 0010390
   VCID: 3A2CC9903056D687C73-806E
End----(Elapsed Time: 01:30, VBatt start/end: 12.0V/11.9V. VIgn 12.0V)-----
