2011 A6 C7 with issues
coconutaudi
Kuala Lumpur, Malaysia
C?ID=345326
Hello there,
ran my just acquired vcds on my A6 C7 a few times and on the last scan after clearing the faults code a few times I've got the following remaining faults codes:
Address 01: Engine (J623-CGWB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 907 551     HW: 4H0 907 551
   Component: 3.0l V6 TFSI  H05 0007
   Revision: --H05---
   Coding: 0A250034052701020000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TFS0214G0907551 002010
   ROD: EV_ECM30TFS0214G0907551_002.rod
   VCID: 6695B5FFE8EFBBD753B-8032
6368 - Bank 2: CMP Sens 2 (G163) / Engine Speed Sensor (G28)
          P0018 00 [039] - Incorrect Correlation
                    Mileage: 165872 km
                    Date: 2019.11.07
                    Time: 11:00:33
                    Engine speed: 690.00 /min
                    Normed load value: 22.0 %
                    Coolant temperature: 93 °C
                    Intake air temperature: 76 °C
                    Voltage terminal 30: 13.304 V
                    Engine speed: actual: 672 /min
                    MAF_ENVD: 136.17647 mg/stroke
                    Calculated oil temperature: 85
                    Engine: operating status: IS
                    ENVD_CAM_IN_2: 0
                    Battery voltage: 13.507813 V
Readiness: 0110 0001
   Part No SW: 4H0 907 063 N    HW: 4H0 907 063 F
   Component: BCM1 2.0      H12 0092
   Revision: 20012002    Serial number: 00000001044197
   Coding: 0200201050B49FE0C181008380001908CF9DC3082F080101000008402100
   Shop #: WSC 02391 785 00200
   VCID: 33331CABEB3D1E7F045-8066
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 110404  H35 0051
   Serial number:         110407090850
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11418017
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 22 04 2011  00000235
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 5228C6A5000000000001
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 243
                    Mileage: 165872 km
                    Date: 2019.11.07
                    Time: 11:00:00
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0056
   Serial number: 06051100040012
   Coding: 02
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
   VCID: 2F3B10DB07953A9F60D-807A
0026 - Motor for Rear Left Upper Body Vent
          B10D3 21 [009] - Signal Amplitude Too Low
                    Reset counter: 243
                    Mileage: 165872 km
                    Date: 2019.11.07
                    Time: 11:00:26
                    Voltage terminal 30: 14.04 V
                    Outside air temperature: 38.5 °C
                    Left Rear Upper Body Vent Motor-Act.val.: 10812
                    Left Rear Upper Body Vent Motor-Specified value: 10812
                    Left Rear Upper Body Vent Motor-Stop open: 11400
                    Left Rear Upper Body Vent Motor-Stop closed: 10000
   Part No SW: 4H0 907 064 AP    HW: 4H0 907 064 AP
   Component: BCM2 2.0      H24 0217
   Revision: 00002001    Serial number: 0149428872
   Coding: 011B0E2200B9048183300804080100000000000000000000000000000000
   VCID: 77ABE8BBBFC5325FF8D-8022
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 243
                    Mileage: 165872 km
                    Date: 2019.11.07
                    Time: 11:00:28
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 A    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0012
   Serial number: 110502-0004-033
   Coding: 1121A633F918EB00
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
   VCID: 303913A71AAB2567797-8064
H02 0008
   Coding: 1D0000
H02 0008
   Coding: 1D0000
0061 - Function Restriction due to Implausible Message(s)
          U1112 00 [137] - -
          [Fehlerhafter DLC der CAN-Messages Kamera_Status  (0x318)]
                    Reset counter: 243
                    Mileage: 165872 km
                    Date: 2019.11.07
                    Time: 11:00:30
My questions are:
1. for address 01, whether I need to replace the Bank 2 camshaft position sensor to clear the fault codes?
2. fault codes for address 09 and address 55 are about headlight range and seem related, what should I do? As for this issue the yellow adaptive light indicator on the instrument cluster is lit.
3. for address 28 and 46?
Appreciate you suggestion and help. Thank you all in advance.
Regards
siLc
Tallinn, Estonia
C?ID=330192
1. Does the engine timing chain rattle on cold startup?
Please post a full unedited autoscan.
coconutaudi
C?ID=345326
I don’t think there is any rattling but I noticed subtle vibration now and then when idling. Once a while I have problem starting. I’ll put up the full scan once Im home. Thank you.
coconutaudi
C?ID=345326
Here is the full scan:
Thursday,07,November,2019,11:05:28:34670
VIN:    License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 42 44 46 52 53 55
          56 5F 62 6C 72 85 8F 90
VIN: WAUZZZ4G9BN031310   Mileage: 165872km-103068miles
   Revision: --H05---
                    Mileage: 165872 km
                    Date: 2019.11.07
                    Time: 11:00:33
                    ENVD_CAM_IN_2: 0
   Part No SW: 4G0 927 156 M    HW: 0B5 927 156 F
   Component: 0B5 30TFSIRdW H10 0024
   Revision: --H10---    Serial number: 0000000785
   Shop #: WSC 04940 001 00001
   ASAM Dataset: EV_TCMDL501 A02196
   ROD: EV_TCMDL501.rod
   VCID: 363525BFF8CF0B5723B-8062
   Part No SW: 4G0 907 379     HW: 4G0 907 379
   Component: ESP PREMIUM   H08 0190
   Coding: 44A687002265E100DB00
   ASAM Dataset: EV_ESPPremiAU57X 003013
   ROD: EV_ESPPremiAU57X_003.rod
   VCID: 6E85CDDFC01F73972BB-803A
   Coding: 05B82F00000000000000
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000097450009
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H11 0056
   Serial number: 06051100040574
   Coding: 6621007824
   ASAM Dataset: EV_AirCondiComfoUDS 002029
   VCID: 270BF8FB2F6562DFA8D-8072
   Coding: 0045F7
   Coding: 02512B
                    Reset counter: 243
                    Mileage: 165872 km
                    Date: 2019.11.07
                    Time: 11:00:00
   Part No SW: 4H0 919 475 J    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0032
   Revision: 11001001    Serial number: 55901107004778
   Coding: 300306
   Shop #: WSC 00097 210 98728
   ASAM Dataset: EV_EPHVA18AU57X0000 001002
   ROD: EV_EPHVA18AU57X0000_001.rod
   VCID: 392F2E83C9D1E42FCE9-806C
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG002BRPH
   Coding: 30323436313330303631554A305234473053
   Serial number: 3575HRB404T0HM766GDR
   Serial number: 3585HRB405H0H0LUC8R2
   Serial number: 3515JRB405D0H4DU9P4N
   Serial number: 3525JRB405F0G944N0G$
   Serial number: 3554VRB40630GR36HOS5
   Serial number: 3564VRB405D0GR36IHD.
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20110505000939
   Coding: 000034
   VCID: 303913A71A2B2567797-8064
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Component: E221 - MFL  H07 0009
   Part No SW: 4G8 920 981 A    HW: 4G8 920 981 A
   Component: TBenGb        H34 0312
   Revision: 19100074    Serial number: 658020411593026
   Coding: 33A709000B012600010000
   ASAM Dataset: EV_RBD4K 004033
   ROD: EV_RBD4K_AU57.rod
   VCID: 313F16A311A12C6F769-8064
   Part No SW: 4G0 907 468 C    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0204
   Revision: --------    Serial number: 00000000141378
   Coding: 00CD073000
   ROD: EV_GatewUDS_AU57.rod
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650387009
   Voltage stabilizer:
   Serial number: 11130001538021200181
   Coding: 02
                    Reset counter: 243
                    Mileage: 165872 km
                    Date: 2019.11.07
                    Time: 11:00:26
   Component: MEM-FS        H03 0153
   Revision: AA000000    Serial number: 00000006129999
   Coding: 00781B0000006001000001010101102030303232203232
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0004
   Revision: --------    Serial number: EJ1BPA4200UA850
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 2D070AD30D99488F521-8078
   Part No SW: 4G8 959 793 C    HW: 4G8 959 793 A
   Component: TSG FA        H04 0210
   Coding: 011F16205E01628002080002
   Shop #: WSC 02312 785 00200
   VCID: 40D94367AA8BB5E7897-8014
   Component: RCEPS         H33 0010
   Revision: 00001000    Serial number: 0010073316
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D19AF14A717770F3-8066
            014 - Defective
                    Reset counter: 243
                    Mileage: 165872 km
                    Date: 2019.11.07
                    Time: 11:00:28
   Part No SW: 4G8 959 792 C    HW: 4G8 959 792 A
   Component: TSG BF        H04 0210
   VCID: 3FDB409BD775CA1FF0D-806A
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000070722
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A0D01CF3C775FB7B73-807E
H02 0008
   Coding: 1D0000
H02 0008
   Coding: 1D0000
          U1112 00 [137] - -
                    Reset counter: 243
                    Mileage: 165872 km
                    Date: 2019.11.07
                    Time: 11:00:30
   Part No SW: 4G0 035 056 A    HW: 4G0 035 056
   Component: Radio U STD   H52 0050
   Revision: AB001007    Serial number: 051EY0B7516476
   Coding: 010003020100000001
   VCID: 1F1BE01B77B5AA1FD0D-804A
   Part No SW: 4G0 035 670 B    HW: 4G0 035 670
   Component: H-BNT-EU      H46 0239
   Revision: --------    Serial number: 428EX0B7514227
   Coding: 050101000003E1EF45108B3E000000030000010000000000
   VCID: 221DE9EF44C787F7FF3-8076
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB1300QPJ1
   Subsystem 3 - Part No SW: 4G2 919 612 L    HW: 4G2 919 612 L
   Component: E380 BDT C7  H08 0120
   Serial number: 90349KDT0007U
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
   Part No SW: 4G8 959 795 C    HW: 4G8 959 795 A
   Component: TSG HL        H03 0210
   Coding: 010F14204001628002080002
   VCID: 42DD496FA487A7F79F3-8016
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0050
   Revision: --H04---    Serial number: 525 PA8J14F0S1
   Coding: 1020004
   VCID: 2517F2F359E970CF9A1-8070
   Component: TSG HR        H03 0210
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H24 0034
   Coding: 64040000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 6597B2F315E9B0CF5A1-8030
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 00060000031F030000030800424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 6FBBD0DBC7157A9F20D-803A
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 70B9D3A7DA2B6567397-8024
End----------(Elapsed Time: 02:06, VBatt start/end: 14.2V/14.0V)-----------
Thank you.
Gremling
Norway, Nordland
C?ID=319714
Hi, hate to break it to you, but this might also be starting signs of a stretched timing chain, not saying it is, but might be. This just happened to my sons A5, it was delivered to Audi workshop, which could confirm that the issue was timing chain being stretched. Increased mismatch between readings from camshaft and crankshaft.
Luckily we got it repaired at sellers cost.
Hope this is not the problem with your car
Another thing is that some of engines had had a sw update, regarding sensitivity of sensors, to my recollections other issues has also been failure of adjustment valve(s).
It should be fairly easy to replace, and if you can borrow one, then you can test to see if problem persist or is repaired. Having a reliable dealers workshop to test the for chain issues might be worth a shoot, prior to buying new valves for camshaft(s)
Hope this helps.
Regards
Gremling
NostraJackAss
What VAG vehicles don't have timing chains that don't fail before useful life warranty? :rolleyes:
coconutaudi
C?ID=345326
Hope this helps.
Regards
Gremling
Yes. Lets hope that is not the problem. Once I'm free I think I should start checking the CMP sensor and its wiring for Bank 2. This is as recommended by the instant of the P code. I'll start with the cheaper option. Thank you for your reply.
coconutaudi
C?ID=345326
Update. Finally got some spare time. I've checked the socket and wiring for the CMP sensor Bank 2 (C163) and found it is ok. So I've decided to replaced the C163. After replacing the sensor the car starts better without too much cranking. There is no more rough idling and engine run smoothly. Ran VCDS and erased the dtc. The dtc never came back. I guessed the problem is solved. Spent MYR180.00 for the sensor. Thank you.
