- Sep 15, 2015
- 39
- 22
- Lidingö, Sweden
- C?ID=205446
Audi Q7 2010 TDI S-Line with an air suspension problem
Step 1 Tag of PR-Build data picture posted ( Last 6 of VIN can be omitted for privacy )
Step 2 Status of car stock or modified in any way? If so list!
Completely stock
Step 3 "VCDS" COMPLETE Auto-Scan in code tags!
Step 4 Describe recent repairs or services, problem at hand, & attempts at repair.
No recent repairs or services. No attempts at repair. Problem is a flashing yellow air suspension light, and the rear end of the vehicle is jacked up to maximum height. Any attempt to use the button in the trunk area to lower the rear has no effect other than causing the light on the button to flash.
Step 5 Are parts OEM or AFT? If so, "what", and what origin?
Original/OEM.
Step 6 Identify specific issues to be addressed/concerned about, or say ALL.
I'm only concerned with the Air suspension codes. Not concerned with anything else unless you think it's directly related. I have routinely seen all of the other codes. I haven't cleared it in a LONG time, but I have cleared them in the past and they come back (CAN, door central locking buttons, glo-plugs, distance sensor heater, etc - nothing that either really causes a problem or is worth the cost of fixing).
Step 7 Now that you jumped through the first few hoops of fire, did you check the FUSES/Battery connections?
No. I have not checked any fuses yet. There's no indication that the system is not getting power. It seems to be running for too long and getting cut off.
So, now that all of that is out of the way... It seems I have a LOT of information to point us to the problem, I just don't know how to interpret it all. We have four fault codes, the flashing yellow light (which indicates that the rear suspension is at maximum level), a visual check which confirms that the rear end of the vehicle is jacked up unusually high, and confirmation that I cannot lower the rear of the vehicle using the button in the rear cargo area. No unusual noises or behavior, though with the rear end up like that, it is noticeably impacting handling. This is my main day-to-day family vehicle so I need to get this fixed quickly! I have owned this vehicle for almost two years. It has had intermittent air suspension problems the entire time, but never anything like this. In the past, the problem always went like this: After a startup, the system would drop the suspension all the way down and the green air suspension light (pointing down) would stay on. All air suspension options in MMI would turn gray. I would stop the vehicle, turn it off, restart it, and the problem would go away and not return for weeks or months. The problem I have now is totally new, where the rear end goes all the way up and the yellow light flashes.
Is there any additional data I can collect? I read something about collecting some measuring blocks, but I didn't see any details on it.
Thanks in advance all! I will update this thread to its completion.
John
Completely stock
Monday,11,November,2019,21:12:20:49964
VCDS Version: 19.6.2.0 (x64)
VIN: WAUZZZ4L3AD0##### License Plate:
Chassis Type: 4L (4F0)
Scan: 01 02 03 05 08 09 13 15 16 17 18 19 20 28 34 36 3C 42 46 47
4F 52 55 56 5F 62 69 6C 6D 6F 72 76
VIN: WAUZZZ4L3AD0##### Mileage: 149500km-92894miles
Address 01: Engine (CAS) Labels:. 059-907-401-CAT1.clb
Part No SW: 4L1 910 401 D HW: 4L0 907 401 A
Component: 3.0TDI EDC17A104AG 0080
Revision: --H02--- Serial number:
Coding: 0121002C191F0A68
Shop #: WSC 40970 222 94360
VCID: 2447ED83E718D36FE3-8070
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 000 - Open Circuit
Mileage: 137842 km
Date: 2019.04.02
Time: 15:10:00
RPM: 882 /min
Voltage: 11.17 V
Temperature: 22.5°C
Lambda: 22.7 %
Temperature: 19.8°C
005663 - Glowplug for Cylinder 6 (Q15)
P161F - 000 - Open Circuit
Mileage: 137842 km
Date: 2019.04.02
Time: 15:10:00
RPM: 882 /min
Voltage: 11.17 V
Temperature: 22.5°C
Lambda: 22.7 %
Temperature: 19.8°C
005662 - Glowplug for Cylinder 5 (Q15)
P161E - 000 - Open Circuit
Mileage: 145129 km
Date: 2019.08.13
Time: 07:11:34
RPM: 882 /min
Speed: 2.2 km/h
Voltage: 11.40 V
Temperature: 22.5°C
Lambda: 21.9 %
Temperature: 18.9°C
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No SW: 09D 927 750 KC HW: 09D 927 750 KC
Component: AL 750 6A 1470
Revision: 00H78000 Serial number:
Coding: 0000504
Shop #: WSC 31414 790 00001
VCID: 79F9ECF7301A7E87E0-802C
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 K HW: 4L0 614 517 K
Component: ESP ALLRAD MK25E1 0020
Revision: 00H30001
Coding: 0627841
VCID: 326B1BDBADEC4DDF61-8066
Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602601405096
Coding: 0000135
VCID: 2541F087EC222A67F4-8070
Subsystem 1 - Part No: 4F0 910 132 G
Component: FBSAUDIC6 EZS H03 0020
Component: FBSAUDIC6 KSG H03 0020
00956 - Key 2
Fault Status: 00110010
Mileage: 146527 km
Date: 2019.09.11
Time: 19:42:48
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 C HW: 4L0 820 043 AB
Component: KLIMA 4 ZONEN H12 0030
Revision: 00---017 Serial number: 00000000212367
Coding: 040816
VCID: 2447ED832718D36FE3-8070
Part No SW: 4F0 910 279 R HW: 4F0 907 279
Component: ILM Fahrer H25 0330
Coding: 0033221
VCID: 387F29F34B90A78F5F-806C
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H17 0100
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4L0 910 561 A HW: 4L0 907 561
Component: ABSTANDSREGELUNGH06 0160
Revision: -------- Serial number: 00000000000000
Coding: 0031161
VCID: 275DFA8F962E3877C6-8072
02002 - Heater for Distance Regulation Sensor (Z47)
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 184
Reset counter: 151
Mileage: 133756 km
Date: 2019.02.02
Time: 17:33:04
Temperature: 10.0°C
Voltage: 12.93 V
Bin. Bits: 00100
Hex Value: 0x0931
Hex Value: 0x0002
Speed: 21.6 km/h
Lateral Accel.: 0.00 m/s^2
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
Component: 70 AIRBAG AUDI8RH43 0230
Revision: 04H43000 Serial number: 00399D065B3G
Coding: 0014128
VCID: 2E530FABB9D4693F05-807A
Subsystem 1 - Serial number: 6332QSME623A191AH
Subsystem 2 - Serial number: 6342QSME703A32067
Subsystem 3 - Serial number: 6352QSME4338322CE
Subsystem 4 - Serial number: 6362QSME623A143AH
Subsystem 5 - Serial number: 63734SME3136050EX
Subsystem 6 - Serial number: 63834SME2F364400-
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0530
Revision: 00H05000 Serial number: 90026092380094
Coding: 0002052
Component: E0221 H02 0030
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 931 J HW: 4L0 920 931 J
Component: KOMBIINSTR. H08 0144
Revision: 00000000 Serial number: CNN432799
Coding: 0F5E63040C010008000000
VCID: 326B1BDB6DEC4DDF61-8066
Address 18: Aux. Heat Labels: 4L0-910-105.lbl
Part No SW: 4L0 910 105 HW: 4L0 265 105 M
Component: Heizgeraet H08 0120
Revision: 0000000E Serial number: 00000009014264
Coding: 0000101
VCID: 60CFA193B3808F4FC7-8034
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 N HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0035
Revision: MB200030 Serial number: 3000M098308025
Coding: 000303
VCID: 3A7B33FBB59CB59FA9-806E
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0107
Serial number: 00000000004140159397
Reset counter: 25
Mileage: 137842 km
Date: 2019.04.02
Time: 13:35:01
Bin. Bits: 10111
Voltage: 11.50 V
Count: 7
Bin. Bits: 10011
Part No SW: 4F0 857 511 J HW: 4F0 857 511 G
Component: FLA H04 0004
Revision: AA001002
Coding: 02019064747464545425363E
VCID: 2F6D12AF7EDE60370E-807A
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AB
Revision: 00---010 Serial number: 00000000352325
Coding: 0000006
VCID: 68DFB9B35BB0F70F0F-803C
00003 - Control Module
Fault Status: 00100011
Fault Frequency: 8
Mileage: 138479 km
Date: 2019.04.10
Time: 21:17:21
Address 34: Level Control Labels: 4L0-910-553.lbl
Part No SW: 4L0 910 553 H HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7870
Revision: --H03001 Serial number: 15.1528-0123.2
Coding: 0015520
VCID: 2F6D12AFBEDE60370E-807A
01577 - Turn-Off due to Over-Temp
Fault Status: 00100001
Reset counter: 38
Mileage: 148993 km
Date: 2019.11.02
Time: 14:50:48
Error Code: 68
Reset counter: 43
Mileage: 148972 km
Date: 2019.11.02
Time: 12:24:56
Error Code: 13
01400 - Suspension Level Control
Reset counter: 65
Mileage: 149424 km
Date: 2019.11.11
Time: 08:40:42
Error Code: 66
02250 - Function Deactivation; Valve Duty Cycle
Reset counter: 63
Mileage: 149423 km
Date: 2019.11.11
Time: 08:38:09
Error Code: 46
Part No SW: 4F0 959 760 C HW: 4F0 959 760 C
Component: MEM-FS H08 0062
Revision: AA000000 Serial number: 00001001346979
Coding: 00581B00000011110000
VCID: 316914D768EA76C718-8064
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0040
Revision: 00H01000 Serial number: 6PZ 009 014-10
Coding: 0010101
Component: J0770_SWA_Slave_H01 0040
Subsystem 3 - Serial number: 5F21.07.0900H010003C910745ÿ
Subsystem 4 - Serial number: 910745ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000101820752
Coding: 011F52205E40440004
VCID: 4683570BF164C17FDD-8012
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 H HW: 4L0 907 289 H
Component: Komfortgeraet H09 0100
Revision: 0100 --- Serial number: 01219373360000
Coding: 3549361
VCID: 356120C75C825AE744-8060
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4L0 035 223 E HW: 4L0 035 223 E
Component: BOSE G3 AU716 H01 0100
Revision: AH001500 Serial number: 00000000008395
Coding: 0D000000
Part No SW: 4F0 910 280 HW: 4F0 907 280 E
Component: ILM Beifahrer H13 0100
Revision: Serial number: 00000000139275
Coding: 0011101
VCID: 5EB39F6B89F4B9BFF5-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000101847220
VCID: 45815007CC62CA67D4-8010
Fault Status: 01101000
Fault Frequency: 33
Reset counter: 254
Mileage: 137842 km
Date: 2019.04.02
Time: 13:35:43
Part No SW: 4L0 910 357 A HW: 4L0 907 357 A
Component: AFS 1 H01 0030
Coding: 0000032
VCID: 2A5B03BB853C051FD9-807E
Part No SW: 4F0 035 053 K HW: 4F0 035 053
Component: Radio U Basic H45 0074
Revision: AB001007 Serial number: 341IZ097634851
Coding: 010003010000000000
VCID: 2541F0872C222A67F4-8070
Part No SW: 4L0 035 670 H HW: 4L0 035 670
Component: H-BNT-EU H41 0187
Revision: -------- Serial number: 474I6097515869
Coding: 010100060004DBEF71000715EF6300030000
VCID: 2D5108A774D212273C-8078
Subsystem 1 - Part No: 8R0 060 884 ED
Component: EUR 2017 2402
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356IZ091064728
Subsystem 3 - Part No SW: 4L0 910 609 HW: 4L0 919 611 C
Component: E0380 Bedient H05 0060
Serial number: 00000001400099
Component: CD-Database 1293
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000101862201
Coding: 010E50204040230004
VCID: 43854E1FC256F457FA-8016
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00008200327685
Coding: 0100000000000000
Shop #: WSC 80093 222 69422
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H03--- Serial number: 525PA8-J9940CA
Coding: 1021001
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 D
Component: ValeoHeckdeckel H29 0410
Revision: --H29001 Serial number: 8K9827852 B
Shop #: WSC 98765 666 38354
VCID: 6CD7C5A34F48DB2F6B-8038
Subsystem 3 - Serial number: RD16.09.09--H29001001A0322ÿ
Subsystem 4 - Serial number: 1A0322ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 003881240-----
Coding: 0003587
VCID: 2643F78B9124217FFD-8072
Subsystem 1 - Part No: 4L0 910 591
Component: J_245_EE16_SKB09H10 0200
Subsystem 2 - Part No: 4L0 910 591
Component: J_394_EE16_SKB09H10 0200
Subsystem 3 - Part No: 4L0 910 591
Component: J_392_EE16_SKB09H10 0200
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000101862200
Fault Frequency: 22
Reset counter: 254
Mileage: 148816 km
Date: 2019.10.27
Time: 18:29:16
Part No SW: 4L0 910 283 E HW: 4L0 919 283 E
Component: Parkhilfe 8-Kan H02 0100
Revision: 00H02000 Serial number: 85130925303084
Coding: 0231166
VCID: 2C5705A38FC81B2F2B-8078
End-------------------------(Elapsed Time: 03:50)--------------------------
Original/OEM.
John
