Vw 2011 T5GP 7speed DSG Shuttle fitting MFSW
PATRICK6822
Liverpool, England
C?ID=295360
I have bought and fitted This: VW GOLF MK6 GTD 2009-2012 FLAT BOTTOM STEERING WHEEL with DSG Paddles to my: 2011 vw T5GP 7speed DSG shuttle.
Fitted the 2 wires from clock spring pins 9 and 10
Pin 9 on clock spring to an ignition live, To pin 15 on the light switch This works the illumination on the steering wheel with the lights switched On.
Pin 10 on clock spring to pin 17 of the white 73pin plug on the body control module ,
this already has a wire in that position as its the Lin bus, Lilac and white wire I have soldered this connection.
My problem: No buttons work left or right,
What does work: DSG paddles and horn work fine,
All the buttons illuminate,
Can anybody help solve my problem Please?
Regards
Patrick
Monday,11,November,2019,16:50:56:39175
VCDS Version: 19.6.2.0  HEX-V2 CB: 0.4508.4
VIN: WV2ZZZ7HZBH114478   License Plate:
Mileage: 245200km-152360mi   Repair Order: 11-11-19 faults
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 18 19 25 4B 56 0B
VIN: WV2ZZZ7HZBH114478   Mileage: 245200km-152360miles
4B-Multifunc. Module -- Status: Cannot be reached 1100
Address 01: Engine (J623-CCHA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 DH    HW: 03L 907 309 K
   Component: R4 2,0L EDC   X41 9133
   Revision: 26X41---    Serial number: 00000000000000
   Coding: 0125401A232400080000
   Shop #: WSC 26214 051 00000
   ASAM Dataset: EV_ECM20TDI01103L906019DH 002008
   ROD: EV_ECM20TDI01103L906019DG.rod
   VCID: 74B2D67CBE32BFD7DDF-8020
   Part No SW: 0BT 300 045 J    HW: 0BH 927 711 C
   Component: DSG DQ500-7F  H04 1407
   Revision: 00H04V01
   ROD: EV_TCMDQ500021_VW36.rod
   VCID: 3C223E5CD6E23797D5F-8068
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 G    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0105
   Revision: 00H43001
   Coding: 208724AD09A5049924A69078AA6616
   Shop #: WSC 02756 790 49152
   VCID: 36362C74E84EEDC723B-8062
   Part No SW: 7E5 907 047 AJ    HW: 7E5 907 047 AJ
   Component: Climatic-T5   H11 0203
   Revision: 00005001
   Coding: 0000000002
   Shop #: WSC 02757 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 77A8E170AF44D4CFF8D-8022
   Part No SW: 7H0 937 087 F    HW: 7H0 937 087
   Component: BCM T5GP H+4  H47 0230
   Revision: BO047001    Serial number: 0396 071110566
   Coding: B8B879B86E61261383284ED07EEA9EDCF08041FF60840000300000000000
   Shop #: WSC 02754 790 12345
   VCID: 37282170EF4414CF38D-8062
   Component: RLS 100311 05  54  0403
   Coding: 03302E
   Subsystem 2 - Part No SW: 7E0 959 801 C    HW: 7E0 959 801 C  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  003 3311
   Coding: 050000
   Subsystem 3 - Part No SW: 7E0 959 802 C    HW: 7E0 959 802 C  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  003 3311
   Coding: 050000
   Subsystem 4 - Part No: 7E1 951 171
   Subsystem 5 - Part No: 1K0 951 605 C
   Subsystem 6 - Part No: 7E1 951 171
   Subsystem 7 - Part No SW: 5K0 959 542     HW: 5K0 959 542
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0142037
   Coding: 830000
                    Mileage: 245097 km
                    Date: 2014.04.02
                    Time: 00:43:37
   Part No SW: 7E0 919 475 C    HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H11 0011
   Revision: --------    Serial number: 47401035600423
   Coding: 000102
   Shop #: WSC 02756 790 50316
   ASAM Dataset: EV_VW75XParkAssis8K A01004
   ROD: EV_VW75XParkAssis8K_A01.rod
   VCID: 323E106404A6F1E70F3-8066
   Component: VW10Airbag009 H06 0013
   Revision: --------    Serial number: 003HL004EFE2
   Shop #: WSC 02754 790 50316
   VCID: 35342B78F5C8E6DF2A1-8060
   Part No SW: 7E0 920 970 C    HW: 7E0 920 970 C
   Component: KOMBI         H20 0220
   Coding: 160E00
   VCID: 2A0E08042C76B927B73-807E
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 815 071 A
   Component: J737__Standheizung  0404
   Revision: 00085000    Serial number: 09019275D00000
   Coding: 0000031
   Shop #: WSC 13636 131 88224
   VCID: 2310E52047DC686FF45-8076
01444 - Under-Voltage Shut-Off (Automatic)
                    Mileage: 245097 km
                    Date: 2014.04.02
                    Time: 00:50:48
                    Temperature: 6.0°C
                    Voltage: 14.01 V
                    Temperature: 4.0°C
01414 - Combustion-Air Blower (V6)
            007 - Short to Ground
                    Fault Status: 01100111
                    Mileage: 245099 km
                    Date: 2014.04.02
                    Time: 00:54:48
                        Start
                    Temperature: 4.0°C
                    Voltage: 14.28 V
                    Temperature: 2.0°C
02251 - Heater Unit Locked
                    Mileage: 245123 km
                    Date: 2014.04.02
                    Time: 23:14:50
                        Malfunction
                    Temperature: 11.0°C
                    Voltage: 14.01 V
                    Temperature: 2.0°C
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 0230
   Coding: 040300
   VCID: 70BADA6CCAAA83F7397-8024
01304 - Radio
                    Reset counter: 102
                    Mileage: 245097 km
                    Date: 2014.04.02
                    Time: 00:43:41
03590 - Control Module for Multifunction Module
                    Reset counter: 102
                    Mileage: 245097 km
                    Date: 2014.04.02
                    Time: 00:43:42
   Component: IMMO          H20 0220
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8EC804ECF67927773-803E
Address 4B: Multifunc. Module
Address 56: Radio
End----(Elapsed Time: 02:28, VBatt start/end: 11.9V/11.6V. VIgn 11.6V)-----
