Audi A6 2005 - battery and EPS lights have come on
Rustychain
C?ID=308958
Good evening
Whilst out in the car today my battery light came on. I wasn't too far from home so decided to continue. I turned off the heated seats etc to reduce the load and also monitored the battery level on the MMI (it stayed at 100% although I wonder how accurate it is). About five minutes later the EPS light also came on. As I got near to home both lights went out!
I put a multi-meter on the battery once at home - it was showing 13.8 v at idle and 13.5 v with all the electrical equipment on.
The VCDS scan is below. I assume the issues I experienced relate to the issues that are logged from today:
- 053255 - Please check Fault Memory in Battery Monitoring Module
- 009783 - Torque Management Feedback Signal A
- 18265 - Load Signal
- 02252 - Generator (looking at the times this seemed to happen first)
- 02479 - Partial Consumer Shut-Off Active
I'd appreciate any thoughts on what might be wrong. Some research suggests it might be the regulator?
Saturday,16,November,2019,13:02:07:57775
VCDS Version: 19.6.1.0 (x64)  HEX-V2 CB: 0.4505.4
VIN: WAUZZZ4F96N032034   License Plate:
Mileage: 261010km-162184mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
          56 61 62 69 72 76 77
VIN: WAUZZZ4F96N032034   Mileage: 261010km-162184miles
Address 01: Engine        Labels: User\059-907-401-ASB.clb
   Part No SW: 4F0 910 401 A    HW: 4F0 907 401 B
   Component: 3.0L V6TDI  G000AG  0020
   Revision: --H01---    Serial number:
   Coding: 0011372
   Shop #: WSC 00656 210 83209
   VCID: 1A6EDA72E091A32724D-804E
004118 - Valve for Air Filter Bypass Flap (N275)
               P1016 - 001 - Open Circuit
                    Fault Status: 01110001
                    Torque: 269.1 Nm
                    Temperature: 7.2°C
                    Temperature: 9.9°C
                    Mass Air / Rev.: 0.0 mg/str
               U1007 - 001 -  - Intermittent
                    Fault Status: 00110001
                    Mileage: 261003 km
                    Date: 2019.11.16
                    Time: 11:52:37
                    RPM: 1344 /min
                    Torque: 113.1 Nm
                    Speed: 57.1 km/h
                    (no units): 943.5
                    Voltage: 11.32 V
                    Temperature: 7.2°C
                    (no units): 4.0
   Part No SW: 4F1 910 156 B    HW: 09L 927 156 A
   Component: AG6 09L 3.0lTDI RdW 0030
   Revision: --H01---    Serial number:        4042590
   Coding: 0000001
   Shop #: WSC 02325 785 00200
   VCID: 2310E796D7DBE2EFF7B-8076
               P2637 - 000 -  - Intermittent
                    Mileage: 261003 km
                    Date: 2019.11.16
                    Time: 11:52:39
                    RPM: 1312 /min
                    RPM: 1280 /min
                    RPM: 1472 /min
                    (no units): 37.0
                    (no units): 25.0
                    Temperature: 52.0°C
                    T.B. Angle: 7.8°
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
   Component: ESP 8.0 quattro H03 0090
   Coding: 0004488
   VCID: 2D0401AE811F249F51F-8078
18265 - Load Signal
            P1857 - 000 - Error Message from ECU - Intermittent
                    Reset counter: 87
                    Mileage: 261003 km
                    Date: 2019.11.16
                    Time: 11:52:37
                    Hex Value: 0x3A00
                    Hex Value: 0x4006
                    Hex Value: 0x0028
                    Hex Value: 0x018D
                    Hex Value: 0x00FF
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H30 0220
   Revision: 31050601    Serial number: 10600300187560
   Coding: 0000147
   VCID: 6390A796975BA2EFB7B-8036
   Subsystem 1 - Part No: 4F0 910 131 E
   Component: FBSAUDIC6 EZS   H44 0070
   Subsystem 2 - Part No: 4F0 910 220 D
   Component: FBSAUDIC6 IDG   H39 0040
00956 - Key 2
                    Fault Status: 00110010
                    Reset counter: 86
                    Mileage: 260899 km
                    Date: 2019.11.10
                    Time: 18:12:35
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
   Part No SW: 4F0 910 730 F    HW: 4E0 035 729
   Component: Interfacebox    H43 2120
   Revision: 00000000    Serial number: 350FR057568631
   Coding: 0001002
   Shop #: WSC 02335 785 00200
   VCID: 2412E48AD2D5E5D78E1-8070
   Subsystem 1 - Part No: 4F0 910 609 B
   Component: Bedienteil MMIC6H03 0010
   Subsystem 2 - Serial number: 00000000174279
   Subsystem 3 - Serial number: 0107.06.050000000100010725ÿ
   Subsystem 4 - Serial number: 010725ÿ
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043     HW: 4F2 820 043 J
   Component: KLIMABETAETIGUNGH12 0160
   Revision: 00000027    Serial number: 00000000148896
   Coding: 0001302
   VCID: 5BE09F76AF2B9A2FFFB-800E
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Fault Frequency: 49
                    Reset counter: 47
                    Mileage: 260699 km
                    Date: 2019.11.07
                    Time: 15:50:58
                    Voltage: 13.50 V
                    Temperature: 13.0°C
                    (no units): 212.0
                    (no units): 217.0
                    Temperature: 9.0°C
   Part No SW: 4F0 910 279     HW: 4F0 907 279
   Component: ILM Fahrer      H14 0080
   Coding: 0002121
   VCID: 6696BE826469D7C7505-8032
   Subsystem 1 - Part No: 4F2 910 113 C  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H11 0040
   Coding: 00022800
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00141886
   Shop #: WSC 02335
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBE7177922
   VCID: 1C62DC6AEAA5DD17361-8048
Address 15: Airbags        Labels: 4F0-910-655-8R.clb
   Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
   Component: 4F AIRBAG AUDI8RH29 0260
   Revision: 07H29000    Serial number: 0037LD08B5N5
   Coding: 0013382
   VCID: 290CF5BEB5F738BFBD7-807C
   Subsystem 1 - Serial number: 6332CSME0A384F179
   Subsystem 2 - Serial number: 6342CSME0A2C7B76H
   Subsystem 3 - Serial number: 6352QSME0518293DI
   Subsystem 4 - Serial number: 6362QSME05033145%
   Subsystem 5 - Serial number: 63734SME02082E43Y
   Subsystem 6 - Serial number: 63834SME05192F7DB
   Part No SW: 4F0 910 549     HW: 4F0 953 549 B
   Component: Lenksäulenmodul H09 0230
   Revision: 00H09000    Serial number: 90025080100101
   Coding: 0102142
   Shop #: WSC 00656 210 88563
   Component: Lenkradmodul    H07 0080
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 A    HW: 4F0 920 980 M
   Component: KOMBIINSTR. M73 H15 0630
   Revision: 01000000    Serial number: 4PX35PL55
   Coding: 2049443
   Shop #: WSC 60457 001 1048576
   VCID: 211CED9ECDC7F0FFE57-8074
Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
   Component: Gateway         H10 0060
   Revision: 10          Serial number: 12008055288084
   Coding: EDFE73C41B3104
   VCID: 2708F386A3E30ECFAB3-8072
   Part No SW: 4E0 910 887 Q    HW: 4E0 919 887 C
   Component: MNS ECE         H44 0850
   Revision: 00000000    Serial number: 305EU057594249
   VCID: 3B203FF64F6BBA2FDFB-806E
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
   Component: TSG FA          H11 0040
   Revision: 00000000    Serial number: ‰3q
   Coding: 0003610
   Shop #: WSC 02327 785 00200
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 G    HW: 4F0 907 289 G
   Component: Komfortgeraet   H19 0140
   Revision: 01400019    Serial number: 01004778620000
   Coding: 0131835
   VCID: 2E0606A28C195F87685-807A
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F0 910 223 D    HW: 4F0 035 223 D
   Component: DSP-High C6     H09 0170
   Revision: PROD_01     Serial number: 00000000788056
   Coding: 0000113
   VCID: 1F18EB66FBB3C60FD33-804A
   Part No SW: 4F0 910 280     HW: 4F0 907 280 A
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000101129
   Coding: 0001103
   Shop #: WSC 02323 785 00200
   VCID: 5EE69662BC398F07985-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
   Component: TSG BF          H11 0040
   Revision: 00000000    Serial number: "Hq
   Coding: 0003610
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0000321
   Shop #: WSC 02334 785 00200
   VCID: 5DE4916EB13F941F81F-8008
   Part No: 8P0 907 357 C
   Coding: 0000003
   VCID: 3A2E3AF240518327C4D-806E
00070 - Starting Battery Voltage
                    Reset counter: 33
                    Mileage: 259320 km
                    Date: 2019.10.02
                    Time: 18:15:55
   Part No SW: 4E0 910 541 L    HW: 4F0 035 541 B
   Component: TUNER EU/US/RDW H42 0560
   Revision: 00000000    Serial number: 394F/057555766
   Coding: 0000001
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 F    HW: 4F0 915 181 B
   Component: J0644 BEM       H12 0760
   Revision: 00000000    Serial number: 00000000137903
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  1506010929
   Coding: 344630393135313035442056413031353036303130393239
02252 - Generator
                    Fault Status: 00101100
                    Fault Frequency: 14
                    Reset counter: 87
                    Mileage: 260981 km
                    Date: 2019.11.16
                    Time: 11:33:25
                    Mileage: 260994 km
                    Date: 2019.11.16
                    Time: 11:45:16
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 795
   Component: TSG HL          H11 0030
   Coding: 0003074
   VCID: 698CB5BE7577F8BF7D7-803C
Address 69: Trailer        Labels: 4F0-910-383.lbl
   Part No SW: 4F0 910 383     HW: 4F0 907 383
   Component: ANHAENGERELEKTR H02 0020
   Coding: 0000331
   VCID: 629EA2928841ABE7BCD-8036
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 794
   Component: TSG HR          H11 0030
   Coding: 0003074
   Part No SW: 4F0 910 283 C    HW: 4F0 919 283 C
   Component: Parkhilfe 8-Kan H12 0020
   Revision: 00H12000    Serial number: 11820515401776
   Coding: 0211016
   Part No SW: 4E0 910 336 F    HW: 4E0 862 335
   Component: Handyvorb2      H10 0580
   Revision: 00000000    Serial number: 00000007558494
   Coding: 0010900
   VCID: 2514F98ED9EF1CDF99F-8070
End----------(Elapsed Time: 01:50, VBatt start/end: 12.6V/13.9V)-----------
Yep, if it were mine, I would try to track down "Generator - Electrical Fault in Circuit" first.
Rustychain
C?ID=308958
Thanks UWE, I'll explore that issue first.
Once there's a break in this crappy weather I'll get the car jacked up and see if there's any obvious problems. I think it's the original alternator so I'm hoping it might just need a new regulator. 🤞
davisev5225
C?ID=263265
I would start with the physical connections to the alternator, even before checking the voltage regulator. There's a high probability that you have a loose or corroded connection that is causing a voltage drop.
Rustychain
C?ID=308958
I'm hoping it might be something that simple - I'll update once I've managed to have a look.
Rustychain
C?ID=308958
I've finally managed to have a look at the car.
I'm hoping the cause is the heavily worn brushes I discovered. One of the slip rings is also grey in colour suggesting one of the brushes hasn't been making contact.
New brushes ordered, I'll update once they're fitted. 🤞
