VW Golf MK7 - Park Pilot function with rear PDC only (?)
Adamantos
Greece
C?ID=381987
Hello, i am owner of this car and i have Rear sensors that warn me when i am in reverse but i dont have the Graphic Interface in my Media and was wondering if it could be enabled or i need the follow parts to order first
https://www.carsystems.eu/vw-golf-7-vii-5q-park-pilot-front-w-ops-5q0919294b-upgrade-kit,id815.html
and then installing/coding?
Tuesday,05,November,2019,17:22:13:15375
VIN: WVWZZZAUZEP061565   License Plate:
Mileage: 77498km-48155mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEP061565   Mileage: 77498km-48155miles
Address 01: Engine (J623-CLHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 N    HW: 04L 907 309 B
   Component: R4 1.6l TDI   H22 9213
   Revision: 84H22---
   Coding: 01250012032405092000
   Shop #: WSC 01050 207 00000
   ASAM Dataset: EV_ECM16TDI01104L906021N 002014
   ROD: EV_ECM16TDI01104L906021N_002.rod
   VCID: 3038EACBFAA09377797-8064
   Part No SW: 0CW 300 047 C    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5260
   Revision: 00043014    Serial number: CU501312075582
   Shop #: WSC 00028 028 00024
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 3B22CDE723E6602FDC5-806E
   Revision: 00000000    Serial number: 6351300000055A
   Coding: 01FA62A12426096D037C060641C82580462490C06082A4F300420078C209
   VCID: 7BA20DE76366A02F9C5-802E
   Part No SW: 5G0 907 044 T    HW: 5G0 907 044 T
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 00020104200100011005004000101000
   VCID: 3828D2EB12D04B37317-806C
   Air quality sensor:
   Part No SW: 5Q0 937 084 AC    HW: 5Q0 937 084 AC
   Component: BCM MQBAB M   H16 0124
   Serial number: 00011335101479
   Coding: 00001842C24100DB4BE44000000403081000000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   VCID: 79AE17EF695A923F8E9-802C
   Component: WWS    131206  042 0551
   Serial number:         131210114903
   Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
   Component: G355_FeuchteS  H07 0002
   Serial number: 20597119
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR02EKR7
   Shop #: WSC 00028 028 00061
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F5AF9F7777EBC0FB0D-802A
   Belt Pretensioner left:
   Serial number: 34169667B16121371138
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169668B18121370663
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 012 13
   Serial number: 3576700000001CE48E0
   Subsystem 4 - Part No SW: -----------    HW: 480 002 012 13
   Serial number: 35867000000AC6587E05
   Subsystem 5 - Part No SW: -----------    HW: 480 401 312 13
   Serial number: 3516502C912FAE33109F
   Subsystem 6 - Part No SW: -----------    HW: 480 401 312 13
   Serial number: 35265029F12FAE3450BQ
   Subsystem 7 - Part No SW: -----------    HW: 480 401 312 13
   Serial number: 3556502C911FBE9231BT
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0135
   Revision: FF027027    Serial number: 20131209500494
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3FDAB9F737FE7C0FF0D-806A
   Part No SW: 5G0 920 861 A    HW: 5G0 920 861 A
   Component: KOMBI         252 2210
   Coding: 07A51A082380000800083A00040000
   VCID: 270A0197CF6ED4CFA8D-8072
   Part No SW: 5Q0 907 530 P    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2163
   Revision: --------    Serial number: 18121310800419
   Coding: 030100040B087300EF00024C1C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewConti 010015
   ROD: EV_GatewConti_010.rod
   VCID: 3E24C4F330F47507FBB-806A
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H15 0038
   Serial number: 27130002077080123493
   Coding: 29FFFF
   Serial number: 0548092103
   Part No SW: 5Q4 959 393 B    HW: 5Q4 959 393 B
   Component: TSG FS        009 0014
   Serial number: 0000086218509
   Coding: 003003208000048000001000
   VCID: 42DCB003440C11E79F3-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000003730843
   Component: EPS_MQB_ZFLS  123 1043
   Coding: 0103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DEBF0F410A0AFF869-8014
   Part No SW: 5Q4 959 392 B    HW: 5Q4 959 392 B
   Component: TSG BFS       009 0014
   Serial number: 0000086394627
   Coding: 003001208600048000801000
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000003724775
   Coding: 090000
   Part No SW: 5G0 035 819 A    HW: 5G0 035 819 A
   Component: MU-S--ER      040 0421
   Serial number: V1C02212130207
   Coding: 02730000FF00000011110001000800001F0100840100010001
   ROD: EV_MUStd4CPASE_VW37.rod
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H51 0022
   Serial number: VWZ8Z9NJ703JGV
End----------(Elapsed Time: 01:00, VBatt start/end: 12.9V/12.9V)-----------
TBAx
C?ID=287144
The linked retrofit package will certainly not allow Park Pilot. This feature requires four more additional sensors, two on each side of the car.
downtime
Finland
C?ID=280813
OP. So you have 3rd party parking sensor set. For sure it’s not factory as you don’t have module 10.
So what you need is park pilot module, wiring set and 4 rear sensors. You current sensors are not usable most likely.
Adamantos
Greece
C?ID=381987
Ok next question, right now i dont even have the Control Unit right? Because i was wondering how my rear sensors are working and giving me audio signal.
I supposed that i had the Control Unit for Park Pilot and just by activating the function via coding would have the Interface.
So to conclude i need the linked package plus additional sensors with all will be connected the the control unit that has the package (old rear sensors, the new sensors from package plus 4 more)
Right?
Adamantos
Greece
C?ID=381987
I bought the car a month ago (2nd hand) and supposed the the previous owner had the exist parking sensors installed from factory :/
Thats why i dont have the button near my gear neither the option at VCDS for ParkPilot. Now everything is explained.
Need to investigate if the exist sensors will fit to the new Module or i need plus rear sensors
downtime
Finland
C?ID=280813
I’m 99.9% sure the sensors don’t fit. The OEM modules are really picky on what sensors are connected.
Adamantos
Greece
C?ID=381987
Ok, now i understand.
Last question, if i say if ( :) ) the rear Sensors was OEM then i would have the Module and at Scan it was enabled from factory right? Because OEM sensors come together with module, it couldn't be only sensors installed (it wouldn't work).
Did i understand right?
Btw, thank you for support.
downtime
Finland
C?ID=280813
Yes, for factory park pilot you always have module. Even the rear only park pilot has a module. And you would see the scan in the autoscan.
Without module it’s a 3rd party parking sensor.
