Touran 5T: Generator is not charging after gw/instrument change
diskoboy
Denmark
C?ID=50403
Hi,
I have replaced the following 2 modules in my car:
Gateway 5Q0 907 530 AM -> 3Q0 907 530 AA
Instrument cluster 5TA 920 750 A -> 5NA 920 790 D
Everything (keys, immo, acc, lane assist, radio and so on) seems to be working except that it keeps saying that generator is not charging.
Coding of gateway is exact the same for old + new. Also adaptions are the same - for the ones that exists on both gateways.
Saturday,09,November,2019,22:51:47:21529
VIN: WVGZZZ1TZHW038734   License Plate: TOURAN
Mileage: 64242km-39918mi   Repair Order:
Chassis Type: 1T-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 69 6C
          6D A5 BB BC
VIN: WVGZZZ1TZHW038734   Mileage: 64242km-39918miles
Address 01: Engine (J623-CZDA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HQ    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H25 2484
   Revision: R7H25---
   Coding: 0125003224741D083000
   Shop #: WSC 10818 002 1048576
   ASAM Dataset: EV_ECM14TFS01104E906027HQ 001004
   ROD: EV_ECM14TFS01104E906027HQ.rod
   VCID: 7AADF0DDDC5A1847873-802E
   CAN Converter 01:
7158 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [036] - -
          [Diagnostic interface for data busRead out DTC]
                    Mileage: 64242 km
                    Date: 2019.11.09
                    Time: 22:39:53
                    Engine speed: 996.50 /min
                    Normed load value: 16.9 %
                    Coolant temperature: 26 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 10.059 V
                    Outside air temperature: 6 °C
                    Absolute intake pressure: 28 kPa abs
                    Engine torque: 20.3 Nm
                    Fuel level: 10.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Intake camshaft bank1 active operating mode-Bits 0-7: 0
                    Overrun cut-off-Bits 0-7: 0
Readiness: 1110 0001
   Part No SW: 0CW 300 049 Q    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0907
   Revision: 00005025    Serial number: 5ZV01609145673
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 4BC36519C34051CF6C5-801E
10810 - Function Restricted due to Insufficient Voltage
          U1400 00 [040] - -
                    Mileage: 64242 km
                    Date: 2019.11.09
                    Time: 22:39:40
                    Engine speed: 11781.75 /min
                    Engine torque: -100 Nm
                    Vehicle speed: 61 km/h
                    Control Module temperature: 64 °C
                    CURRENT pressure: -9.5 bar
                    Clutch: primary stat: Driving
                    selected gear: GANG_6
                    Driving position: N
                    Accelerator position: 0.0 %
                    DTC memory status: 45824
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 62296000001561
   Coding: 0CEA6AA034231374477E360341C72930562CC8E26C8294753822F07AC22202
   VCID: 7BA3F5D9D360214F9C5-802E
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0418113727
   Coding: 032C2C070F
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   VCID: 3C2136C596EEE677D5F-8068
   Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
   Component: GEB.F.Heckoef  H17 0903
   Serial number: 98077301
65794 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Function restriction due to temp low voltage]
                    Reset counter: 187
                    Mileage: 64242 km
                    Date: 2019.11.09
                    Time: 22:39:28
                    Terminal_15_Kessy_specified_value: On
                    Terminal_15_Kessy_actual_value: On
                    Terminal_15_central electric_actual_value: On
                    Terminal_15red_Kessy_specified_value: On
                    Terminal_15red_Kessy_actual_value: On
                    Terminal_S_Kessy_specified_value: On
                    Terminal_S_Kessy_actual_value: On
                    Terminal_S_central electric_actual_value: On
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition not met
                    Enabling immobilizer: Condition met
                    Control Module Voltage: 5.649 V
                    Vehicle speed: 0.0 km/h
                    Engine speed: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: Open
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID sensor 1 authentication: status: No response
                    ID sensor 2 authentication: status: No response
                    ID sensor 3 authentication: status: No response
                    ID sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Part No SW: 5G1 907 044 T    HW: 5G1 907 044 T
   Component: Climatronic   H04 1601
   Revision: 00001K10
   Coding: 08020004200410011105104D0010102A
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   VCID: 392F2FD199DCD35FCE9-806C
   Air quality sensor:
          B10CD 00 [009] - -
                    Reset counter: 147
                    Mileage: 64242 km
                    Date: 2019.11.09
                    Time: 22:40:56
                    Voltage terminal 30: 10.4 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up light: OFF
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 865821091600J3
   Coding: 00071B66C2C102FB57C44018101C172C188A000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 03538D39AB90598FD45-8056
   Subsystem 1 - Part No SW: 5TB 955 119 A    HW: 5TB 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    160817  043 0608
   Serial number:         160824082627
   Component: RLHS  042 0105
   Serial number: S4Y16M09D30H17M16S41
   Coding: 00A8DD
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000035510080
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0045
   Serial number: 000308417617172
   Coding: 0A71563951
   Shop #: WSC 49885 002 104857
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 50F972752A667217197-8004
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0194
   Coding: 32016FCB55FFC428949C804D
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 34311EE5BEBE2E371DF-8060
1389 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [FAULT_VBAT_BUSMON_LOW]
                    Reset counter: 187
                    Mileage: 64242 km
                    Date: 2019.11.09
                    Time: 22:39:41
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 9.2 V
   Part No SW: 5Q0 959 655 AE    HW: 5Q0 959 655 AE
   Component: AirbagVW21    005 0130
   Serial number: 003NSR25CGM9
   Coding: 98CCC0C00C0000005C5450CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
   ROD: EV_AirbaVW20SMEVW37X.rod
   Belt Pretensioner left:
   Serial number: 5TB857705E0272Q00803
   Coding: 80000D
   Belt Pretensioner right:
   Serial number: 5TB857706E0272Q00021
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 002 709 16
   Serial number: 3570000000086145AD1K
   Subsystem 4 - Part No SW: -----------    HW: 480 002 709 16
   Serial number: 3580000000056BEC9F13
   Subsystem 5 - Part No SW: -----------    HW: 480 412 309 16
   Component: SideSensor_Dr  003 0189
   Serial number: 351001A058EA64927D8K
   Subsystem 6 - Part No SW: -----------    HW: 480 412 309 16
   Component: SideSensor_Pr  003 0189
   Serial number: 352001A058E4A8A0FED-
   Subsystem 7 - Part No SW: -----------    HW: 480 402 809 16
   Serial number: 3550001AB223535272F
   Pedestrian Protection Driver:
   Subsystem 8 - Part No SW: -----------    HW: 480 402 909 16
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001C3227F923226Z
   Subsystem 9 - Part No SW: -----------    HW: 480 402 909 16
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001A52303C96757/
   Pedestrian Protection Center:
   Subsystem 10 - Part No SW: -----------    HW: 480 402 909 16
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001A92303C91A67Z
   Subsystem 11 - Part No SW: -----------    HW: 480 000 709 16
   Serial number: I0M00000000B11149D1
   Subsystem 12 - Part No SW: -----------    HW: 480 000 709 16
   Serial number: I0N00000000EEAB42E1P
   Part No SW: 3Q0 953 521 EJ    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0225
   Revision: FF036036    Serial number: 20160703500063
   Coding: 0410
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 7CA1F6C5D66E267795F-8028
291104 - Temperature Sensor for Heated Steering Wheel
          B1455 01 [008] - Electrical Failure
                    Reset counter: 187
                    Mileage: 64242 km
                    Date: 2019.11.09
                    Time: 22:39:28
                    Ubat 30 Voltage: 6.50 V
                    Internal error state: 0
                    LIN_Temp: 254
                    Isense: 0
                    Max.Leistung: 110
                    PWM: 0
                    Offset: 245
                    Slope: 134
                    kp: 18
                    OUT: 50
                    Temperatur Statisch: 30
                    p_t_soll_0: 34.00 °C
                    p_t_soll_1: 39.00 °C
                    p_t_soll_2: 44.00 °C
   Part No SW: 5NA 920 790 D    HW: 5NA 920 790 D
   Component: KOMBI         508 1701
   Coding: 05AD01186F000008018800033001000100000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001026
   ROD: EV_DashBoardVDDMQBA0_VW37.rod
   VCID: 43D34D39EB10998F945-8016
   Component: GW MQB High   521 5364
   Serial number: 26021810802796
   Coding: 030100343F085700FB00025C1C0F00010001050000000000000000000000
   Shop #: WSC 01730 666 28888
   ROD: EV_GatewNF.rod
   VCID: 6E85CC8D901244E72BB-803A
   Component: 2-07-1f-07-1f
   Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 2561612082701199AP2B
   Coding: 2F0000
   Serial number: 9070731604
8526354 - Generator
          P1B01 00 [008] - Electrical Malfunction
                    Reset counter: 187
                    Mileage: 64242 km
                    Date: 2019.11.09
                    Time: 22:39:49
                    Supply voltage: Terminal 30: 9.9 V
                    Terminal 15: On
8526361 - LV Energy Management
          B1802 F1 [009] - Warning Triggered
                    Reset counter: 147
                    Mileage: 64242 km
                    Date: 2019.11.09
                    Time: 22:38:27
                    Supply voltage: Terminal 30: 10.7 V
                    Terminal 15: On
   Serial number: 16000217536010
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD7F1812C5B1F369-8024
   Serial number: 300716EGU23091
   Coding: 001B9320D200048000001000
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0001069677
   Coding: 01010011005001
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_008_VW37.rod
   VCID: 3D273BC18DF4EF7FE21-8068
16648 - Supply voltage
          [Dauerhafte Unterspannung]
                    Reset counter: 187
                    Mileage: 64242 km
                    Date: 2019.11.09
                    Time: 22:50:11
                    Write only channel
   Serial number: 110816EHB14179
   Coding: 001B9120DE00048000801000
   VCID: 42DD483DF40A90879F3-8016
   Coding: 07CA020009000000
   VCID: 75B7E3E1F544773FEA1-8020
   Part No SW: 5NA 035 022 A    HW: 5NA 035 022
   Component: MU-H-LND-EU   H51 1121
   Serial number: A846E0HB063189
   Coding: 02730801FF0000005111110100880A101F0106C401200400FE
   Shop #: WSC 00046 123 12345
   VCID: 313F17F141AC1B1F769-8064
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H52 9130
   Serial number: VWZ6ZJV1770429
   Compact Disc Database:
   Subsystem 2 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1015
0005 - Antenna Amplifier 1 for Radio
          B126D 13 [008] - Open Circuit
                    Reset counter: 187
                    Mileage: 64242 km
                    Date: 2019.11.09
                    Time: 18:57:50
                    Voltage terminal 30: 11.4 V
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 255 dBµV
0006 - Antenna Amplifier 2 for Radio
          B126E 13 [008] - Open Circuit
                    Reset counter: 187
                    Mileage: 64242 km
                    Date: 2011.01.01
                    Time: 01:33:22
                    Voltage terminal 30: 11.5 V
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 255 dBµV
   Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Component: Anhaenger     H27 0264
   Revision: 8A001003    Serial number: 0427037793
   Coding: 0100000202000000
   Part No SW: 5Q0 980 568 B    HW: 5Q0 980 568 B
   Component: RVC Compact+  H07 0250
   Coding: 01230601A700201F000068
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 007012
   ROD: EV_CamSysRVRVCARPANAMQBAB_007_VW37.rod
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30950586600000
   Coding: 03A8
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   VCID: 3FDB41C987F8FD6FF0D-806A
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 25101611K12644
   Coding: 000307080000040100262345C140850098000E230020
   Shop #: WSC 00069 790 00048
262144 - Function Restricted due to Insufficient Voltage
          U1400 00 [009] - -
          [Function_limitation_battery_voltage_temporary_too_low]
                    Reset counter: 147
                    Mileage: 64242 km
                    Date: 2019.11.09
                    Time: 22:50:38
                    Control Module temperature: 32 °C
                    Outside air temperature: 7.0 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 24.2 s
                    Voltage terminal 15: 9.0 V
                    mid: 00 05
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Serial number: 170816DHH0229B
   Coding: 002091200000048000001000
   VCID: 45D75321E524A7BFBA1-8010
   Serial number: 170816DHH02711
End-----(Elapsed Time: 02:20, VBatt start/end: 9.9V/9.0V. VIgn 9.0V)-------
NEtech
Denmark
C?ID=56995
First charge the battery.
Maybe try Coding for [19-CAN Gateway] Byte 4 Bit 6
hmm...... notwithstanding (or, because of) the litany of low/insufficient voltage DTC s, why wouldn't attending to this (below) be a good way to proceed (instead of considering coding issues)? That is, test the heath of the generator - as a first step - perhaps?
8526354 - Generator
                    Reset counter: 187
                    Mileage: 64242 km
                    Date: 2019.11.09
                    Time: 22:39:49
                    Terminal 15: On
How did you deal with Component Protection DTC s after the retrofit?
diskoboy
Denmark
C?ID=50403
It works perfect. Thanks :) :)
diskoboy
Denmark
C?ID=50403
Coding was done online. I don't know what you mean?
diskoboy
Denmark
C?ID=50403
I was a bit to fast the other day - it's quite strange error.
Did the coding Sunday - charging whole day. Monday no problem (did 2 small trips for max 7-8 minutes each)
Tuesday (today) - did 2 small trips - max 15 min. each. Both trips said there is a problem with the alternator after approx 10 minutes. Message disappear in cluster after approx 20 seconds. Problem is that I really don't know if I can continue driving ?
Both new and old gateway logs are here. The original log (5Q0 gateway) was translated from Danish, but the message is the same.
The new GW recognize the alternator with a special number that I have no idea what is. Is it a serial number?
My best guess is if I replace the new one with the old one, I don't have any problems at all (- perhaps new problems with the cluster.)
Address 19: CAN Gateway (J533)     Labels:| NEZ\5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision	: --------    Serial number: 0005350389
   Codning	: 030100343F085700FB00025C1C0F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 7CA1F6C5D66E2677961-8028
   Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: NEZ\3C8-959-537.CLB
   Serial number : 2561612082701199AP2B
   Kodning	: 2F0000
   Coding: 030100347F085700FB00025C1C0F00010001050000000000000000000000
   ROD: EV_GatewNF.rod
   Coding: 2F0000
8526354 - Generator
                    Reset counter: 187
                    Mileage: 64242 km
                    Date: 2019.11.09
                    Time: 22:39:49
                    Terminal 15: On
