NO EPB 53 CONTROLLER
The Doodster
Verified VCDS-User
Cornwall, UK
C?ID=358455
Hi,
I'm trying to open the EPB in service mode and followed the online video but there is no 53 parking brake function so can't open the calipers to change the discs and pads. Also get ROD error when running autoscan. Any help would be appreciated.
Scott (Doodster)
[b]Sunday,17,November,2019,10:37:21:44739
VCDS Version: 19.6.2.0
Dealer/Shop Name: DOODY CARS
VIN: WVWZZZAUZEW411135   License Plate:
Mileage: 117414km-72957mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEW411135   Mileage: 117414km-72957miles
Address 01: Engine (J623-CLHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 M    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 5517
   Revision: 84H22---
   Coding: 01110012032515092000
   ASAM Dataset: EV_ECM16TDI01104L906021M 002009
   ROD: EV_ECM16TDI01104L906021P.rod
   VCID: 2F6DC09D76B38F370E-807A
   Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
   Component: ESC           H31 0472
   Revision: 00000000    Serial number: 61044000000595
   Coding: 01FA8AA11421096D0378060341C82580512890C06082A4F300400074C002
   VCID: 071D483DBE83F777E6-8052
   Part No SW: 5G0 907 426 M    HW: 5G0 907 426 M
   Component: AC Manuell    H01 0705
   Revision: 00001K06
   Coding: 00120104202100001000000000000000
   VCID: 3561F2F594EFB5E744-8060
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
   Part No SW: 5Q0 937 084 AB    HW: 5Q0 937 084 AB
   Component: BCM MQBAB B   H16 0124
   Serial number: 00011411300168
   Coding: 03000842C20100530BA44000000403081000000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   VCID: 78FF3BC1C37D888F9F-802C
   Component: WWS    140417  042 0551
   Serial number:         140422065742
   Part No SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0142
   Revision: --------    Serial number: 39331412305401
   Coding: 0031051001
   VCID: 3E73EDD9A1D976BF95-806A
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Serial number: 003F6R0742K+
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 41899625D0270947E8-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 002 504 14
   Serial number: 35767000000C5C518F00
   Subsystem 2 - Part No SW: -----------    HW: 480 002 304 14
   Serial number: 358670000001AB399F01
   Subsystem 3 - Part No SW: -----------    HW: 480 401 704 14
   Serial number: 3516502AF157E995713M
   Subsystem 4 - Part No SW: -----------    HW: 480 402 204 14
   Serial number: 35265029F1529DF2534K
   Subsystem 5 - Part No SW: -----------    HW: 480 402 204 14
   Serial number: 3556502AF157E99210DQ
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 DJ    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 23041404220889
   Coding: 1604
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 0109562590A7C947A8-8054
No ASAM data for: "EV_SMLSKLOMQB" (VW37)
   Part No SW: 5G0 920 951 A    HW: 5G0 920 951 A
   Component: KOMBI         152 2210
   Coding: 27A402002300260001080800040000
   VCID: 275D28BD5E43D777C6-8072
   Part No SW: 5Q0 907 530 N    HW: 5Q0 907 530 D
   Component: GW MQB Low    123 1164
   Revision: --------    Serial number: 0001920881
   Coding: 030000040B087300EF000048080E00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_010.rod
   VCID: 3C77E7D1B7C564AFBB-8068
   Subsystem 2 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Serial number: 5265803203
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 27041401101586
   Coding: 003002208001040100001000
   Component: EPS_MQB_ZFLS  122 1043
   Coding: 0103
   ROD: EV_SteerAssisMQB_010.rod
   Serial number: 24041403110413
   Coding: 003000208E01040100801000
   VCID: 3F8D90DDA6D37FB79E-806A
   Part No SW: 5G0 035 820 A    HW: 5G0 035 820 A
   Component: MU-S-D-ER     040 0421
   Serial number: V5C01904142812
   Coding: 02730000FF00000021111201000800001F0100060100010001
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 1F4D305D06131FB7BE-804A
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H60 0030
   Serial number: VWZ8Z9PS20142A
End-------------------------(Elapsed Time: 02:58)--------------------------
[/b]
nirvananils
C?ID=289109
As you drove a MQB based car, you should have a look in ECU3 (Brake Electronics)
The Doodster
Verified VCDS-User
Cornwall, UK
C?ID=358455
I don't have that option
nirvananils
C?ID=289109
You have to look in Basic Setting or Adaptions in Brake electronics
The Doodster
Verified VCDS-User
Cornwall, UK
C?ID=358455
Unfortunatly, it will not load as it keeps coming up with unable to load ROD file.
I've managed to do it with a Snap on Solus edge now as I needed the car done but thanks for trying anyway.
Try using the legitimate cable that your registered with us in September of last year rather than the clone you got that data with; I'm confident it will work more better. ;)
The Doodster
Verified VCDS-User
Cornwall, UK
C?ID=358455
Oh! Bugger! I thought I'd binned it. Just checked and its in the bottom of the bag.
Many thanks Uwe
The Doodster
Verified VCDS-User
Cornwall, UK
C?ID=358455
Hi,
Just updated the code in the first post to the correct cable. Still no EPB controller 53 but managed to find it in the ABS controller.
Hi,
That one works a whole lot better, doesn't it? ;)
Your ABS is "MK100IPB". IPB stands for "Integrated Parking Brake".
The pad-change procedure can be found here.
The Doodster
Verified VCDS-User
Cornwall, UK
C?ID=358455
That's great, thanks for the info Uwe, and for the record, the other cable has
gone in the bin :)
