A6 C7.5 air suspension auto lowering feature
fast79
Finland
C?ID=208284
Hi!
I've been searching for a solution concerning oem air suspension auto lowering feature. I found this on aas vcds lowering thread: "There is an additional setting that will prevent your car from auto-lowering at ~30 mph, as well as allow you to raise the suspension while driving at any speed. Standard settings gray out the "raise" button over a certain speed, and are particularly annoying if your car is lowered via the steps above and you would like to keep it raised for an extended period of time (such as city driving with a lot of dips, bumps, ramps, sloped driveways, etc.)" and so on.
This mod is done via green menu in MMI. My car is equipped with RMC system (no nav etc.) and green menu enabled in it but there's no "car" menu etc., just some useless engineering stuff.
Is there a way to do this mod using vcds, not MMI system?
South Molton, UK
We'll need to see a full unedited VCDS Auto-Scan to be able to answer your question.
fast79
Finland
C?ID=208284
I used my autoscan from previous thread (I'm not at my laptop right now):
Sunday,03,March,2019,10:01:16:00849
VCDS Version: 18.9.1.0 (x64)
VIN: WAUZZZ4G6FN056185   License Plate:
Mileage: 135266km-84050mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 20 28 34 3B 42 44 46 47 52
          53 55 5F 62 69 6D 72 8F 90 AC
VIN: WAUZZZ4G6FN056185   Mileage: 135266km-84050miles
17-Instruments -- Status: Cannot be reached 0100
Address 01: Engine (J623-CRTE)       Labels: Redir Fail!
   Part No SW: 4G2 907 311 C    HW: 4G2 907 401
   Component: 3.0TDI EDC17  H33 0001
   Revision: 92H33---
   Coding: 12254012052601030000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TDI0114G2907311C 001001
   ROD: EV_ECM30TDI0114G2907311C.rod
   VCID: 2541FAC824E257628E-8070
   Part No SW: 4G0 927 166 A    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H03 0008
   Revision: --H03---
   Coding: 100001
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: 2B550CF04206611258-807E
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 17A6DE41E8657B829B00
   ASAM Dataset: EV_ESP9BOSCHAU57X 003019
   ROD: EV_ESP9BOSCHAU57X_003.rod
   VCID: 3F8D48A0A67EEDB2E4-806A
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0560
   Coding: 01A9700E000000000000
   VCID: 7AFBF9B4F5DC089A93-802E
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 16011500040338
   Coding: 36021178210000
   VCID: 63C5A4D06A56E952A0-8036
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0311
   Revision: 15020001    Serial number: 00000973397501
   Coding: 0105C01441348FE0C901408300001800CF9CE7082E08020100000894E101170200400024030000
   VCID: 71E9DE98A8AA4BC222-8024
   Component: WWS57X 141126  H37 0080
   Serial number:         141206080957
   Coding: 004DF7
   Serial number: 23634322
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 12 01 2015  00001664
   Serial number: 6E99C467000000000001
Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
   Part No SW: 8X0 035 110 C    HW: 8X0 035 110
   Component: CDC-MP3-Pana  H41 0490
   Revision: 00000008
   VCID: 2D5102E874126F2246-8078
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1002V48V
   Coding: 30333130313730323735554A304C34473053
   VCID: 3B753CB0B266F192C8-806E
   Serial number: 3575HRB40672UKGQ4PCC
   Serial number: 3585HRB405V33HNI5GSE
   Serial number: 3515JRB400Q52RQM91G.
   Serial number: 3525JRB400S52RQMF8TN
   Serial number: 3554VRB405R34JH6K8O8
   Serial number: 3564VRB405R34JH660V.
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 90862OA9000LF
   Coding: 000015
   VCID: 3B753CB0BA66F192C8-806E
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Serial number: 02 12 2014  10003232
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4G8 920 933 Q    HW: 4G8 920 933 Q
   Component: TDieRdw       H07 0043
   Revision: 03001036    Serial number: 658030115596030
   Coding: 03AD12001B410008010000
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K.rod
   VCID: 3E7335A4A174E4BAEF-806A
   Part No SW: 4G0 907 468 AE    HW: 4G0 907 468 AC
   Revision: --------    Serial number: 00000001533347
   Coding: C0CD078118
   VCID: 73E5D490DAB679D2D0-8026
   Serial number: 7439435403
   Voltage stabilizer:
   Serial number: 14102900000000000322
6151 - Instrument Cluster Control Module on Optical Bus
          U10C0 00 [009] - No Communication
                    Reset counter: 132
                    Mileage: 135266 km
                    Date: 2019.03.03
                    Time: 09:50:53
                    Voltage terminal 30: 12.2 V
                    Voltage terminal 15: 12.2 V
                    Control Module temperature: 19 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   VCID: 7CF7FFACFFE836AA81-8028
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 13011500042154
   Coding: 20
   VCID: 3D7132A8AC72FFA2F6-8068
   Coding: 008001
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F6D18E0761E1D3274-807A
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA8208ULT6
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 36632D8489442CFA37-8062
   Component: TSG FA        H03 0507
   Coding: 011F17014000628002080002
   VCID: 479D5040F6AEA5725C-8012
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0021349405
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   VCID: 336514909A3639D210-8066
   Revision: 00002001    Serial number: 0357772071
   Coding: 0100063820B93000C320090428010F470000000000000000000000000000
   Revision: CJ007001    Serial number: 00000000163672
   Coding: 030000
   VCID: 1D31D22804B29FA2D6-8048
   Component: TSG BF        H03 0507
   Coding: 011F17014400628002080002
   VCID: 46835D44F1A4BC7AA7-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001328127
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D5102E87C126F2246-8078
   Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0081
   Coding: 04FA02102A600200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
   Coding: E01E00
   Coding: E01E00
   Part No SW: 4G1 035 182 A    HW: 4G1 035 182 A
   Component: RMC Cnct Plus H61 0139
   Coding: 0100010101E15B47482B060301020100000000
   VCID: 204FEBDC33C0B24AFD-8074
   Subsystem 1 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464L%0E2694600
   Subsystem 2 - Part No SW: 4G1 919 610 E    HW: 4G1 919 610 E
   Serial number: 90349OA700114
   Component: TSG HL        H03 0507
   Coding: 010F15004000628002080002
   VCID: 49995678E0BA53024A-801C
Address 69: Trailer (J345)       Labels:. 4H0-907-383-V2.clb
   Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
   Component: ConWys Trailer H07 0072
   Revision: 7B001002    Serial number: 00000133243642
   Coding: 0100000000000000
   VCID: 33651490923639D210-8066
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0150
   Revision: 14005001    Serial number: 356400615
   Coding: 093205C010
   ROD: EV_HDSGAu571.rod
   Component: TSG HR        H03 0507
   Coding: 00060000031F030000030801424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 31691E98602A0BC262-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 326B1194652C30DA1B-8066
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 143361261
   ROD: EV_RDCMA00100_008.rod
End-------------------------(Elapsed Time: 05:05)--------------------------
