Hi guy's got a bit of a problem with my Audi A8L 2017 model
Just recently I noticed the cooling fan running at high speed when I turn the engine off.
Bizarre thing is when I go out in the morning to start the car stone cold as soon as I unlock the doors the fan starts at high speed also.
Ran a scan and printed the problem off but wanted to ask here before I take it to the dealer.
Any advise please.
Any advise please.
Monday,18,November,2019,12:29:59:17234
VIN: WAUZZZ4H4HN020264 License Plate: KX17 ZGG
Mileage: 68370km-42483mi Repair Order: 18/11/19
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 28 30 34 36 3B 42 44 46 47
52 53 55 56 57 5F 62 6C 6D 6F 72 81 85 88 89 8F 90 AC
VIN: WAUZZZ4H4HN020264 Mileage: 68370km-42483miles
Address 01: Engine (J623-CTBA) Labels:. 059-907-401-V2.clb
Part No SW: 4H0 907 401 Q HW: 4G0 907 401 E
Component: 3.0TDI EDC17 X14 0006
Revision: 58X14---
Coding: 0A2A4032052601030800
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM30TDI0114H0907401Q 001006
ROD: EV_ECM30TDI0114H0907401Q.rod
VCID: 323CE13E34AB54B70F3-8066
4527 - Coolant Fan Control Circuit 1
P0480 00 [047] - Electrical Malfunction
Fault Frequency: 34
Mileage: 68107 km
Date: 2019.11.16
Time: 10:17:42
Coolant temperature: 8 °C
Intake air temperature: 8 °C
Voltage terminal 30: 11.100 V
Air mass: specified value: 0.0 mg/stroke
Coolant temperature at radiator outlet: actual value: 7.4 °C
Heat delivery temperature in cooling system: -273.1 °C
Outside air temperature: 8.5 °C
Coolant fan 2: activation: 10.00 %
Coolant fan 1: activation: 10.00 %
Fuel temperature: 7.2 °C
Part No SW: 4H1 927 158 CL HW: 0BK 927 156 AD
Component: 0BK 30TDIRdW H22 1010
Revision: --H22---
ASAM Dataset: EV_TCMALX51011 002022
ROD: EV_TCMALX51011_002_AU64.rod
VCID: 7CA00F06A66F52C795F-8028
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 AB HW: 4H0 907 379 AB
Component: ESP PREMIUM H10 0930
Coding: 60E5EB8006A7D701E300
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremi 005025
ROD: EV_ESPPremi_005_AU64.rod
VCID: 72BC213EF42B14B7CF3-8026
Part No SW: 4H0 907 064 HB HW: 4H0 907 064 HB
Component: BCM2 2.0 H61 0825
Coding: 05B76F4E000000000000
VCID: 70B82B36FAA726A7397-8024
Serial number: 3217000018256009
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-BFS H08 0156
Revision: AA000000 Serial number: 00000245068453
Coding: 0038320000047201000001010101112131313333283333
VCID: 3430E726CE3F5A871DF-8060
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 N HW: 4H0 820 043 N
Component: Klima 4 Zonen H20 0210
Coding: 362102BE3C0000
ASAM Dataset: EV_AirCondiFront 003001
ROD: EV_AirCondiFront_002.rod
VCID: 2B02FC5A1381057F4C5-807E
Part No SW: 4H0 907 063 GB HW: 4H0 907 063 AB
Component: BCM1 2.0 H20 0368
Revision: 1902003S Serial number: 00001624426601
Coding: 0105001440349FE0C9014087A0001800009DC30A2F080201800008946100170000400034030000
VCID: 6E84354EE09330572BB-803A
Subsystem 1 - Part No SW: 4H2 955 119 D HW: 4H2 955 119 A
Component: WWS641 161220 H38 0100
Serial number: 170109145514
Coding: 0045F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 20173521X81A955547A0
Coding: 02004E
Subsystem 3 - Part No SW: 4H0 941 531 B HW: 4H0 941 531 B
Component: E1 - LDS H07 0044
Serial number: 29 03 2017 00000716
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA126451000028834772
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: 0F088C9800PAG0MUFU03
03455 - Function Restriction due to Faults in Other Modules
Reset counter: 91
Mileage: 64330 km
Date: 2019.10.17
Time: 04:33:11
Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
Component: Airbag10.43 H82 0092
Revision: -------- Serial number: 003P100DAGN5
Coding: 30333045313430303038554A305234483053
VCID: 3B22CC1AE3E195FFDC5-806E
Serial number: 3575HRB405T468HIAP1U
Serial number: 3585HRB405R468HI59LS
Serial number: 3515JRB4012597JML9FD
Serial number: 3525JRB4014597JM89UI
Serial number: 3554VRB401659GF2IPDS
Serial number: 3564VRB401659GF2OOV9
Component: Lenks.Modul H05 0005
Revision: -------- Serial number: 01335QD6000MQ
Coding: 000034
VCID: 372AD02ADF49B19F38D-8062
Subsystem 1 - Part No SW: 4H0 951 528 J HW: 4H0 951 528 J
Component: E221 - MFL H09 0010
Serial number: 16 12 2016 H0035393
Part No SW: 4H0 920 910 T HW: 4H0 920 910 T
Component: TDieGB------- H55 0903
Revision: 44081303 Serial number: 658080417592008
Coding: 33A708001B412600010000
ASAM Dataset: EV_RBD4K 004050
ROD: EV_RBD4K_AU64.rod
VCID: 3536DA22C5C5438F2A1-8060
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 Q HW: 4H0 919 204 Q
Component: Analoguhr D4 H05 0225
Serial number: 2170227000937
Part No SW: 4H0 907 468 AH HW: 4H0 907 468 AC
Component: J533--Gateway H15 0096
Revision: -------- Serial number: 00000002576217
Coding: C0CD077F08
ASAM Dataset: EV_GatewPkoUDS 002000
VCID: 77AA102A9F49719FF8D-8022
Subsystem 1 - Part No SW: 4H0 915 181 G HW: 4H0 915 181 G
Component: J367-BDM H08 0270
Serial number: 54038025081481182402
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 C HW: 8K0 959 663 C
Serial number: 17087002207011200410
Address 28: HVAC, Rear (E265) Labels:| 4H0-919-158.clb
Part No SW: 4H0 919 158 K HW: 4H0 919 158 K
Component: Klima Fond H17 0200
Coding: 2800000000
Shop #: WSC 02313 785 00200
ASAM Dataset: EV_AirCondiHeck 002001
ROD: EV_AirCondiHeck_AU64.rod
VCID: 3828D316D2D7BEE7317-806C
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0030
Revision: S0H06000 Serial number: 00000000002795
Coding: 01010101000000000001000202
VCID: 649057663E5F8A074DF-8030
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Coding: 008000
ROD: EV_AirSuspe_VW51.rod
VCID: 2F3AE84A2799795F60D-807A
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000244721443
Coding: 00383B0000057201000001010101112131313333203333
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 K HW: 4H0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA7703TDDN
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 372AD02ADFC9B19F38D-8062
Part No SW: 4H0 959 793 R HW: 4H0 959 793 G
Component: TSG FA H08 0280
Revision: -------- Serial number: 0000247627063
Coding: 011F1E015E0162C202083006
VCID: 48C8A3D6A2B7CE67417-801C
Address 44: Steering Assist
Revision: 00002001 Serial number: 0438557057
Coding: 011B0E2280B93985F320C7C40A0316470000000000000000000000000000
Subsystem 1 - Part No: 4H0 951 177
Subsystem 3 - Part No SW: 4H0 959 591 B HW: 8V3 959 591 A
Component: J245 PS50.402 H03 0004
Serial number: 0000FST001J16RI00000
Coding: 901F00
Subsystem 4 - Part No SW: 4H0 947 135 G HW: 4H0 947 135 G
Component: Dachelektroni H13 0080
Serial number: A2017000000000155033
Subsystem 5 - Part No SW: 4H0 959 591 A HW: 4H0 959 591 A
Component: V252 PS014 H06 0005
Serial number: WOO1000KP4O
Subsystem 6 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: GEB.F.Heckoef H16 0811
Serial number: 66001288
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000209450
Coding: 030000
VCID: 1D6622825DB5FBCFC21-8048
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H08 0280
Revision: -------- Serial number: 0000246267884
VCID: 3C20CF06E66F92C7D5F-8068
Part No SW: 4H0 907 801 M HW: 4H0 907 801 M
Component: EPB-4 H01 0018
Revision: -------- Serial number: 00000002158373
ASAM Dataset: EV_ParkiBrake 001033
ROD: EV_ParkiBrake_VW51.rod
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Part No SW: 4H4 907 357 E HW: 7P6 907 357 B
Component: MxB-ECU 001 0100
Coding: 02F6022022130200
VCID: 3430E726CEBF5A871DF-8060
Subsystem 1 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7570
Coding: E00300
Subsystem 2 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7570
Coding: E00300
Matrix Headlamp Powermodule 1 Left:
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo li. H03 0031
Coding: E00300
Matrix Headlamp Powermodule 1 Right:
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo re. H03 0031
Coding: E00300
13706001 - Databus
[Empfangener Fehlerwert im Signal Kamera_FDD_Funktionsstatus: CAN Message Kamera_Status]
Reset counter: 91
Mileage: 64329 km
Date: 2019.10.17
Time: 04:32:10
5353456 - Fog mode active
C118E 00 [008] - -
Fault Frequency: 10
Reset counter: 92
Mileage: 64955 km
Date: 2019.10.19
Time: 18:14:44
Part No SW: 4G0 035 061 S HW: 4G0 035 061
Component: Radio U DAB H60 0154
Revision: AB001007 Serial number: 109CQ0H5019221
Coding: 010103010000000001
VCID: 2D06F2422D150B4F521-8078
Address 57: TV Tuner (R78) Labels: None
Part No SW: 4G0 919 129 C HW: 4G0 919 129
Component: NGTV-DVB H04 0690
Revision: R0043000 Serial number: 06801302534001
Coding: 03000000
Part No SW: 4H0 035 654 D HW: 4H0 035 654 D
Component: H-BNT-EU H51 1072
Revision: -------- Serial number: 449D$0HB004073
Coding: 02010100000BF1EF45908B1E00000003000101000000000000
VCID: 270A006A0FE9211FA8D-8072
Subsystem 1 - Part No: 8R0 060 884 FK
Component: EUR 2018/2019 2702
Subsystem 2 - Part No SW: 4H0 919 604 H HW: 4H0 919 604 H
Component: DU8 D4 SV NB H63 0060
Serial number: AUZ8ZDHY901B62$
Subsystem 3 - Part No SW: 4H2 919 600 L HW: 4H2 919 600
Component: E380 BDT D4 H11 0110
Serial number: 00000000238757
Component: CD-Database 9040
Reset counter: 20
Mileage: 62323 km
Date: 2019.10.09
Time: 15:15:33
Text: DU902A,Front,M,0,0,6
03623 - Invalid Security/Release Code
Reset counter: 20
Mileage: 62323 km
Date: 2019.10.09
Time: 15:15:32
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H08 0280
Revision: -------- Serial number: 0000250127716
Coding: 010F1E01400062C202083006
Part No SW: 4S0 907 441 B HW: 5Q0 907 441 A
Component: D4-PA RVC Mid H07 0050
Coding: 024611010201000300
ASAM Dataset: EV_CamSysRearPANAAU914 002002
ROD: EV_CamSysRearPANAAU914_AU64.rod
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 AC HW: 4H0 959 107 AC
Component: HDSG-Modul H12 0049
Revision: 10012001 Serial number: 090701351
Coding: 021004C020
ASAM Dataset: EV_DeckLidContrUnit 001032
ROD: EV_DeckLidContrUnit.rod
VCID: 6FBA284AE719395F20D-803A
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000229387
Coding: 220000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 6392547A3BD18D3FB45-8036
Component: TSG HR H08 0280
Revision: -------- Serial number: 0000250127711
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H2 927 731 A HW: 4H2 927 731 A
Component: GSM-RL H09 0083
Revision: 0R0D5015 Serial number: SN170123 0022
ROD: EV_GSM2x3Mono.rod
VCID: 2C00FF46168F024745F-8078
Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
Component: DPC-SG H28 0081
Coding: E0140000
ROD: EV_OnBoardCamerDPC.rod
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00030660119201
Coding: 672FF2
ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00030660179801
Coding: 272FF2
Component: RGS-VL H16 0080
Coding: 00060000031F030000030800424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313EEE3231AD6FAF769-8064
Component: RGS-VR H16 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 170600241
ROD: EV_RDCMA00100_008.rod
End----------(Elapsed Time: 03:07, VBatt start/end: 11.7V/14.5V)-----------
