Mk7.5 GTE Euro LED Headlights to Mk7.0 GTI USA Car
the brit
C?ID=73227
I threw a pair of OEM 2019 Golf GTE European market headlights onto a 2015 USA Market GTI, with the correct matching modules etc for the GTE.. The wiring physically plugged in :rolleyes: The headlights could be installed once I installed 7.5 Fenders and a TCR bumper to match ;)
The result was about what I expected from this random experiment : the lowbeam LEDs worked, highbeams did not, turn signals did not.
Here's the scan after this (and while the steering wheel was removed)..:
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: 3VW5T7AU4FM015918   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 52 55 5F 75 A9 VIN: 3VW5T7AU4FM015918   Mileage: 167326km-103971miles 01-Engine -- Status: Malfunction 0010
Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0004
   Revision: --H13---
   Coding: 091900122424002F1000
   Shop #: WSC 00066 790 00020
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001006
   ROD: EV_ECM20TFS0205G0906259A.rod
   VCID: AC144E26C747CF2F95-80F8 2 Faults Found:
15188 - Oil Pressure Switch
          P164B 00 [032] - Malfunction
                    Mileage: 166900 km
                    Date: 2019.11.01
                    Time: 07:15:24                     Engine speed: 3315.50 /min
                    Normed load value: 46.3 %
                    Vehicle speed: 163 km/h
                    Coolant temperature: 88 °C
                    Intake air temperature: 1 °C
                    Ambient air pressure: 830 mbar
                    Voltage terminal 30: 14.570 V
                    Unlearning counter according OBD: 32
                    Engine: operating status: PL
                    STATE_LS_SAE[1]: OL_INTR
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 236 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.772 V
                    FAC_TPS_1_SAE: 86.328125 %
                    FUP_H_SAE: 17450.0 kPa 19854 - Steering Column Control Module
          U0212 00 [047] - No Communications
                    Fault Frequency: 19
                    Mileage: 166900 km
                    Date: 2019.11.01
                    Time: 07:15:24                     Engine speed: 3302.00 /min
                    Normed load value: 37.3 %
                    Vehicle speed: 162 km/h
                    Voltage terminal 30: 14.472 V
                    ECU_STATE: SYN_ENG_IGK_ON
                    Engine oil temperature: 106.0 °C
                    Time since engine start: 5233.3 s
                    T_ES: 0 min
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Large increment: not activated
                    Cruise control switch actuation-Control component verified: No
                    STATE_ERR_ABC_PRED: 0 Readiness: 0000 0001 -------------------------------------------------------------------------------
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 51584000001157
   Coding: 01FA6BA1342109710080020181CB2980D62C9000408194B400430050C009
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
   VCID: C4C406864FD7276F7D-8090 2 Faults Found:
0297 - Steering angle sensor
          B1168 16 [137] - Voltage Too Low
                    Reset counter: 179
                    Mileage: 167312 km
                    Date: 2019.11.02
                    Time: 00:09:48 16390 - Display for Tire Pressure Monitoring
          C1146 02 [137] - Signal Failure
                    Reset counter: 179
                    Mileage: 167312 km
                    Date: 2019.11.02
                    Time: 00:09:58
   Revision: 00021000    Serial number: 0335526990
   Coding: 030C0C
   VCID: BA38787E3D13619F17-80EE No fault code found. -------------------------------------------------------------------------------
   Part No SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
   Component: Climatronic   H03 0907
   Revision: 00001K08
   Coding: 00020014200100000005000012111800
   VCID: F3A6955A5AF9D0D714-80A6    Fresh Air Blower Front:    Geber für Kältemitteldruck/Kältemitteltemperatur:    Air quality sensor: 3 Faults Found:
459015 - Databus
          [Feuchtesensor innen - kein Signal/Kommunikation]
                    Reset counter: 171
                    Mileage: 166899 km
                    Date: 2019.11.01
                    Time: 07:15:19 263426 - Air Quality Sensor
          B10AF 31 [008] - No Signal
                    Reset counter: 211
                    Mileage: 167272 km
                    Date: 2019.11.01
                    Time: 15:32:03                     Voltage terminal 30: 11.8 V
                    Outside air temperature: 20.5 °C
                    System run time-Terminal 15 on: 9 s 262658 - High Pressure Sensor
          B10AE 31 [008] - No Signal
                    Reset counter: 211
                    Mileage: 167272 km
                    Date: 2019.11.01
                    Time: 15:32:00                     Outside air temperature: 20.5 °C
                    Engine speed: 0 /min
                    Temperature after evaporator: 36.0 °C
                    System run time-Terminal 15 on: 6 s
   Part No SW: 5Q0 937 087 N    HW: 5Q0 937 087 N
   Component: BCM PQ37BOSCH 028 0106
   Revision: --------    Serial number: 86580207140662
   Coding: 00110A464041A2E969E44000001407201800000000000000000000000000
   Shop #: WSC 00066 790 00145
   ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
   ROD: EV_BCMBOSCH_013.rod
   VCID: C6C01C8E79EB157F63-8092    Control Unit For Wiper Motor:
   Component: WWS    140611  043 0581
   Serial number:         140712033619
   Coding: 0E4DDD    Sun Roof:
   Subsystem 2 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO2834025+
   Coding: 181801 10 Faults Found:
558100 - Databus
          [Airbag_02 Datenbus empfangener Fehlerwert]
                    Fault Frequency: 21
                    Reset counter: 174
                    Mileage: 166900 km
                    Date: 2019.11.01
                    Time: 07:15:22 919560 - Light Switch
          B126A 29 [136] - Signal Implausible
                    Reset counter: 211
                    Mileage: 167272 km
                    Date: 2019.11.01
                    Time: 16:30:09 5130 - Bulb for Front Left Turn Signal
          B11E8 15 [009] - Open or Short to Plus
                    Reset counter: 171
                    Mileage: 166900 km
                    Date: 2019.11.01
                    Time: 07:15:37 5386 - Bulb for Front Right Turn Signal
          B11EA 15 [009] - Open or Short to Plus
                    Reset counter: 171
                    Mileage: 166914 km
                    Date: 2019.11.01
                    Time: 07:20:54 15626 - Bulb for Left Brake Lamp / Turn Signal
          B1333 15 [008] - Open or Short to Plus
                    Reset counter: 211
                    Mileage: 167219 km
                    Date: 2019.11.01
                    Time: 10:10:46 18698 - Left LED Module for DRL and Parking Lights
          B12EC F2 [009] - Voltage Supply Open or Short to Plus
                    Reset counter: 171
                    Mileage: 166900 km
                    Date: 2019.11.01
                    Time: 07:15:24 19210 - Right LED Module for DRL and Parking Lights
          B12ED F2 [009] - Voltage Supply Open or Short to Plus
                    Reset counter: 171
                    Mileage: 166900 km
                    Date: 2019.11.01
                    Time: 07:15:24 934148 - No Communications with Rain/Light Sensor
          U10F6 00 [009] - -
          [Sensor für Regen- und Lichterkennung->kein Signal/ Kommunikation]
                    Reset counter: 171
                    Mileage: 166900 km
                    Date: 2019.11.01
                    Time: 07:15:22 939524 - No Communications with Humidity Sensor
          U10F5 00 [009] - -
          [Sensor für Feuchteerkennung->kein Signal/ Kommunikation]
                    Reset counter: 171
                    Mileage: 166900 km
                    Date: 2019.11.01
                    Time: 07:15:26 329480 - Heated Passenger Seat
          B1806 F0 [009] - Safety Shut-Off due to Occupant Detection
                    Fault Frequency: 30
                    Reset counter: 179
                    Mileage: 166900 km
                    Date: 2019.11.01
                    Time: 07:15:32
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM00FUM2
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: D1EA3FD280A5C2C7C6-8084    Occupant Detection:
   Subsystem 1 - Part No SW: -----------    HW: -----------
   Component: BF-Gewichtss.  --- ----
   Serial number: ---0000---000-----09
   Coding: 2D2D2D    Side Sensor Driver Front:
   Subsystem 2 - Part No SW: -----------    HW: 480 001 704 14
   Serial number: 357000000001D1D46F0P
   Coding: 2D2D2D    Side Sensor Passenger Front:
   Subsystem 3 - Part No SW: -----------    HW: 480 002 105 14
   Serial number: 35800000000B20F4EF0Y
   Coding: 2D2D2D    Side Sensor Driver Rear:
   Subsystem 4 - Part No SW: -----------    HW: 480 402 904 14
   Serial number: 3510002C7157E9D263BF
   Coding: 2D2D2D    Side Sensor Passenger Rear:
   Subsystem 5 - Part No SW: -----------    HW: 480 402 904 14
   Serial number: 3520002C7157E9D1E33F
   Coding: 2D2D2D    Front Sensor Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 205 14
   Serial number: 3550002BB15C4211238X
   Coding: 2D2D2D    Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 205 14
   Serial number: 3560002BB15C421252F1
   Coding: 2D2D2D 12 Faults Found:
          B1000 1B [137] - Resistance Too High
                    Mileage: 163776 km
                    Date: 2019.10.28
                    Time: 19:26:31 9440539 - Driver's Safety Belt Tensioner Igniter 2
          B100D 1B [137] - Resistance Too High
                    Mileage: 163776 km
                    Date: 2019.10.28
                    Time: 19:26:31 9440027 - Driver's side; side-airbag igniter
          B100B 1B [137] - Resistance Too High
                    Mileage: 163776 km
                    Date: 2019.10.28
                    Time: 19:26:31 9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [137] - Resistance Too High
                    Mileage: 163776 km
                    Date: 2019.10.28
                    Time: 19:26:31 9438747 - Igniter for Seat Belt Tensioner; Driver's Side
          B1006 1B [137] - Resistance Too High
                    Mileage: 163776 km
                    Date: 2019.10.28
                    Time: 19:26:31 9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [137] - Resistance Too High
                    Mileage: 163776 km
                    Date: 2019.10.28
                    Time: 19:26:31 9441051 - Front passenger's safety belt tensioner igniter 2
          B100F 1B [137] - Resistance Too High
                    Mileage: 163776 km
                    Date: 2019.10.28
                    Time: 19:26:31 9442075 - Driver's Belt Force Limiter Igniter
          B1013 1B [137] - Resistance Too High
                    Mileage: 163776 km
                    Date: 2019.10.28
                    Time: 19:26:31 9442331 - Passenger's Belt Force Limiter Igniter
          B1014 1B [137] - Resistance Too High
                    Mileage: 163776 km
                    Date: 2019.10.28
                    Time: 19:26:31 9444885 - Driver's seat position sensor
          B101E 15 [137] - Open or Short to Plus
                    Mileage: 163776 km
                    Date: 2019.10.28
                    Time: 19:26:32 9445141 - Passenger's seat position sensor
          B101F 15 [137] - Open or Short to Plus
                    Mileage: 163776 km
                    Date: 2019.10.28
                    Time: 19:26:31 9445937 - Seat occupied recognition control module
          B1022 31 [137] - No Signal
                    Fault Frequency: 49
                    Reset counter: 179
                    Mileage: 163776 km
                    Date: 2019.10.28
                    Time: 19:26:34
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0155
   Revision: FF028028    Serial number: 20140517400074
   Coding: 0400
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 8444C6860F57E76F3D-80D0 No fault code found. -------------------------------------------------------------------------------
   Part No SW: 5G1 920 856     HW: 5G1 920 856
   Component: KOMBI         342 4270
   Coding: 0BAD09122980CF0502087E001000000000000000
   VCID: EB968D3A02C90817DC-80BE No fault code found. -------------------------------------------------------------------------------
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2186
   Revision: --------    Serial number: 12061410000535
   Coding: 0101000820085900EF00022A080F00000001050000000000000000000000
   Shop #: WSC 00066 790 00149
   ASAM Dataset: EV_GatewConti 011017
   ROD: EV_GatewConti_011.rod
   VCID: C2C8009E55C3295F4F-8096    Alternator: 2 Faults Found:
131612 - No Communications with Actuator for Structural Accoustics
          U10DF 00 [008] - -
          [Timeout Knoten 0x1C / A9 - Aktuator für Körperschall]
                    Reset counter: 211
                    Mileage: 167272 km
                    Date: 2019.11.01
                    Time: 15:32:02                     Supply voltage: Terminal 30: 12.3 V
                    Terminal 15: On 197169 - Controls in Steering Wheel
          U108E 00 [009] - No Communications
          [MFL (LIN#2) Timeout]
                    Reset counter: 179
                    Mileage: 166900 km
                    Date: 2019.11.01
                    Time: 07:15:30                     Supply voltage: Terminal 30: 14.7 V
                    Terminal 15: On
   Revision: 00000000    Serial number: 14000147474001
   Coding: 5500000000000000
   Shop #: WSC 00066 790 07029
   ROD: EV_ELVMarquMQB.rod
   VCID: B42456461F7797EFCD-80E0 No fault code found. -------------------------------------------------------------------------------
   Serial number: 030714060503DV
   Coding: 003E13200000040000000000
   VCID: C0CC0A965BCF3B4F59-8094    Drivers Door Rear Control Module:
   Serial number: 00000000000002833002
   Coding: 011000 No fault code found. -------------------------------------------------------------------------------
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8102
   ROD: EV_SteerAssisMQB_010.rod
   VCID: B5226B42140D8EE7FA-80E0 2 Faults Found:
12288 - Supply voltage
          [Abschaltung wegen zu niedriger Versorgungsspannung Abschaltung aufgrund von Unterspannung]
                    Mileage: 167326 km
                    Date: 2019.11.13
                    Time: 03:08:45                     Motor status: 01
                    Supply voltage: 6.00 V
                    Temperature: 44.0 °C
                    KFC: 30
                    KFA: 00 01
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 5.17 V
                    uAdSensI_SwitchedKl30_xdu16: 5.18 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00 16135 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
                    Mileage: 0 km                     Motor status: 00
                    Supply voltage: 12.75 V
                    Temperature: 9.0 °C
                    KFC: 3F
                    KFA: 00 07
                    uioUdNotFilt_xdu16: 12.77 V
                    uAdSensI_SwitchedKl30_xdu16: 12.76 V
   Serial number: 040714060500G7
   VCID: BFCE096A263144B720-80EA    Passengers Rear Door Control Module:
   Serial number: 00000000000002814627
   Coding: 191000 No fault code found. -------------------------------------------------------------------------------
   Coding: 021A01010B000400
   VCID: C0CC0A965BCF3B4F59-8094 6 Faults Found:
5276144 - Power Output Module for Left Headlamp
          C1081 F0 [137] - Not Coded
                    Reset counter: 171 5276400 - Power Output Module for Right Headlamp
          C1082 F0 [137] - Not Coded
                    Reset counter: 171 13679104 - Local Data Bus
          U10BA 00 [137] - No Communication
                    Fault Frequency: 81
                    Reset counter: 179
                    Mileage: 167272 km
                    Date: 2019.11.01
                    Time: 18:06:18 5275953 - Power Output Module for Left Headlamp
          C1081 31 [008] - No Signal
                    Fault Frequency: 49
                    Reset counter: 219
                    Mileage: 166900 km
                    Date: 2019.11.01
                    Time: 07:15:31 5276209 - Power Output Module for Right Headlamp
          C1082 31 [008] - No Signal
                    Fault Frequency: 51
                    Reset counter: 219
                    Mileage: 166900 km
                    Date: 2019.11.01
                    Time: 07:15:31 13705478 - Databus
          [RLS_01 Datenbus fehlende Botschaft]
                    Reset counter: 171
                    Mileage: 166900 km
                    Date: 2019.11.01
                    Time: 07:15:31
   Part No SW: 5G0 035 876     HW: 5G0 035 876
   Component: MU-S-NS-US    014 0645
   Serial number: V7B00806140972
   Coding: 027300020000000021220002001800001F0203340100010546
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: E99AF73208351A07AE-80BC    Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5G0 919 605 K    HW: 5G0 919 605 K
   Component: ABT_Std_Nav  H60 0030
   Serial number: VWZ8Z9PS6003PU         Data medium:
   Subsystem 2 - Part No SW: 5G0 919 866 H    HW: -----------
   Component:  NAR 2014/15  --- 0020
   Serial number: -------------------- 1 Fault Found:
7219 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Emergency call module (0x33) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 219
                    Mileage: 163798 km
                    Date: 2019.10.30
                    Time: 15:46:28                     Voltage terminal 30: 14.2 V
   Part No SW: 5QE 035 285     HW: 5QE 035 285
   Component: OCULowMQBUS   006 0528
   ROD: EV_OCULowMQB.rod
   VCID: 8248C09E1543E95F0F-80D6 No fault code found. -------------------------------------------------------------------------------
   Component: SAS-GEN 2     H06 0013
   Serial number: 140422200134
   VCID: EB968D3A02C90817DC-80BE No fault code found. End----------(Elapsed Time: 01:35, VBatt start/end: 12.4V/12.4V)-----------
myounus
Northwest UK
C?ID=321059
Can you advise what the OEM lights are - are they genuine VW lights or an aftermarket version?
Which 'correctly mnatching modules' did you plug in? You have module 55 in this scan and I'm pretty sure those light run off a 4b multifunction module.
^^^ myounus: all very good questions indeed!! However, interesting dynamic in the auto-scan - the hex55 module in the scan summary is missing from the detailed report - how does this happen (since there is no "communication failure" DTC for this module)? The "recipient" car did have HIDs originally because BCM Byte 2, Bits 0-1 =hex02 and because of the suggestion of a hex55 module in the auto-scan - very odd!!
Plus, interesting DTCs all round - was this car in an accident (air-bag module DTCs)?? Perhaps OP can try deleting ALL DTCs and re-post in an attempt to clean-up the auto-sacan?
the brit
C?ID=73227
Thanks for the help!!
The lights are genuine, which were supplied directly from VW AG, using the following part numbers:
GTE LED headlight left - blue stripe 5G1941077B
GTE LED headlight right - blue stripe 5G1941078B
These were the modules I ordered (By my own rushed research on ETKA):
Module 8V0907399D x 2
Module 7P5941572A x 2
the brit
C?ID=73227
The car is now in a shipping container heading to South America where I'm going to attempt to navigate across the complete continent in under 3 weeks, so no scans until it and I arrive, haha.
I'm going to take it straight to a dealership in Colombia to fix / finish whatever I can before we start the drive proper.
The steering wheel (and seats) were replaced with race versions, to match the roll cage that was installed.
Correct on the car having the OEM 2015 HID lights originally :)
The only DTC I did *not* expect was the oil pressure switch. I literally scanned the car inside the container as it left, so I'm planning to take a oil pressure gauge with me..
k.barghouthi
Palestine
C?ID=326133
Hi, as long you fitted the correct BCM/FCM/Gateway and wiring is 100% correct, it can be coded with ODIS online to match the coding / correct Parametrization and then with VCDS to match BCM to car preparations.
if you need help, send me a message
Regards
myounus
Northwest UK
C?ID=321059
Regards
No it's not that simple. ODIS will not simply paramaterise them but they are not from this VIN. Someone with the knowhow or another tool will be required. VCDS cannot do this.
k.barghouthi
Palestine
C?ID=326133
Well you found the Guy, i did 3 cars like this with ODIS :), we know how to parametrize the control units.
Regards
the brit
C?ID=73227
Regards
I didn't change the BCM, and haven't changed the pins etc on the wiring.. By the time I got to the car it was time to start driving unfortunately. I can log into ELSA and check the wiring for both cars (if I can see the European GTE car - it's often region locked under the USA account).
The car will be at a dealership in Colombia next week, where I have told I can use their ODIS, and I'll have my VCDS of course.
