VW 2016 Golf MK7 Cruise Control (CCS) wire to Engine Control Unit (ECU)
sosterman
Morocco
C?ID=380597
I've looked almost everywhere and only found a reference to a J263, T94/56 which I understand to be a 94 pin connector for the ECU, pin 56. The problem, or my confusion is this ECU has two connectors. A 105 pin and a 91 pin connector. The instructions indicate that the pin-out is engine specific. Am I missing something or looking at the wrong unit? Is their someone that can steer me in the right direction? I found the pin 5 of the J527, T16/5 for the Steering column electronics control unit and have no problem running the wire. I have already installed the MFSW controls in the steering wheel. Fairly simple and straight forward. I would like to resolve this prior to bringing the codes to the dealer to have them activate the CCS. Also, I bought the car at a VW dealer in Morocco without cruise control.
Thanks,
Wednesday,13,November,2019,13:55:04:34757
VIN: WVWZZZAUZGW318884   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F
VIN: WVWZZZAUZGW318884   Mileage: 4106km-2551miles
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 BP    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H22 1198
   Revision: B5H22---
   Coding: 011D0012030401083000
   ASAM Dataset: EV_ECM20TDI01104L906026BP 002002
   ROD: EV_ECM20TDI01104L906026BP_002.rod
   VCID: 79AFED35C9512E9F8E9-802C
   Part No SW: 0D9 300 041 H    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4902
   Revision: 06253104    Serial number: TFK01604121265
   ROD: EV_TCMDQ250021.rod
   VCID: 1D67D9A53D39B2BFC21-8048
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 61106000000503
   Coding: 01FA62A124210974057F060841C72980462490A0608294F300620078C202
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   Revision: 00021000    Serial number: 0401266553
   Coding: 030C1C
   Shop #: WSC 12345 123 61029
   VCID: 3A2D32398CD7E587C73-806E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00020114200100011005004000101002
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 6A8DC279BCF79507773-803E
   Air quality sensor:
   Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
   Serial number: 01061611301007
   Coding: 00111A46C24122FB4AE44000000C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 04518CC1BE936377EDF-8050
   Component: WWS    160406  043 0551
   Serial number:         160416010852
   Component: RLHS  037 0059
   Serial number: S3Y16M04D27H04M38S11
   Coding: 90A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.403  H03 0004
   Serial number: 0000FST000WMJXY00000
   Coding: 181901
   Revision: --------    Serial number: 39331611600189
   Coding: 0031151011
   VCID: 43D34FDDFB1DA44F945-8016
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    015 0388
   Serial number: 003MLR1N4WW-
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F5B032DD77500AFB0D-802A
   Belt Pretensioner left:
   Serial number: 34169667D23041650021
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169668D22041650307
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 004 16
   Serial number: 357670000000A655BA1X
   Subsystem 4 - Part No SW: -----------    HW: 480 002 004 16
   Serial number: 35867000000B1525BA1W
   Subsystem 5 - Part No SW: -----------    HW: 480 402 104 16
   Serial number: 3516502A520414E2C2B3
   Subsystem 6 - Part No SW: -----------    HW: 480 402 104 16
   Serial number: 3526502AF20414E3324%
   Subsystem 7 - Part No SW: -----------    HW: 480 401 604 16
   Serial number: 3556502B520414F100F+
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 20041604220688
   Coding: 0410
   ASAM Dataset: EV_SMLSKLOMQB 020001
   VCID: 074B9BCD8FA5486F88D-8052
   Part No SW: 5G1 920 641 A    HW: 5G1 920 641 A
   Component: KOMBI         208 7653
   Coding: 07A519182B80000E02083A001400000000000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009005
   ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
   VCID: 2411EC411E5383778DF-8070
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1244
   Revision: --------    Serial number: 0004776514
   Coding: 030100041F087300FB00024E1C0F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H12 0034
   Serial number: 02120004599160020291
   Coding: 2B0000
   Serial number: 7289390004
8782084 - Tiptronic Downshift Switch/Paddle in Steering Wheel
          B114E 96 [009] - Component internal failure
                    Reset counter: 88
                    Mileage: 4090 km
                    Date: 2019.11.12
                    Time: 02:16:26
                    Supply voltage: Terminal 30: 12.1 V
                    Terminal 15: On
8782085 - Tiptronic Upshift Switch/Paddle in Steering Wheel
          B114F 96 [009] - Component internal failure
                    Reset counter: 88
                    Mileage: 4090 km
                    Date: 2019.11.12
                    Time: 02:16:26
                    Terminal 15: On
8782090 - Cruise Control Switch
          B1154 96 [009] - Component internal failure
                    Reset counter: 88
                    Mileage: 4090 km
                    Date: 2019.11.12
                    Time: 02:16:26
                    Terminal 15: On
   Revision: 00000000    Serial number: 16000070740010
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311C01AEB313F71DF-8060
   Serial number: 230216EBM04902
   Coding: 003B1320D000048000001000
   Serial number: 00000000000009805421
   Coding: 110000
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 8103
   VCID: 44D14CC1FE13A377ADF-8010
   Serial number: 120416ED934978
   Coding: 003B1120DE00048000801000
   VCID: 42DD4AD9E407AD479F3-8016
   Serial number: 00000000000009783321
   Coding: 090000
   Coding: 029A00000B000200
   VCID: 40D940D1EA0BBF57897-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 3Q0 035 877 A    HW: 3Q0 035 877 A
   Component: MU-S--ROA     H24 0245
   Serial number: VWZAZ2S0169485
   Coding: 02730000FF00000051110001001028001F0200D40120010001
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 33331F1DABBD14CF045-8066
   Subsystem 1 - Part No SW: 3G0 919 605     HW: 3G0 919 605
   Component: ABT_Std-2  H43 4064
   Serial number: VWZ6Z9S1131601
End----------(Elapsed Time: 01:45, VBatt start/end: 12.4V/12.4V)-----------
From a WD for Convenience system, left-hand drive , (L0L) From January 2014 - not sure that it will help. but note the asterix provisos at the bottom of the picture
PS: Ignore the "Heated steering wheel" reference - I haven't included the J519 connections in the pic
sosterman
Morocco
C?ID=380597
Thank you. Where can someone find this information?
