Audi 4.2L v8 (BVJ) wacky idle
Chachboi
Cleveland, OH
C?ID=385042
Hey guys, this is my first post to the forum and I'm looking to get some help. A little back story on the car: It is a 2007 A6 4.2 V8 that I bought a while ago for $2k because the guy thought it needed a headgasket, but I figured it was just intermediate cooling pipe o-rings (which it was). So I do know how to work on these cars, but this new problem has me stumped. It has 128k miles and runs perfectly aside from the idle.
The Problem:
I have a random code for the HP fuel sensor and one for the O2 sensor. They only pop up once a day on the first cold start when it gets to about 640rpm (see AutoScan)
And this thing idles like a cammed out 70's muscle car when warm at about 640rpm. when cold started it has misfires but the computer does not recognize any (checked adv. blocks in vcds and 0's across the board)
Things I have done:
Oil Flush and change 1k miles ago
Run injector cleaner
Performed the CRC Intake valve cleaning with the car running (not manual clean) Valves looked fine when I had the intake off but was planning to do a cleaning when it warms up again in the spring.
New PCV valve
New Coils
New Valvecover gaskets
Fixed all oil leaks
Things I question:
Intake runners are operated by two motors, but bank 2 is higher than bank 1 (misaligned?) ..Throttle body adjustment performed, didn't change anything.. There is a high pitched whining sound
from the actuator motor when the car is turned off. (almost like its stuck, but moves freely when revved)
Had an intermittent "Bank 1 catalyst Below efficiency" That went away about 6 months ago and hasn't come back (I've heard these cats go bad)
Runs up the RPM range perfectly with no misfires
Block 93 has all adjustments between -/+2 except for Bank 2 intake phase position that has no reading (Blank box).
I removed and regapped all of the spark plugs to 0.028 and it seems to have liked it just slightly more, but the spark plugs are AutoLite Platinum (from what I understand a sub-par spark plug)
So Just looking to see what would be next recommended as far as what to do, my thoughts were swapping the camshaft sensors to try and get a reading on bank 2 Intake position Phase and then probably inspect the catalytic converter.
AutoScan:
Ignore the electrical faults, that was due to a bad Sirius module That was draining the battery. ( battery was and is fully charged now)
Friday,08,November,2019,09:29:57:10008
VIN: WAUDV74FX7N053017   License Plate: JJ
Mileage: 207010km-128630mi   Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
          53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUDV74FX7N053017   Mileage: 207010km-128630miles
0F-Digital Radio -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
Address 01: Engine        Labels:. 079-907-560-BVJ.clb
   Part No SW: 4F1 910 560 A    HW: 4F1 907 560
   Component: 4.2l V8/4V          0030
   Revision: 74H03---    Serial number:
   Coding: 01050009190F0120
   Shop #: WSC 06117 444 52446
   VCID: 211FE2C4DDCB9B8FE69-8074
004506 - Fuel Pressure Sensor (G247)
               P119A - 001 - Malfunction - Intermittent - MIL ON
                    Fault Status: 10100001
                    Mileage: 206846 km
                    Date: 2019.11.05
                    Time: 09:52:12
                    RPM: 671 /min
                    Load: 20.4 %
                    Temperature: 87.0°C
                    Temperature: 6.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.224 V
004369 - Oxygen (Lambda) Sensor Regulation: Bank 1
               P1111 - 001 - System too Lean
                    Fault Status: 01100001
                    Mileage: 206905 km
                    Date: 2019.11.06
                    Time: 10:19:43
                    RPM: 650 /min
                    Load: 18.0 %
                    Temperature: 84.0°C
                    Temperature: 41.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.605 V
   Part No SW: 4F2 910 156 H    HW: 09L 927 156 C
   Component: AG6 09L 4,2lFSI USA 0010
   Revision: --H01---    Serial number:        4229218
   Coding: 0000002
   Shop #: WSC 02325 785 00200
   VCID: 2A0D05E8A0FD58D7B73-807E
006231 - Load Signal
               P1857 - 001 - Error Message from ECU - Intermittent
                    Fault Status: 00100001
                    Mileage: 206702 km
                    Date: 2019.10.30
                    Time: 10:36:39
                    RPM: 672 /min
                    RPM: 672 /min
                    (no units): 30.0
                    (no units): 24.0
                    Temperature: 89.0°C
                    T.B. Angle: 0.0°
Address 03: ABS Brakes        Labels:
   VCID: 55F78614DC03272FCA1-FFFE
   Part No SW: 4F0 910 852 A    HW: 4F0 905 852 C
   Component: FBSAUDIC6 ELVSG H01 0030
   Revision: 31050601    Serial number: 10601200532485
   Coding: 0000007
   Shop #: WSC 02323 785 00200
   VCID: 2411EBD0C2D98EA78DF-8070
   Subsystem 1 - Part No: 4F0 910 131 L
   Component: FBSAUDIC6 EZS   H45 0080
   Component: FBSAUDIC6 KSG   H27 0080
00190 - Driver's Door Handle Touch Sensor (G415)
                    Fault Status: 00111011
                    Reset counter: 172
                    Mileage: 206564 km
                    Date: 2019.10.28
                    Time: 10:54:25
00192 - Rear Left Door Handle Touch Sensor (G417)
                    Reset counter: 166
                    Mileage: 206842 km
                    Date: 2019.11.04
                    Time: 18:33:14
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
   Part No SW: 4F0 910 732 R    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 361HO067505326
   Coding: 0000003
   Shop #: WSC 02335 785 00200
   VCID: 323D1D88882D10170F3-8066
   Component: Bedienteil MMIC6H02 0060
   Subsystem 2 - Serial number: 00000000520262
   Subsystem 3 - Serial number: 0108.09.060000000100010997ÿ
   Subsystem 4 - Serial number: 010997ÿ
00384 - Optical Databus
                    Fault Status: 00101011
                    Fault Frequency: 70
                    Reset counter: 164
                    Mileage: 206711 km
                    Date: 2019.10.31
                    Time: 06:31:13
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043     HW: 4F1 820 043 AC
   Component: KLIMABETAETIGUNGH20 0170
   Revision: 00000031    Serial number: 00000000309961
   Coding: 0532520
   VCID: 5BE3902CBF27F15FFC5-800E
                    Fault Status: 00101010
                    Reset counter: 173
                    Mileage: 206563 km
                    Date: 2019.10.28
                    Time: 10:42:09
                    Temperature: 24.0°C
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
                    Reset counter: 167
                    Mileage: 206585 km
                    Date: 2019.10.28
                    Time: 13:39:49
                    Voltage: 14.40 V
                    (no units): 221.0
                    (no units): 255.0
   Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
   Component: ILM Fahrer      H17 0240
   Coding: 0113123
   VCID: 3039178086212207797-8064
   Subsystem 1 - Part No: 4F1 910 113 B  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0210
   Coding: 00064784
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH12 0090
   Coding: 00146221
   Shop #: WSC 02335
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBF8189177
   VCID: 1C61D330FAA9B66735F-8048
Address 0F: Digital Radio
Address 15: Airbags        Labels: 4F0-910-655-8R.clb
   Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
   Component: 66 AIRBAG AUDI8RH29 0300
   Revision: 14H29000    Serial number: 00359D0BBX87
   Coding: 0013878
   Subsystem 1 - Part No: 4F0 910 339 A
   Component: BF-Gewichtsens. H02 0050
   Subsystem 2 - Serial number: 6332CSME123F0D22%
   Subsystem 3 - Serial number: 6342CSME131C682E9
   Subsystem 4 - Serial number: 6352QSME110C7A73I
   Subsystem 5 - Serial number: 6362QSME12684D6DV
   Subsystem 6 - Serial number: 63734SME14232D1B
   Subsystem 7 - Serial number: 63834SME45733B0F7
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
   Component: J0527               0410
   Revision: 00H03000    Serial number: 90025062230448
   Coding: 0012241
   VCID: 270BFCDCB3EF65BFA8D-8072
   Component: E0221           H07 0090
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4F0 920 981 G
   Component: KOMBIINSTR. M73 H18 0110
   Revision: 00400000    Serial number: 5FG78A696
   Coding: 2129263
   Shop #: WSC 41251 067 57207
   VCID: 2313E8CCC7D7899FF45-8076
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468     HW: 4L0 907 468
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0900B06901800B
   Coding: F5D5DE77307A06
   Shop #: WSC 02334 785 00200
   VCID: 6C81C3F06A8986E705F-8038
                    Reset counter: 113
                    Mileage: 206563 km
                    Date: 2019.10.28
                    Time: 10:42:06
                    Reset counter: 162
                    Mileage: 206721 km
                    Date: 2019.10.31
                    Time: 07:45:35
02230 - Digital Radio (DAB) (R147)
                    Reset counter: 124
                    Mileage: 206802 km
                    Date: 2019.11.04
                    Time: 09:42:28
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0082954
   VCID: 619FA2C49D4BDB8FA69-8034
   Part No SW: 4E0 910 888 C    HW: 4E0 919 887 D
   Component: MNS US          H48 0960
   Revision: 00000000    Serial number: 381HW067504828
   VCID: 2E0509F89C1534F76BB-807A
02444 - Disk Drive Load / Eject Malfunction
                    Fault Frequency: 130
                    Reset counter: 133
                    Time Indication: 15
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 793 E
   Component: TSG FA          H12 0120
   Revision: 00-00000
   Coding: 0051947
   Shop #: WSC 02327 785 00200
   VCID: 2C0103F0AA0946E745F-8078
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 G    HW: 4F0 907 289 G
   Component: Komfortgeraet   H22 0170
   Revision: 01700022    Serial number: 01019348630000
   Coding: 4619421
                    Fault Status: 01101100
                    Reset counter: 133
                    Mileage: 195260 km
                    Date: 2019.02.14
                    Time: 16:00:28
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
   Component: DSP-High C6     H09 0240
   Revision: PROD_01     Serial number: 00000000013231
   Coding: 0000026
   Shop #: WSC 37605 000 1048576
   VCID: 2517F6D4C9E377AF9A1-8070
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000038578
   Coding: 0012014
   VCID: 5EE59938AC35E4779BB-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 792 E
   Component: TSG BF          H12 0120
   Revision: 00-00000
   Coding: 0051947
Address 53: Parking Brake
Address 55: Headlight Range
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 H
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 394IX067680180
   Coding: 0000002
   VCID: 313F12848D2B2B0F769-8064
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: J0644 BEM       H12 0590
   Revision: 00000000    Serial number: 00000000101014
   Shop #: WSC 06117 444 64721
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  2609070297
   Coding: 344630393135313035442056413032363039303730323937
   Shop #: WSC 00000 384 00290
02256 - Quiescent Current
                    Reset counter: 162
                    Mileage: 206741 km
                    Date: 2019.10.31
                    Time: 21:31:18
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
   Component: TSG HL          H21 0050
   Coding: 0051754
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.lbl
   Part No SW: 4F0 910 273 B    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0100
   Revision: 00050100    Serial number: 00000700029445
   Coding: 0062422
   VCID: 221DEDC8D8CD8097FF3-8076
            002 - Lower Limit Exceeded - MIL ON
                    Fault Status: 11100010
                    Reset counter: 25
                    Mileage: 203646 km
                    Date: 2019.08.15
                    Time: 08:48:48
                    (no units): 0.0
                    Voltage: 14.30 V
                    (no units): 19.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H45 0630
   Revision: 00000000    Serial number: 00000609010244
   Shop #: WSC 12336 024 394758
   VCID: 34311B9072391E271DF-8060
   Part No SW: 4F0 910 441     HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J6820IV
   Coding: 1000304
   VCID: 5DE79E34A133FF6F821-8008
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Component: TSG HR          H21 0050
   Coding: 0051754
   Part No SW: 4F0 910 283 F    HW: 4F0 919 283 F
   Component: Parkhilfe 4-Kan H09 0060
   Revision: 00H09000    Serial number: 06220624703372
   Coding: 0021206
   Part No SW: 4F0 910 336 H    HW: 4E0 862 335
   Component: Handyvorb2      H13 1130
   Revision: 00000000    Serial number: 00000007541741
   Coding: 0010900
   VCID: 2809FFE0BEF16AC7A17-807C
End----------(Elapsed Time: 02:04, VBatt start/end: 14.2V/14.6V)-----------
NostraJackAss
Welcome to the VCDS forum OP and did you JPPSG yet?
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
Maybe induced issue during repairs conducted?
VVVVVAT Time is it & for air leak repair/trace/HPP mechanical's for inadequate stroke/leak down, injectors being plugged/incorrect atom pattern or HPP or lift FP and to be un pimped to remove the FOD + enhance grounds?
You mean change parts on these cars right and to your knowledge correctly, maybe recheck work?
Chachboi
Cleveland, OH
C?ID=385042
I live in the Northeast so my working has slowed a bit. Yes I understand what VCDS measurements and blocks mean and am pretty handy with Google. I've done a tear down to the block and rebuild of a 2.0T FSI and the car is 8k miles since with not a thing wrong with it, so yeah pretty embarrassed that this car is kicking my brain here. Since posting I have gone over all vacuum lines around the engine and smoke tested. On the coldest day so far at about 16 deg. F it had acted very funny with the throttle body but after doing a TB alignment it has gone and not returned. When doing output testing everything actuates. I have since messed with it more and reset trims and now my idle values are pretty even yet my partials are almost fixed opposite of each other. I have even exhaust pressure from each exhaust pipe so my next check will be blockage but don't think it will be that. Still rough idle. Funny thing is it is worst cold and hot but when it gets halfway warmed up it idles very smooth aside from a miss here and there that won't show on the misfire counter in VCDS. Then once warm it shakes at idle again. And I have swapped and cleaned all cam sensors and still have a blank value for bank 2 cam phase timing yet don't have chain slap and only have an intermittent miss on 5 when 4 acts up.
Could a weak HPFP on one bank only cause this? Or no because they connect? No codes still :(
NostraJackAss
Maybe it has something to do with the fuel PSI sensor & the OBD2 data should be considered to fix the fuel system by isolated mechanical testing to identify the failure?
