Audi a3 . 8P ABS problem fault code ;16352
ahmed ait siaddi
Morocco
C?ID=381337
HELLO ; I have an audi a3 8P
I have a problem in the module ABS
Thursday,14,November,2019,20:47:20:13605
VCDS Version: 19.6.2.0  HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8P19A079654   License Plate: A3
Mileage: 172680km-107298mi   Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WAUZZZ8P19A079654   Mileage: 172680km-107298miles
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 056 R    HW: 03G 906 021 AB
   Component: R4 1,9L EDC G000SG  2916
   Revision: --H09---    Serial number: AUX7Z0HNFNI00P
   Coding: 0000071
   Shop #: WSC 80093 222 69422
   VCID: 36352622E4442FE723B-8062
001025 - EGR System
               P0401 - 000 - Insufficient Flow - Intermittent
                    Fault Status: 00110000
                    Mileage: 172662 km
                    Date: 2019.11.11
                    Time: 22:32:08
                    RPM: 1890 /min
                    Speed: 31.0 km/h
                    Load: 27.5 %
                    Duty Cycle: 14.6 %
                    Duty Cycle: 95.1 %
                    Mass Air / Rev.: 240.0 mg/str
                    Mass Air / Rev.: 465.0 mg/str
000564 - Boost Pressure Regulation
               P0234 - 000 - Limit Exceeded (Overboost Condition) - MIL ON
                    Fault Status: 11110000
                    Mileage: 172674 km
                    Date: 2019.11.12
                    Time: 12:41:25
                    RPM: 2604 /min
                    Speed: 105.0 km/h
                    Load: 79.2 %
                    Voltage: 14.29 V
                    Bin. Bits: 00101000
                    Absolute Pres.: 2029.8 mbar
                    Absolute Pres.: 2539.8 mbar
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0106
   Revision: 00H35001
   Coding: 1142201209290003881104E9901D00413800
   Shop #: WSC 06314 123 12345
   VCID: 74B1DC2ABEB87DF7DDF-8020
16352 - Control Module - Electrical Error
                    Fault Status: 00101110
                    Reset counter: 24
                    Mileage: 172657 km
                    Date: 2019.11.11
                    Time: 10:26:12
                    Count: 4
                    Count: 12800
                    Count: 98
                    Count: 49411
                    Count: 2
                    Reset counter: 24
                    Mileage: 172657 km
                    Date: 2019.11.11
                    Time: 10:26:34
                    Count: 7
                    Count: 12800
                    Count: 104
                    Count: 50449
                    Count: 1
01486 - System Function Test Activated
                    Reset counter: 24
                    Mileage: 172657 km
                    Date: 2019.11.11
                    Time: 09:32:57
                    Count: 3
                    Count: 2
                    Count: 12288
                    Count: 320
                    Count: 43776
                    Count: 1
   Part No: 8P0 820 047 B
   Component: J255  Klima Man H07 0030
   VCID: 2F3B13461B1E1E2F60D-807A
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
   Component: Bordnetz-SG     H54 2801
   Revision: 00H54000    Serial number: 00000009116967
   Coding: 10A82F8190141380EF00001C0000000000094A156401040300A800000000
   Shop #: WSC 06314 000 08192
   VCID: 48C958DA9EB0A917417-801C
   Subsystem 1 - Part No: 8P1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H10 0040
   Coding: 00064784
   Shop #: WSC 06314
9 Faults Found:
                    Fault Status: 00101100
                    Reset counter: 61
                    Mileage: 172518 km
                    Date: 2019.10.25
                    Time: 00:56:00
                    Voltage: 12.10 V
01502 - Bulb for Rear Fog; Left (L46)
                    Reset counter: 61
                    Mileage: 172518 km
                    Date: 2019.10.25
                    Time: 00:52:00
                    Voltage: 12.30 V
00906 - Horn (H1)
                    Fault Status: 00101001
                    Reset counter: 64
                    Mileage: 172648 km
                    Date: 2019.11.11
                    Time: 20:39:00
                    Voltage: 12.60 V
01516 - Terminal 30; Left
                    Fault Status: 00101011
                    Reset counter: 64
                    Mileage: 172648 km
                    Date: 2019.11.11
                    Time: 20:39:00
                    Voltage: 12.65 V
01064 - Terminal 58d; Interior Dimming
                    Fault Status: 00100111
                    Reset counter: 64
                    Mileage: 172648 km
                    Date: 2019.11.11
                    Time: 20:39:00
                    Voltage: 12.65 V
00926 - Terminal 30
                    Reset counter: 64
                    Mileage: 172648 km
                    Date: 2019.11.11
                    Time: 20:40:00
                    Voltage: 5.00 V
00927 - Terminal 30 (Right)
                    Reset counter: 64
                    Mileage: 172656 km
                    Date: 2019.11.11
                    Voltage: 12.55 V
                    Reset counter: 61
                    Mileage: 172518 km
                    Date: 2019.10.25
                    Time: 00:24:00
                    Voltage: 11.90 V
00984 - Left Tail Light (M4)
                    Reset counter: 61
                    Mileage: 172518 km
                    Date: 2019.10.25
                    Time: 00:12:00
                    Voltage: 11.85 V
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 J    HW: 8P0 959 655 J
   Component: Airbag AU1042 H06 0090
   Revision: --------    Serial number: 003000000000
   Coding: 303142383038303030354A55304C38503053
   Shop #: WSC 06314 000 00000
   ROD: EV_Airba10AURB4.rod
   VCID: 49CF5DDE893A501F5E9-801C
   Serial number: 3572DRB400008424B8F
   Serial number: 3582DRB4000084207ADV
   Serial number: 35128RB4000047174569
   Serial number: 35228RB40000471D4FBV
   Serial number: 35547RB4000048ABE9E7
   Serial number: 35647RB4000048ABEDFD
13636864 - Control Module for ABS Brakes
          U1015 00 [008] - No Communications
          [Lost Communication With Vehicle Dynamics Control Module]
                    Reset counter: 64
                    Mileage: 172656 km
                    Date: 2019.11.11
                    Time: 00:24:09
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0000042
   VCID: 41DF45FEBD8A985F869-8014
   Part No SW: 8P0 920 931 S    HW: 8P0 920 931 S
   Component: KOMBIINSTR. VDO H18 0830
   Revision: D0H18006    Serial number: 224NH006056422
   Coding: 0004128
   VCID: 43D34FF6A7968A4F945-8016
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533__Gateway   H16 0210
   Revision:   H16       Serial number: 3400K08B140407
   Coding: E9807F06000202002102
   VCID: 372B2B26E34ED6EF38D-8062
                    Reset counter: 64
                    Mileage: 172656 km
                    Date: 2019.11.11
                    Time: 09:18:17
                    Fault Frequency: 119
                    Reset counter: 24
                    Mileage: 172656 km
                    Date: 2019.11.11
                    Time: 09:18:18
01304 - Radio
                    Reset counter: 24
                    Mileage: 172656 km
                    Date: 2019.11.11
                    Time: 09:18:21
   Revision: D0H18006    Serial number: AUX7Z0HNFNI00P
16346 - Control Module - ROM Error
            014 - Defective
   Part No SW: 8P0 959 801 K    HW: 8P0 959 801 K
   Component: Tuer-SG         H03 0060
   Coding: 0000148
00912 - Window Regulator Switch; Front Left (E40)
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 232    2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A0D025220FC7B07B73-807E
                    Reset counter: 74
                    Mileage: 172656 km
                    Date: 2019.11.11
                    Time: 09:16:21
                    Voltage: 12.13 V
                        DU
                    Temperature: 26.0°C
                    Speed: 50.0 km/h
                    Speed: 50.0 km/h
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 L
   Component:    KSG          H11 0080
   Coding: 1880200002186D0985054C8F0167
   VCID: 45D751EEA9A2B47FBA1-8010
   Part No SW: 8P0 959 802 K    HW: 8P0 959 802 K
   Coding: 0000148
   VCID: 44D14CEAA2988D77ADF-8010
01553 - Motor for Central Locking; Passenger Door (V57); Lock
Address 56: Radio
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
   Component: Tuer-SG         H04 0040
   Coding: 0000144
   Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
   Coding: 0000144
   VCID: 42DD4AF2B88C83479F3-8016
End----------(Elapsed Time: 01:19, VBatt start/end: 12.3V/12.3V)-----------
ahmed ait siaddi
Morocco
C?ID=381337
no its warranty run out . I check all abs system the code in the first post
MartinsX
Riga, Latvia
C?ID=268515
Check fuses first. If not agree replace abs module
In addition I'd suggest not only fuses but load test all power and ground wires to ABS/ESP unit.
From my experience: I have solved a lot of cases where other workshops have replaced ABS modules but the same fault codes are still here :D
NostraJackAss
I most especially like when I get my customers a free or reimbursable repair, wouldn't you?
I agree with Mr. X he knows his shit!
I would like to add, that often a bad ignition switch, can indeed result in such an ABS fault too and wouldn't you know it, that's a known defect too; & often covered by campaign?
ahmed ait siaddi
Morocco
C?ID=381337
thanx guys for your time . i will double check the fuses and the wires . i was looking for an abs modules to replace it i found some but not the same module
