2013 Audi Q3, coding start/stop button
Ionutz
Luxembourg
C?ID=384700
I wish to code the start/stop button so the engine doesn't stop each time I need to stop the car. Like many others I think is not an useful function.
I've tried to apply the procedure:
Module 09 > Security Access > code 20113 > Adaptions > Read channel 34 then
You have these options:
- subtract 4 from the value = stop/start off by default
- add 32 to the value = enable stop/start memory
- add 64 to the value = invert the light in the stop/start switch (light
on when stop/start on rather than when off)
The problem is that my car doesn't accept the security code 20113. Would you please let me know if the procedure is different for this car. Below the scan:
Thank you
Friday,08,November,2019,06:04:56:10062
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUZZZ8UXDR1XXXXX   License Plate: XXXX
Mileage: 45690km-28390mi   Repair Order:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 03 08 09 10 15 16 17 19 25 3C 42 44 46 52 53 55 5F 62 72
VIN: WAUZZZ8UXDR1XXXXX   Mileage: 45690km-28390miles
   Part No SW: 03L 906 018 CN    HW: 03L 906 018 ES
   Component: R4 2.0l TDI   H28 9979
   Revision: 41H28---    Serial number:
   Coding: 00190012042401080000
   Shop #: WSC 40458 001 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018CN 003009
   ROD: EV_ECM20TDI01103L906018CN.rod
   VCID: 78BCF66AC3F4058F9F-802C
   Part No SW: 5N0 614 109 AF    HW: 5N0 614 109 AF
   Component: J104   C6 450M VD01 0120
   Revision: --H07---    Serial number: 00000006869641
   Coding: 0054660
   Shop #: WSC 00049 770 00241
   VCID: 6FAECD367EBA42374E-803A
02214 - Tire Pressure Warning
                    Reset counter: 37
                    Mileage: 45467 km
                    Date: 2019.11.04
                    Time: 06:57:10
                    Speed: 70.0 km/h
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 14.75 V
                    Bin. Bits: 00011111
                    Count: 185
                    Hex Value: 0x0000
   Part No SW: 8U0 820 043 C    HW: 8U0 820 043 C
   Component: E87  Klimavoll      0050
   Revision: 00H03000    Serial number: 8U0820043C
   VCID: 312A0B4EA80E14C718-8064
   Part No SW: 8X0 907 063 K    HW: 8X0 907 063 K
   Component: BCM PQ35  M   111 0715
   Revision: AH111715
   Coding: 06000A2CA8051AC0201840C02100094C53FF84AA216F912AE408878400C5
   Shop #: WSC 00049 770 00009
   VCID: 44C4529AC7BC916FC3-8010
   Subsystem 1 - Part No SW: 8U1 955 119     HW: 8U1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS316 130407  H36 0085
   Serial number:         130411000924
   Coding: 0047F7
   Serial number: 21213517
   Coding: 02006E
00332 - Control Circuit for Tank Flap
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 239
                    Mileage: 45095 km
                    Date: 2019.10.24
                    Time: 20:42:08
                        Term 15 Off
                    Voltage: 12.65 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
   Part No SW: 8X0 919 475 N    HW: 4H0 919 475 AG
   Component: PARKHILFE 8K  H01 0050
   Revision: 11001001    Serial number: 61031310800602
   Coding: 08C204
   ASAM Dataset: EV_EPHVA18AU21X0000 003006
   ROD: EV_EPHVA18AU21X0000_003.rod
   VCID: 51EA6BCE00CE74C778-8004
   Part No SW: 8U0 959 655 B    HW: 8U0 959 655 B
   Component: AirbagVW-AU10 H07 0520
   Serial number: 003LRR050T2S
   Coding: 30353132313030303030554A304C38553053
   Shop #: WSC 00049 770 00119
   ASAM Dataset: EV_AirbaAU10SMEAU316 001005
   ROD: EV_AirbaAU10SMEAU316_001.rod
   VCID: 46C04892F980A37FDD-8012
   Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3496KSME764A6224ZZZ.
   Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3506KSME054D5424ZZZP
   Serial number: 3516KSME0F686224ZZZW
   Serial number: 3526KSME0B755424ZZZS
   Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3555USME605E5223ZZZ$
   Part No SW: 8X0 953 501 D    HW: 5K0 953 569 H
   Revision: FF010017    Serial number: 20130427101630
   Coding: 1184204000
   VCID: 3B362966B242EE97B2-806E
   Subsystem 1 - Part No SW: 8U0 951 528 E    HW: 8U0 951 528 E
   Component: E221 - MFL  H09 0010
   Part No SW: 8U0 920 940 C    HW: 8U0 920 940 C
   Component: KOMBI_COLOUR  H03 0151
   Coding: 12CF01
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04396
   VCID: 383C366A8374C58F5F-806C
   Part No SW: 8U0 907 468 L    HW: 8U0 907 468 L
   Component: GAT 5CAN 2L M H13 0059
   Revision: 1U150034    Serial number: 3441U13308006C
   Coding: FBCF1A5A000100610253
   VCID: 4BD679A6EAE25E1702-801E
   Component: J367-BDM  H07 0180
   Serial number: 30120E50221491332449
   Serial number: 13109002110021200181
   Component: IMMO          H03 0151
   Coding: 000002
   ROD: EV_Immo_UDS_VDD_AU10.rod
   Part No SW: 8U0 907 566 B    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0010
   Revision: 00H02000    Serial number: 6PZ 010 316-05
   Coding: 0000101
   VCID: 40CC5E8A13A48D4FE7-8014
   Subsystem 1 - Part No: 8U0 907 568 B
   Component: J770  SWA Slave H02 0010
   Subsystem 2 - Serial number: 6PZ 010 316-25
   Subsystem 3 - Serial number: 5F16.05.1200H020003C130391ÿ
   Subsystem 4 - Serial number: 130391ÿ
   Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
   Component: TSG FA        H10 0415
   Coding: 011E06201C00000000
   VCID: 52E864C20DC80FDF41-8006
   Part No SW: 5N1 909 144 P    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.374 1202
   Revision: 1BH04839    Serial number: 00130870089201
   Coding: 0000258
   VCID: 3FCE5D766E5AF2B79E-806A
   Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
   Component: TSG BF        H10 0415
   Coding: 011E06201E00000000
   VCID: 51EA6BCE08CE74C778-8004
   Revision:   H19       Serial number: 00000000937875
   Coding: 0025167
   VCID: 36203852416033FF4D-8062
   Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
   Serial number: 130422-0002-027
   Coding: 1157941010022500
   Shop #: WSC 00049 770 00151
   ROD: EV_HeadlRegulBasic.rod
   VCID: 42C85482D5A89F5FF1-8016
   Part No SW: 8U0 035 193 C    HW: 8U0 035 193 A
   Component: RMC Cnct Nav  H54 0801
   Coding: 0100060002C153070A23020103010000000000
   VCID: 35223F5E9C6638E744-8060
   Subsystem 1 - Part No: 8X0 919 884 E
   Component: P18-50-12.06  0001
   Subsystem 2 - Part No SW: 8U0 919 603     HW: 8U0 919 603
   Component: DUBasic AU316  H41 0018
   Serial number: AUZ8ZDD0603KU2X
   Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
   Component: TSG HL        H07 0415
   Coding: 010E06200000000000
   VCID: 4FEE6DB61EFA62376E-801A
   Component: TSG HR        H07 0415
End----------(Elapsed Time: 01:15, VBatt start/end: 14.8V/14.7V)-----------
Address 03: DTCs clearedFriday,08,November,2019,06:10:24:10062
   Coding: 0054660
   Revision: AH111715
   Coding: 0047F7
   Coding: 02006E
                    Reset counter: 239
                    Mileage: 45095 km
                    Date: 2019.10.24
                    Time: 20:42:08
                        Term 15 Off
                    Voltage: 12.65 V
                        Term 50 Off
   Coding: 08C204
   Coding: 1184204000
   Coding: 12CF01
   Coding: 000002
   Coding: 0000101
   Coding: 0000258
   Coding: 0025167
End----------(Elapsed Time: 01:14, VBatt start/end: 14.8V/14.8V)-----------
Where did you find the above "procedure"? I do not think it is applicable to your BCM.
Ionutz
Luxembourg
C?ID=384700
I found it on some VW related forum, not here anyway. After seeing the security code 20113 isn't accepted by my car I believe you are right. Do you know the right procedure for this car? Thanks
AudiSportB5S4
CT, USA
C?ID=58275
FYI - If you go the security access spot and hover over the white space where you tried keying in 20113 with no success, it usually will tell you the appropriate code.
hadez16
C?ID=289891
Q3 8U is NOT a MLB car. Instructions mentioned is for MLB cars like A6 4G or A4 8K Facelift.
I say this for the quaddilliontrillion-billionth time: Not possible on Q3 8U.
Ionutz
Luxembourg
C?ID=384700
Hello! I would like to disable the speed limit beep. It makes this beep when it's getting to 120km/h.
Thank you
The following Adaptation channels in your 17-Instruments may be of interest:
IDE03348-MAS01456*],33.1,,Speed warning - Speed
IDE03348-MAS03206*],33.3,,Speed warning - Speed warning
Ionutz
Luxembourg
C?ID=384700
Thank you!
