A5 2.0l TFSI 2019 Unknown Error Code
Ashraf6119
C?ID=174194
Hi,
Scanned this vehicle today and found unknown fault code with few other fault codes as well can some body please tell me what tis fault codes could be for...
1) 5456 - Unknown Error Code
P06E9 00 [175] - -
2) 9458950 - Telematics Module
U13EB 00 [009] - Flight mode activated
[eCall_activation_service_mode]
The other thing is when I start the vehicle I get a warning on dash which says (Drive System Active. Please Switch Off Ignition) what does this means...........?
Below is the full Auto Scan...........
Saturday,16,November,2019,11:27:56:07075
VCDS Version: 19.6.2.0  HEX-NET CB: 0.4508.4
VIN: WAUZZZF55KA031663   License Plate: I B M A5 BLUE
Mileage: 22469km-13961mi   Repair Order:
Chassis Type: F5-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 19 29 2B 39 42 44 46 52 5F 6D 80 81
          A5 BB BC D6 D7
VIN: WAUZZZF55KA031663   Mileage: 22469km-13961miles
80-Batt. reg. aux. accum. -- Status: OK 0000
Address 01: Engine (J623-DLVA)       Labels: None
   Part No SW: 8W0 907 115 Q    HW: 06L 907 309 E
   Component: R4 2.0l TFSI  H31 0003
   Revision: 1HH31000
   Coding: 1A2540132324050334082000000000000000000000000000
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM20TFS0118W0907115Q 001005
   ROD: EV_ECM20TFS0118W0907115Q.rod
   VCID: C7DEC3467EB6D777A6-8092
          P06E9 00 [175] - -
                    Fault Frequency: 15
                    Mileage: 22455 km
                    Date: 2019.11.14
                    Time: 18:19:33
                    Engine speed: 0.00 /min
                    Coolant temperature: 88 °C
                    Intake air temperature: 51 °C
                    Voltage terminal 30: 11.680 V
                    Starter control: terminal 50 acknowledgment-Bits 0-7: 39
                    Starter control: relay 1-Bits 0-7: 3
                    Starter control: release conditions-Bits 0-7: 0
                    Starter control: release conditions-Bits 0-7: 4
                    Starter control: shut-off conditions 1-Bits 0-7: 0
                    Number of manual engine starts: 1542
                    Number of automatic engine starts: 0
2822 - Bank 1; System Too Rich off Idle
          P2178 00 [096] - -
                    Mileage: 22459 km
                    Date: 2019.11.15
                    Time: 09:57:37
                    Engine speed: 2364.00 /min
                    Normed load value: 22.4 %
                    Vehicle speed: 43 km/h
                    Coolant temperature: 82 °C
                    Intake air temperature: 10 °C
                    Voltage terminal 30: 14.640 V
                    Engine status: COENG_RUNNING
5667 - Mass Air Flow Sensor (G70)
          P0101 00 [237] - Implausible Signal
                    Mileage: 22459 km
                    Date: 2019.11.15
                    Time: 09:57:37
                    Vehicle speed: 44 km/h
                    Voltage terminal 30: 14.620 V
Readiness: 0010 0001
   Part No SW: 8W2 927 155 DS    HW: 0HK 927 156 B
   Component: B9 2.0T 140kW H01 0001
   Revision: --H01---    Serial number: 0000003020
   ASAM Dataset: EV_TCMDL382021 002031
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 9562590E749AB5E7E4-80C0
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041190010000335
   Part No SW: 8W0 907 379 AF    HW: 8W0 907 379 J
   Component: ESP9 Plus     H16 0777
   Coding: 04AA089A14A50A9711A4489700805292F5B5D2201028508812004A49AFAD4B
   Shop #: WSC 06334 790 00001
   ROD: EV_ESP9BOSCHCMP_002.rod
   VCID: 895A057E2822610770-80DC
12845363 - Implausible Data Received from Engine Control Module
          U0401 00 [175] - -
          [Signal_MO_QBit_Motormomente_invalid_(1)]
                    Mileage: 22459 km
                    Date: 2019.11.15
                    Time: 09:57:37
                    95 00 80 17 8C 24 00 00 00 00
                    Unlearning counter according OBD-OBD unlearning counter: 28
13772320 - Engine Control Module
          U1226 00 [044] - Implausible Message
          [Signal_MO_QBit_Motormomente_invalid_(1)_or_PDU_Motor_11_not_received_correctly_(combination_of_Timeout:_CS:_AC)]
                    Fault Frequency: 9
                    Mileage: 22463 km
                    Date: 2019.11.15
                    Time: 10:21:32
                    8E 00 82 00 46 24 00 50 20 20
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 T    HW: 8W0 820 043 T
   Component: Klima Zone 3  H60 0251
   Coding: 140900095544440D02000100080000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: C4C4D44A4F80FC6F43-8090
   Subsystem 1 - Part No SW: 4M2 820 021 C    HW: 4M2 820 021 C
   Component: J126 FLuftV  H09 0004
   Serial number: 00000000000003220106
   Serial number: 4F911A8900PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: E265 Kli Fond  H40 0080
262914 - High Pressure Sensor
          B10AE 21 [009] - Signal Amplitude Too Low
                    Reset counter: 128
                    Mileage: 22458 km
                    Date: 2019.11.15
                    Time: 09:56:13
                    Outside air temperature: 7.50 °C
                    Engine speed: 1460 /min
                    Compressor current: actual value: 0.00 A
                    Temperature after evaporator: 11.50 °C
328003 - Motor for Recirculation Flap
          B1092 07 [009] - Mechanical Failure
                    Reset counter: 127
                    Mileage: 22455 km
                    Date: 2019.11.14
                    Time: 18:17:50
                    Recirc. air flap motor: spec.value: 11884
                    Recirculation air flap motor: actual value: 10006
                    System run time-Terminal 15 on: 563 s
                    Recirculation air flap motor: diagnostic-Last operating state: No routine started
                    Recirculation air flap motor: diagnostic-Operating condition: Blocking handling
                    Voltage terminal 30: 11.93 V
                    Outside air temperature: 13.00 °C
328179 - Motor for Rear Air Distribution
          B1093 07 [008] - Mechanical Failure
                    Reset counter: 168
                    Mileage: 22455 km
                    Date: 2019.11.14
                    Time: 18:17:50
                    Rear air distr.flap mot.:spec.val: 16629
                    Rear air distribution flap motor: actual value: 10005
                    Rear air distribution flap motor: diagnosis-Last operating state: No routine started
                    Rear air distribution flap motor: diagnosis-Operating condition: Blocking handling
                    Voltage terminal 30: 11.91 V
   Part No SW: 8W0 907 063 DG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0313
   Coding: 07501143E17900CD051587141BAC80F9110B3108000000000000000020001A810A450122025601
   ASAM Dataset: EV_BCM1BOSCHAU736 019008
   ROD: EV_BCM1BOSCHAU736_019.rod
   VCID: 834617560A0E3B573A-80D6
   Subsystem 1 - Part No SW: 8W6 955 119 C    HW: 8W6 955 119 A
   Component: 494 RL 181024  036 0481
   Serial number: 00000001810180302471
   Coding: FFC7F7
   Serial number: 22347093X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AG    HW: 4M0 941 531 AG
   Component: E1 - LDS  H06 0008
   Serial number: 16 10 2018  01681896
   Serial number: GX1CE119101823811165
   Coding: 210000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135 B    HW: 4K0 947 135 B
   Component: Dachmodul  H42 0413
   Serial number: C00165105
   Coding: 0D0104
   Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2818000185652001
196758 - Databus
          [Brake control module: received error value in signal ESP system status]
                    Reset counter: 128
                    Mileage: 22459 km
                    Date: 2019.11.15
                    Time: 09:57:38
                    average_Voltage_terminals: 14.80 V
                    Outside air temperature sensor-Outside air temperature on CAN: 7.50 °C
                    interior_temperature: 10.50 °C
                    Vehicle speed: 53.55 km/h
                    Terminal control-Terminal 75 status: On
                    Terminal control-Terminal 15 status signal: On
                    Terminal control-Terminal 15 via CAN: On
                    Terminal control-Term 75: qualification: OFF
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 F    HW: 8W0 959 655 F
   Component: Airbag10.44   H03 0107
   Serial number: 003UP00NJMA3
   Coding: AACCF0C00CA00000585400F3D0CC00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006016
   ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
   VCID: CCD4FC6A67D0342F8B-8098
   Subsystem 1 - Part No SW: -----------    HW: 442 060 601 19
   Serial number: 3577Y00C92B6E570F16F
   Subsystem 2 - Part No SW: -----------    HW: 442 060 601 19
   Serial number: 3587Y00B92B03AB29343
   Subsystem 3 - Part No SW: -----------    HW: 442 0B1 101 19
   Serial number: 3517700B32D9C90272EL
   Subsystem 4 - Part No SW: -----------    HW: 442 0B1 101 19
   Serial number: 3527700A92ED42D3C2F.
   Subsystem 5 - Part No SW: -----------    HW: 442 0C0 201 19
   Serial number: 3557500A12E1335491E6
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 442 0C0 201 19
   Serial number: 3567500A12E13357129+
   Pedestrian Protection Center:
   Subsystem 7 - Part No SW: -----------    HW: 442 0C0 201 19
   Serial number: 2307500C92E13363724/
   Subsystem 8 - Part No SW: -----------    HW: 442 430 204 19
   Component: PedPSensor_D2  256 0887
   Serial number: I0M9M00C32FFCA50833U
   Subsystem 9 - Part No SW: -----------    HW: 442 430 204 19
   Component: PedPSensor_P2  256 0887
   Serial number: I0N9M00C32FFCA5451F%
   Part No SW: 4N0 907 129 S    HW: 4N0 907 129 S
   VCID: C1CADD5E5092E94768-8094
   Part No SW: 8W5 920 790 E    HW: 8W5 920 790 E
   Component: FBenRDW       H19 0417
   Coding: 25A440D6288006000120E9601000000000000000
   ASAM Dataset: EV_DashBoardAU736 001032
   Part No SW: 8W5 907 468 H    HW: 8W5 907 468 G
   Component: Gateway       H43 0145
   Revision: AS010003    Serial number: 038AS093719117
   Coding: 0201000100208640298700000059001248180007100000000175078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 003170
   VCID: CED0F66291CC063FE5-809A
   Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0004
   Serial number: 20190117032000 20468
   Subsystem 2 - Part No SW: 8W0 915 181 A    HW: 8W0 915 181 A
   Serial number: 5314740105
                    Mileage: 22455 km
                    Date: 2019.11.14
                    Time: 18:18:20
   Part No SW: 4M0 907 397 AB    HW: 4M0 907 397 B
   Component: LCM_MLBevoH05 0024
   VCID: F7BE73864ED667F716-80A2
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 18000392962008
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_AU37.rod
   VCID: B424848A1F204CEFF3-80E0
   Part No SW: 8W0 959 593 H    HW: 8W0 959 593 F
   Component: TSG FS        009 0130
   Serial number: 0000361815592
   Coding: 001FCA625001000000001402
   VCID: CFEEEB6696C60F37EE-809A
   Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0410
   Coding: 09000380800000
   ASAM Dataset: EV_EPSZFAU49X 003023
   ROD: EV_EPSZFAU49X_003.rod
   VCID: C2C8D2525594F25F71-8096
17664 - Databus
          [KFC_ESP_22_SNA]
                    Reset counter: 128
                    Mileage: 22459 km
                    Date: 2019.11.15
                    Time: 09:57:37
                    Expanded ambient data 1-Engine running: Engine_Running_Stable
                    Expanded ambient data 1-Supply voltage: 0.00 V
                    Expanded ambient data 1-Temperature: -70 °C
                    Expanded ambient data 1-System status: 5
                    Expanded ambient data 1: 00
                    Expanded ambient data 1-driving_direction: 0
                    Expanded ambient data 1-KFA: 0
                    Expanded ambient data 1-KFC: 69
                    Expanded ambient data 1-Ready_To_Drive_Bit: 0
                    Expanded ambient data 1-StartStop Info: 0
                    Expanded ambient data 1-Steering_Angle_Calculated: 14 °
                    Expanded ambient data 1-Steering_Angle_Calculated_Sign: 1
                    Expanded ambient data 1-Steering_torque: 0.10 Nm
                    Expanded ambient data 1-Steering_Torque_Sign: 1
                    Expanded ambient data 15-MsgStateFifo_Byte0: 00 00 00 00
                    Expanded ambient data 15-MsgStateFifo_Byte1: 00 00 00 00
                    Expanded ambient data 15-MsgStateFifo_Byte2: 00 00 00 00
                    Expanded ambient data 15-MsgStateFifo_Byte3: 00 00 00 00
                    Expanded ambient data 15-NumOfMsgCntFaults: 00
                    Expanded ambient data 15-NumOfMsgCrcFaults_2: 00
                    Expanded ambient data 15-NumOfMsgNoFaults_3: 00
                    Expanded ambient data 15-NumOfMsgTimoFaults_1: 00
   Part No SW: 8W0 907 064 GB    HW: 8W0 907 064 DB
   Component: BCM2 MLBevo   025 0424
   Coding: 013500002FB100406309A0000400080211020010804306502F04000000040030001F0001000010
   ASAM Dataset: EV_BCM2HellaAU736 016016
   ROD: EV_BCM2HellaAU736_016_AU49.rod
   VCID: 824812521514325F31-80D6
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY183300MEJ
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000046139534
   Part No SW: 8W0 959 592 H    HW: 8W0 959 592 F
   Component: TSG BFS       009 0130
   Serial number: 0000361753614
   Coding: 001FCA225C01000000001400
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 035 C    HW: 8W5 035 035
   Component: MU-P-LND-EU   035 1329
   Serial number: A829A0KB091451
   Coding: 01940301FF0A000053111101000A00312F000DE701700100DE
   VCID: B73EB3860E56A7F7D6-80E2
   Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Subsystem 2 - Part No SW: 8W8 919 605     HW: 8W8 919 605
   Component: DU High AU49x  H32 0170
   Serial number: TPO00123101800820594
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK122111800040058
   Compact Disc Database:
   Component: Gracenote2  --- 1017
   Part No SW: 8W8 959 107 D    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0170
   Revision: --------    Serial number: A2-C744-8781-0
   Coding: 0610
   VCID: CAD8FA726DA42A1FB9-809E
Address 80: Batt. reg. aux. accum. (A1)       Labels: None
   Part No SW: 8W0 915 101 A    HW: 8W0 915 101 A
   Component: MQ-BMS        H20 0126
   Serial number: 18000063875001
   ASAM Dataset: EV_BMS12VLiIonSDIAU49X 001001
   ROD: EV_BMS12VLiIonSDIAU49X.rod
   VCID: B12A8D9EE03279C798-80E4
   Part No SW: 8W2 713 041 N    HW: 8W2 713 041 K
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 19010750424800
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: BFCEDBA626669FB71E-80EA
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W6 907 217 B    HW: 8W6 907 217 A
   Component: BVS           H17 0052
   Coding: 0404090300000403024023A0A50000FC00F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
1123173 - Databus
          [ESP_21_ESP_Systemstatus]
                    Reset counter: 128
                    Mileage: 22459 km
                    Date: 2019.11.15
                    Time: 09:57:38
                    Control Module temperature: 16 °C
                    Voltage terminal 15: 14.60 V
   Part No SW: 8W0 959 595 H    HW: 8W0 959 595 F
   Component: TSG HFS       009 0130
   Serial number: 0000362292035
   Coding: 000FC8220001000000001000
   VCID: D1EAED1E80F219C7F8-8084
   Component: TSG HBFS      009 0130
   Serial number: 0000362292037
   ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
   VCID: 977E53066E9687F7F6-80C2
End----------(Elapsed Time: 02:00, VBatt start/end: 13.8V/13.7V)-----------
P06E9: Engine Starter Malfunction
Considering this is a 2019 car with only ~14,000 miles on it and you have other engine faults one of which has the MIL on, I would take it to the dealer and have them address those issues under warranty.
Telematics Module - Flight mode activated
I see no Telematics module in this car. I suppose it's possible that functionality has been integrated into one of the modules?
The GW does have this channel:
IDE13338-MAS16261 -- Basic functions connect - Flight mode (Deactivating / Activate)
Have a look; my guess is Flight Mode is activated there and you could de-activate it (if the owner likes to be tracked).
Ashraf6119
C?ID=174194
Hi Uwe,
Thanks for the reply I did forgot to mention the this vehicle was bought from the action with a front end damaged but, there were NO any airbag deployed and now its fully repaired and this where the only fault codes stored.........
I will have a look in GW module for IDE13338-MAS16261 -- Basic functions connect - Flight mode (Deactivating / Activate and report back........
This car starts fine than how come this P06E9: Engine Starter Malfunction will not clear it keeps coming back as soon as I clear it...
