I am posting this in hopes I can figure out what is going on and what I might have done wrong. My car went red on the steering wheel light so I did a scan and it told me the Controller was bad so I replaced it. I also replaced my clock spring at the same time because it looked like there was something inside that might be causing issues. Now it won't even read that I'm connected to the steering wheel and I am left stumped. I don't know what to do now and I really want my car to drive again since I still have less than 100,000 miles on it. Here is the most recent scan. Please, someone help me.
Sunday,27,October,2019,15:25:02:31068:facepalm:
VIN: 3VWRT71K06M710655 License Plate: FREEDE
Mileage: 145650km-90502mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWRT71K06M710655 Mileage: 145650km-90502miles
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L EDC G000SG 7550
Revision: --H01--- Serial number: VWZ7Z0E2827737
Coding: 0050071
Shop #: WSC 00066 000 00000
VCID: 6393AD1527522DDFB45-8036
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Revision: 00T12001
Coding: 0021122
Shop #: WSC 00066 551 00000
VCID: 40D94299968456C7897-8014
Part No: 1K0 820 047 DK
Component: Climatic PQ35 090 0505
VCID: 70B9D259E6A48647397-8024
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000187748
Coding: 14010E234004180000140000001400000008730B5C
Shop #: WSC 23322 444 66617
VCID: 2A0D003100F8BC97B73-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0402
Coding: 00065493
Shop #: WSC 23322
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD0217HR
Coding: 0012627
VCID: 2E050C213C10D0B76BB-807A
Subsystem 1 - Part No: 1K0 959 339 F
Component: BF-Gewichtsens. 007 0005
Subsystem 2 - Serial number: 6332MSME0B3277089
Subsystem 3 - Serial number: 6342MSME0B33036DB
Subsystem 4 - Serial number: 6351HSME0834202D%
Subsystem 5 - Serial number: 6361HSME083E0020
Subsystem 6 - Serial number: 63727SME08025616V
Subsystem 7 - Serial number: 63827SME08254B5FB
Address 16: Steering wheel
Part No: 1K0 920 952 D
Component: KOMBIINSTRUMENT 3HL 1212
Coding: 0023207
VCID: 2B0305350F02A59F4C5-807E
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 280010590485B7
Coding: 3D3F0B40071002
Component: IMMO 3HL 1212
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 36352441C440E87723B-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 323D18512828F4570F3-8066
00003 - Control Module
014 - Defective
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AF
Component: KSG 0401
Coding: 137803281B09058F880F048051A0
Shop #: WSC 00046 412 819200
VCID: 74B1DE4992BCBA67DDF-8020
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 372B2945C34A117F38D-8062
Part No SW: 1K0 035 180 D HW: 1K0 035 180 D
Component: Radio DE2 011 0014
Revision: 00011000 Serial number: VWZ4Z7E3052925
Coding: 0010400
VCID: 211FE71D7DCE7FCFE69-8074
014 - Defective
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2434
Coding: 0000144
VCID: 313F175D2D2ECF4F769-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
Component: PTC-Element 0404
VCID: 2D070B2D3116ABAF521-8078
End----------(Elapsed Time: 01:18, VBatt start/end: 14.5V/14.6V)-----------
