Fault code C10E2
Secondaaaa
I have a fault code on a 2013 1.2Tsi Golf C10E2 54 (008) - Missing calibration/Basic Setting Intermittent.
Basically the hsa sometimes wont release. I did replaced the engine battery and 4days later this issue started. Not sure if that has any relationship to the issue.
Can someone explain how to calibrate the Hsa using VCDS please?
Many thanks,
Secondaaaa
myounus
Northwest UK
C?ID=321059
Can you please post an autoscan. If you're not sure how to, see my signature.
Secondaaaa
Thanks for getting back to me so fast. I will do as you have asked in a day or two as I need to get the car to do the scan.
Thanks again,
Secondaaaa
2013 Golf 1.2 TSI C10E2 Missing Calibration
The HSA is often not releasing.
Please can someone explain how to calibrate this?
Many thanks,
Secondaaaa
Tuesday,19,November,2019,08:25:35:28900
VCDS Version: 19.6.2.0 (x64)
VIN: WVWZZZAUZDP028678   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZDP028678   Mileage: 94583km-58771miles
Address 01: Engine (J623-CJZB)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 E    HW: 04E 907 309 A
   Component: 1.2l R4 TSI   H08 7695
   Revision: WAH08---
   Coding: 01110012230411082000
   Shop #: WSC 47161 001 1048576
   ASAM Dataset: EV_ECM12TFS01104E906016E 001011
   ROD: EV_ECM12TFS01104E906016H.rod
   VCID: 2447A4902FAB1B6FE3-8070
   Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
   Component: ESC           H75 0437
   Revision: 00000000    Serial number:
   Coding: 01FA8AA120222A74037D060701CB2580510454C06080A4F300280028C0
   Shop #: WSC 00028 028 00308
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
   ROD: EV_Brake1UDSContiMK100IPB_008_VW37.rod
   VCID: 7DF1B1F4EC818AA7CC-8028
32951 - Control Module for Electronic Parking Brake
          C10E2 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 96
                    Mileage: 94223 km
                    Date: 2019.11.07
                    Time: 12:51:06
Address 08: Auto HVAC (J301)       Labels:. 5G0-907-426.clb
   Part No SW: 5G0 907 426 J    HW: 5G0 907 426 J
   Component: AC Manuell    H01 0503
   Revision: 00001K06
   Coding: 00120004200100001000000000000000
   ASAM Dataset: EV_ACManueBHBVW37X 002017
   ROD: EV_ACManueBHBVW37X_002_VW37.rod
   VCID: 326B52C8655F85DF61-8066
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
   Part No SW: 5Q0 937 084 M    HW: 5Q0 937 084 M
   Component: BCM MQBAB B   H14 0106
   Serial number: 00011232500772
   Coding: 03000842C20100530FA44000000403081000000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 010001
   ROD: EV_BCMBOSCH_010.rod
   VCID: 428B0208D5FF355FF1-8016
   Component: WWS    121113  042 0551
   Serial number:         121114152013
   Coding: 0E4DD5
   Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
   Component: AirbagVW20    011 0361
   Serial number: 003F5R01FL01
   Shop #: WSC 00028 028 00059
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 408F0800DBF3274FE7-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 002 111 12
   Serial number: 35767000000416583C0O
   Subsystem 2 - Part No SW: -----------    HW: 480 002 111 12
   Serial number: 35867000000154C84C0W
   Subsystem 3 - Part No SW: -----------    HW: 480 401 112 12
   Serial number: 3516502AD0D46473518A
   Subsystem 4 - Part No SW: -----------    HW: 480 401 112 12
   Serial number: 3526502AD0CD5EC5635Z
   Subsystem 5 - Part No SW: -----------    HW: 480 400 412 12
   Serial number: 3556502AF0D5D621914J
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 AB    HW: 5Q0 953 549
   Revision: --------    Serial number: 05121208490046
   Coding: 0600
   Shop #: WSC 40195 333 37120
   VCID: 76E3AED8C9B7D9FF8D-8022
No ASAM data for: "EV_SMLSKLOMQB" (VW37)
   Part No SW: 5G0 920 950     HW: 5G0 920 950
   Component: KOMBI         136 0555
   Coding: 27A402002380260001082800040000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008026
   VCID: 65C1F9946411226734-8030
   Part No SW: 5Q0 907 530 D    HW: 5Q0 907 530 D
   Component: GW MQB Low    120 1109
   Revision: --------    Serial number: 0000166131
   Coding: 030000042B086400EF000048080E00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_006.rod
   Subsystem 2 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 4221688601
   Part No SW: 5Q4 959 393     HW: 5Q4 959 393
   Component: TSG FS        007 0006
   Serial number: 0000045007537
   Coding: 003002208001020100001000
   VCID: 55A1C9543471B2E7A4-8000
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 01
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D7171F4AC014AA78C-8068
   Part No SW: 5Q4 959 392     HW: 5Q4 959 392
   Component: TSG BFS       007 0006
   Serial number: 0000046062703
   Coding: 003000208001020100801000
   VCID: 7F0D4BFCE68D98B7DE-802A
   Part No SW: 5G0 035 820     HW: 5G0 035 820
   Component: MU-S-D-ER     038 0130
   Serial number: V5C01012120690
   Coding: 02730000FF0000002111120100A800001F0100060100010001
   ASAM Dataset: EV_MUStd4CPASE 002036
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 5EB3D678414771BFF5-800A
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H44 0020
   Serial number: VWZ8Z9M24012AF
End-------------------------(Elapsed Time: 03:22)--------------------------
Secondaaaa
   Revision: WAH08---
                    Reset counter: 96
                    Mileage: 94223 km
                    Date: 2019.11.07
                    Time: 12:51:06
   Revision: 00001K06
   Coding: 0E4DD5
   Coding: 0600
   Coding: 01
Secondaaaa
Thanks but I have already tried this & it did not work.
Secondaaaa
Threads merged. We do not need or want two threads with the same question about the same car.
Many thanks,
Secondaaaa
Secondaaaaaaaaaaaaaaaaaaaaa................. !!! :D Hi.
I'm not sure how to address your problem (other than myounus suggestion) - but in respect of your suspicion regarding the battery replacement, my belief is that this is not the case because of the supporting records in your DTC.
The time date stamp on the DTC is Date: 2019.11.07 Time: 12:51:06. . This means that the fault was first recorded 12 days before the date of your auto-scan (i.e. 8 days before the battery replacement). The further record Fault Frequency: 2 also indicates that since first appearing, the fault has only re-occurred once more.
So, without intending any offense, or implication - what was the car doing @ around mid-day-ish on 7th November? Perhaps have a look @ the AdpLog.CSV & CodingLog.CSV files in the c:\Ross-Tech\VCDS\Debug sub-directory on your laptop for records around this time- maybe?
Secondaaaa
Secondaaaa
I do apologize Uwe. I am new to these forums & am finding how to use it a bit difficult and would ask to be forgiven for my mistakes.
Many thanks,
Secondaaaa :)
Secondaaaa
Hi Don,
I thought I has sent a message to you yesterday but I cannot see it. But thanks for replying to me.
I'm thinking that I might not be trying to reset as Mika_M & you said to try. I understand the idea of pressing the brake and operating the park brake switch but am I missing something about being in ''a test drive Basic Settings??'' I know I sound stupid but this is new to me & I do apologise for that.
Many thanks in advance:)
Secondaaaa
[IDE05335-ENG114972] Electro-mechanical parking brake function test
Mika_M
Finland
C?ID=183725
I am not really sure what you have tried. What I suggested, was to follow those instructions that Dana wrote in that old post. First cycle handbrake on and off while pressing brake pedal, then go for a little drive (not sure if this driving is needed?).
After that, apply basic setting [IDE05335-ENG114972] Electro-mechanical parking brake function test while keeping your foot off brake pedal.
If you have already tried all that, then I don't have any more suggestions.
