2004 A4 1.8T Engine Misfires
OKAUDIGUY
Vernon, British Columbia
C?ID=384931
This is my first post here and one of very few forum posts, correct me if I'm doing this wrong. Love my Audi's but need some help.
Happened Immediately following replacement of a cracked Air / Smog Pump Check Valve
So a quick back story. Car was noted to run a bit rough on a road trip. Noticed smog pump check valve was cracked and leaking. Duct tape repair got us home nicely running smooth with no issues. Ordered a new part from Rock auto. SKP 058905291K Air / Smog Pump Check Valve (8409.91.0090)CAD$ 2.87 BUT!!! as soon as it was fired up instantly running rough, way worse than with the old cracked (broken barbed hose nipple with 100% leak, prior to duct tape fix!!!). The direction of check valve install double-checked. So it would appear to me, as a total rookie, this was just incredible fluke timing. I also checked all the coils as I just went through a similar rough running (not as rough) of my other (Yes I have 2 same year a4 1.8ts) Anyway this car has fairly high Kms and other major issues such as ABS but I dont want it to end this way. Please help. Here's the codes from the first auto Scan.
Wednesday,13,November,2019,08:52:08:32812
VCDS Version: 19.6.2.0  HEX-V2 CB: 0.4508.4
          67 69 75 76 77
VIN: WAUVC68E14A226867   Mileage: 313700km-194924miles
Address 01: Engine        Labels: 06B-909-518-AMB.lbl
   Part No SW: 8E0 909 518 AK    HW: 8E0 909 018 A
   Component: 1.8L R4/5VT     G   0004
   Coding: 0016711
   Shop #: WSC 63251 000 00000
   VCID: 79AFEAADC5C1500F8E9-5160
16684 - Random/Multiple Cylinder Misfire Detected
            P0300 - 008 -  - MIL ON
16687 - Cylinder 3
            P0303 - 008 - Misfire Detected - MIL ON
16688 - Cylinder 4
            P0304 - 008 - Misfire Detected - MIL ON
16686 - Cylinder 2
            P0302 - 008 - Misfire Detected
17834 - EVAP Purge Valve (N80)
            P1426 - 004 - Open Circuit - Intermittent
Readiness: 0110 1101
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517 A
   Component: ABS/ESP allrad      3429
   Coding: 04275
   Shop #: WSC 06435
   VCID: 2615F1D161FF0FF793B-51F2
            35-00 - -
00273 - ABS Inlet Valve; Rear Right (N133)
            35-10 - - - Intermittent
00274 - ABS Inlet Valve; Rear Left (N134)
            35-00 - -
01200 - ABS Valves Supply Voltage
01421 - High Pressure Switch Valve 2 for Electronic Stability Program (N228)
            30-00 - Open or Short to Plus
   Part No: 8E0 820 043 AD
   Component:   A4 Klimaautomat   1450
   Coding: 00000
   Shop #: WSC 93320
   VCID: 6393A8C5524DBADFB45-513C
01794 - Control Module - Incorrect Chassis (VIN) Number
            35-00 - -
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  KAN 0517
   Coding: 01014
   Shop #: WSC 63251
   VCID: 3537269DAC59746F2A1-4B1E
            57-00 - Electric Circuit Failure
02104 - Light Detection Sensor (G399)
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 K
   Component: Airbag 8.4EP        1001
   Coding: 0010607
   VCID: 3FDB44B59B65BE3FF0D-5184
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0611
   Coding: 01042
   Shop #: WSC 63251
   VCID: 3E2539B1996FB737FBB-4B1E
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8E0 920 900 N
   Component: KOMBI+WEGFAHRS. RB4 D42
   Coding: 01331
   Shop #: WSC 93320
   VCID: 2F3B14F54E054EBF60D-5160
   WAUVC68E14A226867     AUZ6Z0D0045326
   Part No: 8E0 959 433 BB
   Component: Komfortgerát T7B    1612
   Coding: 12044
   Shop #: WSC 93320
   VCID: 72BDDD819DB72357CF3-4B1E
   Subsystem 1 - Part No: 8E1959801
   Component: Tõrsteuer.FS BRM 0004
   Subsystem 2 - Part No: 8E1959802E
   Component: Tõrsteuer.BF BRM 0004
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0004
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0004
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 - -
00955 - Key 1
01034 - Electric Window Thermal Protection Active; Driver
01705 - Selection Switch for Mirror-Adjust (E48)
            80-00 - Single-Wire Operation
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00060
   Shop #: WSC 63251
   VCID: 04518B59B7331DE7EDF-4B3C
   Part No: 8E0 035 195 G
   Component: symphony II NP2    0410
   Coding: 01001
   Shop #: WSC 27649
   VCID: 2B0300E57A2D329F4C5-5066
End----(Elapsed Time: 05:35, VBatt start/end: 11.2V/11.0V. VIgn 11.0V)-----
NostraJackAss
Hello and welcome to the VCDS forum OP!
N80 being sorted for open circuit would be a good start and qualifying vacuum leaks no?
Compression check and plugs burn rate condition?
Any FOD?
Did you JPPSG yet?
Almost 200,000 miles! :thumbs:
I would hunt down and correct whatever is causing the EVAP Purge Valve - Open Circuit DTC first. That could potentially screw up the fuel trims and cause misfires.
Next, I would clear faults and watch what happens to the fuel trims immediately thereafter.
OKAUDIGUY
C?ID=384931
Any FOD?
Did you JPPSG yet?
Thanks, I have not done anything yet. I was hoping for a quick fix LOL. I will do this diagnosis as suggested. It might take me a couple days to get to this. Stay tuned and thanks for responding.
OKAUDIGUY
C?ID=384931
Thanks UWE, I'll check into the Evap Purge Valve. It may be a couple days before I can get to it.
OKAUDIGUY
C?ID=384931
So checked into this a few days ago. Certainly re-learned my lesson should have just taken a close visual inspection and I would have found this sooner. So the short story is I guess this happened when we were changing oil, shoving arm into unscrew oil filter dislodged(broke it must have been ready to let go and it just needed a little nudge) the vacuum exact part# not yet identified but pretty sure its this one. Vacuum Check Valve Breather 058 133 784 AF, 07C 133 529 A I have temporarily epoxied it back together so just need to source a new one. Looks like it comes as whole assembly. I circled the actual broken bit in red and yellow for what my search turned up as a common assembly.
https://www.dropbox.com/s/fse7yrdwf3cxqhb/2019-11-16 16.29.03.jpg?dl=0 It runs fine now with the temp fix. I guess I'll scan again for giggles. Next stop ABS brakes!!! Cheers
