Enable TPMS on A3 2018 MMI menu
macapple
Verified VCDS-User
malaysia
C?ID=363509
hi
i am trying to open some setting in ABS for TPMS option but somehow i gotten this error stated
just wish to tick some bytes to enable TPMS
Error stated as below
Only limited Coding information is available for this control module
if you happen to need additional details please email support
do i need to key in some security code to access before i can code ?
thanks
South Molton, UK
Have you already posted an Auto-Scan of this A3? If you have please post a link to it, if not please post a full unedited VCDS Auto-Scan.
macapple
Verified VCDS-User
malaysia
C?ID=363509
Tuesday,12,November,2019,18:05:04:63906
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
Mileage: 32174km-19991mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F 65 6C BB BC
 Mileage: 32174km-19991miles
Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HB    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H25 4418
   Revision: R7H25---
   Coding: 02250032232401082000
   Shop #: WSC 29277 002 1048576
   ASAM Dataset: EV_ECM14TFS01104E906027HB 001006
   ROD: EV_ECM14TFS01104E906027HB.rod
   VCID: 6B96CFE6827C52175C-803E
   CAN Converter 01:
Readiness: 1110 0001
   Part No SW: 0CW 300 049 J    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0905
   Revision: 00005006    Serial number: CU501605137744
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 44C4445ACF627D6FFD-8010
   Part No SW: 5Q0 614 517 BJ    HW: 5Q0 614 517 AG
   Component: ESC           H62 0636
   Revision: 00000000    Serial number: 61466000003170
   Coding: 13F18AA22421126F897F0E0441CC29C8512448917082947302210004020802
   Shop #: WSC 00046 000 00000
   VCID: 7AB8FAA2FD26FB9FD7-802E
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Component: AC Automat    H14 0060
   Revision: 20028000    Serial number: 00000000942368
   Coding: 03100004110000001000000000001400
   VCID: 3228128265D6C3DF5F-8066
   Component: AQ_Hum_Sensor  H03 0005
   Serial number: A8584C2800PAG0MUFU01
   Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
   Serial number: 01061614400337
   Coding: 07041A42C24122F543804004001807A80000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 0444845A8FE2BD6FBD-8050
   Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS371 160503  043 0585
   Serial number:         160517071625
   Coding: 0A47F7
   Serial number: 61860977
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
   Serial number: 04 03 2016  00001534
   Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0054
   Revision: --------    Serial number: 39231614000859
   Coding: 0000140011
   VCID: 3C343CBAB79205AF85-8068
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Component: AirbagVW20    015 0388
   Serial number: 003MMR1T9NJQ
   Coding: 98CCC000000000005C54000000C800000065
   Shop #: WSC 06385 790 00016
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 004C884A9BFAA14F99-8054
   Subsystem 1 - Part No SW: -----------    HW: 480 002 105 16
   Serial number: 35767000000E3430BB1W
   Subsystem 2 - Part No SW: -----------    HW: 480 002 105 16
   Serial number: 3586700000082430BB1Q
   Subsystem 3 - Part No SW: -----------    HW: 480 401 805 16
   Serial number: 3516502BB2076342425-
   Subsystem 4 - Part No SW: -----------    HW: 480 401 805 16
   Serial number: 3526502AF20763449052
   Subsystem 5 - Part No SW: -----------    HW: 480 401 105 16
   Serial number: 3556502992057291C365
   Part No SW: 5Q0 953 549 E    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 11061804680124
   Coding: A018
   Shop #: WSC 27213 003 1048576
   VCID: 3E3036B2A18E17BFAB-806A
   Part No SW: 8V0 920 871 R    HW: 8V0 920 871 R
   Component: KOMBI         H03 6423
   Coding: 27AD19882A800B080100EE001000000000000000
   VCID: 4BD66F66E23CB2173C-801E
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 25051610800074
   Coding: 030100043F0857005B000248180B00000001010000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 79BAE5AEF820F087DE-802C
   Subsystem 2 - Part No SW: 8S0 951 523 C    HW: 8S0 951 523 C
   Component: J453 MFL  H07 0002
   Serial number: 20170719083548 00758
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185704001605211169
   Serial number: 110516EE90176A
   Coding: 001C0B205C01040000001002
   VCID: 43C64746CA6C7A57C4-8016
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1082
   Coding: 810F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74A4D49ADF428DEF8D-8020
   Serial number: 080516EE406587
   Coding: 001C03205E01040000001002
   VCID: 42C84242D576735FCF-8016
   Coding: 019E000001000000
   VCID: 75A2E99ED43894E7BA-8020
   Part No SW: 8V1 035 035 C    HW: 8V1 035 035 C
   Component: MU-P-LND-EU   055 1326
   Serial number: A698K0JS029728
   Coding: 01730107FF0A000011110001000A00106F0028C601700100DE
   Shop #: WSC 00046 123 12345
   ROD: EV_MUHig4CGen2HBAS_AU37.rod
   Subsystem 1 - Part No SW: V03 959 802 DH    HW: -----------
   Component: ROW 2019  --- 0076
   Component: DU High  H49 0014
   Serial number: AUZ8Z9H1Y07S81
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BL    HW: 8V0 919 614 BL
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL129061600010793
   Compact Disc Database:
   Component: Gracenote2  --- 1017
3073 - Cellular Antenna
          B1053 13 [009] - Open Circuit
          [GSM/UMTS aerial - open circuit]
                    Reset counter: 12
                    Mileage: 32174 km
                    Date: 2019.11.12
                    Time: 18:00:49
                    Voltage terminal 30: 12.4 V
3084 - GSM antenna 2
          B1533 13 [009] - Open Circuit
                    Reset counter: 12
                    Mileage: 32174 km
                    Date: 2019.11.12
                    Time: 18:00:49
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 4M0 907 273 B    HW: 4M0 907 273 B
   Component: RDKHUFAU736   H04 0010
   Serial number: 40000000005092
   ROD: EV_RDKHUFAU736_AU37.rod
   VCID: 2F2E1BF676E4EE3730-807A
12652553 - Internal Control Module Memory Check Sum Error
          B2000 96 [137] - Component internal failure
          [ECU_defect_receiver_demodulation-Pin]
                    Mileage: 14336 km
                    Date: 2019.11.02
                    Time: 18:19:29
                    Voltage terminal 30: 11.50 V
8390147 - Tire Pressure Monitoring
          C10DC 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 12
                    Mileage: 32174 km
                    Date: 2019.11.12
                    Time: 18:00:46
                    Expanded ambient data 1-Left front tire pressure sensor: identification: 570429242
                    Expanded ambient data 1-Right front tire pressure sensor: identification: 563497415
                    Expanded ambient data 1-Left rear tire pressure sensor: identification: 560520054
                    Expanded ambient data 1-Right rear tire pressure sensor: identification: 570164147
   Coding: 0273010100002003400040
   VCID: 393A25AEB8A030879E-806C
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 300416EDT03117
   Coding: 000C03204001040000001002
   Serial number: 300416EDT03114
End----------(Elapsed Time: 01:30, VBatt start/end: 12.3V/12.3V)-----------
macapple
Verified VCDS-User
malaysia
C?ID=363509
https://ibb.co/kM9LzC6
Error as per image , i tested another 2 more cars , same issue , running same cable and computer
macapple
Verified VCDS-User
malaysia
C?ID=363509
Thanks Uwe , i will need some time to digest , do you mean in short that my ABS controller is coded wrongly in the first place that the reason i cant code now ?
No, that is not at all what I mean.
There is no documentation built into VCDS for this ABS module. The best documentation I have seen is the spreadsheet created by Somnus, linked above.
Just because there is no documentation in VCDS itself does not mean you can't change the coding; you can, you just have to do it somewhat more manually, "by hand".
TBAx
C?ID=287144
Uwe: Out of pure interest will there be a label file for the MK100 ABS in a future release of VCDS. I don't mean a "hell of complete" label, but something that includes the often used and safe modification like ESP switch configuration, Hill Hold enabling etc.
hadez16
C?ID=289891
This could fail due to slight but ongoing coding changes even for different indices. Could be hard to find a stable set of bits that do not move......
But I am no ABS guru.
TBAx
C?ID=287144
Redirect labels to the rescue. :)
However most "function xy installed" bits don't move, see ESP switch coding, that is still the same even with ESPs with coding of >40 Bytes.
I'm not sure, specifically whether it's a good idea to encourage peoplke to mess with their ABS coding.
hadez16
C?ID=289891
Sometimes I see the pipe symbol for MQB ABS Coding Labels which indicates ASAM label coding, but there is none when you click on coding.
Does something like this exist (experimental labels from ODX data) for these ABS units?
I would need a specific example to look at in order to make an informed comment.
hadez16
C?ID=289891
No problem, I'll gather some on the weekend :thumbs:
hadez16
C?ID=289891
Adresse 03: Bremsenelektronik (J104) Labeldatei:| 5Q0-907-379-ESP-V1.clb
Teilenummer SW: 5Q0 614 517 AF HW: 5Q0 614 517 AF
Bauteil: ESC H62 0398
Revision: 00000000 Seriennummer: 51656000001624
Codierung: 19EE62922429096F4079060841CA2498462490026082247200610070C00202
Betriebsnr.: WSC 00049 770 00101
ASAM Datensatz: EV_Brake1UDSContiMK100ESP 035019
ROD: EV_Brake1UDSContiMK100ESP_035_SE37.rod
VCID: 75B610A98544B58F797-8020
Kein(e) Fehlercode(s) gefunden.
German vcds excerpt, Seat Leon 5F MY2016
So the label file has "Only limited coding [blah blah blah]", but VCDS sees this as something. And the ASAM data has something similarly unhelpful, a single line indicating "Param to DOP, HEXBYTES", but again, VCDS sees this as something. Thus the '|' indicating that there's information in both the label and the ASAM data. Unfortunately, neither source is actually of much use.
